Okay,
Little situation update.
1 year, without being able to Work on.
Since the start of this project, my big problem is the tubing, with 45 foot of tube, and one incredible number of adaptators.
After one years, I have one new approach of the problem, so the solution found is using acrylic rigid tube.
But new solution = new material = new problem
With 5 loops, made a smart agencement is a hard job !
So I am searching people that have already used primochill acrylic tube.
I need advice for the better use posible of this products.
I am already trying to find a cool tubing design, but I am open to all idea.
Thank you
