Bruno747
- Location: Looking on google to see what Nvidia is going to o
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way
2012/01/15 12:09:12
The public demands an update lol!
2012/01/15 13:59:22
Hope you're not having too much trouble...
2012/01/15 15:02:26
Hi, I work on it, I have finished the design of the parts used for attache the reservoirs. These parts are made from Acetal and CNC and I am very busy I have added my two 140mm radiators. I have changed the tubes used for GPU loops It's also Tygon but more rigid (Tygoon 2375) thank you to follow the topic
post edited by budington - 2012/01/16 12:49:51
2012/01/15 16:06:08
God this rig looks sick. I hope one day I can try to put a rig like this together.
2012/01/17 15:27:07
The connectors for one 140 mm is finished. but when i did work on the second, i made a big mistake and i have broke the fan....
loveha
- Ribbons : 53
2012/01/17 15:59:58
How many feet of tubing total do you think?
Case: Corsair 900DMotherboard: EVGA Z170 Classified E179CPU: Intel Core i7 6700K 4.6GHzRAM: 16GB Corsair DDR4 2133 16-15-15-36GPU: EVGA GTX 1070 FTW DT SLIPSU: EVGA 1000w G2SSD: Samsung 512GB 950 Pro NVME M.2Monitor: Acer Predator X34 100Hz G-SyncSound: Schiit Modi 2 DAC~Schiit Vali 2 AmpHeadphones: AKG K7XX Massdrop Edition
2012/01/17 16:09:32
I have never seen this done before, very nice work. cant wait to see more
2012/01/17 16:09:38
loveha How many feet of tubing total do you think? humm I don't know, but like 45 feet
post edited by budington - 2012/01/18 05:43:24
2012/01/20 11:43:46
new picture for the 140mm, the connection is a little bit complicate, but it's working fine  I am also working has changed the hard drive carriers  there remains many things to do...but it go to the right direction
DEEBS808
2012/01/22 02:41:32
2012/01/30 19:48:26
HeThing budington all of the construction picture are make with my cell phone, final picture with better camera Sounds great to me :D One of the measures taken to ensure that the pictures in the future are on the best possible quality ... Not only for computer pictures, I make a Chroma key chamber Not finished but on the good way...
2012/01/31 02:13:10
2012/01/31 23:27:53
2012/01/31 23:48:42
Very good idea with that carbon plate!
2012/01/31 23:50:09
thx
2012/02/01 05:36:27
Do you plan on modding those SSDs? Black paint maybe?
2012/02/01 08:43:00
only if I find a reversible solution, It's two Intel 510 120Gb still under warranty
2012/02/01 13:27:31
I have more or minus the same idea. Thank
kerrgreg
2012/02/02 03:11:29
Looking great! although wont all those 90deg fittings kill your water flow rate? Please correct me if I'm wrong or your solution Im reasonably new to water cooling.
2012/02/02 03:19:44
Hi Kerrgreg, You are right, but the loops are simple with only one waterblock per loop ans using an overkill pump... so I dont think it will be a problem
Gold Leader
- Ribbons : 44
2012/02/02 07:56:28
Very very cool setup this one!  The reason why I love it so much is because that it has four EVGA GeForce GTX 480's in it, also seems that two of your cards have no backplates, but for that I found you a solution, so I PM'ed you that As for this picture: As that layout goes, understandable about the layout since you told me via PM that the cards and the system will be setup upright hehe, are you using a BTX based case due to this, since I have seen similar setups with upright placed setups, as weight dividing goes this would be a better layout right? As for the cards missing the EVGA logo's you could mail EVGA about this, they might send you the logo's you are missing, just an idea mate
post edited by Gold Leader - 2012/02/02 08:22:02
2012/02/02 08:21:25
Thanks,  The order of the cards on the picture as you are showed, is not representative of final setup. on this four cards I have two green and two orange, I have decided to make G/O/G/O or O/G/O/G .... You must also take into account that the motherboard is mounted in reverse ATX, so the backplate is not visible
Gold Leader
- Ribbons : 44
2012/02/02 08:24:25
2012/02/02 08:34:48
humm Reverse ATX and BTX is no comparable .. BTX is an layout totaly diferent Reverse ATX is ATX with the motherboard upside down
Gold Leader
- Ribbons : 44
2012/02/02 09:24:42
budington humm Reverse ATX and BTX is no comparable .. BTX is an layout totaly diferent Reverse ATX is ATX with the motherboard upside down Oh yeah that's right yeah thanks for pointing that out man As for your setup that's a beefy 1920 CUDA Cores you got there, very nice man also a neat advantage of the GTX 480 is that they have GPGPU Precision point support something the 500 series lack, this can be very useful with your GPGPU workloads you plan to use these for hehe, Folding @ Home for example, I dunno if Folding @Home has GPGPU precison Point support, if so 480's would render more than a 580 heh, per CUDA Core per Mhz. It would of been nice if the GTX 480 was made with 512 CUDA cores and 3GB of ram, that would of been a perfect scenario heh. I still have my GTX 480, it's a legendary GeForce actually, as GeForce history goes
post edited by Gold Leader - 2012/02/02 09:37:32
2012/02/03 01:44:40
I will try use DI-Noc 3M Vinyl film HeThing Do you plan on modding those SSDs? Black paint maybe?
2012/02/03 05:25:29
it's just a test to see how it looks with the DI-Noc Vinyl what do you think? Before... After...
post edited by budington - 2012/02/03 05:29:32
2012/02/03 05:47:58
It looks much better, but why not cover the entire SSD?
2012/02/03 05:55:19
it's just for test purpose only
