sethleigh
My EK full cover 1080 water block showed up (yay!) and I'm going to shut down in a little while and install it. Being a long-time computer tinkerer I have several thermal compound tubes lying around, plus the little tube of EK-TIM ectotherm that came with the EK block. My options are: Noctua NT-H1 Prolimatech PK-3 Arctic Silver 5 Arctica Silver 3 EK-TIM ectotherm I've pretty much ruled out the Arctic Silver ones as being a little dated by today's standards. I'm leaning toward the Prolimatech PK-3, based on this chart, but the Noctua and EK are still in the running. The conservative side of me favors the EK since it would eliminate any questions from the manufacturer should it ever become an issue, but the Prolimatech seems to perform the best. Any opinions? Lastly, I do chuckle at myself over this, because as big questions of the day go, tiny differences in thermal compound performance rank pretty low on my list of concerns, and I'm sure I'd be happy with any of them. But why not indulge in a little geekdom for its own sake from time to time, amirite?
post edited by sethleigh - 2016/08/25 14:54:20
Happy EVGA customer for over 11 years and counting. Affiliate Code: 0Y7-1VU-ATW2 EVGA X99 FTW K, Intel Core i7 6900@4.2ghz/3.5ghz cache, 32gb G.Skill DDR4 3200 MHz CL14 RAM, EVGA 1080 SC w/EK water block, 1TB 850 EVO SSD, EVGA Supernova G2 850W PS, Monoprice 4K monitor, Win 10 Anniv. 64-bit
- Ribbons : 44
Re: EK water block showed up, and I have a choice of thermal compounds - advise!
2016/08/25 15:01:52
Non-conductive & Non-capacitive --- ONLY --- if they over spread no harm no issue MX-4 = my vote
post edited by Cool GTX - 2016/08/25 15:07:54
1) ASUS Z97-WS, i7-4790K@4.9GHz, 2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842 2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD Affiliate code 05MLLDCG6B
sethleigh
2016/08/25 15:04:09
Thanks for the comment. At this point I'm not going to order anything else, so it's got to be one of the ones I've got on hand. Both the Prolimatech and the Noctua are non-conductive, and I assume the EK is too, though I haven't looked it up.
- Ribbons : 44
2016/08/25 15:08:28
Thermal paste roundup 2015 Prolimatech PK-3 ---- looked the best delta T TIM that has little or NO curing time & does not dry out --- is what you want to go with
post edited by Cool GTX - 2016/08/25 15:10:43
sethleigh
2016/08/25 15:14:45
Sounds Prolimatech it is! Thanks for the comments. I'm going to run some tests here to establish a baseline for my 1080 SC for temperature and clockrate and whatnot, and then do the install and see how it changes. Whether it allows more overclocking or not, at the very least lower temperatures will allow higher Boost 3.0 speeds without dropping as things heat up.
2016/08/25 15:35:35
CaseLabs SM8 w/Pedestal- X99 Classified - EVGA 980ti HC's x 2 - 5930k @ 4.5 - 32GB Hyper X predator - 2 x 480mm EK rads - EK blocks and pump/res - All Bitspower black fittings - 1Tb samsung 850 evo 2tb total ssd space - EVGA 1300G2 - Predator X34 - Mayflower Objective 2 DAC/AMP - Beyerdynamic DT990 Pro - Sennheiser HD598 - Mackie CR4 monitors
ARIOS-X1
2016/08/25 16:05:42
I personally use IC diamond (non conductive) TIM. It has no break in time and near absolute no thermal breakdown over time. One application and you never have to worry about changing it again untill you get a new cooler and it will stay good literally for years. Other TIM's I have seen start to cake and crack over periods of time with high temps, but due to the synthetic diamond compound in IC it's the most durable TIM out on the market. I've looked through many compairson charts and IC diamond was the second best compared to the Liquid Metal Ultra (which is conductive) with only 1 degree temp difference between the two. Only problem with IC is that is causes scratches on the cooler block and CPU when you remove it. Due to this it usually means you lose your warranty for your CPU and Cooler, and may have trouble with re-sell value. I use it with an OC i7-6800k @ 4.45Ghz 1.45V and my temps have never gone past 70C with an ambient room temp of 80F. I personally won't use any other TIM besides IC but thats just my preference. Unless your doing extreme OC'ing then IC won't matter much compared to all the other TIM's you've listed. If I were you I'd go with the Prolimatech as I doubt it will disapoint you.
post edited by ARIOS-X1 - 2016/08/25 16:12:04
ARIOS-X1 Celestial Being Gundam Cooler Master HAF 932ASUS SABERTOOTH X99Intel i7-6800k 4GhzEnermax Liqtech 240 AIOCorsair Dominator Platinum 32GB 2400MHzEVGA GTX 1070 FTWGIGABYTE GTX 970 G1 Gaming (Backup/PhysX)Corsair AX860 PSU, Cable Mod Black/Silver Custom Sleeves20 Case Fans Low RPM Cooling
2016/08/25 18:06:42
sethleigh
2016/08/25 20:33:06
Well I'm back, and the fact that I'm typing this means it hasn't leaked yet and destroyed my computer, LOL. I did put some paper towels around the fittings and run just the pump using one of those adaptors that bridges two pins from the power supply. I let it run for about ten or fifteen minutes, during which time I was also tipping it in different directions and trying to get all the air out. I'm not sure it's all out yet, but I did add coolant several times and it's pretty full right now. I used the Prolimatech PK-3 for the thermal compound. I re-used the EVGA backplate, which I'd read can't be done. It was actually easy. I have no idea why people say it doesn't work. Haven't run any tests aside from a couple minutes of Valley yet, but that will come.
post edited by sethleigh - 2016/08/25 21:00:58
- Ribbons : 44
2016/08/25 20:49:23
Woot Bring on the Pics Living life on the edge - 10 min leak test
sethleigh
2016/08/25 20:59:55
HayzBaby
2016/09/21 18:12:00
I used IC Diamond as well for years. My first build was back in 09 when the 1156 cpu chip and the 480 hydrocopper made its debut. I ran IC Diamond on the Cpu and Gpu since Last thursday( 7 year outdated). At the time, it was the best on the market, so I couldn't tell you the difference between that versus a lesser brand. I think over the 7 year span, I reapplied maybe 3 or 4 times, only because of tubing upgrades and just regular maintenance/cleaning of the build. It never let me down. It was though, not dried up, but not fresh either. it was like a soft playdough, wet clay, etc. Easy to take off with alcohol like any other TIM, but never dried up. This go around, I bought some Gelid GC Extreme off of the EK website when I bought my blocks( cpu/gpu) along with a long awaited upgrade(6700/1070 SC/z170 ftw/16gb vengeance ram). My current temps, as I type this are 25 cpu and 26 gpu running default clocks. I have IC Diamond left over, but maybe only enough to do one chip and not both. So I couldn't give you a proper comparison between the two TIM's. But this GC Extreme seems to be pretty great stuff, non conductive, non-everything. Cpu i applied it with a blob in the center, and the Gpu i blobbed it, then spread it even with the little applicator they provide with the GC Extreme. That way, you know the whole thing is covered, and you don't have to worry about bad spread
sethleigh
2016/09/23 21:41:40
Yeah, I used Prolimatech PK3 with my 1080 SC, but ran out after that, and so for my i7 6900 I used the Ektotherm that came with my EK Supremacy EVO block. My temps are a little higher than yours, but I'm running the 6900 at 4.2ghz, and my room temperature is usually in the high 70s and sometimes 80s. The Ektotherm was much runnier than the Prolimatech. Not sure if that's good or bad, but I think it helps the TIM spread around evenly. Given the charts I've looked at, most of the top-tier TIMs come within 1-2 C of each other, and that's good enough for me.
