Comparing these two 5.1 surround sound systems?
SAMOEDADDY
2014/08/28 11:28:37 (permalink)
I currently have an old ALTEC LANSING VS3251 70 Watts 5.1 and was looking at the Logitech - Z506 to replace it.
I have some Best Buy rewards money to spend, that is why I am choosing the Logitech specifically.
The specs seem about the same. Does the technology advice to sound better even if the specs are similar?
Looking for some input thank you.
OLD SYSTEM: http://www.newegg.com/Product/Product.aspx?Item=N82E16836113007
NEW SYSTEM:  http://www.bestbuy.com/site/logitech-z506-5-1-surround-sound-speakers-6-piece-black/1215025.p?id=1218236333141&skuId=1215025&st=pc%20speakers&cp=1&lp=13
"NO SUCH THING AS FUTURE PROOF"
Be Quiet! Silent Base 802 Black Window * MSI X570 MEG ACE * Amd 5950x * Gigabyte RTX 4090 Gaming OC * 64GB DDR4 GSkill * Corsair H115i Pro * Evga Supernova GT 1300 * Logitech G35 * Win 11* Samsung 49" Monitor
4 Replies Related Threads
    NordicJedi
    • Ribbons : 77
    Re: Comparing these two 5.1 surround sound systems? 2014/08/28 15:14:17 (permalink)
    Moving to Gen. Hardware.
    6012mhz on L/N2
    5321mhz on L/N2
    5091mhz on air
    The Lightsaber
    The Emperor Reborn
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Comparing these two 5.1 surround sound systems? 2014/08/28 15:58:41 (permalink)
    I had those Z506's for a short while cause I thought my Altec Lansing's went out on me, but it was just a bad audio cable. Those Z506's are pretty decent for the price, but the rear speakers are pretty weak.
    Personally, I want one of those Z906 speaker sets... I've almost bought them a few times when Logitech sent me a 40% off deal a while back. But I all ready have a Onkyo receiver and two really nice BOSE stand up speakers that are not being used, so those are going to be my replacement. I also have a 12" subwoofer that I currently have no use for, so I will be hooking that up for fun as well.
    Main PC | Secondary PC
    Intel i9 10900K | Intel i7 9700K
    MSI MEG Z490 ACE | Gigabyte Aorus Z390 Master
    ASUS TUF RTX 3090 | NVIDIA RTX 2070 Super
    32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17
    SuperFlower Platinum SE 1200w | Seasonic X-1250
    Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GB
    Cougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5
    3DMark Results:Time Spy|Port Royal
    PvtBlackdog
    Re: Comparing these two 5.1 surround sound systems? 2014/09/06 06:15:16 (permalink)
    Z906 (Logitech) are just awesome and can highly recommend that set!!!!
    ARMYguy
    Re: Comparing these two 5.1 surround sound systems? 2014/09/06 07:15:19 (permalink)
    Im using my old klipsch promedia 5.1 speakers, with a pioneer sub and a receiver i bought at best buy. It actually replaced those z506's and it sounds at least 100 times better. Don't buy those 506s, they are literally garbage and they break and sound bad in days. Honestly, even though my klipsch pro media 5.1 amp went long ago, the speakers are still some of the best you can get for PC audio, and they can easily be powered by a receiver.
    Asus Strix Z790 F - Intel 13700 K - Gigabyte 4090 Windforce - 32gb DDR 5 - 1TB Samsung SSD 850 evo - Windows 10 Pro - 1TB Samsung M.2 860 - Inland 2 TB NVMe - Acer Predator X27
