EVGA Hybrid Cooler Kit Fan specs?
trawetSluaP
2015/06/26 05:51:20 (permalink)
Hi,
I recently bought the Hybrid Cooler kit for my Titan X and am looking to replace the stock fan.
Does anyone know where I can find the specs for it (e.g. CFM and static pressure)?
Thanks,
Paul
Case: Phanteks Enthoo EVOLV ATX
CPU: i7-4770K + Swiftech H220-X
Motherboard: ASUS Maximus VII Formula
RAM: Corsair Dominator Platinum 16GB 2400 MHz
GPU: EVGA Titan X SC + Hybrid Cooler/Backplate
Storage: 2 x Samsung 840 Evo 250GB
PSU: EVGA SuperNOVA 1200 P2
10 Replies Related Threads
    CoercionShaman
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/26 06:13:06 (permalink)
    Are you wanting something specific in the replacement?  With less noise?  More static pressure?  As any 120mm fan will work, you may not need that specific information.  I do not know specifically where to find it, though.
    Many people have been using the Corsair SP120 and AF120 fans.
    I'm sure you already read through http://forums.evga.com/FindPost/2327117.
    What use is knowledge if there is no understanding?~Stobaeus
    Intel i5 4670K @ 4.2GHz, Corsiar H100i v2 AIO, 32GB G-Skill Trident X @ 2133 MHz, MSI 1080 Gaming X w/ 2139 MHz boost, ASUS Maximus VI Hero, Samsung 840 EVO 240GB, WD 750GB, CM V1000, Dell U3415W 21:9 @ 75Hz, Windows 10 Pro AE, CM Storm Trooper
    fattony33
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/26 06:16:40 (permalink)
    I just got the kit for my 980 ti sc and I replaced the stock fan and now on high oc I have not gotten above 40c. It works good as of right now I have it plugged in to my mother board
    btw.http://m.newegg.com/Produ...?itemnumber=35-608-052
    post edited by fattony33 - 2015/06/26 06:51:13
    trawetSluaP
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/26 06:28:03 (permalink)
    CoercionShaman
    Looking for a higher performing fan that is quieter ultimately.
    Have looked into Gentle Typhoon AP-15s and Aerocool DS Edtions.  Not sure how much better they'd perform without knowing the stock fans specs.
    CoercionShaman
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/26 07:08:54 (permalink)
    I know Asetek makes the cooler for EVGA and Corsair.  Corsair obviously mounts their own fans to the cooler assembly.  I have no idea what fan EVGA uses.  I don't remember reading it anywhere on here, either.  Hopefully someone with more knowledge than me can answer it for you.
    I was initially going to change mine out, but my temps and noise level led me to just leave on the stock fan until I get bored one day and have nothing else to modify.
    EVGA_JacobF
    EVGA Product Manager
    • Ribbons : 22
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 09:38:20 (permalink)
    Please see below
       jfreeZr - [rebuilding]  4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2
       hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
    ManikMonday
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 10:23:10 (permalink)
    EVGA_JacobF
    Please see below
    Wow the stock fan SP was much better then I expected! Any word on the Sound DBA at full load?
    Thanks for sharing this info Jacob!
    nunzmon
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 11:14:48 (permalink)
    I was thinking of changing mine , but not now!
    Asus Rampage IV blk 4930k @ 4.6 1.29v
    4x4g corsair Dominator gt ram 2400 9.11.11.31 1t
    2 NVIDIA Titans X hybrid Asus pg348q monitor
    Vlada011
    • Ribbons : 7
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 12:13:46 (permalink)
    If someone want elegant fans for Hybrid in Push-Pull configuration this model is good...
    Noiseblocker BlackSilent Pro PL-PS 600-1500RPM  4pin PWM fan 100.0m3 24dB
    I doubt fans need to work faster than 1500RPM on Hybrid, and this model is silent on MAX speed.
    But if someone want faster have lot of solution CORSAIR SP120, SP120 LED...
    EVGA Hybrid cooler system is Asetek... CORSAIR AIO systems from Asetek usually give better temps than ColiT.
    Kraken is Asetek too. New CORSAIR H110i GTX is Asetek too, CORSAIR say their best performing CPU cooler.
    ManikMonday
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 12:52:17 (permalink)
    ^^ good suggestions!
    I was actually looking at the overclockers favs either a noctua or Gentle Typhoon.
    trawetSluaP
    Re: EVGA Hybrid Cooler Kit Fan specs? 2015/06/30 13:38:56 (permalink)
    Got some Gentle Typhoon AP15's for both the Hybrid Cooler and my Swiftech H220-X.  Much quieter and slightly better temps.
