Re: EVGA GeForce GTX 1070 SC ACX 3.0 fan noise at 680-730 RPM
2016/11/13 13:39:42
youtube. com/watch?v=Kw7bMnlDwhk
Here's a quick video I shot with my Nexus 5 (not the best tool for audio-recording), I used PrecisionX to adjust the fanspeed from 18% to 21%, then to 19%. You may need to turn up the volume, but the noise should be quite distinguishable. The phone is on my table, roughly 50cm away from my mouse and roughly the same distance from the GPU (closed case) with a table in-between.
