Hot!Cooler Master Mastercase 5 / Pro Custom PC build
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/08/28 02:04:58 (permalink)
Continuing to evolve nicely Bill.
#61
mnpctech
Mnpctech Representative
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/05 06:03:35 (permalink)
Thank you, and Sorry for delay! Milling billet cable combs for the 24 pin ATX cable, http://mnpctech.com/buy-s..th-cable-combs-for-pcs/
Mnpctech PC Mod Store Discount for EVGA Forum Members
#62
  • Ribbons : 44
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/05 14:53:44 (permalink)
Some very nice parts.
Aluminum billet combs would look sharp anodized in different colors.  What is the max OD of wire that fits these ?
1) ASUS Z97-WS, i7-4790K@4.9GHz,  2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842
2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD    Affiliate code 05MLLDCG6B
#63
dillon
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/05 17:16:31 (permalink)
good job sir ! . I need to take this step to get on this level ..
Asus rampage 5  Edition 10
I7  6800k 4.2MHZ
32gb Corsair Vengeance
EVGA GTX 980 TI SC
Corsair ATX 1200
Corsair Force gt 500gb
Samsung SSd 500 gb
Case Labs STH10 AKA White Widow
Acer XB270HU
HEAT
#64
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/07 12:22:36 (permalink)
@dillon, Thank you, modding is fun, just need to make time, right?
@ COOL GTX, 3mm OD, Ive got 4mm sleeving on the way, to test, posted this unlisted video testing 3mm OD
https://www.youtube.com/watch?v=jwiJV2D4o04
#65
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/09 13:16:04 (permalink)
I just finished making 24,16,14,12,8,6 and 4-pin billet cable combs last night.
#66
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/10 00:33:36 (permalink)
Those combs rock Bill.
#67
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/13 09:37:07 (permalink)
Glad you like them, a lot of people complained about plastic versions breaking, and I can see that!
Starting scuffing gpu waterblock covers and taping in preparation for GULF Blue finish. These covers are Black Acetal Koolance GTX 980s waterblocks are on sale for $69 each
I'll also be painting bridge, and backplates...
#68
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/14 09:29:55 (permalink)
Bill do you sell those aluminum billet combs by the way?
#69
  • Ribbons : 44
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/14 09:42:45 (permalink)
http://mnpctech.com/buy-stealth-cable-combs-for-pcs/
#70
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/16 06:04:10 (permalink)
Indeed, and Thanks Cool!
Finished painting the video card waterblocks, bridges, and backplates with Porsche 917 GULF Racing Factory Blue Paint.
Dismantled GTX 980 Koolance Waterblocks
Basecoat Primer on Koolance GTX 980 waterblock
Basecoat Primer on Koolance GTX 980 waterblock Bridge
Koolance GTX 980 waterblocks with Porsche 917 GULF Racing Factory Blue Paint
#71
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/17 01:32:57 (permalink)
Love that GULF blue color
#72
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/17 10:06:46 (permalink)
Koolance waterblocks re-assembled with painted backplates
#73
  • Ribbons : 44
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/17 14:13:12 (permalink)
Nice paint job
#74
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/19 09:59:21 (permalink)
Thank you GTX!!! I also re-sprayed the front bezel grill to match the case.
#75
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/19 23:35:24 (permalink)
Simply love those colors and look forward to more pics.
#76
  • Ribbons : 44
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/20 04:58:35 (permalink)
Special paint for the plastic parts ?
#77
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/22 08:29:06 (permalink)
@rjohnson, thanks buddy, we're almost to finish line, I just need PSU and SSDs, and DDR
@GTX, flexible primer this time, for the plastic parts, otherwise I have used the SEM self etching primer on plastic without any issues
Decided on dual serial for the GTX EVGA 980s SLI bridge so I had to cut and bend new SS tubing segments for entering and exiting the GPU blocks. Here is the Koolance SLI Bridge, GTX Backplate and Blocks
post edited by mnpctech - 2016/09/22 08:31:13
#78
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/09/26 11:13:32 (permalink)
On Saturday I received my DDR sticks, 32GB of Corsair Vengeance. The sticks were Black, so I hit local home improvement store and found a great aerosol substitute paint for the Porsche Gulf Racing Blue, it's Harbor Blue enamel paint by Rustoleum. I'm using these to create a DIY video guide to painting DDR heat spreaders, too!
#79
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/10/01 09:53:40 (permalink)
DDR heat spreaders are finished, Video Guide Link for Taking Apart & Painting DDR
#80
  • Ribbons : 52
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/10/02 02:58:30 (permalink)
Outstanding Bill. There were some queries about painting memory modules on our forums so I will make a new post and put your link in it.
#81
  • Ribbons : 44
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/10/02 10:43:32 (permalink)
I was wondering about any thermal change in color,or if the painted heatsinks would run hotter than stock, myself
Nice detail / color scheme though
#82
mnpctech
  • Ribbons : 15
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/11/01 07:35:40 (permalink)
Thanks again rj!
and the temperature isn't significant enough to cause discoloring to the paint.
Have you guys heard of Ensourced? Somebody refered me to this guy for custom cable sleeve ordered and extension cables with paracord. Really Nice Quality & GREAT PRICES. I initially thought Burnt Orange would work with my color theme, but didn't look right, so thinking of matching the Stainless Tubing instead, so I bought these three variations of Grey.... Hmmm
8 pin GPU Paracord individually sleeved cable in "Smoked Grey"
"Charcoal Grey" paracord
"Graphite Grey" paracord
#83
LCRava
  • Ribbons : 8
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/11/01 12:13:33 (permalink)
So sexy! Great build as always Bill.
MY AFFILIATE CODE: X6EXZ64PSH
"I don't always GAME in 4K, but when I do, I prefer 4 TITANS"
#84
CptSpig
Re: Cooler Master Mastercase 5 / Pro Custom PC build 2016/11/01 14:23:32 (permalink)
Dude that thing is dope! You have some mad skills.
Mother Board: EVGA X99 Classified
CPU: Intel I7 5930K Haswell @ 4.2 GHz
Cooling: EKWB  EK-XLC Predator 360 (incl. QDC)
GPU: Nvidia TITAN X Pascal with EK-FC Acetal+Nickel Pre-Fill
RAM: 32GB Corsair Dominator Platinum  3200 MHz
PSU: EVGA SuperNOVA 1000 G2 80 Plus Gold
SSD: Samsung 850 PRO 512 and 840 PRO 256
OS: Windows 10 Pro / 64 bit
Case:  Corsair Obsidian Series 750D Full-Tower
#85
