- Ribbons : 98
Hello! You may have already seen a thread where I have been giving away a bunch of free stuff with free shipping. If not, the thread is here: http://forums.evga.com/Giveaway-Lower-48-US-Only-Computer-Parts-m2266842.aspxThe above thread is almost dead because I am almost out of valuable free computer parts to give away. This thread is slightly different. How so? I want to give away some more free stuff in order to unclutter my life, but this stuff is large and/or heavy. In other words, I am offering more free stuff, except this time you will need to pay for the shipping if you want one of these items. How will this work?1) PM me your street address and state the item(s) you are interested in. 2) First come, first serve. 3) Once you PM me, I will PM a shipping estimate back to you. 4) Once you PayPal me the value of the shipping estimate, I will ship it to you. 5) If a deal falls through, I will move on to the next person in line. Thermaltake Toughpower 1200W [NO LONGER AVAILABLE] Lian Li Open Tech/Test Bench [NO LONGER AVAILABLE] Phase Change Cooler #1 [NO LONGER AVAILABLE]This unit is a custom-built unit. It was designed "to hold -35c or colder at 300 watts and idle around -45c". I had no way of measuring my heat load so I cannot say for sure if that specification holds true, but I do know that it has served me well with no hiccups. There is just a simple on-off switch in the back to turn it on.  Phase change "#1" is the one on the right with LED temperature display  Phase Change Cooler #2 [NO LONGER AVAILABLE]This unit started out as a lowly Prometeia Mach II GT. One day, the flexible hose ruptured. So, I had it repaired and upgraded. It now has a longer stainless flex line, an upgraded evaporator and higher CFM fan (the reason the front is modified), and has been tuned to handle 250W and customizable to work well with either CPUs or GPUs. According to the person who modified it, all it needs is an additional evaporator fan (push-pull configuration) in order to support 300W of heat load.  Phase change "#2" is the one on the left.  The PVC shell around the cold head has not yet been cemented. This means that you can choose which hold-down plate (comes with two [pictured]) will suit your application best when it arrives and then cement it permanently.
post edited by ty_ger07 - 2014/12/21 20:54:06
Re: Giveaway: Phase Change Coolers, Open Test Bench, Power Supply
2014/12/17 17:21:00
PSU
KILLER_K
2014/12/17 17:37:08
Leave some for the other folks...... How heavy is the Phase change and what adapters comes with it? Demonik5150 PSU
My Affiliate Code: EKD06T601Y
2014/12/17 17:38:08
Pmed about phase change #1 :-)
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
- Ribbons : 98
2014/12/17 17:58:04
KILLER_K Leave some for the other folks...... How heavy is the Phase change and what adapters comes with it?
They are both quite heavy. Sorry, I don't have a scale. I am GUESSING (don't quote me on this) that shipping will be around $50 for each one. But it will depend on your location and how shipping prices have varied. Here is unit #1: The top:  The bottom (a picture of the plate which would be up against the back of your motherboard):  Pardon the foam stuck to the bottom.  You will need to put foam on the top of the plate so that it doesn't short on the back of your motherboard of course. Unit #1 is designed to fit a variety of different CPU sockets. I don't know off the top of my head which ones specifically, but you can see that there are many options "built in". Here is unit #2:  Unit #2 was designed to be used in a wide variety of applications. I never glued it together because I wanted to be able to adapt for various applications. I used my own ghetto brackets clamped together. It comes with these brackets: You will have to choose which of the two brackets you want to use. Once you choose a bracket, install it, put the PVC tube around the cold head, install the PVC collar in the back of the cold head (inside the PVC tube), and glue the PVC tube to the PVC collar to make it permanent. The two included brackets should work for a variety of Intel, AMD, or NVIDIA products.
post edited by ty_ger07 - 2014/12/21 19:07:38
LFaWolf
2014/12/17 18:02:11
My Affiliate Code: WF7SIE2ZR9 System 1: i7 3960X OC to 4.1GHz * Prolimatech Megahalems CPU Cooler * ASUS Rampage IV Extreme * EVGA GTX Titan Superclocked 3-way SLI * 64GB Kingston HyperX Beast 2133MHz @1.6V * Samsung 840 Pro 256GB SSD * Crucial M500 1TB SSD * SoundBlaster ZX-R * EVGA G2 1300 PSU * NZXT Switch 810 White Tower * Logitech z5500 Surround Sound Speakers * Logitech MK560 Wireless Keyboard/Mouse * HP ZR2740w IPS 3x Surround -------------------------------- System 2: i7 3960X OC to 4.3GHz * Prolimatech Megahalems CPU Cooler * ASUS Rampage IV Extreme * EVGA GTX 680 4GB FTW 3-way SLI * 64GB Crucial Ballistix LP 1600MHz @1.5V * Seagate 600 256GB SSD * Crucial M500 1TB SSD * SoundBlaster Z * Seasonic X-1250 PSU * Antec Eleven Hundred * Logitech z906 Surround Sound Speakers * Logitech MK560 Wireless Keyboard/Mouse * ASUS PB278Q 3x Surround
KILLER_K
2014/12/17 18:03:52
Awesome and thanks for the information. That is exactly what I needed. If Scarlet-Tech skips it let me know. Thanks
post edited by KILLER_K - 2014/12/17 18:06:36
2014/12/17 18:11:14
KILLER_K Awesome and thanks for the information. That is exactly what I needed. If Scarlet-Tech skips it let me know. Thanks
I had sent two messages in pm before I even posted in here, lol. I forgot to specify number 1. I hate to say, I won't be skipping ad I have been looking for a phase change since day 1 of overclocking and trying to get temps down. The 3960x and 5960x would both love this thing.
KILLER_K
2014/12/17 18:25:55
Again not a big deal. Good luck on 300 watts with either of those cpus overclocked though. As they will be way past a 300 watt load overclocked. A 3960z @ will pull around 470 watts running at 4.8GHz A 5960x @ will pull around 450 watts running at 4.6GHz
I'm sure you know this though. If not just passing the information along to you. Good luck with the phase changer it is a nice one. big thanks for doing this for everyone. Scarlet-Tech I had sent two messages in pm before I even posted in here, lol. I forgot to specify number 1. I hate to say, I won't be skipping ad I have been looking for a phase change since day 1 of overclocking and trying to get temps down.
Baltothewolf
- Ribbons : 5
2014/12/17 18:30:29
My Laptop (GT70 Dominator Pro): - Intel I7 4810MQ @ 2.8ghz . - 12GB RAM. - GTX 880M.. - 1x Samsung 840 EVO 500GB.- 1X 1TB 7200 spinny drive.
- Ribbons : 98
2014/12/17 18:59:30
Baltothewolf Is that psu gone?
It's not gone, but there is someone already interested in it. I will be getting shipping estimates tomorrow. I have received PMs for mostly everything so far. Only Phase Change #2 is sort of on the fence.
new2019
2014/12/17 19:56:25
I'l take the Phase Change #2 , il cover the shipping . PM sent .
EVGA SR2 | X5650 | X5650 | Corsair Dominator |
- Ribbons : 98
2014/12/17 20:35:55
KILLER_K ... what adapters comes with it?
I already answered above, but here are a few pictures to show them in action.  Larger: http://open-web-community.com/uploads/computer%20parts/phaseinaction1.jpg "Unit #2" is hooked up to the video card in these pictures. You can probably see in the above picture that I used none of the PVC collar. I just put a simple plate with a notch cut out over the cold head and then screwed it down. I also wrapped insulation around it in the absence of the PVC housing. Two more pictures.   That's my world record 9400GT run with the 9400GT at -30 to -40c.
post edited by ty_ger07 - 2014/12/17 20:37:25
new2019
2014/12/17 20:53:06
^^looks awesome , il make a bracket to fit it .
RainStryke
- Ribbons : 40
2014/12/17 21:32:09
Intel i7 4790K - Corsair H90 - MSI Z87 MPOWER MAX AC - MSI GTX 980 (81.7% ASIC) - 16GB G.Skill 2400MHz - Seasonic X-1250 - Crucial MX100 512GB - Corsair Carbide 500R EVGA Affiliate Code: S27QNQME0X
notfordman
- Ribbons : 14
2014/12/17 22:01:54
RainStryke Awesome giveaway!
+1 and then some... Very generous ty_ger07 !!
- Ribbons : 98
2014/12/17 22:44:31
new2019 ^^looks awesome , il make a bracket to fit it .
I was just looking... and ... I forgot that I had these. I believe the bigger plate is for LGA 1155 and LGA 1366 and the smaller plate is for LGA 775 and GPUs. AMD is probably somewhere in there too.    What you do is install whichever of the two plates, and then PVC cement the PVC shell into place to hold it all together permanently.
post edited by ty_ger07 - 2014/12/17 23:29:59
new2019
2014/12/18 01:24:29
- Ribbons : 98
2014/12/18 09:32:17
Well, the shipping company is busy and being rude. They don't want to give me an estimate because they are busy. But I am trying to explain that I will be shipping this stuff and just need to do it in two steps instead of 1.
- Ribbons : 98
2014/12/18 09:45:34
I got a shipping estimate for the PSU.
I bought boxes for the test bench and phase change coolers. I will pack them all up nicely and then maybe the shipping company will give me the time of day to give me an estimate. Maybe I will have to do one at a time and go through the line each time or something.
- Ribbons : 98
2014/12/18 11:20:46
Ok, I got some estimates. I will be sending PMs out shortly.
new2019
2014/12/18 11:33:43
2014/12/18 11:46:38
awesome evga member!!! that will be a wonderful xmas gift to the members
- Ribbons : 98
[ONE PENDING, MOST SHIPPED] Giveaway: Phase Change Coolers, Open Test Bench, Power Supply
2014/12/18 13:03:40
I have sent out PMs to everyone for the items they are interested in. I have not received a shipping payment for any of the items yet. In other words, everything has been claimed, but nothing has been purchased yet. EDIT: Phase Change unit #1 and Test/Tech bench case have been shipped. EDIT 2: PSU has been shipped.
post edited by ty_ger07 - 2014/12/20 11:39:22
Re: [ONE PENDING, MOST SHIPPED] Giveaway: Phase Change Coolers, Open Test Bench, Power Sup
2014/12/29 19:49:25
*Just as a reminder. In this section, you cannot even charge for shipping. I know I'm a little late here, but wanted to mention it for future giveaways.* EVGAWeb_ShaneD Since you bunch seem to be quite zealous with the generosity, we determined a new section was needed for everything related to members giving each other stuff.
- Post your own contests - keep in mind these contests must be items you personally own that you are giving away free and clear without any sort of payment or affiliation with another person/business/entity.
- Post your thank yous - any time someone gives you something, post here to thank them.
We have also determined that we will no longer be giving away BR's for giveaways. Thank you and continue the love fest.
NOTE: I will be offline from 11/21/16 to 12/15/16. If you have a problem please PM another Mod, as I won't be available to answer you back. Thanks. My Affiliate Code: 8WEQVXMCJL
RainStryke
- Ribbons : 40
2014/12/30 03:00:20
He is providing a giveaway free of payment. The only charge is shipping, which he isn't making a profit off of... It's pretty free and clear of any sort of payment... Unless his shipping charges are inflated. **EDIT** I could be wrong, but it's hard to decipher the way that guideline is meant to be upheld since it doesn't exactly clarify shipping specifically as being a form of payment.
post edited by RainStryke - 2014/12/30 11:22:38
2014/12/30 08:51:32
They definitely aren't inflated. I greatly appreciate it being done the way this one went, and I do agree it wouldn't be considered payment, as he gave exact shipping quotes. He didn't even request money for the shipping materials.
I do understand the purpose behind the giveaway, no money exchange rule also, which is to keep people from charging shipping for game codes they aren't allowed to sell.
- Ribbons : 98
Re: [ENDED] Giveaway: Phase Change Coolers, Open Test Bench, Power Supply
2014/12/30 08:58:03
XrayMan *Just as a reminder. In this section, you cannot even charge for shipping. I know I'm a little late here, but wanted to mention it for future giveaways.*
Thank you for the heads up. I would estimate that it was $1000 worth of stuff given away for $100 worth of shipping -- some of which was later donated to non-profits or other organizations. Perhaps it would have been better suited for the Hot Deals section. Either way, I am glad that it was a success and that it is finished.
2014/12/30 16:17:17
RainStryke He is providing a giveaway free of payment. The only charge is shipping, which he isn't making a profit off of... It's pretty free and clear of any sort of payment... Unless his shipping charges are inflated. **EDIT** I could be wrong, but it's hard to decipher the way that guideline is meant to be upheld since it doesn't exactly clarify shipping specifically as being a form of payment.
I'm going to ask for a clarification on this from Rob. I will post here again when I get an answer.
2015/01/06 21:04:14
Good lord how on earth did I miss this? :( Good on you Ty_Ger!
Desktop: i7 3820 - ASUS X79 Sabertooth TUF - 4x4GB G.Skill TridentX 2400C9 - EVGA GTX 580 Classified ULTRA Hydro Copper Microsoft Surface Pro 4: i7 6650U - 16GB RAM - 256GB SSD - Sennheiser HD 598 - DualShock 4 Controller
