EVGA GTX 690 LED Controller v1.1.0.0
EVGA_JacobF
EVGA Product Manager
  • Ribbons : 22
2012/05/22 16:20:47 (permalink)
Version v1.1.0.0
Release: 3/12/13
  • New GUI Interface
The EVGA LED Controller application for EVGA GeForce GTX TITAN and GTX 690 is available now! You can download it here.
Here is a brief overview on how it works. When I start the application I will see the below:
The first selector at the top left lets me select the card logo I want to adjust. The selection directly below that lets me select various different options. IMPORTANT NOTE: Anything other than manual control REQUIRES EVGA Precision X to be running in the background! For FPS Monitoring make sure that you have FPS monitoring enabled in EVGA Precision X.
Lets select GPU Utilization. When EVGA Precision X is also running in the background (or minimized to system tray) the LED on my EVGA GTX TITAN or GTX 690 will automatically adjust based on the GPU Utilization. In the below image I am running EVGA OC Scanner X to increase my GPU utilization to 94%, thus the illumination on my EVGA GTX 690 logo is set accordingly. When I close EVGA OC Scanner X, the LED turns off.
Lastly, the apply at startup will ensure that my custom LED settings will always apply on Windows boot!
post edited by EVGATech_MattM - 2014/08/08 02:07:29
   jfreeZr - [rebuilding]  4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2
   hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
48 Replies Related Threads
    surfnet
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/05/22 21:48:28 (permalink)
    Thank you sir!  "breathing" in sync now.  Kudos!!
    jthull
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/05/23 09:02:52 (permalink)
    Taking any requests? How about a "wave" function between two 690s.  One goes up, one goes down.
    Basically like the breathing, but with the timing set different on the two.
    Durzel
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/05/26 12:38:49 (permalink)
    +1 for the above option.
    Was rather hoping that "breathing" would work alternately with 2 cards fitted, rather than being in sync.  Would be fairly easy to do this I would assume?
    PanzerMensch
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/05 09:43:04 (permalink)
    This is so rad! Cant wait to try this when I get mine shipped to me!
    terrorist96
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/07 20:14:13 (permalink)
    Why don't you also put this in the download section under Support?
    NELSONTHE2ND
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/15 17:39:03 (permalink)
    I just ordered a EVGA 690 Signature. Does this software come included on driver disc
    bhk1004
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/17 18:19:33 (permalink)
    Will this work on the hydrocopper?
    bhk1004
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/18 16:51:01 (permalink)
    any word on this working on the hydrocopper block for the 690?
    bhk1004
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:15:05 (permalink)
    my hydrocopper block for the 690 arriving tomorrow... would appreciate if the LED controller works for this as well.
    quaan
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:42:34 (permalink)
    it doesnt
    bhk1004
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:49:03 (permalink)
    quaan
    it doesnt
    dont take this the wrong way, but how do you know?
    fabbasi
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:51:53 (permalink)
    I can prove they dont
    bhk1004
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:53:23 (permalink)
    Cool. Can you show me plz? Or even a simple answer like I have it and it doesn't work would suffice....
    post edited by bhk1004 - 2012/06/19 11:56:41
    fabbasi
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/06/19 11:58:00 (permalink)
    Gtx 690 Works great!
    Gtx 680 HC 0 (Zero) response
    GTX 690 HC should work, I am guessing its the same board just an HC block on top with same connecting point.
    post edited by fabbasi - 2012/06/19 12:04:53
    steamcore
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/07/10 16:00:32 (permalink)
    I have Dual 690's and the LED has never turned on the second one.  I chalked it up to needing to install the drivers once windows was running, but alas no go.   Using this utility doesn't turn it on, (only one card shows in the top drop down box but I'm not sure if there is supposed to be two).  Could I have a defective LED?
    TheDarkWraith
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/08/05 11:04:10 (permalink)
    Installed this and it causes my Win7 Ultimate 64bit to always reboot after finishing the windows logo thing the first time it tries to boot. The next attempt to boot works fine. If I reset the computer I have to go through this whole process again. Any ideas as to why?
    I remove the software and still have the same problem. So to verify for sure this software is the cause of my new booting problem I reinstalled Win7 (clean install) and only installed video drivers. Shut down computer and restarted. Booted fine. Installed LED controller. Shutdown computer and restarted. Back to boot problem.
    Would really love to know how to remove the software left behind by the deinstaller so I can totally remove this and get my 'old' system back to normal.
    EDIT:
    For s's and grins I decided to update the motherboard BIOS in my Crosshair V motherboard. It was running 0404 and I upgraded to 1402. I'm happy to say that the problem went away! Now I don't know exactly why updating the BIOS would do this?
    post edited by TheDarkWraith - 2012/08/05 16:32:42
    banshee4711
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/08/07 19:26:36 (permalink)
    any chance a led controller for the 680 classy would be available soon?
    Z87 Classified Mobo/ Corsair HX1000/GTX 980 Classified 3xSLI
    eewqtw
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/08/17 03:48:09 (permalink)
    CAN support other Other brands gtx 690?
    tyler.szabo
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/09/01 06:06:12 (permalink)
    I have an EVGA GTX 790 690, that is recognized without issue by other applications; however when I run the program (and indeed grant administrative privileges) I get the following message:
    ---------------------------EVGA LED Controller---------------------------
    This device is not supported!
    ---------------------------OK   ---------------------------
    Environment:
    Graphics card: 04G-P4-2690-KR
    Motherboard: GA-Z77X-UD5H (F8 BIOS)
    CPU: i5-3570k (HD4000 disabled in bios)
    OS: Windows 7 x64
    Other software:
    Precision X 3.0.3 installed
    OC Scanner X 2.2.0 installed
    NVIDIA driver 301.42 installed
    Lucid Virtu MVP 2.1.115a.23214 installed; but hardware virtualization is disabled. (edit) uninstalled, no change
    post edited by tyler.szabo - 2012/09/09 02:39:59
    eikast
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/09/09 00:18:11 (permalink)
    tyler.szabo
    I have an EVGA GTX 790, that is recognized without issue by other applications; however when I run the program (and indeed grant administrative privileges) I get the following message:
    Environment:
    OS: Windows 7 x64
    Other software:
    Hehe I think you mean GTX 690.
    http://www.heatware.com/eval.php?id=70164
    i5 3570K @ 4.5 GHz 1.28V
    eVGA Titan X SC 1380 MhZ boost core clock.
    Switech MCR140-X Drive
    EK Titan X waterblock
    16 GB G.Skill 1600 MHz
    MSI Z77a-gd55
    Samsung 1TB 840 SSD
    1TB 7200 RPM HDD
    Logitech G502
    Sennheiser PC 350 SE
    Razer BlackWidow Ultimate (Battlefield 4 edition)
    Razer Destructor 2 (Battlefield 4 edition)
    Asus Xonar Essence Stx
    Acer XB280HK
    tyler.szabo
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/09/09 02:44:37 (permalink)
    Whoops, thanks :). It would be nice to have a 790, but it seemed so extravagant to have bleeding edge hardware brought back from the future.
    Tadhg
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/09/25 13:56:29 (permalink)
    Tyler.szabo: You wouldn't be interested in the 2015 Model laptops. Get with the times. 2012 technology is so outdated. I'm sure these beasts have better than a 790!
    http://www.youtube.com/watch?v=DPjDPzgKV14
    Intel i7 920 2.78 @ 3.03 :CPU | Main: EVGA X58 SLI3
    Corsair Dominator 12GB :RAM | Video: EVGA 780 GTX SC (3gb)
    ThermalTake BlackWidow 850w :PSU | Monitor: 3x U3011
    Razer Mamba (2 Gen) :Input: Razer BlackWidow Ultimate (1 Gen)
    Logitech X 530 :Audio: Turtle Beach PX5
    #23
    lastsamurairick
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/09/29 10:44:30 (permalink)
    This are such Sexy Sexy GPU's is ok i want to hold one.
      Affiliate Code:H4NN05P25X
    #24
    sjp770
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/10/05 04:02:25 (permalink)
    Is there an app for the 680 Classifieds LEDs?
    i7-3930K @ 4.6GHz, ASUS Rampage IV Formula, EVGA GTX 680 Classified 4GB HydroCopper, Corsair Vengance 16Gb 1600Mhz DDR3,  Intel 520 series 240Gb SSD, Corsair NFORCE3 120Gb SSD, 3x Dell 24" Portrait Surround , Corsair AX1200i PSU, HWLabs GTX 560 100% inside a Corsair 800D
    #25
    fbsrkc06
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/11/11 10:00:15 (permalink)
    gtx 690 great
    #26
    chris619
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/11/11 10:07:46 (permalink)
    Thats awesome.
    #27
    cyclogenisis
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/12/03 10:46:16 (permalink)
    awesome thanks for this, will try when I get home.
    CPU: i7 3770k OC 5.0ghz vcore 1.480  http://valid.canardpc.com...c.php?id=2623057  |    CPU Block: XSPC Raystorm
    Mobo: Asus P8Z77 PRO
    GPU(s):  eVGA GTX 690    |     GPU Block: XSPC GTX690 Razor
    SSD: ADATA SX900 256GB
    RAM: DDR3 16GB Kingston HyperX T1 1600mhz (KHX1600C9D3T1K2/8GX)x2
    PSU: Corsair 1200i 80+ Platinum
    SSD: ADATA SX900
    #28
    yourgod
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/12/07 02:30:09 (permalink)
    Oh come on, do something creative like syncing the LED(s) to the beat of whatever is playing on WinAmp!
    Thermaltake Xaser VI case (echo...echo...), Asus P9X79, Intel 3930K, 32GB Kingston HyperX, Zalman CNPS12X cos Noctua are fugly, EVGA GTX 970 SC ATX 2.0 4GB, 14TB of HDDs (WD, Hitachi, Seagate), dedicated 160GB 7200rpm swap drive, Dell 27" u2713hmt @ 2560x1440.
    #29
    mito!
    Re:EVGA GTX 690 LED Controller v1.0.0.9 2012/12/14 06:28:01 (permalink)
    Sorry, what exactly is this LED controller for?
    Is it for a SLI setup of two GTX 690?
    /\/\ito
    i7 3770K, asus p8z77-v lk, evga gtx 690, 4gb pc1600 mushkin, pc power & cooling 750w
    #30
