Moondrake
Re: EVGA Hadron Air Really loud PSU fan, even when in desktop with very little load
2014/03/13 10:22:31
Solved my PSU problem very easily and I'm a bit embarrassed I didn't think of it earlier...
I made a second Fan profile before starting to game with my CPU fan and top exhausts at 50% while cool 40° (+/- 1000rpm) and about 70% at 60°. It was so simple especially since the hadron does not have intakes I forgot to get some airflow going right from the start. FanExpert didn't think of it, why would it, it doesn't know the case, that's for going automatic... *shame*
Yes, you can hear the fans now, which is to be expected in a mITX gaming rig, but after 2 hours of continuous uniengine at absolute max, the PSU stays quiet. The system's not louder than my xbox or ps3 which is ok with me. Airflow in anticipation of load is key here, it seems As Dedaciai says, it has a distinctive pitch, but it isn't the turbine it was when my fans only started the real airflow at about 60°. To get it quieter now, I'd have to test with other exhaust fans.
Beer40oz
2014/03/13 11:20:23
Just ordered my Air box... now by reading this I do not wan't to open the box and just return it. If that PSU fan is very loud that beats my purpose since this rig will be on 24x7. Will see...
Dedaciai
2014/03/13 11:37:08
Beer40oz Just ordered my Air box... now by reading this I do not wan't to open the box and just return it. If that PSU fan is very loud that beats my purpose since this rig will be on 24x7. Will see...
It's not so much that it is loud as it is the pitch that may drive you up the wall. I ordered some acoustic foam off of amazon and it should be here next Tuesday. I am really hoping that it will change the pitch enough to silence my PSU fan's pitch. If it does, I'll post pics of my work.
Intel Core 4770K @4.25GHz Asus Maximus VI Impact Crucial MX200 M.2 SSD 512GB EVGA RTX 3070 XC3 Ultra Corsair Vengance PRO RAM 16GB @ 2400MHz DAN CASE A4 ThermoCool Copper CPU Cooler Corsair SF600 Watt PSU
Dedaciai
2014/03/17 15:20:52
The foam thing did not work (3/4" with the hard layer in the middle) even when it was double layered. Oh well, I guess I will wait till someone else comes out with a nice looking, very small mITX case like this one. I hope EVGA updates this case (make it quieter, room to hide cables, remove HDD cage, etc.) and give me a reason to upgrade, lol. I'll just keep my headphones on in the mean time.
Moondrake
2014/03/18 00:17:10
Dedaciai The foam thing did not work (3/4" with the hard layer in the middle) even when it was double layered. Oh well, I guess I will wait till someone else comes out with a nice looking, very small mITX case like this one. I hope EVGA updates this case (make it quieter, room to hide cables, remove HDD cage, etc.) and give me a reason to upgrade, lol. I'll just keep my headphones on in the mean time.
Was looking at the Corsair 250D as a replacement, since it's a clean design, but sadly double the width of the Hadron. I don't know if it be "quieter" per se, but it will run a little cooler and you'd have the choice for the PSU. The Hadron really is the best looking mITX (BitFenix Prodigy is also good looking, like a mini mac pro, but its size is more on the mATX side)
DirtyApe
2014/03/18 14:58:58
Can't take it, 24 hours is long enough with this little jet engine. Very disappointing as I love the case otherwise.
Pschiiit
2014/03/20 13:27:59
I wonder if you open the psu, get ride of the 40mm and either let it open air or make vents on the top and let the exaust fan from the top do the job. I think the 40mm do something like 18CFM at max so the two top fan do more than that.
Pschiiit
2014/03/20 13:28:02
goots
2014/03/20 22:54:17
just got my build up and running today. Was kind of worried about the psu noise but after installing the OS I am satisfied atm with the psu. The stock case fans are much more audible than the PSU
T-White
2014/03/21 02:39:05
I had a whine on my Hadron Air when I got it. It would start up, be quiet for a bit then I had some fan noise and ticking. EVGA rma'd it immediately and I got a new one within a week of shipping my defective one out. You have to keep in mind that the case is very compact and that heat is an issue. I have a reference GTX 780 card and have modified the fan profile to pump out more heat faster, I also changed the case fans and put dual PMW Noctua's in and adjusted the profile on those as well to increase flow the higher the load on the system. My system runs good, and is quiet, I can only here the fan on my Thermalright AXP-200R when it's at idle. It's a good case, just give EVGA a chance to make it better.
EVGA Hadron Air i7 4770K (Costa Rica) Gigabyte GA-Z87N-WIFI EVGA GTX 780 SC G-Skill TRIDENT X (16GB) Samsung 840 EVO 128GB Seagate SSHD 1TB
goots
2014/03/28 21:38:19
Dedaciai
DirtyApe Can't take it, 24 hours is long enough with this little jet engine. Very disappointing as I love the case otherwise.
So I finally got my build up and running and used my 670 from an old dell. The system is very loud. After I adjusted the cpu fan and case fans it is now tolerable, but yes! now I can hear the psu. The high pitch of that thing is driving me crazy... Instead of putting it on my desk I installed it under my desk lol. Now I understand why this thing is noisy.
Zombly
2014/04/02 07:46:17
How long has it taken for everyone's PSU to go crazy mode? I've been using mine for 2ish weeks now and still quiet, my GPU is a bit loud but that's because for some reason stock settings was 100% fan, stupid AMD GPU, should of went nvidia, but ran out of resources with this case.
yoryocor
2014/04/07 13:12:12
So, mister evga (or an owner); will the noctua 40mm fan fit in the psu? Someone spend 14 bucks and try it! I want to buy this case, but not if it is making horrible noise! Does evga actually test stuff before manufacturing and shipping? Sheesh!
post edited by yoryocor - 2014/04/07 13:14:09
Pschiiit
2014/04/07 13:27:29
You can't replace it by the noctua, the noctua is 40x10 4500rpm and produce less then 5cfm the one from the psu is 40x28 10000rpm and does 18cfm.
The best thing is to use the top fan to extract the maximum air. So on a demanding game like planetside 2 you need them at 100% but something like elder scroll online, you need them at 75%. I do that with a MSI 770 TF and my psu stay quiet if the case get too hot the psu will get too warm and since the fan is small you don't want that.
Second advise get a blower type card, i wanted the EVGA 770 blower but it would have cost me 60€ buck more for the same card. Wish I lived in the US.
rexob4485
2014/04/09 09:15:21
I must be incredibly lucky, because I rarely hear my PSU fan, I know it runs too because I can feel it, and I definitely hear it initially when it starts. Other than that though, pretty quiet.
yoryocor
2014/04/10 10:57:05
Pschiiit You can't replace it by the noctua, the noctua is 40x10 4500rpm and produce less then 5cfm the one from the psu is 40x28 10000rpm and does 18cfm.
Thanks for the info. Blowers cost less than acx in euro evga website...where are you?
yoryocor
2014/04/10 10:59:55
Wonder if evga will sell me a case without psu. Lemme mod mine with the silverstone. Sucks they make a great rig with a noisy and nonstandard psu.
rprice07
2014/04/14 11:26:15
I'm having the same issue, I'm going to work on adjusting fan profiles and look into buying a noctua fan replacement. No point in trying the RMA lottery according to what everyone has been saying... :) I didn't have much luck getting an unscratched window from them either. Probably my last non-video card purchase from EVGA :/ (Might look at another Corsair, maybe the 250D) Love their graphics cards doe.
ilukeberry
2014/04/20 19:08:16
I've blocked for a second my psu fan with a stick.. and my system gets completely silent. I'm using 780 ti reference and evga mitx acx cooler... there is definably some flaw in psu cooling design.
post edited by ilukeberry - 2014/04/21 05:57:01
Intel i9 13900KS | EVGA Z790 Classified | Corsair Vengeance 4x16GB 6600MHz | NVIDIA RTX 3080 Ti FE | Corsair MP600 PRO 2TB | PHANTEKS Glacier One 360 T30 Gen2 AIO | Seasonic PRIME TX-850 | PHANTEKS Enthoo Evolv X
Victorcc1981
2014/05/07 19:20:24
ilukeberry I've blocked for a second my psu fan with a stick.. and my system gets completely silent. I'm using 780 ti reference and evga mitx acx cooler... there is definably some flaw in psu cooling design.
Guys, i could solve almost totally the problem of my PSU noise. I found that the noise was the psu fan, so I turned the case upside down leaving the back facing up, unscrewed the metal cover that sits on the back of the case (exhaust PSU fan) and removed part of the round seal to access spindle lock the propeller, and applied a little of the product WD40 (spray lubricant) leaving it work for a few minutes. Put the seal back, screwed back the metal cover,returned the case to the normal position, power on... and bingo! Noise decreased by almost 80% :thumb: As you can see in both videos: PSU fan Noise: /watch?v=MCM0gYbbojY And almost none PSU fan noise /watch?v=3FYDB1StyVw
post edited by Victorcc1981 - 2014/06/30 20:53:27
My Youtube Channel: https://www.youtube.com/user/victorleidiCase: Hadron Air (PSU 500W Gold +) Motherboard: Asus Z97i-plus CPU: Intel core i7 4790k 46-46-45-44 Cooler: Noctua NH-U9B SE2 Thermal Paste: Noctua NT H1 GPU: EVGA GeForce GTX 780 SC + ACX cooler RAM Memory: Corsair Vengeance Pro 2400mhz 2x4GB SSD: Samsung 840 Pro 512GB Monitor: AOC IPS LED 21.5pol i2269 Slim Áudio: Edifier MP300 Plus 22W RMS (1x sub 15W + 2x 3,5W) Keyboard/Mouse: Microsoft Wireless 3000 Surge Protector: Clamper Energia
ilukeberry
2014/05/08 01:16:23
Wow that's really a difference! i haven't set up my brand new that i got from RMA yet so i don't know how loud this one will be.. i'll set up my rig later today. :)
post edited by ilukeberry - 2014/05/08 02:19:03
ilukeberry
2014/05/08 02:25:02
ilukeberry
2014/05/09 01:11:33
Anyways. i've build yesterday my computer with the new case i got from RMA and i can say PSU is *much* quieter !
jeepn
2014/05/09 07:03:27
Sounds like a lubricant issue for sure, good job Victor! Cant wait to join the ranks of the Hadron owners and support EVGA once again. Im also making the jump from from ATX to mITX, and from i7 to i5. Seems the more builds you do, the cheaper they get as you figure out what you need and dont need (or use). Glad it fits EVGAs top of the line VGAs as I wont get chincy in that department. The wife has always hated my cases so this was the perfect case for our needs.
NZXT H210i / AMD 5900X / Arctic Cooling Liquid Freezer II - 280mm / Asus Rog Strix x570i Gaming / EVGA RTX 3080 XC3 Ultra Gaming / 32GB G.SKILL Trident Z Neo DDR4 3600 / Samsung 980 Pro M.2 4.0 1TB / Seasonic 850 Associate Code: DH31IHN4NAL6231
ilukeberry
2014/05/09 09:23:15
I came from Cooler Master HAF X to EVGA Air Hadron.. i absolutely love the form factor :)
Victorcc1981
2014/05/09 15:23:11
jeepn Sounds like a lubricant issue for sure, good job Victor! Cant wait to join the ranks of the Hadron owners and support EVGA once again. Im also making the jump from from ATX to mITX, and from i7 to i5. Seems the more builds you do, the cheaper they get as you figure out what you need and dont need (or use). Glad it fits EVGAs top of the line VGAs as I wont get chincy in that department. The wife has always hated my cases so this was the perfect case for our needs.
Thanks. This was my first build, so I still have much to learn. I build it first because i needed a good rig, and second because i take it as a hobby, I love hardware
post edited by Victorcc1981 - 2014/05/12 04:48:05
rvanevery
2014/05/15 16:53:45
No excessive fan noise with mine, yet, it will spin up a little when things start warming up but nothing like the initial boot.
Corsair 540 AIR ASUS X99 WS | E5-2695v3 | 128GB ECC DDR4 | 3x EVGA Titan X SC | 2x 1TB Samsung 840 | 1.92TB Liteon SSD | LEPA G1600 Alienware 13 i5-5200u | 8GB DDR3 | 960m | 1TB Crucial M550 | Graphics AMP + Titan X
ilukeberry
2014/05/16 14:03:17
rvanevery No excessive fan noise with mine, yet, it will spin up a little when things start warming up but nothing like the initial boot.
I guess you got the fixed revision of PSU mine is also fine now.. :)
4ND3R5
2014/06/30 09:40:17
Same problem here. I replaced the two top fans with noctua ones and have them blowing in because I use my case on its side. Gonna try the "oil-trick" and possibly change the noctuas to blow out and see what happens. Don't want to rma my case because then I'd be without a computer until the new one arrives :(
mostlygeek
2014/07/08 05:55:54
I'm about to open a support ticket for my Hydro PSU. I don't think the fan is spinning too fast (it's nothing like the boot up sequence) but the noise at idle is quite annoying. I'm not yet sure if it's just the tone or the volume/speed as well, perhaps it idles slightly too fast. It's louder/more annoying than the gfx, cpu and system fans combined. I also have an Air with near identical components inside, and it's PSU is very very quiet (on desktop). When it's under the desk you can hardly tell that it's on.
