Hot!EVGA 1080 FTW .. Caught fire with some parts exploding
darksouls
2016/10/03 12:48:48 (permalink)
 As usual was on a normal game of overwatch, suddenly i heard a bang as something blew in my case!! and the screen went black, checked the side panel of the case and could clearly see a small flame coming out of the card which was there for a bit with some smoke that followed.
The damage is at the capacitors section i guess or the voltage regulators not sure tbh
I'm using a corsair 1200i PSU and also a wall voltage regulator. Furthermore, I never opened the card nor did i remove the back-plate, furthermore, I never OC'ed it and placed in a well ventilated case
Is it only some bad luck or anyone else had similar problems with the card. I've Always used EVGA cards and this never happened to me before
The problem is that I bought this from Amazon and I live in Dubai, is there a way to RMA it to Dubai instead of shipping to the USA or Europe which will cost me a lot (more than 150$) and might take some time, I might get the card back in month or so !!!
I would appreciate it if someone can help on this please
I uploaded a photo of the area the card caught fire at
Cheers
DS
post edited by darksouls - 2016/10/03 21:59:17
Intel 6850K @ 4.4Ghz
Corsair Hydro Series h100i v2
Asus X99 Deluxe II
EVGA 1080 FTW Hybrid in SLI with
EVHA 1080 FTW
G.skill Ripjawz 32GB DDR4 - 3000
Samsung 950 Pro 256GB nvme m.2
Corsair 1200i PSU
29 Replies Related Threads
    arestavo
    • Ribbons : 8
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 13:11:32 (permalink)
    Register your card if you haven't already: https://www.evga.com/support/register.asp
    Then call or email tech support: http://www.evga.com/about/contactus/
    EVGA affiliate code: 9ZWDWFNW6A
    (Don't forget to upload your invoice or no credit is given!)
    FOLD ON
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 13:36:45 (permalink)
    arestavo
    Product already registered, and invoice uploaded and all the works ..etc
    RMA system forwards me to the EU site and the RMA section is not working and keep getting page run time error msg
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    arestavo
    • Ribbons : 8
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 13:42:14 (permalink)
    Try emailing them not using their built-in system?
    FOLD ON
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 13:44:31 (permalink)
    arestavo
    Did that as well..
    anyone knows which part that blew up and what might have caused it ?
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    hapkiman
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 14:25:07 (permalink)
    Could it be related to the power socket adapter used in Dubai?  Do you use the standard 3 pin British plug (220-240v) or were you using a power converter?  Sounds like a power surge of some type.  What kind of "voltage wall regulator" were you using?
    i7 6700K, Corsair H80iGT, 16GB Corsair Vengeance DDR4 @3000MHz, EVGA GTX1080 FTW, MSI Z170A Gaming M7, Samsung 950 Pro 512GB, Samsung 840 EVO 250GB, WD 1TB, Creative SB Zx, Dell P2715Q 4K/UHD @60Hz, Samsung B2230HD 1080p @60Hz, Windows 10 Pro, Corsair Air 540, Seasonic 860watt XP2, Corsair K70 RGB, Razer Deathadder Chroma
    • Ribbons : 57
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 14:43:30 (permalink)
    darksouls
    arestavo
    Did that as well..
    Hard to say. But that is right in the area where the PWM or power regulation section is. So that is the most likely culprit. There's no way to repair this yourself. Anyhow, they are usually pretty quick about responding.
    post edited by HeavyHemi - 2016/10/03 16:24:16
    12GB Corsair Dominator 2000C9
    EVGATech_ChrisB
    Administrator
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 18:17:59 (permalink)
    Dear darksouls,
    I am sorry to hear that you had a problem with your card.  I can't say for sure what happened, but I can assure you that we are here for help with warranty.  I have escalated your thread to our EU support team and I expect that they will contact you once they open.
    darksouls
     As usual was on a normal game of over watch, suddenly i heard a bang as something blew in my case!! and the screen went black, checked the side panel of the case and could clearly see a small flame coming out of the card which was there for a bit with some smoke that followed.
    Cheers
    DS
    Salem13
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 18:22:28 (permalink)
    Exploding caps are scary, lets hope this is a huge anomaly!
    arestavo
    • Ribbons : 8
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 19:02:05 (permalink)
    Salem13
    Heck yeah they are. I'm radio by trade (USAF), but I was helping out some radar guys at one point. They have HUGE transmitter assemblies (some half the size of refrigerators), and the driver cards at the bottom are lined with caps. One of those caps popped while the assembly was removed for testing, and shrapnel bounced around the cab - not something that I'd like to be around a lot (and they do it all the time! The radar guys AND the caps!).
    FOLD ON
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 21:26:46 (permalink)
    hapkiman
    yup, in Dubai we use the standard British 3 pin plug and I'm not using any power converters. I'm using a Masterplug power surge protector and voltage regulator.
    All other PC components are working fine btw, MB, CPU RAM .. etc and I tried two different graphic cards on the mb and all working fine
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    • Ribbons : 44
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 21:38:53 (permalink)
    Glad to see the rest of your PC was spared any damage.  Nice to have spare GPU, even if it is an older one
    1) ASUS Z97-WS, i7-4790K@4.9GHz,  2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842
    2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD    Affiliate code 05MLLDCG6B
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 21:42:47 (permalink)
    EVGATech_ChrisB
    Dear darksouls,
    darksouls
    Cheers
    DS
    Thank you Chris, your help is much appreciated
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/03 21:47:59 (permalink)
    I installed one of my previous 2 x EVGA 980ti Hybrid's that went to my wife's pc when i got the 1080 FTW, now got one of them back in my case till I get this thing sorted out
    post edited by darksouls - 2016/10/03 22:01:08
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/30 02:53:26 (permalink)
    Well since i posted this thread amonth back it seems that the problem was related to the vrm overheating issue afterall ...
    I got my replacement card from EVGA europe super fast ... big thnx to the team there but now im worried that this card will go bad as well ... anyone knows if they addressed this problem with the replacement cards ??? I oredered the pads from evga and still waiting on them ...
    Furthermore, now i have another 1080 ftw hybrid ..running in sli with the replacement card .. waiting as well on the 1080 ftw hybrid to hit amazon as evga does not accept international cc's ..
    Should o worry about the hybrid as well .. does it have the same problem ? Anyone ?
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    Angier_1985
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/30 02:57:46 (permalink)
    http://www.evga.com/support/guestregister.asp
    Enter your serial numbers there. If the cards have been shipped before 30/8 there is a 4% chance you have faulty VRM
    IF that is the case, you should have seen an error by now.
    Greetings from Dubai btw, mate :D waiting for my hybrid to arrive from a german outlet via SnS.
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 03:28:14 (permalink)
    Angier_1985
    Nice to know that and thnx for the headsup ..
    where did you get the kit from, is it the FTW or the normal one ? as i can't find the 1080 FTW Hybrid kit anywhere else
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    Angier_1985
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 03:30:52 (permalink)
    It's an importer from the US, selling via ebay. Nothing too professional and I just got it out of personal acquaintance.
    I'd give it another month or two before you can expect any reasonable stock of hybrid kits or even cards around here. Been told that the big suppliers sit in the EU and they will of course first make sure that the EU is covered before the middle east gets it's piece. And then there are the customs and the fact that many stores around don't go for EVGA but Asus, because of the kids with the big wallets and all the brand awareness on their mind.
    NucleusX
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 03:39:00 (permalink)
    NucleusX
    lol check this out ! https://www.youtube.com/watch?v=O2-VaOPOvgI
    CPU:  Intel 486 DX2. 66Mhz (Turbo). Cooling: LN2.
    MTB: ECS. Chipset: SIS. HD: WD Raptor 300mb x 512. 154GB. Raid 0.
    RAM: Corsair Obliterator Gold. EDO. 16mb. 66mhz. x8.
    GPU:  Nvidia GTX Riva TNT2 FTW OC. PCI. 32mb. x4 Quad SLI.
    PSU:  ATX 200 watt (no label). Case: RGB Milk Crate.
    sooqa
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 11:20:38 (permalink)
    How long you use your card?
    Salem13
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 11:27:02 (permalink)
    NucleusX
    NucleusX
    LOL, that's quite a fire while not being plugged into power.
    • Ribbons : 68
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 11:38:09 (permalink)
    Salem13
    It almost looks like it shorted out with the CPU Cooler.
    I wonder what Sabertooth Motherboard that was?
    post edited by bcavnaugh - 2016/10/31 11:41:02
    phoenixst
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 11:55:22 (permalink)
    That red sound card piggy back riding the GPU fan is just wrong...
    Now I'm afraid to leave my PC running while I'm away.
    #23
    ZCTxCHAOSx
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 12:09:15 (permalink)
    darksouls
    Glad you finally found out the truth.  One of these days all these people denying it here will too and we can all move on and figure how to cure this rather than avoiding.  As far as I know at this point, it is any EVGA 1070/1080 Pascal card that has a back plate.  I see some mixed things about those manufactured after 8/30 being ok.  My 1070 SC burned out last week after 4 months use, so it was before the 8/30 date. Good luck to you :)
    #24
    • Ribbons : 57
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 12:43:32 (permalink)
    ZCTxCHAOSx
    darksouls
    Cool story bro! Did you notice that the PCIe power was not even plugged into the GPU?  So, what does that video have to do with anything?
    #25
    ZCTxCHAOSx
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 13:21:13 (permalink)
    post edited by ZCTxCHAOSx - 2016/10/31 21:29:58
    #26
    • Ribbons : 57
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 13:28:41 (permalink)
    ZCTxCHAOSx
    ZCTxCHAOSx
    darksouls
    First of all, I didn't even reference the video. Second of all, some power is provided through the board slots.  The pin connections are simply for more power to the PCB (which is even more concerning it happened with low wattage applied).  Third of all was this spontaneous combustion? An illusion like your mental capacity? Please quit hijacking peoples threads with your nonsense. You should have better things to do like inhaling your hemi fumes.
    Interesting. So we really don't know what happened here, but you decided to make up a story and then direct further insults my direction. That doesn't seem to say much about your credibility.
    #27
    ZCTxCHAOSx
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 13:34:38 (permalink)
    post edited by ZCTxCHAOSx - 2016/10/31 21:30:32
    #28
    • Ribbons : 57
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 13:45:41 (permalink)
    ZCTxCHAOSx
    ZCTxCHAOSx
    ZCTxCHAOSx
    darksouls
    "Well since i posted this thread a month back it seems that the problem was related to the vrm overheating issue afterall ... "  That is from the OP.  Good lord dude get a grip.  All I was saying was I was happy he found his issue.  I really don't care whatsoever what credibility you give me.  I am just a paying customer of EVGA who had problems. Period.
    No, you're actually the one screaming for folks to NOT BUY EVGA based on your opinion that 'every 1080 and 1070 with a backplate' is defective. Such an alarming claim needs credible evidence. So far, besides a couple of reports of failing SMD devices, there is none. This is separate from the VRM/Memory area running hotter than other models. If you had stuck with reporting your issue and trying to get a resolution, I wouldn't be saying a thing. But no, you decided to advocate a complete boycott and post several  insults to those pointing out the evidence, doesn't align with your histrionics. That isn't acceptable in my opinion. The offer for you to provide evidence that every 1070 and 1080 with a back plate is defective is still open.
    #29
    darksouls
    Re: EVGA 1080 FTW .. Caught fire with some parts exploding 2016/10/31 19:30:09 (permalink)
    sooqa
    A couple of weeks before it died
    Asus X99 Deluxe II
    EVHA 1080 FTW
    Corsair 1200i PSU
    #30
