JohnKebab
Hello everyone, I recently updated the VBIOS of my GTX 1080 SC and since then, under load the fans go crazy and make a huge noise that I'm able to hear it even when playing a game wearing a headset. At idle they're not spinning and once in game after 7-8 minutes they go up to 2400rpm (under HWMonitor they show 5000rpm but it's obviously an error). I joined screenshots of HWMonitor at idle and under load. Yes the cards runs cooler than before the VBIOS update, but the noise that the fans make is seriously unbearable. I saw that there was a Thermal Pod mod that you could apply in addition to the VBIOS update but it not something I'm capable of doing. Is there a way to fix this ? Thanks in advance. The rig : - MSI Z170A SLI PLUS - i5-6600k - Dark Rock 3 (pushing air to the rear of the case) - Kingston HyperX Savage 2*8GB DDR4 2800MHz - Cooler Master G650M 80+ Bronze - NZXT S340 Black&Red - 1x120 fan intake on the front bottom - 1x120 fan exhaust rear
Anarion
Re: EVGA GTX 1080 SC ACX Unbearable fan noise
2016/11/12 03:11:25
Single 12cm exhaust fan and single 12cm intake fan isn't really that great setup... That certainly doesn't help. Use GPU-Z, Afterburner or Precision X to monitor your card temps rather than HWMonitor.
Intel Core i7 3770K & Thermalright True Spirit | ASUS P8Z77-V | Corsair AX760 | Define R4 | 4x4GB G.SKILL RipjawsX 1600MHz | EVGA GeForce GTX 1070 GAMING ACX 3.0 | Creative Sound Blaster Zx | Sennheiser HD 595 | Samsung 830 128GB & 2x Samsung F3 1TB & Toshiba 3TB | Windows 10 Pro x64
JohnKebab
2016/11/12 03:45:36
Well I was thinking about adding 2 more fans, which one do you recommend ? Something like 2* BeQuiet Pure Wings 2 140 PWM INTAKE in the front and the default 120 for the rear and top ?
Bar81
2016/11/12 04:01:14
Since you're limited to two in the front you might as well go big with 140mm fans. Try that with the included rear and top fans. If still needed you can swap out the top one with a 140mm.
Intel 6700T, Thermalright Macho Zero, Asus Sabertooth Z170 S, 64GB Crucial Ballistix Sport LT, EVGA 1070 FTW, Samsung 850 EVO, Phanteks Enthoo Evolv, Kingwin Stryker 500W
JohnKebab
2016/11/12 04:09:54
So like I said : Front (INTAKE) : 2* 140 PureWings 2 (no PWM) 140x140 Rear and top (EXHAUST) : default 120x120 Is that it ?
Bar81
2016/11/12 04:11:12
That's all you can do with that case.
JohnKebab
2016/11/12 04:14:45
The shop opens at 2pm so I'll get those today and keep you up to date. Thanks By the way, since I only have 3 SYSFAN on my mobo, I guess I have to plug one of the fans on the CPUFAN2. Does it matter ?
Bar81
2016/11/12 04:17:24
JohnKebab
2016/11/12 04:34:42
Do I have to get an adapter to plug two on one SYSFAN header ?
post edited by JohnKebab - 2016/11/12 04:39:46
seahawkgfx
2016/11/12 05:21:44
It is not the problem of the case fans. My 1080 went from 1250rpm under load to 2050rpm under load with the BIOS up-date. Flashing the old BIOS again, it is back to 1250rpm. Imho EVGA needs to come up with a new BIOS that is not as aggressive.
2016/11/12 05:29:05
Could you not have just set a custom fan curve to control the fan's speed, rather than re-flashing to the old BIOS. MSI AB or Precision X OC both work quite well. I actually prefer AB.
post edited by hapkiman - 2016/11/12 05:31:17
i7 6700K, Corsair H80iGT, 16GB Corsair Vengeance DDR4 @3000MHz, EVGA GTX1080 FTW, MSI Z170A Gaming M7, Samsung 950 Pro 512GB, Samsung 840 EVO 250GB, WD 1TB, Creative SB Zx, Dell P2715Q 4K/UHD @60Hz, Samsung B2230HD 1080p @60Hz, Windows 10 Pro, Corsair Air 540, Seasonic 860watt XP2, Corsair K70 RGB, Razer Deathadder Chroma
ZeroBANG
2016/11/12 05:48:18
Sorry but what did you think the BIOS update would do? They stated loud and clear that it increases the fan curve (and nothing else), so of course the Fans will be louder if they spin faster. I'm going with the Thermal Pad mod INSTEAD because i don't want that kind of noise and i tested myself where my threshold of "acceptable noise" is for this GPU... and 2000 RPM is as high as i think is acceptable without getting into Jet Engine territory. All you can do now to get the card silent again is to do a custom fan curve in MSI Afterburner or EVGA Precision X. And do the Thermal Pad Mod yourself, it really isn't hard, GamerNexus has a good video up on their Youtube how to install it. -> youtube.com/watch?v=8DQYP0SN_Kk //edit sorry, forum keeps eating my links ...unless you can find the original BIOS somewhere and flash it back, i don't know where you would get that, maybe it is somewhere on the EVGA site, i don't know.
post edited by ZeroBANG - 2016/11/12 05:57:34
JohnKebab
2016/11/12 06:23:29
With the two 140mm Pure Wings 2 in the front as intake, and the default 120mm on the top and rear. Still the same thing. My cpu runs 10° cooler though. seahawkgfx It is not the problem of the case fans. My 1080 went from 1250rpm under load to 2050rpm under load with the BIOS up-date. Flashing the old BIOS again, it is back to 1250rpm. Imho EVGA needs to come up with a new BIOS that is not as aggressive.
Where did you get the original VBIOS ? hapkiman Could you not have just set a custom fan curve to control the fan's speed, rather than re-flashing to the old BIOS. MSI AB or Precision X OC both work quite well. I actually prefer AB.
I'll try MSI AfterBurner. Do you have any advice on how to set a good fan curve ? ZeroBANG Sorry but what did you think the BIOS update would do? They stated loud and clear that it increases the fan curve (and nothing else), so of course the Fans will be louder if they spin faster. I'm going with the Thermal Pad mod INSTEAD because i don't want that kind of noise and i tested myself where my threshold of "acceptable noise" is for this GPU... and 2000 RPM is as high as i think is acceptable without getting into Jet Engine territory. All you can do now to get the card silent again is to do a custom fan curve in MSI Afterburner or EVGA Precision X. And do the Thermal Pad Mod yourself, it really isn't hard, GamerNexus has a good video up on their Youtube how to install it. -> youtube.com/watch?v=8DQYP0SN_Kk //edit sorry, forum keeps eating my links ...unless you can find the original BIOS somewhere and flash it back, i don't know where you would get that, maybe it is somewhere on the EVGA site, i don't know.
Yeah I already watched the video but in case something goes wrong I don't want to have a 700€ gpu that's broken in my hands. Also if I have to sell it or send it to warranty to the seller they can refuse it since it's been modified.
2016/11/12 06:39:58
seahawkgfx
2016/11/12 07:22:48
JohnKebab Where did you get the original VBIOS ?
I saved it with GPUZ before doing the update.
JohnKebab
2016/11/12 10:16:53
I adjusted the fan curve to look like this : After 1.5 hour of load, the GPU didn't exceed 65° and the fans hit 1400rpm max which is very correct. My CPU didn't exceed 50°, it's perfect. Thanks to everyone !
2016/11/12 10:20:33
JohnKebab
2016/11/12 12:50:41
Well, it does go back to 77° and 2200rpm on Overwatch but perfectly fine on GTA V (59°/55% fan;1500rpm). I don't get it...
2016/11/12 17:50:22
Original vbios can be downloaded here. You'll need to use the latest version of nvflash to reflash the original.
JohnKebab
2016/11/13 13:45:10
Thank you for these links.
I'm seriously thinking about installing those pads and switching back to the original VBIOS. I'll contact the seller tomorrow to know if my warranty is still valid if I install this mod or if it does not.
MikeBGeyer
2016/11/13 14:38:13
Get a hybrid kit, much cooler and way less noise.
JohnKebab
2016/11/14 00:59:09
Apparently they don't ship to France. And buying a $120 cooler to cool down a $650 graphics card shouldn't be a necessity...
seahawkgfx
2016/11/14 01:09:15
JohnKebab
2016/11/14 08:15:19
That's the plan, I guess. I got the confirmation by the seller that my warranty is kept if I apply the mod since it's EVGA themselves that recommend it.
Do you have any idea on how much time it takes to receive the kit in europe ?
bdary
- Ribbons : 55
2016/11/14 08:24:26
EVGA X99 Classy ~ EVGA 1080 FTW ~ EVGA 970 SSC for PhysXi7-5930K @ 4.40GHz ~ Corsair H100i ~ 16GB G.Skill RipJaws 4 @ 2400MHzSamsung 840 Pro w/ W7 HP & W10 Pro 64bit (Dual Boot) ~ Samsung 840 256GBEVGA 1300W G2 ~ CM HafX ~ ASUS ROG Swift 144Hz Gsync ~ Acer 27" 120Hz 3D Firestrike >> http://www.3dmark.com/fs/9823006 TimeSpy >> http://www.3dmark.com/spy/297131EVGA Affiliate Code - M1D1QH1FTU
