Correct power cable?
fmalone
2015/10/09 08:01:33 (permalink)
I need to replace the power cable that came with my EVGA 220-G2-0850-XR. Is there anything special I need to know or can I just pick up something like this: http://tinyurl.com/pvojsnj ?
4 Replies Related Threads
    Zuhl3156
    • Ribbons : 34
    Re: Correct power cable? 2015/10/09 08:57:53 (permalink)
    Yes, that will work.
    • Ribbons : 115
    Re: Correct power cable? 2015/10/09 19:37:47 (permalink)
    Yep, that's fine. It's the other cables on the PSU that should come from Evga.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    haghighihk
    Re: Correct power cable? 2015/10/09 23:48:54 (permalink)
    C13 couplers are all the same.
    Modular power supply connectors on the other hand are model specific.
    Yet Another Hadron Air Build
    Asus Z97i Plus
    EVGA Hadron Air
    Intel i5 4670k
    EVGA Geforce GTX 960 SSC
    8GB EVGA Superclock DDR3-2400 RAM
    Samsung 850 M.2 SSD 240GB
    • Ribbons : 115
    Re: Correct power cable? 2015/10/10 03:15:32 (permalink)
    haghighihk
    Yes. That's what I meant to say.         =)
     &nbsp
