Re: EVGA EK FC Terminals for EVGA EK water block?
2014/09/23 14:03:14
On EK block (link in the above post), those two holes is not where you attach your loop though, right? You mount... well... that rectangular thingy (whatever it is called) with in/out ports on top of those two holes, or you mount an SLI bridge instead for multi-GPU loop.
But that's EK, not sure how this works with EVGA HC, even those are made by EK, I think they are different.
