EVGA 1070 SC constantly hitting power limit
buzzdrew7
2016/11/08 15:26:32 (permalink)
It's hitting the power limit without any overclocking on heaven benchmark with v sync off.  Not sure why it's doing this.  Games are running fine and haven't had any major issues.  Just updated the BIOS and waiting for the thermal pad to come in.  Should I be concerned???  Is there anything I can do to alleviate this?
post edited by buzzdrew7 - 2016/11/08 16:29:35
9 Replies Related Threads
    SinistaLad
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/08 16:11:13 (permalink)
    Can confirm this also. Bashes the limit constantly.
    carb1de
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/09 01:33:47 (permalink)
    that's good though right? shows full utilisation of the card? if you force vsync on through the control panel, you'll probably see it fall?
    i'd be interested to see, if you bump the power target to the max (112%?) whether you reach that too
    • Ribbons : 122
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/09 14:48:24 (permalink)
    As long as the card runs at advertised speeds you're ok. If you really want this fixed you'll need to rma your card.
    carb1de
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/09 15:20:27 (permalink)
    But nothing is broken is it? Vsync is off so the gpu is left unconstrained to spit out as many frames as it possibly can?!
    DeathAngel74
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/09 15:30:54 (permalink)
    Mine has yet to hit the power limit. Except during initial overclocking experimentation. But I'm also only gaming at 1080p.
    Then
    Now
    post edited by DeathAngel74 - 2016/11/09 15:36:19
    Corsair Carbide 300R Windowed ATX Mid Tower Case
    ASUS ROG MAXIMUS VIII HERO Z170
    Intel Core i7 6700k 4.6 GHz 1.35v-1.37v adaptive
    32GB Corsair Vengeance LPX DDR4 DRAM 3200 MHz C16 16-18-18-36-2T
    EVGA Geforce GTX 1070 SC ACX 3.0 2101MHz/8726MHz 1.075v-1.081v
    Corsair H100i v2 Hydro w/2x SP120 and 2x Thermaltake RIING 12 Blue LEDs
    7x Thermaltake RIING 12 Blue LEDs
    EVGA SuperNOVA 1300 G2 1.3kW Fully Modular
    ADATA 480GB (storage/games)
    ADATA 960GB (Windows/Games-Origin/Steam/GoG)
    Realtek ALC1150/SupremeFX 2015
    Windows 7 SP1 Ultimate x64
    http://www.3dmark.com/3dm/15307550
    http://valid.x86.fr/ez4v5d
    • Ribbons : 122
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/09 15:44:00 (permalink)
    carb1de
    Nothing is broken.
    QdotJ
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/10 07:26:20 (permalink)
    buzzdrew7
    Yes, turn off Precision overlay and enjoy your card.
    TheC4rnage
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/11 15:16:20 (permalink)
    DeathAngel74
    Then
    Now
    You get 2100+ core gaming too?
    I cant get over 2000 here, and it frequently hits power limit and when that happens it goes down to 1960-1970
    DeathAngel74
    Re: EVGA 1070 SC constantly hitting power limit 2016/11/11 23:18:05 (permalink)
    can't get past 2101, but yeah constant during gaming, except drops between loading screens.
