DG-87 front panel causes fan to whine
mhill78
2016/10/14 17:03:39 (permalink)
If I place my front panel to snap in all the way, I've noticed one of my fans grinds up against the dust filter.  Anyone else had this issue?
3 Replies Related Threads
    EVGATech_MDecker
    EVGA Tech Support
    Re: DG-87 front panel causes fan to whine 2016/10/14 18:17:40 (permalink)
    Hello,
    I am sorry to hear that.
    Are you using the stock fans with the DG-8 or aftermarket? If you take out the dust filter is it bowed in or misshapen in any way?
    (つ◕౪◕)つ━☆゚.*・。゚X99Micro2 | 5960X | TitanX  。゚・*.☆゚
    Crimson AL
    Re: DG-87 front panel causes fan to whine 2016/10/14 18:32:04 (permalink)
    I've noticed the way the front panel is slanted it takes some airflow from the fans and makes a little more noise than what I've experienced from standard fronts.  I took the front air filter off.
    mhill78
    Re: DG-87 front panel causes fan to whine 2016/10/16 10:32:14 (permalink)
    EVGATech_MDecker
    Hello,
    Stock fans.
    and when I looked at the dust filter, it doesn't appear misshapen.
