claytonwilliams
Ok, so i saw a case online that was a desk, well two of my favorite things are computers and workin with wood so here it is. bear in mind it is going to be a pretty slow build and likely wont get updated till i get a little more progress done. also any suggestions will be appreciated :) *edit Thought i would add a cost as i was going along and this is as good a place as any :) 2 sheets 1/2"x5'x5' Russian Birch 60$ (this stuff is great to work with btw almost no voids in the plys and actually shapes pretty good with a router) to be continued......
post edited by claytonwilliams - 2014/04/09 22:02:44
- Ribbons : 282
Re: Case build for a 4p and and a 2600k
2014/04/07 06:41:15
All Air or Air and Water or only Water Cooling? Looking good so far, remember that BigAdv are ending at the end of the year or Jan 2015. I moved my 2P 32 Cores over to Crunching even though it still supports BA.
claytonwilliams
2014/04/07 08:22:30
Im still ery new to alot of it, not sure what bigava is really, the 4p will be a cruncher and media server:) it will be all air till i can put together the money to water cool then it will be pretty :)
- Ribbons : 115
2014/04/07 22:45:59
May be awhile before it's done, but may be worth the wait. =)
- Ribbons : 84
2014/04/08 00:45:57
Looks good so far. I wish I had the skills for that.
claytonwilliams
2014/04/08 10:33:11
Ty very much!! I'm really getting excited about it. hopefully i'll get some more done on it in the next few days and can post some more pictures. Any suggestions on some cheap quite case fans? 120mm as 140 would be just a lil tight where i wanna put them.
- Ribbons : 84
2014/04/08 10:55:07
claytonwilliams Ty very much!! I'm really getting excited about it. hopefully i'll get some more done on it in the next few days and can post some more pictures. Any suggestions on some cheap quite case fans? 120mm as 140 would be just a lil tight where i wanna put them.
I recommend these: http://www.corsair.com/se...ans/quiet-edition-fans
claytonwilliams
2014/04/09 10:32:36
Ty again for the recomendation!! I have seen some really cool stuff with the carbon fiber vinal, anyone sugest a place to get it from and tips on putting it on a large surface. I am debating covering basically the whole desk with it tho i have not used it before and would hate to mess it all up
notfordman
- Ribbons : 28
2014/04/09 11:51:28
claytonwilliams
claytonwilliams
2014/04/11 17:04:14
claytonwilliams
claytonwilliams
2014/04/21 11:13:36
help me!! haha I am trin to decide what kinda finishes to put on it. I have some very old reclaimed barn oak that i will make the top out of but everything else is still up for debate. I know you guys are awhole lot better at the design aspect then I, so throw me some suggestions. I am still thinkin i may do some kinda large water rez on the front of the two legs but still kinda lost. I want it to rock!!
HayzBaby
2014/04/21 18:22:26
The reservoirs in the legs is a nice idea. But that is alot of tubing to run. Let alone the lose in pressure. Maybe throw in a 2nd pump to give back your headpressure. I dont know your budget. Maybe put in fake reservoirs, just have a tube and pump combo for looks for the legs. Idk haha
claytonwilliams
2014/12/17 18:48:57
" /> Been a very long time since any update. Just got the 4p mounted and got alot of the wiring sorted, but it is up and running in its new home. Ran outta time tonight but hopefully will have it together with the case fans tomarrow. Then time to break down the 2700k and mount it in the other side.
Tropickz
2014/12/17 20:27:36
Should be interesting to see what's next but so far
EK_Derick
EK Forum Support
- Ribbons : 6
2015/01/03 08:37:30
