DIY Swiftech MCP355 / Laing DDC3.2 Pump Repair Guide - Walkthrough
[AK]Zip
2011/06/05 05:32:20 (permalink)
As many have seen in my previous video comparing the modded MCP355 (DDC2) to the MCP35X these next 4 videos involve pumps, but in this case it is a full walk-through from start to finish on how to repair your own failed pump. I know this will be useful to many since so many DDC based pumps have failed throughout the years.
The pump being used today is the Swiftech MCP355 based on the Laing DDC3.2 pump. These videos are educational videos providing my experience and step by step of how to repair your own failed up. This video is designed to be followed along or as a guide for your own repair.
A similar video will be made on how to repair the older Swiftech MCP350/355 based on the Laing DDC1/DDC2 pumps. The process is very similar, but so that there is no confusion those videos will follow one an additional repair PCB board is supplied to me.
I want to thank Elganja of AnandTech for supplying the failed pump at a low cost and DIYINHK for supplying the board. The PCB board can be purchased on eBay. http://myworld.ebay.com/diyinhk
My plan is to repair one of each DDC series (DDC1, DDC2, and DDC3) pump and do a full technical comparison of the modified pumps along with the different readily available pumps for water cooling your computer.
I will be testing for heat output, current draw, noise level, flow rate, and pressure on each pump configuration.
I already have many pumps, but will compile a full list of everything I would like to get into the review and hopefully either find sponsorship from the manufacture or some kind owners who would be willing to mail their personal pump(s) in for testing.
Any comments or suggestions are welcome. More information to come soon. Stay tuned.
Part 1:
Part 2:
Part 3:
Part 4:
  • Corsair 800D | Corsair HX850W | LG 20X DVD+/-RW | TRUE 120 | Intel I7 920 D0 @ 4.2GHz (200X21, 1.275v) | Intel X25-M G2 120GB | 2 - WD Green 2TB | 6GB OCZ Platinum PC3 12800 | EVGA X58 SLI | X-Fi Platinum | EVGA GTX 480 SLI (780/1970)
  • Dell U2311H 23in (IPS) | Saitek Eclipse II | Razer Boomslang 2007 CE | Razer Exactmat
    Heatware 115-0
  • #1
    1 Reply Related Threads
      [AK]Zip
      Re:DIY Swiftech MCP355 / Laing DDC3.2 Pump Repair Guide - Walkthrough 2011/07/16 13:59:42 (permalink)
      There is a new revision of the upgrade board. It is now white and has built in LED's.
      Looks pretty good with a clear top. I think this would look very nice with a clear res top so that the light has more area of diffusion.
      Lights on:
      Lights off:
      Heatware 115-0
    • #2
