Budington Project 2.0... 6 rads. , 5 pumps, 5 loops, SLI 4Way and many more [work log]
Page: < 12345 > Showing page 2 of 5
saer.
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/15 16:32:11 (permalink)
I never realized, that you are using 4 pumps and 4 (480) rads to only cool 1 cpu and 3 gpu's ? Huh?
Talk about EXTREME overkill and a waste of money, but it's your money so waste it as you wish
post edited by saer. - 2011/10/15 16:35:45
#31
techsoldier
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/15 16:50:04 (permalink)
^^^I agree the components don't really warrant such extreme measures as 4 separate loops. Quite honestly you'd probably have the same temps with 4 240mm radiators each cooling an individual component. I think this is one of those form over function builds. Regardless, I'll be interested to see the whole package along with some temps.
#32
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/16 12:51:19 (permalink)
this computer is working 24/24 @ 100% (folding)
I want an ultra quiet computer and  very easy to work on cooling loops...
I am testing many hardware so with independent loops it's very easy to remove one card.
The cooling capacity is realy huge, but With this mods I dont want change each year my radiators.
In my last mody I use 2x 360mm for the cards and temp in 5V is not realy good @ 100%
The CPU with one 480 it's special...because it's possible that I add one fourth cards
#33
pyrebuilder
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/16 16:20:38 (permalink)
ok i have to ask, how are you getting the middle card its water without flowing through top or bottom cards? i just keep thinking on it and have no idea how you are doing it.
Computer builder, rocket flier, D&D player.
EVGA SR-X, intel Xeon E5-2630 v2
2x EVGA GTX 980 hydro copper
32GB corsair RAM 1600Mhz
10TB HDD, 256GB SSD
And all the bugs a Rosewill Blackhawk-ultra can hold.
#34
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/16 16:40:10 (permalink)
the space between each card is enough  large to connect a  90 ° connector
#35
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/10/17 15:40:20 (permalink)
Today, we have finished the first serie of prototypes.
#36
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/04 20:58:55 (permalink)
Hi, sorry for this long silence, before the end of the next week, all special parts will be tested.
New PSU will be installed,  the newest Enermax maXrevo 1500W.
The plan was a little bit modify...
The 7110 keeps the seven Caviar black and the fourth OCZ Vertex 2 with the raid card....
The 7110 will re-equiped with an i7 970, Asus Rampage III Gene, Corsair Dominator GT 3x4Go 2Ghz, EVGA GTX 580 for primary card and EVGA GTX 480 for phisiX
So on the new rig, i mount two Intel 510 120Go, one Crucial M4 240Go and one Caviar Black 2To
see you soon
#37
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/09 16:15:07 (permalink)
The New maXrevo 1500W It's smaller than my Revolution 85+ 1250W !
And this is the first picture of the prototypes
post edited by budington - 2011/11/10 06:30:46
#38
Halo_003
  • Ribbons : 50
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/12 19:54:41 (permalink)
You got the 1500W?! SICK! Got a link for that?
#39
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/12 20:44:32 (permalink)
you don't see the pictures ?
#40
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/20 20:55:32 (permalink)
still on it but many work to do
four GTX 480 FTW
 Some hardware modification is on its way
stay tuned
P.s If you have a 4 way SLI bridge and you dont use it please send me a MP
post edited by budington - 2011/11/20 21:06:01
#41
SharkGTX
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/20 23:18:19 (permalink)
You thought, I don't come?)) incorrect answer)))
Hi. You know, that I love extreme h2o, but I guess there are some not smart moments:
1) why do yiu need 5 loops?!
3x d5 blows this setup up to holy ****...
2) why only 4x weak 480mm EK Coolstream?! And for the 5x D5 ?! Its silly...
You would have disbalanced H20 setup with much less efficiancy.
3) why 4x480?! Why not 3x580 (its more powerfull and less energy eating configuration)
Please don't offence me, but I knew what I'm saying ;)
#42
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/21 00:26:32 (permalink)
I do no thought,  it gives me a headache.
1) why ? I dont need, I whant it !
2) the idea is: make one loops for each componant, 4x480mm, each one for one GTX 480. The fifth uses a 140mm radiator (CPU)
If this had been possible I would not have these radiators but the available space is used to the millimeter
3) because I have 4x GTX 480.. they were purchased and used for almost two years
#43
SharkGTX
Re:Budington Project 2.0... 4x 480mm, 4 pumps, 4 loops, SLI 3Way 2011/11/21 00:41:02 (permalink)
Understood:)
Good luck
#44
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm, 5 pumps, 5 loops, SLI 4Way 2011/11/22 05:32:00 (permalink)
I have many works to do, the end is very far away ;)
Thx
post edited by budington - 2011/11/25 01:17:48
#45
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2011/11/25 01:12:30 (permalink)
little update, I add two radiators so in total this case will have six.
One 480mm for each GTX 480 and two 140mm for the cpu loop
the first that says I'm crazy
has likely due
post edited by budington - 2011/11/25 01:18:28
#46
Little Sister
  • Ribbons : 10
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2011/11/25 06:58:12 (permalink)
Looks great so far. do you have a link to the max revo 1500w PSU?
INTEL I7 2600K  -  CORSAIR H100  -  EVGA Z68 FTW  -  CORSAIR DOMINATOR GT 2000MHZ 16GB  -  EVGA GTX 580 3GB SLI X3
WESTERN DIGITAL BLACK 1TB X2  -  CORSAIR FORCE GT 120GB X2  -  PLEXTOR BLU-RAY BURNER  -  CORSAIR AX1200
ENERMAX FULMO GT  -  WINDOWS 7 ULTIMATE X64
#47
Little Sister
  • Ribbons : 10
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2011/11/25 07:01:44 (permalink)
#48
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2011/11/25 07:14:42 (permalink)
budington
has likely due
you´re crazy..                      But I like it and I want to wish you good luck with this rig!
Exceed yourself!
#49
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2011/11/25 07:39:51 (permalink)
I will try, but the finish line is so far
#50
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/03 19:07:17 (permalink)
Hello everyone. in first I wish you a happy new year ( I know i'm a little bit late )
where to begin?
The machined parts are finished and I have worked a little bit today.
Connecting tube with so little space is a little bit scary, so please keep all your member inside the topic.
The result of this dish of spaghetti is... no one of this tubes are crushed and the door close correctly
so I have connected the CPU loop and GPU1 loop
adding the GPU2 loop
with GPU3 and 4 but not connected for the moment
thank you for watching
post edited by budington - 2012/01/03 19:12:10
#51
1MadGrunt
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/03 20:28:16 (permalink)
Wow, now that's extreme! Looking good budington.
#52
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/04 00:28:32 (permalink)
Looking VERY good!
#53
blood4guts
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/04 07:00:09 (permalink)
This will look very good once the water is running through all of this. Subscribed to the thread
#54
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/04 15:51:32 (permalink)
Hi,
Thanks for comment, yes it is starting looking good.
Today I have put the two 140mm radiators, It’s not on the final position, I have to test if in reverse position I have enough place to put 90° connectors…
With this two, I have six radiators on this case
I have moved the CPU and GPU1 loops.
I have placed the pumps and power supply to show if all fit correctly… and it’s works… but it starts to do a lot of stuff
Thanks for watching
#55
Bruno747
  • Location: Looking on google to see what Nvidia is going to o
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/04 20:23:35 (permalink)
I just hope you are willing to be patient with those reservoirs, the right hand side of each is going to the a PITA to get to de bubble, the return is so close to the intake, and so close to the top that I NEVER could get mine to keep from frothing up, and I even tilted the case backwards, filled it till I couldn't fill no more and STILL had bubbles.
Are those reservoirs revision 1 or 2?
SWEET build tho,
#56
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/05 06:34:34 (permalink)
Thanks
I hope too :D
it's rev. 1.1
post edited by budington - 2012/01/05 12:52:22
#57
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/05 07:06:54 (permalink)
Next time you're going to post pictures, try pics without flash. The pics will be much much better :D
     - your rig deserves great pictures..
#58
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/05 07:42:34 (permalink)
all of the construction picture are make with my cell phone, final picture with better camera
#59
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/05 08:54:13 (permalink)
budington
Sounds great to me :D
#60
