Re: EVGA GTX 980 Ti ACX2.0 Annoying Fan Noise at 35-37% RMP
2015/06/25 07:22:09
Easily solved, my fans on my 980ti make this noise around 52-54%. Set up a custom fan profile and set a breakpoint at about 33%, and set the other one at say 39% right above the one you set at 33%..(so in other words both break points should be on the same temperature) this will make it skip 34% through 38% and you will not hear the whine again. Fine tune for best results.
i5 4690k @4.4ghz
EVGA GTX 980 Ti ACX (1250 core/1452 boost)
EVGA Z97 Stinger
EK Watercooling
Noctua Fans
8gb Ripjaws X Ram
EVGA Nex650G
INwin 901
