Hot!Cooling fan and heat sink combination for Z170 FTW mobo??
VCraig
2016/02/15 10:17:51 (permalink)
For my purposes (not a oc'ing every thing enthusiast) the Z170 FTW mobo is a good fit for me. As such, if anyone here is running a I7-6700 on air with this mobo what was you choice of a fan and heat sink combination CPU cooler?
CM Cosmos S case, Evga E758 A1 SLI
EVGA 860W PS
I7-930 OC.d @ 3.6 GHz
Samsung 512 GB SSD
12 GB G-Skill DDR3 @ 1600
GTX 980 SC
1920x1200 Dell U2410 IPS Monitor
W7 x64
33 Replies Related Threads
    VCraig
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/15 13:14:36 (permalink)
    (This is for snapbeaver... I tried to reply to your post but wouldn't post. So will try here with the following):
    Thanks taking time to reply!
    So, just to confirm - you ARE using the Noctua-u-12 with your Z170 FTW board? I'm just looking (and thus my post) for a compatible single or dbl. push/pull fan and heat sink combo that can mate with a I7-6700 w/o having to contend with fan speed control - i.e., just plug and play and be done with it.
    EVGA 860W PS
    Samsung 512 GB SSD
    GTX 980 SC
    W7 x64
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 03:22:19 (permalink)
    pics
    noctua u12s
    this cooler is good for 4500mhz  24/7 with a good margin, and no mating  DIMM (1mm free space) or heatsink, top pci-e slot
    hope these pics can be of any help to someone
    note> different brands of fans can be thicker than others, despite the fact they are labeled 25mm
    over and out
    post edited by snapbeaver - 2016/03/13 15:28:08
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 06:25:57 (permalink)
    snapbeaver
    pics
    noctua u12s
    predator heatspreaders are thick as hell
    sorry for the mess  (temporary setup, awaiting case delivery)
    but i use my "pwm mod" to lover the voltage to these fans..
    they are dead silent now, and still running in smart mode
    over and out
    My $30 cooler master Evo 212 is exactly like that I got the 1 fan you can buy the 2nd smoke grey for like $7 or add your on 120mm and save $40 bucks from buying the 212 dual fan cooler itself
    mines good on air at 4.6 + .25mv offset in prime95 stable
    Just posted this in OC forum but about cooler
    Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    I plan to move up to evga cooler soon done spent enough lol
    MB temps were reading constant 48-49C on the board
    As you can see here I reversed the fan to backside to pull memory heat through to they are both tight coolers but work fine the coolermaster you can actually slide the fan up as needed away from memory I have 2 now
    post edited by pittbull - 2016/02/16 06:34:24
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 06:41:22 (permalink)
    whats your maxxed out vcore voltage @ 4500mhz? in eleet
    i cant submit replies, so i post my reply here instead
    ok, i have only set the vcore offset, not the adaptive vcore setting its left at default auto
    i see not reason why i should use a vcore target voltage in offset mode, i am old school i guess
    Just dial in the vcore with the offset, takes max 5 min stable and done.. lets game
    the offset setting is adapting the vcore just fine along the power states, you only set the max vcore roof (more chefs = bad soup?)
    i never read any OC guides, so maybe i am missing something here, or gaining,  i dunno
    my chip wants 1,325v as max vcore to be fully system stable at 4500mhz, if now the Eleet reading is trustworthy
    post edited by snapbeaver - 2016/02/20 20:23:30
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 06:47:21 (permalink)
    snapbeaver
    eleet is not installed on my system yet
    I was at 4.6 OC
    The Skylakes you use adaptive voltage for best performance on these boards (Z170's)
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 07:25:14 (permalink)
    Hmm prime stable?
    Prime95 is not good for ensuring / testing system stability, the only thing it will do for you, is to let you know if you passed the software that day, and if your cooling is enough, nothing else i am afraid
    its more like a never ending hamster-wheel, your system can still fail the following day even if you passed the day before..
    To force series of monotonous calculations over and over again to reach solid stability?, Today's systems is far more more complex than so
    use it for stress testing instead, not stability testing / ensuring
    it was first released 20 years ago
    / Just some thoughts out loud
    post edited by snapbeaver - 2016/02/16 14:22:33
    VCraig
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 13:56:40 (permalink)
    Many thanks, guys for the cooling fan/heat sink combo suggestions and info.
    I had looked at the CM 212 EVO before posting but wanted to see what forum users were using with their Z170 FTW board. Now I'm torn between the Noctua and CM coolers knowing both are compatible with the FTW board.  But since a 2nd fan can be added later if wanted, I'm leaning toward the CM 212 EVO which is the cheaper option at $30 (and only ~$7 or $8 for a second fan if needed).
    EVGA 860W PS
    Samsung 512 GB SSD
    GTX 980 SC
    W7 x64
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/16 14:15:23 (permalink)
    your welcome..
    good luck with the setup
    enzoetdino
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/17 00:28:41 (permalink)
    VCraig
    Hi I have just bought the Noctua NH-C14S and installed it on my EVGA z170 FTW yesterday evening. Without overclocking, the maximum temp reach by the CPU are around 48 C (room at 20C). When overclocked at 4.4, the CPU temp reached 62 C.
    It is very silent even mounted with the 2 fans at 1200 rpm. The only thing, it is very close to my GTX 960 but this not an issue, I have not spotted anything wrong with the CPU temp.
    My case is a bit tight for this equipment, I am sure you can reach better temp with a better case than mine. I will try to upload some pics.
    Hope it helps.
    CPU Intel I7-6700K OC (4.6GHz)
    Cooler Noctua NH-C14 modified (2x140mm PWM fans)
    Motherboard EVGA Z170 FTW
    Corsair Vengeance 4X4GB DDR4 3200MHz
    1 x EVGA GeForce GTX 960 SSC GAMING ACX 2.0+
    1 x Gigabyte GeForce GTX 550 Ti
    2 x Samsung SAM 850 Pro 128GB SSD (raid 1 for OS and software)
    1 x LG 14x Blu-ray DVDRW
    2 x WD Hard Drives (2TB for games/archives/BOINC)
    Case Nanoxia Deep Silence 5 Rev. 5
    2 X 22" Monitors (LG and Asus)
    enzoetdino
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/17 00:38:22 (permalink)
    Here is the result. The case is an Antec sonata IV recycled and modified a bit to improve airflow.
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/17 19:03:45 (permalink)
    VCraig
    I'm using the $30.00 Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
    Didn't expect it to be so cool maybe my case though 55C max in BF4 @ 4.6ghz
    Need to move the fans up a little but it is big seems like all the skylake 1151 coolers are pretty massive and come close to memory and chipset sinks. I have dual 120mm fans as offered with the 212X dual fan but saved money and got the Evo the fan can be bought separate cheaper lol
    post edited by pittbull - 2016/02/24 06:30:41
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/19 08:10:53 (permalink)
    I hit 61C in 3dmark 11 yesterday to bad vantage killed the free edition it's there but install and will ask you key/registration since new update
    Put me in the 1K evga bucks this 960 2gb is holding me back big time
    Score P11039
    http://www.3dmark.com/3dm11/10953124
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/19 09:15:47 (permalink)
    your physics score was better than mine at 4600mhz, damn
    but i whopped your butt in the graphics.. ^^
    hmm the score dont match the diagram, which one is accurate?
    http://www.3dmark.com/3dm11/10956502
    comparison
     http://www.3dmark.com/com...956502/3dm11/10953124#
    post edited by snapbeaver - 2016/02/19 09:40:34
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/19 09:51:12 (permalink)
    snapbeaver
    comparison
    Told you this cards killing my system from hitting full potential 2gb card 960 vs a 980 TI not to compare too lol
    I['ve notice the card is somewhat bottle necking CPU too. Well it works for me now business season is here for next 8mths lol so not much gaming to do. Maybe have upgrade on card later on 2 970s in SLI is cheaper and will destroy a 980TI though from results I have seen.
    post edited by pittbull - 2016/02/19 09:58:33
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/19 16:38:31 (permalink)
    For gaming this is a great card..
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 03:34:48 (permalink)
    snapbeaver
    Hmm prime stable?
    Primes good still burn that CPU in with it if it makes it through prime you got a keeper lol. I think I was hitting 92C in prime I ran it for a good while passed everything. So I know I got good CPU I always prime my CPU's in the first 30 days of purchase never know if you got a half DOA just ticking in the socket. Sure didn't want to find out after 30 days chunking the $$$ out on this 6700 skylake unlocked ;p
    snapbeaver
    I can imagine lol, So Kingpin hit 44,000 on quad 980 TI kingpin cards. This shows about the only thing good in the 960 ftw 2gb which was a RMA with backplate and all beautiful card love the backplate's. I get a constant 200fps in BF4 on 1080p hdmi, down side is my 660 SC 4gb destroys everything else about this card 960 will only run auto medium in game the 2GBs makes it run hotter even with ACX on medium nearing mid 70s in temps ughhh.
    That score qualified me for 1k evga bucks who knows maybe for the first time in my life I might actually win something lol besides free lottery tickets haha
    660 could run high easily, I thought the 660 was dead ended up being PCIe slot 1 on my 780i FTW which carried me a decade I had 680i in there before the 780i FTW.
    Now I'm trying to sell 8gb of brand new GSkill ddr2 I paid over $210+ for brand new still is brand new lol
    4gb of ocz reaper htc
    2 to 3 cpus 2 duals and one beasty EO step Q9550 that CPU is amazing the EO step good lord.
    I got z17 bios chip for 780i FTW or whole board the pcie slot actually works with self power older pci cards any card with a 6-8 pin power source will not boot it.
    Put em on EBay yesterday first time trying to sell lol such a noob selling I put up buy it now and best offers on them hopefully they sell. That 8gb kit I just had bought was great ddr2
    Also on CPU-Z it displays some right info and some way off, I use HWiNFO things dead on and tells you everything pretty much AIDA64 does but for free.
    post edited by pittbull - 2016/02/20 03:51:29
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 05:19:40 (permalink)
    quote>
    >> this is the reason why i never buy sought after second hand hardware °)
    post edited by snapbeaver - 2016/02/20 07:15:36
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 05:23:05 (permalink)
    buy what? also what s second hand sought after hardware you're referring too?
    YT link only goes to YT main page?
    Not sure where you're coming from when you get a new CPU you want to burn it in make sure it holds up if doesn't you got 30days to replace why would you not make sure you have a CPU that can make through the stress?
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 05:27:03 (permalink)
    enzoetdino
    VCraig
    Hope it helps.
    That is hot I idle at 26 to 28C on 4.4 Low 50's in Battlefield 4 maybe there's more talk to these than performance I'm using a $30.00 cooler master evo 212 and it perform superior in cooling but I got the THOR V2 case and it is the coolest running air case I have ever came across. I just my 2nd fan instead of buying the 212 dual fan evo when you can buy the same fan and save $20+ bucks.
    I have seen it dip since installing to 24C
    Looking at the mount your blowing air straight into the cpu onto the board and that is going to increase heat anywhere. You want the CPU cooler blowing to the rear exhaust at least to disperse heat properly.
    Now this is mass cooling airflow
    post edited by pittbull - 2016/02/20 05:36:34
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 06:19:31 (permalink)
    had to test again, it was fun..
    added 100mhz on the cpu = 4700mhz
    But i think the numbers turned out low.. 19672
    But good gaming performance regardless. the vsync rarely drop more than 10 FPS under a game  (close combat FPS drain).....
    http://www.3dmark.com/3dm11/10960415
    post edited by snapbeaver - 2016/02/20 07:12:28
    snapbeaver
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/20 07:16:39 (permalink)
    pittbull
    ok, i have never heard about someone doing that.. degrading the cpu before deciding to keep it..
    dont they hold up out of the box brand new? i am pretty sure all the brand new intel cpus can handle the stress from a system, my cpu is reaching 50c-55c while gaming, and i have not yet seen the cpu gone past 60c in everyday use,.. are you saying it can drop dead all of a sudden?
    the link showed a 426BB that exploded in the dyno
    post edited by snapbeaver - 2016/02/20 07:48:17
    Arne Saknussemm
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/21 13:46:49 (permalink)
    I think it only makes sense...after all when I buy a new car I rev the engine as hard as possible continually for 24 hours...just to be sure....
    post edited by Arne Saknussemm - 2016/02/22 05:59:34
    #23
    NickRutter
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/22 05:48:10 (permalink)
    Hi!
    New to the forum and the EVGA family.
    Due to the lack of USB headers on the FTW mobo I had to opt for an air cooled solution rather than a AIO radiator solution, and thereby ended up going with a Be-Quiet Dark Rock 3 in Pull config (due to clearance issues from the RAM heat spreaders). I also added a couple of 140mm PWM case fans that each blow directly across RAM & CPU and the GPU. My overclock is a modest 4.4GHz but then again I am going for stability and not "insanity". The CPU idles at about 26-29C but I haven't pushed it far as I just built the system.
    Fractal Design Nano S w/ Window
    EVGA Z170 Stinger|EVGA GTX 980 Ti Hydro Copper|EVGA Supernova GS 650
    i7-6700K|16GB Corsair Vengeance LPX 2400 MHz|Samsung 850 EVO 2x 250GB (RAID 0) + Samsung 850 EVO 1TB|Custom Waterloop: EK-XTOP SPC-60 PWM + EK-RES X3 110 Lite + Alphacool 280mm Slim Radiator + 2x Fractal Design HP-14 PWM Fans
    Current WiP: Fractal Design Define S | EVGA Z170 FTW | EVGA GTX 1080 FTW | EVGA Supernova G2 850W| i7-6700K | 32 GB Corsair Dominator Platinum | Custom Waterloop
    #24
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/02/24 06:54:56 (permalink)
    NickRutter
    Hi!
    4.6 is the sweet spot .25mv offset (adaptive voltage)and on air I'm at 26-29
    BF4 load never passes 57C max
    Intel Xtreme I hit 73C but my case has a lot to do with it it's air cooling monster, I didn't even max my fans out.
    #25
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/03/05 07:59:09 (permalink)
    snapbeaver
    pittbull
    Yo have 30days on CPU return first thing I do is burn in then stress it good if it passes all the stressing it's a keeper why would you not want to know if you have a partially DOA CPU or one that will be a DOA after running it for a bit out of the box then those 30 days pass your going to be dishing out for a brand new CPU????? Does that make any sense? Pretty clear..... :)
    Here are my stock air cooling temps Idle vs Load
    Load
    enzoetdino
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/03/07 00:48:07 (permalink)
    Hi
    I have made a new modification on my case yesterday evening. I had two low noise spare 120mm fans so I have fitted them to extract the hot air build-up in the top of my tower (previously, it was a hole with an air filter). I have gained 7-8 C on my CPU temperature full loaded! So at 4GHz. Room at 22 C, my CPU temp is 49-50 C. This morning at 19 C, my CPU temp was 47 C (so it is coherent). With my previous case configuration, when the room was at 19 C, My temp was 54-55 C.
    That modification allows me to stay below 62 C at 4.6GHz full loaded (without noise and a room at 22C). I can be below 60 full loaded but that increase significantly the noise.
    I have order grills to avoid my daughter putting her little fingers on the fans. I will take picture of every once well fitted :-) So, it is possible to convert an old case into something efficient and saving money at the same time :-)
    #27
    pittbull
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/03/07 04:46:19 (permalink)
    enzoetdino
    Hi
    The right case can make a lot of difference trust me this THOR V2 on stock air never seen anything like it, I had a thermaltake full tower on my last rig 780i FTW the pcie slot 1 went out on but the thing absolutely was horrible, no kidding to keep my memory and card temps cool I had 15 fans in it no lie.
    My cpu temps were no issue I was still running DDR2 just a month ago on it was maxed, I will never invest in thermaltake case again ever. I did drop a E0 stepped Q9550 quad in it for the remaining year it ran never seen a cpu stay so cold the E1 step were horrible cpu's. But I got 3 1st gen intels about to put on ebay now done sold off my 3 packs of ddr2 I had done upgrades on.
    I thought about waterblocking my cpu due to our hot upcoming summers usually past 100+F with always bad humidity where I live but I getting better temps on air than I have seen on newegg reviews and corsair site itself they couldn't even OC a skylake stable to 4.5 but they were doing it all wrong to begin with. Was looking at the 140 exhaust mounts RAD's but even the big blocks 240s temps were over my minimum / max load temps on air plus all the blocks had quiet a few reviews of pump failures destroying peoples whole systems, even newegg expert reviews.
    I never have watercooled I will be looking into some other companies smaller blocks, this case will take a 240 RAD on top but tight bc the MB mounts so high and I also use the 8Phase power at very top of the FTW board. Really thinking about stepping up to the classified see what it is like never ran past FTW boards but they have never let me down last system went a decade had a 680i in it for the first part then swapped to 780iFTW.
    The pics above are legit idle / max loads I will hit 61C in 3dmark maybe but no issue. After burn in and stressing this cpu has been excellent at everything I prefer to do that and stress a new cpu within first days of purchase as mentioned above to make sure it is not gonna have a error or failure within first 30days and everyone seems to think it is dumb but has never failed a processor ever like I said I still got 3 1st gens run like new even used for years. E7300, 8400, and that Q9550 did the same with them all.
    post edited by pittbull - 2016/03/07 04:53:50
    #28
    enzoetdino
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/03/07 05:09:08 (permalink)
    pittbull
    The pics above are legit idle / max loads I will hit 61C in 3dmark maybe but no issue. After burn in and stressing this cpu has been excellent at everything I prefer to do that and stress a new cpu withing first days of purchase as mentioned above to make sure it is not gonna have a error or failure within first 30days and everyone seems to think it is dumb but has never failed a processor ever like I said I still got 3 1st gens run like new even used for years. E7300, 8400, and that Q9550 did the same with them all.
    I had (and still have) watercooling on my Pentium IV 3.8 GHz lol. I was living the South-East of France at this time and in the summer with ambient temperature around 37C (95F), watercooling was the best choice for the noise and the temperature. Now in the UK with a very hot summer at 25C (77F) . I do not thing watercooling is appropriate for my use.
    It is clear that the case is important, but I had to make chice at home as we had a very bad start in 2016 and have to change a lots of stuff in a couple of weeks, our washing-machine failed, steering of my wife's car could not work properly (we changed the car lol), my daughter broke the TV while playing with the cats when I was about to clik on "check out" ordering my new motherboard and processor as my previous computer could not start anymore (dead motherboard)... and I pass you the leaks in the Kitchen and bathroom and other stuff lol. Anyway everybody is alive  but no more savings LOL.
    So instead of buying a expensive case, I used the jigsaw and buy two filters.
    I will post my temp and some pictures of my mod when everything will be fitted (the two new fans are just locked on the hole at the moment).
    post edited by enzoetdino - 2016/03/10 01:52:04
    #29
    conrad.c
    Re: Cooling fan and heat sink combination for Z170 FTW mobo?? 2016/03/09 17:52:38 (permalink)
    @snapbeaver
    if you have a lot of space between the cooling and the first slot pci-e? I wonder if we can put Noctua NH-u14s is 2.5 cm wider and whether it will cover the first slot pci-e
    #30
