Hot!Cooler Master Mastercase 5 / Pro Custom PC build
mnpctech
Mnpctech Representative
  • Ribbons : 15
2016/03/09 11:33:43 (permalink)
Finally, I get to build something for myself :D The opportunity presented itself after Cooler Master sent me their new Mastercase 5 ($109.99) to evaluate and brainstorm retail accessories / bolt-on custom parts as part of their "Make it Yours" campaign. The Mastercase Pro is the same chassis as mastercase 5, but includes window panel and top cover for $139.99. If I kept waiting for personal time to build a PC for myself, it would have never happened due to lack of free time. I have to admit, I didn't like the Mastercase at first. I captured my mod zoo staff/friends unbox Mastercase 5 / Pro in my VLOG. I feel Cooler Master missed a lot of details that could have made the case even better. Especially since CM marketed it as "modular" and designed for DIY liquid cooling. It falls 40% from it's marketing pitch, but the overall build quality and finish is outstanding and eventually won me over after dismantling and re-assembling the case. Here is my final thoughts about the Mastercase, keeping in mind that I look at cases from perspective as PC Customizer and Case Modder.
RAVES:
*Overall Build Quality, Fit & finish.
*Top panel / cover design options are nice.
*Modular HD/SSD tray design and mounting options are best to date.
*240/360/280 radiator option for front is nice.
My suggestions REVISIONS:
*Top radiator mounting location should be offset, to clear DDR slots on some motherboards
*100% Riveted chassis?! I understand using rivets over screws to save time in manufacturing, but at minimum, the mid section floor should be removable for better access.
*Lack of Water pump and reservoir mounting. CM's competitors started embracing DIY cooling market over year ago, by including mounting options for reservoirs and water pumps.
*Mastercase 5/ Pro window panel is very flimsy. The "smoked" poly window is bluish/purple and has very poor clarity for viewing inside the case.
Inspiration for the custom painted exterior will be the 1970 Porsche 917 from Steve McQueen's "Le Mans" movie. His 917 from the movie was chassis #022 and purchased in 1970 from Porsche by Steve McQueen's movie production company, Solar Productions. It was also the company that would bring the movie "Le Mans" to the big screen. This is the car that McQueen's character, Michael Delaney, starts the race in, and "crashes" late in the race, "writing the car off." The car that was crashed was really a Lola T-70, painted and rebodied, to look like a 917. Many innovations in cinematography, were first tried in this movie. They even went so far, as to weld brackets to the front frame work of the 917, so they could mount a camera to shoot Steve, and the other drivers, in the cockpit.
I'll replacing the #20 with #5 to represent the Mastercase 5 and using this clear side panel.
Cooler Master Mastercase 5 Chassis assembled with final coat of Gulf Racing Blue paint from 1970 Porsche 917 race car
Porsche 917 inspired graphics are finished on the Cooler Master Mastercase 5 / Pro. Next stage is clearcoating everything.
Mnpctech PC Mod Store Discount for EVGA Forum Members
84 Replies Related Threads
    Sleinous
    • Ribbons : 31
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/09 11:52:04 (permalink)
    Great project! Love Le Mans ! :-)
    My Affiliate Code: GL1IAAFWJF
    • Ribbons : 52
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/10 06:13:47 (permalink)
    Another great looking project
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/10 07:04:53 (permalink)
    Hows that 980 video card treating you? Thank you for watching and commenting!
    The front I/O panel on the Cooler Master Mastercase 5 / Pro is a bit bland for this theme. I decided to modify it with something that looks more race car appropriate. l'll start with steel face plate and chose some switches and controls from Mnpctech that include a red Fighter Pilot with momentary toggle for Main Power. The reset will be blue anodized vandal resistant push. I also found a VDO brand 12 volt gauge from the center console of a Volkswagen Rabbit GTI. I'd love to find some mounting bezels for 5mm LEDs for Power & HD activity.
    The switches will be mounted with Mnpctech's billet vandal switch mounting plate. Here is all of the custom switch and toggle parts with links to their product pages. Mnpctech is the only source for "Military Pilot" Toggle switches modified for use with your custom PC. Fighter Pilot / Race Car Ignition Toggle Start with red cover,*PC Switch Plates
    Order blue vandal switch for your PC power or reset, PC Switch Plates
    SPST (Push for Momentary, IP-67 rated, CMP #MP19S-F10, Flush Flat Button, Metal Body, SPST-NO, Push button switch. Mounts in a 3/4" hole. Contacts Rated 5A @ 110VAC, 5A @ 220VAC. Compression screw Terminals. VDE/CE listed, RoHS Compliant.<br>
    Order Mnpctech Pro-Line Two switch mounting plate, PC Switch Plates
    Mounting plate has 22mm hole and 16mm hole. It fits Bulgin, Delrin, Lamptron, and ModMyToy Vandal Resistant Switches. Machined by Mnpctech in 6061 billet aluminum. Length = 3.5" x Width = 1.5" x Thickness = 3/16" Bulgin Mounting Plate Includes: 4, 6/32 x 3/4"screws and nuts.
    Replace your PC Power or PC Reset button with this Blue Anodized Vandal Resistant Switch. Made of Nickel Plated Brass.
    Darkside 5mm pre-sleeved custom PC LEDS, Darkside Dazmode UV White Red Blue Green Orange PC LED LIGHTS
    The upper portion of the black base for the RED Toggle Switch will be shortened later.
    EVGATech_AndrewA
    EVGA Tech Support
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/10 08:01:38 (permalink)
    Looks great! Can't wait to see the finished product
    • Ribbons : 52
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/10 22:17:21 (permalink)
    This is so awesome! If I had the cash I'd have him build a mod for me.
    Vlada011
    • Ribbons : 7
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/11 03:33:12 (permalink)
    For me this is nicest case from CM.
    Better even than Cosmos series.
    I'm glad they build much nicer case than Stryker and Trooper.
    But I think now is time to CM evolve on aluminum and join to Lian-Li class.
    Because Lian-Li is for older serious public, older enthusiasts.
    Nothing without sound of aluminum can.
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/11 11:41:57 (permalink)
    Thanks for watching guys! CM used to make aluminum cases. Lian Li has created a nice niche market for themselves.
    Parts laid out with final clear coat. Time to pop rivet!
    Black Powdercoated 1/8" Pop Rivets, http://mnpctech.com/pc-mod-tools/pc-pop-rivets/
    post edited by mnpctech - 2016/03/11 11:48:27
    VVhiplash
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/11 13:53:20 (permalink)
    At first I was like oh neat.. the cooler master blah blah..  *scroll, scroll, notices SICK paint job* WOAH!!!
    H-YEAH man, now THIS is a sick custom rig! I can't WAIT to see this all wrapped up. My brother is a huuuuuge racing fan and he's going to love looking at this one. Its going all OVER facebook! Excellent work!
    ll Steiger-Dynamics Maven ll Intel i7-5930k 4.2Ghz ll ASRock X99 Extreme6/AC ll Liqmax II 240 ll GeiL Super-Luce 32gb 2666mhz ll (x2)EVGA GTX 980 SC ll Samsung XP941 500gb and 850 Pro 1TB ll EVGA PS 1000W Platinum ll
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/12 08:02:06 (permalink)
    Great to hear, and I like your avatar! GULF RACING theme Cooler Mastercase 6 / Pro Chassis assembled and ready for mounting EK XTX 360 radiator next.
    • Ribbons : 92
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/13 03:38:14 (permalink)
    Looks great. Good job.
    My Affiliate Code: 8WEQVXMCJL
    zophar
    • Ribbons : 23
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/13 08:18:47 (permalink)
    Coming along very nicely Bill. Loving the colors, and the front panel looks killer with the switches and the volt gauge. Keep up the great work, and I can't wait to see your progress.
    • Ribbons : 52
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/13 08:35:13 (permalink)
    Becoming more and more interesting
    VVhiplash
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/13 22:41:40 (permalink)
    mnpctech
    Haha thanks, its my latest and greatest PC :) Its actually an HTPC. I'll but doing a EVGA MODS-Rigs post for it soon.
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/14 07:53:15 (permalink)
    Thank you for your replies and comments, I'm enjoying this project too! I feel like I lost time to work on it yesterday, Can we please end day light savings?!
    The fans I'm using in this Cooler Master Mastercase 5 / Pro case mod are 120mm PROLIMATECH Ultra Sleek Vortex. Here is their product page, http://www.prolimatech.com/en/products/detail.asp?id=2722
    This is 2nd time I've used these fans in custom build and love them. They're 15mm thick, so they can help you save space. Especially when mounting a radiator in the top panel which can block space to accessing DDR slots. I've painted the fan blades on these fans "GULF orange" to match our color theme.
    By request last year I created this DIY video guide to painting PC cooling fans, https://www.youtube.com/watch?v=AqIURuIeqjU and understand the thought of painting the blades on PC fans will raise concern with some people. I've done it on misc commissioned and personal builds for over decade and have yet to see any of those painted fans fail. I refrain from applying heavy coats which could throw off the balance of the blades, causing the fan bearings prematurely.
    You can remove the fan blade hub by using a flat head screw driver to pop off the white retaining ring.
    Next step is prepping the surface of the blades for primer base coat before we can apply the color coat.
    The blades were topped off with gloss enamel clear coat.
    post edited by mnpctech - 2016/03/14 07:55:37
    Vlada011
    • Ribbons : 7
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/14 08:39:49 (permalink)
    Great hand work.
    You really have skill for these things and idea is great.
    rebel2302
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/14 14:54:42 (permalink)
    Really nice paint job on the case!
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/15 05:52:46 (permalink)
    Thank you for watching and commenting guys!
    For anyone who either already owns or considering buying the Cooler Master Mastercase 5 / Pro, and also DIY liquid cools, you may have pondered about the maximum radiator thickness allowed? Mounting a radiator inside the chassis you're only limited by how much you're willing to enlarge the factory radiator cut-out. I prefer to buy more internal space and mount my radiator between the chassis and the front bezel, I've outfitted mine with EK's XTX 360 that measures 64mm thick, but not without two compromises. You'll need to create a custom front grill for the bezel, as factory one will no longer fit. You also need trim the backside of the upper horizontal brace under the 5.25 bay location.
    Dimensions (LxWxH): 400x130x64mm
    Weight: Approx. 1496g
    Liquid Capacity: Approx. 510 ml (17,25 fl oz)
    FPI: 11
    Fan installation: 12 x M3 threads on both sides each (for 3x120mm fan each)
    Pressure tested: 1bar
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/17 10:23:07 (permalink)
    For the EK 360 XTX Radiator I'll be using Nidec-Servo's Scythe Gentle Typhoon (Model# D122C). This fan has been regarded as the best static pressure optimized fan by DIY PC community since it's release in 2008. The original D122C is no longer made, but there is limited stock available at some online retailers. Last year the D122C Scythe GT fan was resurrected and manufactured as "Darkside Black Edition" by Dazmode. It's the same specs as the original, but now has Black fan blades. Many PC Modders including myself have painted these fans to fit the color schemes of our custom PC builds. I've been asked several times over the years how to remove the metal c-clip without losing or breaking it?*This is my DIY guide to removing and installing external retaining ring or c-clip. Like many others, I've also lost these tiny c-clips while learning the best technique for handling this task.
    Nidec-Servo's Scythe Gentle Typhoon Factory Spec PDF link, http://www.nidec-servo.com/en/digital/pdf/D1225C.pdf*
    Speed: *2150RPM
    Air performance : 68.8CFM
    Nose: 34db (25cm from the fan, free air)
    Power: 12VDC, 0.123A (0.63A peak max)
    Operational voltage range: 5-12V (~900rpm-2150rpm)
    Bearing: Ball
    Expected life: 100000h/35c or 55000h/60c
    Appearance: Full black
    Dimensions: *119 x 119 x 25 mm / 4.68 x 4.68 x 0.98 in
    WARNING:
    Perform this task with Safety Glasses, the tiny Black metal retaining ring (c-clip) can and likely will pop off, so perform this task in a clean workspace, so you can find it. I suggest doing the work on a large white bed sheet and holding a large magnet near the fan hub as you remove and re-install the c-clip, to increase you're chances of not losing the c-clip. I haven't found a source for ordering replacement c-clips yet, but I'm still searching.
    Here is my suggested Tools & Supplies
    Safety Glasses (not pictured)
    Heat Gun for removing the fan label. Hair Dryer on HIGH setting will work as well.
    10" Wire Cable Tie
    Large magnet (not pictured)
    External Fixed-Tip Retaining Ring Pliers, http://www.saeproducts.com/retaining-ring-tool.html
    Tweezers
    Needle Nose Pliers
    Super Glue (not pictured)
    The fan blade looks as if it would snap-on and off, but not the case.
    We need to remove the back label to access the external metal c-clip on the fan shaft.
    Swipe heat gun or hair dryer back and forth over the label.
    Use the Tweezer to peel off the fan label.
    Stick the fan label on a clean metal surface while you perform your work.
    You will tie down the fan hub with this Twisty tie. The fan shaft has a retention spring inside. You need to compress this spring, so you can remove the metal c-clip. If you don't, it's almost a guarantee that the c-clip will fly off the shaft faster than a bullet.
    Using Twisty tie to compress the fan hub spring, by tying down the hub to the fan frame.
    Close ups of the Black metal c-clip inside the Scythe Gentle Typhoon.
    Insert the two prongs of the Retaining Ring Plier inside the jaw of the c-clip.
    If you have a large Magnet, Position it near the fan hub, just in case the c-clip pops off.
    Holding the black metal c-clip in the Retaining Ring Plier.
    You will widen the jaw of the c-clip and need to bend it back to it's original opening, so it maintains it's grip.
    Hold the c-clip in the Tweezer while using a Needle Nose Plier to compress jaw of the c-clip.
    Doing this will allow you to re-use the metal c-clip.
    Here is the Scythe Gentle Typhoon 120mm Cooling fan dismantled, next step is choosing whether to apply the GULF Blue or Orange, or both colors?
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/19 06:52:00 (permalink)
    I debated about which color to paint the Scythe GTs for EK's 360 XTX Radiator. Decided to leave the fan blade hubs their factory grey and paint the frames GULF Blue, which works together and helps break up all of the orange.
    Clear coat applied
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/21 08:52:04 (permalink)
    Re-assembled the GTs yesterday with these replacement C-clip Retainer Rings that fit Gentle Typhoon fan axels, http://mnpctech.com/case-mods-gaming-pc-liquid-modding-custom-computer-mnpctech-overclock-cooling-fan-grills/ball-bearing-pc-cooling-fan-external-retaining-ring-or-c-clip-pliers-clone.html
    I use two micro flat head screw drivers to snap the c-clip over the fan motor axle / shaft
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/22 05:32:22 (permalink)
    EK's 360mm XTX radiator has convenient port on bottom for draining your loop. I'm using a Koolance Drain Valve with two of their swiveling 90 degree "snake" extensions.(Bitspower also makes a nice drain valve)
    Koolance Drain valve (4 way Splitter won't be used in this build)
    I'm using two of these Koolance swiveling 90 degree "snake" extensions. The others were used in Origin PC build, http://mnpctech.com/genesis-the-evolution-of-the-mod-munky-staff-project-with-origin-pc-genesis-full-tower.html
    The two swiveling 90 degree "snake" extensions allow you to angle the drain valve under the Mastercase bezel and foot.
    Having the drain valve outside of the chassis makes periodic maintenance of draining and refilling the liquid loop easy.
    LCRava
    • Ribbons : 8
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/23 09:20:42 (permalink)
    This is one of the sickest mods I have ever seen!!! I didn't like that chassis until today.
    MY AFFILIATE CODE: X6EXZ64PSH
    "I don't always GAME in 4K, but when I do, I prefer 4 TITANS"
    #23
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/23 10:43:26 (permalink)
    Glad you like it, Thanks for commenting, agree, I didnt like the Mastercase at first either...
    Only had few minutes yesterday to work on my build. Decided on Black wire fan grills for the GTs. I like the look. I guess some would call them "old school" when compared to vast array of fan grills available today, btw All of the machined aluminum parts for Deep Silver's Homefront: Revolution Gaming PC are getting finished, so I'm dividing workshop time between both builds. What a contrast lol, from "don't scratch the paint!" on "what is the best grit to score this finish"on Homefront.
    I also swapped out the Black factory thumbscrews for Mastercase SSD trays to machined knurled silver aluminum.
    #24
    • Ribbons : 52
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/23 11:16:52 (permalink)
    Just incredible work.
    #25
    • Ribbons : 44
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/23 11:31:35 (permalink)
    Nice photos of a interesting build.
    Thanks for all of the detailed photos & "tricks"
    I call those small c-clips (like on the fan), Gee-whiz clips; cause your going to be saying gee-whiz where did it go if your not careful.
    1) ASUS Z97-WS, i7-4790K@4.9GHz,  2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842
    2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD    Affiliate code 05MLLDCG6B
    #26
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/27 16:47:16 (permalink)
    Thanks again for watching guys! and Sorry for lack updates. I'm watching Ebay for deal on Core i7, socket 1150 4790K 4.0 or 4770K 3.5, then I'll need to get a water block for the CPU. Still debating on GPU(s) I'm not looking for latest and greatest.
    post edited by mnpctech - 2016/03/27 16:49:39
    #27
    EVGATech_MDecker
    EVGA Tech Support
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/27 21:27:41 (permalink)
    this is a true work of art. Loving it!
    (つ◕౪◕)つ━☆゚.*・。゚X99Micro2 | 5960X | TitanX  。゚・*.☆゚
    #28
    Vlada011
    • Ribbons : 7
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/28 00:31:04 (permalink)
    My god when I remember, I searched this little part 2 hours once in house, on knees with magnifying glass before 4-5-6 years
    He jump over my head who knows where in room... And I found him... I found him! I scream as lunatic...
    My friend remove that ring from 5-6 fans, he put fan in plastic bag and his head and hand inside bag and easy with tweezers remove him.
    And if ring jump he is close....
    Best fan ever made, only need to be re-paint because default look very bad. And it's very hard to remove dust from blades even with alcohol once if become dirt.
    I stop to use them because of that. CORSAIR fans are much easier to clean.
    post edited by Vlada011 - 2016/03/28 00:36:50
    #29
    mnpctech
    • Ribbons : 15
    Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/03/30 05:57:03 (permalink)
    @Vlada, I hear ya on that, and just an fyi, darkside orders the GT from factory with Black fan hubs, https://www.dazmode.com/s...150rpm_69cfm_30db_fan/
    @EVGATech, Thank you and please excuse the choice of MB, (lol) as it fit my budget and theme nicely (DUCKS UNDER DESK) I'm still debating on GPU(s) tho.
    post edited by mnpctech - 2016/03/30 05:59:41
    #30
