himmatsj
Link: http://www.legitreviews.com/nvidia-evga-geforce-gtx-1060-video-card-review_184301/11 So as you can see, the GTX 1060 SC idles at 45% fan speed, and it is also locked to a minimum of 45% from the BIOS, meaning you can't go any lower with tools like Precision and Afterburner. But I simply don't understand why this is necessary. The GTX 960 SC which has pretty much the exact same cooler has a 0DB mode on idle, where the fans shut off. If anything, idle temps with the passive cooling should be just as good if not better with the GTX 1060 SC. I'm not worried about the noise at all (1100 RPM is practically silent for me), but I'm worried about the wear and tear of the card. I game maybe 1-2 hours on average a day at most, but the PC stays on for at least half a day. It's going to inevitably shorten the life of the fan, and increase dust collection...no? I hope some EVGA reps can clear this up. It's pretty disappointing, cause the GTX 1060 SC otherwise looks like a beast of a card! (60C load temps FTW!!!)
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: EVGA GTX 1060 (SC) idles at 45% fan speed, BIOS locked to the same speed as well
2016/07/20 09:43:12
Every card before the 900 series ran constant fan speeds. There wasn't a 0db fan option, outside of using a waterblock.
45% is right where the 750ti was sitting because it had a 2 pin fan, and was controlled by power from the card. I wonder if Nvidia went with a 2 pin on this series.
himmatsj
2016/07/20 09:48:12
I did have an EVGA 750 SC (non Ti) myself, and that too idled at 42%. I don't have an issue with noise, it's just that people say the fan wears out slower in 0DB mode. Speaking of which, indeed I should check out other cards with reference PCB and see if they have 0DB mode or not.
the_Scarlet_one
- Ribbons : 79
2016/07/20 09:54:53
The 1060 pcb only has a two pin fan from what shows on Google. The statement that fans don't wear out as quick with 0db is a fact. A cars engine doesn't wear out if it is turned off either. But if you turn your car off at every single stop light, you are going to damage the starter. It's uncommon for fans to wear out on the gpu.
himmatsj
2016/07/20 09:59:36
I never knew two pin fans existed. So what about them disallows 0DB mode? Can they even be altered at all using Afterburner?
bdary
- Ribbons : 116
2016/07/20 10:13:01
Personally, I would never let my GPU(s) run (idle or loaded) without the fans running. My 970's have a bios with the 0db setting. I would only use it if I have MSI AB or EVGA PrecX set up to run with a custom fan curve keeping the fans running at a minimum when idle.
2016/07/20 10:29:33
I don't think you need to worry about the gpu fan burning out as it most likely has a 100,000 hour life expectancy rating.
the_Scarlet_one
- Ribbons : 79
2016/07/20 10:40:46
himmatsj I never knew two pin fans existed. So what about them disallows 0DB mode? Can they even be altered at all using Afterburner?
It would take a power from the card rerouting power directly to the fan over and over. Everyone it turned on, it would have to reroute power. They may find it best to leave it running all the time so that the card stays stable.
EVGA_JacobF
- Ribbons : 26
2016/07/20 17:17:40
We will be updating to a 0dB fan mode.
himmatsj
2016/07/20 20:00:49
Scarlet-Tech
Scarlet-Tech, I just want to ask you, Let's say I get the fan to spin at 20% on idle (below 50C, a flat 20%). Is a low speed "bad" for the GPU? Or is it fine? Cause maybe 45% may be too much, and sometimes 0% may be ineffective, so is it OK for a user to customize it to between 20-30% at idle? Or is it "too slow" and will cause the fan to get spoil? Is there such a thing?
the_Scarlet_one
- Ribbons : 79
2016/07/20 20:05:37
Yes. 20% would be perfectly fine, but you would need a fan that could do it. Just above you, Jacob said they would look into the 0db. I don't know much about 2 pin fans, but I seem to remember the 750/750ti having an issue of the fan not working properly below 42% or something. It could be something along those lines with the initial bios. Either you get 0 rpm or a minimum 42% to get them to work properly.
I know with pwm fans, you can go to barely moving and they work just fine, since it's just a fluctuating signal telling the fan how fast to go.
ipkha
- Ribbons : 6
2016/07/20 20:51:25
Most DC controlled fans can't run that low. It's my understanding most DC fans need at least 30-40% power to get going reliably at speed. PWM fan can run all the way down to 10% or so because they get full power, just control the speed electronically. Pretty sure a 2pin fan wouldn't have that capability, you'd need at least 3 if you gave up the speed reporting pin.
himmatsj
2016/07/21 02:37:20
Scarlett-Tech, I need some more clarification regarding this matter. Do you mean to say that these 2-pin fans cannot be controlled at all via apps like MSI AB and EVGA PX? And do these 2-pin fans even respond to changes in temperatures? If no, how do they know when to switch fan speeds? Look at this GPU-Z reading for the EVGA GTX 1060 SC: http://www.legitreviews.com/wp-content/uploads/2016/07/evga-GTX1060-Temps.jpg The fan speed/RPM seems to be constant at 57% under load. Zero fluctuations. So that means it doesn't dynamically scale higher/lower as the temps change? Also does it mean the fan only has two preset values: idle and load? Also, is that 45% a number that EVGA would have specifically chosen for the minimum speed of the fan, or does it actually truly mean that the fan cannot spin below 45% (assuming the BIOS has a lock and that it can be overridden)?
post edited by himmatsj - 2016/07/21 03:50:20
jeffreyl
2016/07/21 07:08:14
EVGA_JacobF We will be updating to a 0dB fan mode.
Does that mean future models, or will it be via driver/firmware?
the_Scarlet_one
- Ribbons : 79
2016/07/21 08:33:08
himmatsj Scarlett-Tech, I need some more clarification regarding this matter. Do you mean to say that these 2-pin fans cannot be controlled at all via apps like MSI AB and EVGA PX? And do these 2-pin fans even respond to changes in temperatures? If no, how do they know when to switch fan speeds? Look at this GPU-Z reading for the EVGA GTX 1060 SC: http://www.legitreviews.com/wp-content/uploads/2016/07/evga-GTX1060-Temps.jpg The fan speed/RPM seems to be constant at 57% under load. Zero fluctuations. So that means it doesn't dynamically scale higher/lower as the temps change? Also does it mean the fan only has two preset values: idle and load? Also, is that 45% a number that EVGA would have specifically chosen for the minimum speed of the fan, or does it actually truly mean that the fan cannot spin below 45% (assuming the BIOS has a lock and that it can be overridden)?
I can't explain it any better than I have.
ipkha
- Ribbons : 6
2016/07/21 08:44:26
More than likely, they'll have to put zero power to fan header at idle, 45% is probably the best setting after the 60 degree threshold and a ramp up from there. There's no pin to control the fan speed exactly like the PWM style fans.
Fans use 2 pins minimum. 3 pin fans are voltage controlled, thus your cheap fan controller puts between 5v and 12v to fan. Any less and the fan won't be able to start. The 3rd pin is a speed sensor to report back to controller. 4 pin fans have 2 power pins, 1 speed reporting pin and 1 PWM control circuit. This allows the fan to pull all 12v to the motor and an electronic speed controller to precisely pulse the motor to achieve pinpoint speed control. This is why they can down rpm in the 10% range.
A DC controlled fan generally needs at least 30% power to start spinning. Many fan controllers won't let you drop below 40% as some fans need that to get going. So 12V X 45% =5.4V which is close to that 5V needed to get the fan going. Thanks it can ramp up to the full 12V and run at 100%.
himmatsj
2016/07/21 08:52:20
the_Scarlet_one
- Ribbons : 79
2016/07/21 08:59:03
It may have a 4 pin fan, and then a 2 pin led control, but I have never seen an LED on a X60 series card. Maybe Nvidia made a good move forward. Not many people have this card in hand, so you will need someone that has one to show it off.
ipkha
- Ribbons : 6
2016/07/21 09:00:03
Well that looks like a 4 pin fan alright. So in that case it should easily be controllable by the PrecisionX OC software. Not sure why it's locked in the BIOS though.I wonder if it's a glitch or intended. I'm leaning towards glitch since Jacob said they'll be adding it.
Sorry about the confusion, I see now where the conversation got derailed (750 ti).
EVGA_JacobF
- Ribbons : 26
2016/07/21 09:14:27
We are working on a new firmware update that will allow for 0db under idle. This update will be applied to new production cards and available for download for existing.
himmatsj
2016/07/21 09:26:58
ipkha Well that looks like a 4 pin fan alright. So in that case it should easily be controllable by the PrecisionX OC software. Not sure why it's locked in the BIOS though.I wonder if it's a glitch or intended. I'm leaning towards glitch since Jacob said they'll be adding it.
So you mean to say the 750/Ti had a preset minimum speed because it had 2-pins and that corresponded to the lowest possible 5V value, and the card can then scale freely above that from 5V-12V?
ipkha
- Ribbons : 6
2016/07/21 10:11:25
jeffreyl
2016/07/22 09:02:00
EVGA_JacobF We are working on a new firmware update that will allow for 0db under idle. This update will be applied to new production cards and available for download for existing.
Great news, thanks!
albontor
2016/07/23 05:05:40
0dB mode will be also available for the non SC card?
Uzanar
2016/07/26 10:29:19
Where would I look for this vBIOS once it's released?
the_Scarlet_one
- Ribbons : 79
2016/07/26 10:30:56
Uzanar Where would I look for this vBIOS once it's released?
Just send an inquiry to Support@EVGA.com or create a ticket under your product list for the GPU and the support staff can forward it to you.
Uzanar
2016/07/26 10:31:13
Scarlet-TechJust send an inquiry to or create a ticket under your product list for the GPU and the support staff can forward it to you. Okay, thanks for the fast answer. Do you think they will announce it in any way or should I just do it instantly when I get my card?
post edited by Uzanar - 2016/07/26 10:40:59
FattysGoneWild
2016/07/26 10:36:02
Will this be coming for the 1080 FE as well? I just made a thread about this a few days ago. http://forums.evga.com/EV...-running-m2517860.aspx
HP Omen 880-160se custom ordered OS: Windows 10 64 bit MOBO: HP Tampa2 CPU: Intel i7 8700k @4.8GHz RAM: 32GB DDR4 2400 GPU: PNY XLR8 RTX 3080 PSU: Delta 750w 80 Plus Platinum NVMe M.2 SSD: Samsung 512GB MZVLW512HMJP SSD: 250GB Samsung 860 EVO HDD: 2TB Seagate Barracuda ST2000DM001 Sound: Logitech Z623 THX 2.1 Speakers Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display Keyboard: HP Omen 1100 Mouse: HP Omen 600
EVGATech_ChrisB
EVGA Tech Support
2016/07/26 15:57:06
Hi, I can confirm that we will not have a 0db fan BIOS for the 1070/1080 Founder Edition models. FattysGoneWild
Uzanar
2016/07/26 16:04:14
EVGATech_ChrisBHi, I can confirm that we will not have a 0db fan BIOS for the 1070/1080 Founder Edition models. Hello! Is the updated vBIOS for the EVGA GTX 1060 finished yet and where should I look for it whenever it is finished?
