Budington Project 2.0... 6 rads. , 5 pumps, 5 loops, SLI 4Way and many more [work log]
Page: < 12345 > Showing page 4 of 5
Chrome-M-Dragon
  • Ribbons : 27
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 06:49:20 (permalink)
i dunno, i like the way he has it there. The sticker of the drive gives it a great contrast.
#91
notfordman
  • Ribbons : 14
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 12:21:51 (permalink)
I also like the way the SSD looks, but it is not up to me. You have put a lot of work in this build so far. I really like the CNC parts ,they turned out very nice!
#92
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 13:11:19 (permalink)
It is not that I do not like them as they are now.. not at all..
I would just cover the entire SSD, but I think it comes down to personal preferences.. :D
#93
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 14:02:05 (permalink)
Yes, no problem, but I don't know at this time if I like more the full cover or partial...
I have ordered more carbon plates and one extruded carbon tube.
Normally the "latest" CNC machined parts will be delivered the next week... with this parts, one of the most complicated step will start.
This step is, determine and permanently fixed the two dual reservoirs and  draw the circuits from these reservoirs.
#94
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/04 21:57:55 (permalink)
#95
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/05 02:06:30 (permalink)
budington
#96
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/06 03:12:41 (permalink)
new dry carbon plate and extruded carbon
#97
LDcooling
LD Cooling
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/06 08:12:55 (permalink)
It is awesome!
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots:http://www.evga.com/forums/tm.aspx?m=934784
LD PC-V8 Watercooling case: http://www.evga.com/forums/tm.aspx?m=629563
LD PC-V10 Watercooling + Phase Change case: http://www.evga.com/forums/tm.aspx?m=701824
LD Cooling on Facebook: http://www.facebook.com/p...71942482842090?sk=wall
Website: http://www.ldcooling.com/
#98
joaks87
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/06 15:49:34 (permalink)
This build is insane! Love the work so far!!
#99
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/07 02:15:21 (permalink)
I just started sleeving the GPU's power cables...
the result in some hours
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/07 04:54:51 (permalink)
tada
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/07 07:34:25 (permalink)
two more and the gpu power is finished
eNuQQ
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/07 12:34:53 (permalink)
That's just an insane amount of work, keep it up!
Got to love those 510's.
Intel Core i7 2600K @4.5GHz | GIGABYTE P67A-UD7 | 8GB Mushkin Frostbyte 1600MHz | Corsair AX1200
Noctua NH-D14 | 2x EVGA GTX580 Classified | Intel 510 120GB SSD | ASUS Xonar Essence STX | Corsair 800D
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/07 23:00:34 (permalink)
GPUs power cable finished
next one ATX + EPS
for the price of the power supply... Enermax  could make an effort on the design of wiring...
uncle poop
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/09 06:34:40 (permalink)
this is some sick stuff man... amazes me what people's imaginations and skills can come up with...
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/09 07:31:53 (permalink)
Thx
Cable finished
but the tool did not survived...
nickbaldwin86
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/09 07:59:26 (permalink)
I break every tool I have ever used... but I sleeve a lot of cables so.
I ended up making my own tool with a hobby knife :D harder metal and much stronger tool to work with
=EGC=Ripley
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/09 08:27:35 (permalink)
This tool was used for a lot of cables, used one year and four power supply... maybe 300 cables... so it's not bad
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 01:49:47 (permalink)
Hello to all those who follow this topic
i have to ask you one little thing !
someone has seen PCI-e 8 and 6 pins power connector at 90° ??
i am looking for some time and i do not found shop selling this kind of product
if someone know where find this connectors, i need it
thank you
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 06:10:47 (permalink)
I think that you'll have to make them yourself. There is a member here on the forum that have done that before.. So it is plausible.
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 06:50:42 (permalink)
I think like yourself
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 06:55:13 (permalink)
budington
I bet it is a time killer.. but the end result might end up being worth it..
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 07:01:06 (permalink)
indeed
I have to thinks a little bit
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/15 07:15:45 (permalink)
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/04 08:46:37 (permalink)
Hi all,
I am one of the lucky winner of one EVGA NEX 1500
http://www.evga.com/articles/00692/
I will be back soon with some updates of this topic.
stay connected
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/04 09:21:46 (permalink)
^^ Congrats on the win! :D
xsv161
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/04 19:07:15 (permalink)
Wow, your system looks great so far. Keep up the good work!
notfordman
  • Ribbons : 14
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/05 05:16:31 (permalink)
LUCKY!!!! Congrat's on the Nex PSU! Love your build. Have been following from the start.
dipzy_v
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/06 08:07:34 (permalink)
Great build and congrats on winning the power supply, Enjoy
 Heatware: dipzy_v
 Intel 4930K|Gigabyte X79 UP4|16GB Gskill DDR3|EVGA TITAN X SC|512GB 850 Pro SSD|3TB HDD|Corsair AX1500i|Asus PG348Q|Ducky YOTS|Corsair M65|
jacksonn24
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/08/26 11:15:41 (permalink)
congrats on the winning of the PSU.how do you like it? and your build is nice look good so far
