Re: DG87 fan splitter to fan controller
2016/10/14 12:22:28
depends on if your radiator fans are PWM or not. if they are then you'll need a PWM splitter and connect it to the motherboard as the fan controller in the case is just a voltage regulated fan controller and not a PWM fan controller.
