Hot!DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan
mnpctech
Mnpctech Representative
  • Ribbons : 15
2015/11/25 07:30:09 (permalink)
The Nidec-Servo's Scythe Gentle Typhoon (Model# D122C). This fan has been regarded as the best static pressure optimized fan by DIY PC community since it's release in 2008. The original D122C is no longer made, but there is limited stock available at some online retailers. Last year the D122C Scythe GT fan was resurrected and manufactured as "Darkside Black Edition" by Dazmode. It's the same specs as the original, but now has Black fan blades. Many PC Modders including myself have painted these fans to fit the color schemes of our custom PC builds. I've been asked several times over the years how to remove the metal c-clip without losing or breaking it?*This is my DIY guide to removing and installing external retaining ring or c-clip. Like many others, I've also lost these tiny c-clips while learning the best technique for handling this task.
Nidec-Servo's Scythe Gentle Typhoon Factory Spec PDF link, http://www.nidec-servo.com/en/digital/pdf/D1225C.pdf*
Speed: *2150RPM
Air performance : 68.8CFM
Nose: 34db (25cm from the fan, free air)
Power: 12VDC, 0.123A (0.63A peak max)
Operational voltage range: 5-12V (~900rpm-2150rpm)
Bearing: Ball
Expected life: 100000h/35c or 55000h/60c
Appearance: Full black
Dimensions: *119 x 119 x 25 mm / 4.68 x 4.68 x 0.98 in
WARNING:
Perform this task with Safety Glasses, the tiny Black metal retaining ring (c-clip) can and likely will pop off, so perform this task in a clean workspace, so you can find it. I suggest doing the work on a large white bed sheet and holding a large magnet near the fan hub as you remove and re-install the c-clip, to increase you're chances of not losing the c-clip. I haven't found a source for ordering replacement c-clips yet, but I'm still searching.
Here is my suggested Tools & Supplies
Safety Glasses (not pictured)
Heat Gun for removing the fan label. Hair Dryer on HIGH setting will work as well.
10" Wire Cable Tie
Large magnet (not pictured)
External Fixed-Tip Retaining Ring Pliers, http://mnpctech.com/case-...-or-c-clip-pliers.html
Tweezers
Needle Nose Pliers
Super Glue (not pictured)
External Fixed-Tip Retaining Ring Pliers, http://www.saeproducts.com/retaining-ring-tool.html
The fan blade looks as if it would snap-on and off, but not the case.
We need to remove the back label to access the external metal c-clip on the fan shaft.
Swipe heat gun or hair dryer back and forth over the label.
Use the Tweezer to peel off the fan label.
Stick the fan label on a clean metal surface while you perform your work.
You will tie down the fan hub with this Twisty tie. The fan shaft has a retention spring inside. You need to compress this spring, so you can remove the metal c-clip. If you don't, it's almost a guarantee that the c-clip will fly off the shaft faster than a bullet.
Using Twisty tie to compress the fan hub spring, by tying down the hub to the fan frame.
Close ups of the Black metal c-clip inside the Scythe Gentle Typhoon.
post edited by mnpctech - 2015/11/28 04:26:37
Mnpctech PC Mod Store Discount for EVGA Forum Members
10 Replies Related Threads
    mnpctech
    • Ribbons : 15
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/25 07:31:18 (permalink)
    Insert the two prongs of the Retaining Ring Plier inside the jaw of the c-clip.
    If you have a large Magnet, Position it near the fan hub, just in case the c-clip pops off.
    Holding the black metal c-clip in the Retaining Ring Plier.
    You will widen the jaw of the c-clip and need to bend it back to it's original opening, so it maintains it's grip.
    Hold the c-clip in the Tweezer while using a Needle Nose Plier to compress jaw of the c-clip.
    Doing this will allow you to re-use the metal c-clip.
    Here is the Scythe Gentle Typhoon 120mm Cooling fan dismantled
    If you're wanting to paint your PC cooling fan. You can watch my DIY video guide to painting PC cooling fans
    https://www.youtube.com/watch?v=AqIURuIeqjU
    View of the spring inside the Gentle Typhoon PC Cooling fan, "Be careful, don't lose it!"
    To re-install the metal fan c-clip, grip the c-clip in reverse position on the plier.
    Reversing the c-clip on the plier will make it easier to re-install the metal cooling fan c-clip
    Before releasing the plier, make sure the c-clip is properly seated on the fan shaft, otherwise it will fly off!
    If the cooling fan label has very little adhesion left, I'll apply drops of Krazy or Super Glue to re-apply the label.
    The job is finished!
    Please post other PC cooling fan models you know of that use this same type of metal c-clip
    wmmills
    • Ribbons : 18
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/25 08:23:35 (permalink)
    A e-clip should work just as well: https://www.teamassociate..m/parts/hardware/clips/ Rc cars have the same size and type rod/bearing axles, suspensions etc.... As far as taking those little things off I used to use a clear garbage bag with my hands and the part in it.
    post edited by rjohnson11 - 2015/11/28 00:40:02
    MOBO: EVGA P67 FTW, CPU: I5 2500K, RAM: Gskill PI 1600 CAS 6, SSD: Samsung 830 128gb, HDD: WD Caviar Black 750gb, PSU: CoolerMaster V-1000, CPU HSF: EVGA ScC HSF~ P/P 88CFM Yate Loons, G-CARD:EVGA GTX780, CASE: LIAN-LI PC-V2010B, OS: Windows 7 Ultimate 64bit, MON: AOC i2367F, HdSet: steelseries Siberia
    NEVER CONFUSE EDUCATION WITH INTELLIGENCE!
    Nozler
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/25 12:16:04 (permalink)
    Dink as it hits the shop floor I've done that twice Lolz only found one, these eyes aren't what they used to be. Nice how to btw.
    heatware
    mnpctech
    • Ribbons : 15
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/25 16:03:21 (permalink)
    @wmmills, Awesome, Thank you!
    @Nozler, a dirty black shop floor is even worse, and Thank you for purchasing the overkill grill!
    for future purchases, I've posted Mnpctech Discount Voucher code for EVGA forum members here, http://forums.evga.com/VO...Supplies-m2409799.aspx
    wmmills
    • Ribbons : 18
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/26 07:48:44 (permalink)
    mnpctech
    NP brotha!!! Anything for the DIY community.  :)   I wish I could direct you to a exact replica of the clip that's on that fan but I haven't seen that type on anything before so im not sure where you'd find it, other than from Nidec themselves maybe..... if they are willing to part with them since im sure they send as many flying around their shops as the rest of us, lol. I took my Antec tri cools apart and painted them back in 2006, I think, when I painted my Antec 900, first edition, but I cant for the life of me remember how they were put together or id at least provide that info so you could either include them on the list or put them in the "no good" list. Ill update this post with any info i come across for ya though. \m/
    EDIT: Found a place that sells the exact clip you need, but you have to get a quote for a bulk purchase, which for you might not be a bad thing. I cant find any places that sell just a bag of them in general. http://datasheets.globalspec.com/ds/287/Daemar/38C16A13-9E85-4FAA-B943-B148562AF634
    post edited by wmmills - 2015/11/26 08:07:24
    mnpctech
    • Ribbons : 15
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/27 04:03:41 (permalink)
    Awesome! I will contact them, and look into stocking them for anyone who may lose theirs, Thank you!
    • Ribbons : 52
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/28 00:43:03 (permalink)
    An excellent tutorial. Thanks for sharing!
    mnpctech
    • Ribbons : 15
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/28 04:31:05 (permalink)
    Awesome, I have more DIY guides I'm working to share with EVGA forum members. Here is another fan I found in our workshop that utilizes the same Black metal e-clip / c-clip. It's a 120mm Delta WFB1212H
    notfordman
    • Ribbons : 14
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/28 11:53:36 (permalink)
    Great guide Bill, thanks for sharing it. Nice and detailed which I think is real helpful. I especially liked the tip of tying the hub down to relieve pressure on the clip.
    mnpctech
    • Ribbons : 15
    Re: DIY Guide: Taking Apart Gentle Typhoon Ball Bearing PC Cooling Fan 2015/11/29 07:49:33 (permalink)
    Glad you liked it! I'm working on another DIY guide to post later this week!
