ofycz5aflu
Any chance EVGA could provide a few custom BIOS's for the 1080 cards which have a slightly more aggressive fan curve to avoid throttling? And maybe a BIOS which disables the LED lights? And preferably a BIOS which does both? Reason I am asking is that I really don't like having to run software to adjust this stuff, and EVGA precision seems to be very buggy at the moment...
Tech_RayH
- Ribbons : 7
Re: Custom BIOS with a more agressive fan curve and LED disabled?
2016/07/29 13:34:42
If you are not overclocking the card, you can create a custom fan curve with PrecisionX instead of PrecisionX OC, and if you want to turn off the LED completely, then you can go to the Geforce Experience > LED Visualizer > and turn off the LEDS. There are no custom BIOS for the cards and there will likely not be for these particular features.
...an untrammeled flow of words in an open forum. - Adlai E. Stevenson
ofycz5aflu
2016/07/29 13:42:21
While I appreciate your proposed solutions, I would really prefer to resolve this without having to install any software... Though I get that it's most likely not going to happen, I still think it's worth a try to get EVGA's attention to something about it...
Heini2
2016/07/29 15:30:45
I too refuse to install bloatware to control hardware, so........ I just received a 1080 SC ACX3 and unplugged the lights and removed the back plate before installing. The fan curve I may have a problem with since I'm used to running reference cards with ACX coolers so the more aggressive fan curve of the reference boards do well with the ACX coolers. I've gamed a little with it but have not pushed it yet but so far the indicators are it will runner warmer than a Titan X with ACX2+ cooler, because of the bios's fan curve.
Z170 Sabertooth Mk1 / i7-6700K + NH-D15 / Trident Z (2x16GB)@3000 / 2080Ti XC Ultra / Essence STX II / 950 Pro 512GB / G3 1000W / MG279Q / HAF XB EVO / Win10 X64 Pro
lordaeron1
2016/07/29 15:34:52
ofycz5aflu While I appreciate your proposed solutions, I would really prefer to resolve this without having to install any software... Though I get that it's most likely not going to happen, I still think it's worth a try to get EVGA's attention to something about it...
+1 for the RGB permanent shutdown. didn't buy the card for the RGB lights and the light is wasting energy for nothing (as i don't see it). would be nice to be able to shut the Led's via hardware. another option that i think possible with a bit of engineering\programming :EVGA precision have access to write to bios,in other words... the options you picked saved permanently inside the card itself.
I7-6700k (stock) | Msi M7 gaming | Kingston hyperx savage16Gb DDR4@ 2800Mhz | Evga Gtx 1080 FTW | Corsair H110i | Samsung 840 EVO 120GB SSD + Crucial Mx 200 250GB | Seasonic X-750w Gold | Cooler Master Haf X (Aka 932) | DELL U2713h | Xonar D1.
- Ribbons : 282
2016/07/29 15:41:22
Heini2 I too refuse to install bloatware to control hardware, so........ I just received a 1080 SC ACX3 and unplugged the lights and removed the back plate before installing. The fan curve I may have a problem with since I'm used to running reference cards with ACX coolers so the more aggressive fan curve of the reference boards do well with the ACX coolers. I've gamed a little with it but have not pushed it yet but so far the indicators are it will runner warmer than a Titan X with ACX2+ cooler, because of the bios's fan curve.
No different then installing the Graphic Driver, I would not call it bloat ware if you need the tool to complete your job or needs. ofycz5aflu While I appreciate your proposed solutions, I would really prefer to resolve this without having to install any software... Though I get that it's most likely not going to happen, I still think it's worth a try to get EVGA's attention to something about it...
Unplug the LED on the Card if you do not want to see it. You can use NVIDIA Inspector 1.9.7.6 http://www.majorgeeks.com/files/details/nvidia_inspector.html to set the fan.
darkkterror
2016/07/29 16:29:20
I don't think that word means what you think it means. Also, it is literally the job of software to control hardware. Without software your hardware would be useless to you. Aside from something like a physical hardware switch, everything you do to control the hardware is through software.
- Ribbons : 135
2016/07/29 16:37:09
Back in the day, EVGA used to do some custom BIOS for their cards. The problem was too many people bricking their cards through improper flashing or using the wrong BIOS. So, they stopped doing it. For the LED, you can use the led visualizer app that is in every driver install to turn it off. Its located in...C:\NVIDIA\DisplayDriver\368.95\Win10_64\International\LEDVisualizer. The path will differ slightly depending upon your driver version and OS. It will stay until you do a clean install of the driver. For the fan profile, you either need use an app, or live with it as as.
- Ribbons : 135
2016/07/29 16:37:15
Heini2
2016/07/29 16:38:49
darkkterror
I live in a very literal world. If software uses disk space, memory and/or cpu to run it is BLOATWARE.
darkkterror
2016/07/29 16:41:04
Heini2
darkkterror
You realize that literally every piece of software fits that description, right?
- Ribbons : 135
2016/07/29 16:47:32
Heini2
darkkterror
Then the software you are using to post here, meets your definition of bloatware. You're being silly. I get what you're saying, as I prefer as little extra software and services running as possible.
Lobehold
2016/07/29 19:26:28
I too, am VERY interested in a custom bios with lights off and fan turned up a bit higher. Ideally the card should stay below 70c under all circumstances.
