Stelpap
Hello everybody, I bought the other day this gpu (gtx970 ssc gaming acx 2.0+ 3975) and i have a problem with the power supply. It needs 6pin and 8pin connection. My psu has only one 6pin cable. The box of the gpu came with some cables too. One of them may turn 2 molex to one 6pin. My question is this: may i connect the one 6pin to the 6pin slot and the other 6pin to the 8pin slot (without an adaptor to turn in 8pin)? and at what risk? After doing some digging with google i got confused. People claim that connecting a 6pin cable to 8pin slot doesn't matter at all, whereas other claim that you need a new psu with 2 pcie 6+2pin. My psu is 600w and 1 year old by the way. i use i5 4460, 8GB of ram, two hdds and a ssd. Thanks in advance.
Re: Can i connect 6pin to 8pin on GTX 970 SSC GAMING ACX 2.0+ 3975 without a problem?
2016/04/30 09:00:45
No, you will need an adapter to turn the 6-pin into an 8-pin.
bob16314
- Ribbons : 761
2016/04/30 09:51:23
Sure, go right ahead and put the 6-pin plug in the 8-pin socket and give it a go..An 8-pin socket is backwards compatible with a 6-pin plug and won't hurt a thing..As long as it don't cough up an error at boot saying "Please power down and connect the PCIE cables" (or something to that effect), try it..It might fail due to lack of power under load though..If it works, it works and if it don't, it don't. You need to get an adapter, but just using the 6-pin plug in the 8-pin socket might work in a pinch until you get one..And yes, definately do get one, there are many types available. FWIW, my (170W) card that has one 6-pin and one 8-pin socket runs perfectly fine, all the time, using just two 6-pin plugs..Actually, when I was testing it a long time ago I forgot about it for about a week and never had a problem, even overclocking it. Your card is a 201-watt card..It can get 75 Watts from the PCIe slot..A 6-pin connector is for 75 watts..75W x 3 = 225W, which is slightly more than what your card rates at..More on PCIe Supplemental Power Connectors here..Like I said, if it works, it works and if it don't, it don't.
Stelpap
2016/04/30 09:55:38
Thank you so much for your quick responses @Sajin and @EVGATech_AndrewA! I will try to find an adapter and then it should do the trick for now. I plan to buy a brand new psu as well, because people keep mentioning that the adapters should be avoided. However, i can't understand why. For example, my new gpu had some adapters inside the box. If the companies offer them, then why we should avoid them...?
Stelpap
2016/04/30 09:59:14
bob16314 Sure, go right ahead and put the 6-pin plug in the 8-pin socket and give it a go..An 8-pin socket is backwards compatible with a 6-pin plug and won't hurt a thing..As long as it don't cough up an error at boot saying "Please power down and connect the PCIE cables" (or something to that effect), try it..It might fail due to lack of power under load though..If it works, it works and if it don't, it don't. You need to get an adapter, but just using the 6-pin plug in the 8-pin socket might work in a pinch until you get one..And yes, definately do get one, there are many types available. FWIW, my (170W) card that has one 6-pin and one 8-pin socket runs perfectly fine, all the time, using just two 6-pin plugs..Actually, when I was testing it a long time ago I forgot about it for about a week and never had a problem, even overclocking it. is a 201-watt card..It can get 75 Watts from the PCIe slot..A 6-pin connector is for 75 watts..75W x 3 = 225W, which is slightly more than what your card rates at..More on PCIe Supplemental Power Connectors ..Like I said, if it works, it works and if it don't, it don't.
Whoa! are you sure about this? I would try it but i fear that something's gonna fried and i don't want problems.
bob16314
- Ribbons : 761
2016/04/30 10:07:13
Absolutely, positively, 1010% sure..An 8-pin socket is backwards compatible with a 6-pin plug, read the link..It may work in a pinch until you get an adapter..It will not hurt a thing, at all..I said I ran mine for a week like that.
Stelpap
2016/04/30 10:15:17
bob16314 Absolutely, positively, 1010% sure..An 8-pin socket is backwards compatible with a 6-pin plug, read the link..It may work in a pinch until you get an adapter..It will not hurt a thing, at all..I said I ran mine for a week like that.
Ok! thank you very much! I'll give it a try and i'll come back later to tell you what happened. EdiT: i read the article in the link you posted! It was really helpful (of course along with you!).
bob16314
- Ribbons : 761
2016/04/30 10:33:36
Okay..Hopefully you won't get that "Please power down blah blah blah" error or anything..But just putting the 6-pin plug in an 8-pin socket won't harm a thing..If it works, it works and if it don't it don't.
Stelpap
2016/04/30 10:46:18
First things first. @bob16314 THANK YOU SO MUCH for encouraging me!!! Ok! here's what happened... I plugged the two 6-pin cables, the pc turned on but this message came up "please power down and connect the PCIe power cable(s) for this graphics card". Then i tried something else. Gpu's box came up with an adapter Y that turns two 6-pin plugs to one 8-pin plug. I decided to use that one and i simply connected the remaining one 6-pin plug -the other 6-pin was connected directly in gpu's slot- to one of the two slots of the adapter (the other remained empty!) and it worked like a charm!!! I installed the driver and everything's ok for now. Can i play some games now or should i wait to get an adapter that turns 2 molex to 8-pin just for safety?
2016/04/30 10:58:54
You still need to buy an adapter. The card may shutdown on you under load using only the 6-pin.
bob16314
- Ribbons : 761
2016/04/30 11:09:22
Yeah, was kinda thinking that error would crop up. Play games now and see how it rolls..You have a 201 watt card..75W can come from the PCIe slot itself and the remaining 126 watts come from the supplemental power connectors..A 6-pin supplemental power connector is good for 75 watts, an 8-pin for 150 watts..You're not overloading anything at stock speeds..Chances are you could probably run it like that forever..Basically what you have now is a 6-pin to 8-pin adapter, which may be okay as long as you don't plan on overclocking the card..A proper adapter would enhance stability, performance and overclocking potential.
Stelpap
2016/04/30 15:20:25
@bob16314 i will never overclock my gpu. Basically i have never overclocked something and i will keep it that way. @Sajin Of course i will get a proper adapter just for safety reasons. I will test some games tomorrow and i will come back to tell you how it goes.
Dschijn
2016/04/30 15:40:17
A 600W PSU with only 1x6-Pin? Is the PSU 10 years old? :D
Stelpap
2016/04/30 15:42:05
Dschijn A 600W PSU with only 1x6-Pin? Is the PSU 10 years old? :D
Believe it or not it's almost 2 years old... Nevermind... Problem solved.
Broken
2016/05/01 10:19:55
Wait a minute. Your GTX 970 SSC has an 8 pin and and 6 pin connector???? Mine only has two 6 pins.
Stelpap
2016/05/01 12:52:47
Broken Wait a minute. Your GTX 970 SSC has an 8 pin and and 6 pin connector???? Mine only has two 6 pins.
Maybe we don't own the exact same version/model of the GTX970... Mine is this: EVGA GeForce GTX 970 SSC GAMING ACX 2.0+ 04G-P4- 3975-KR. If you're interested you may take a look here: So, what's the exact model of your GTX970?
post edited by Stelpap - 2016/05/01 14:14:04
Broken
2016/05/01 13:18:50
Lol, was sure I got a 3975 but got a 2975.
Stelpap
2016/05/01 14:19:00
Broken Lol, was sure I got a 3975 but got a 2975.
Basically we own the same card but with some differences...
Stelpap
2016/05/04 07:09:13
So far so good. Everything works fine. I didn't even have a problem running Assassin's Creed Unity. Hopefully tomorrow my proper adapter will arrive.
DeathAngel74
- Ribbons : 10
2016/05/04 07:35:37
970 sc, 970 ssc, 970 ftw acx 2.0 have 2 x6-pins. All 970 acx 2.0+ have 1 x6 and 1 x8 pins. 225w vs. 300w
post edited by DeathAngel74 - 2016/05/04 08:57:44
Carnage specs: Motherboard: ASUS ROG STRIX X299-E GAMING | Processor: Intel® Core™ i7-7820x | Memory Channels#1 and #3: Corsair Vengeance RGB 4x8GB DDR4 DRAM 3200MHz | Memory Channels#2 and #4: Corsair Vengeance LPX Black 4x8GB DDR4 DRAM 3200 MHz | GPU: eVGA 1080 TI FTW3 Hybrid | PhysX: eVGA 1070 SC2 | SSD#1: Samsung 960 EVO 256GB m.2 nVME(Windows/boot) | SSD#2&3: OCZ TRION 150 480GB SATAx2(RAID0-Games) | SSD#4: ADATA Premier SP550 480GB SATA(Storage) | CPU Cooler: Thermaltake Water 3.0 RGB 360mm AIO LCS | Case: Thermaltake X31 RGB | Power Supply: Thermaltake Toughpower DPS G RGB 1000W Titanium | Keyboard: Razer Ornato Chroma | Mouse: Razer DeathAdder Elite Chroma | Mousepad: Razer Firefly Chroma | Operating System#1: Windows 7 SP1 Ultimate X64 | Operating System#2: Linux Mint 18.2 Sonya (3DS Homebrew/Build Environment)
