Budington Project 2.0... 6 rads. , 5 pumps, 5 loops, SLI 4Way and many more [work log]
Page: < 12345 > Showing page 3 of 5
Bruno747
  • Location: Looking on google to see what Nvidia is going to o
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/15 12:09:12 (permalink)
The public demands an update lol!
#61
blood4guts
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/15 13:59:22 (permalink)
Hope you're not having too much trouble...
#62
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/15 15:02:26 (permalink)
Hi,
I work on it, I have finished the design of the parts used for attache the reservoirs.
These parts are made from Acetal and CNC and I am very busy
I have added my two 140mm radiators.
I have changed the tubes used for GPU loops It's also Tygon but more rigid (Tygoon 2375)
  thank you to follow the topic
post edited by budington - 2012/01/16 12:49:51
#63
w4ss4b3
  • Ribbons : 21
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/15 16:06:08 (permalink)
God this rig looks sick. I hope one day I can try to put a rig like this together.
#64
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/17 15:27:07 (permalink)
The connectors for one 140 mm is finished.
but when i did work on the second, i made a big mistake and i have broke the fan....
#65
loveha
  • Ribbons : 53
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/17 15:59:58 (permalink)
How many feet of tubing total do you think?
Case: Corsair 900D
GPU: EVGA GTX 1070 FTW DT SLI
PSU: EVGA 1000w G2
#66
nickbaldwin86
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/17 16:09:32 (permalink)
I have never seen this done before, very nice work. cant wait to see more
=EGC=Ripley
#67
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/17 16:09:38 (permalink)
loveha
humm
I don't know, but like 45 feet
post edited by budington - 2012/01/18 05:43:24
#68
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/20 11:43:46 (permalink)
new picture for the 140mm, the connection is a little bit complicate, but it's working fine
I am also working has changed the hard drive carriers
there remains many things to do...but it go to the right direction
#69
DEEBS808
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/22 02:41:32 (permalink)
#70
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/30 19:48:26 (permalink)
HeThing
budington
all of the construction picture are make with my cell phone, final picture with better camera
Sounds great to me :D
One of the measures taken to ensure that the pictures in the future are on the best possible quality ...
Not only for computer pictures, I make a Chroma key chamber
Not finished but on the good way...
#71
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/31 02:13:10 (permalink)
budington
HeThing
budington
AWESOME!
#72
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/31 23:27:53 (permalink)
Here some pictures to show the loops almost finished
And this is a dry carbon plate, made for cable managment and because it's sexy...
#73
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/31 23:48:42 (permalink)
Very good idea with that carbon plate!
#74
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/01/31 23:50:09 (permalink)
thx
#75
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/01 05:36:27 (permalink)
Do you plan on modding those SSDs?
Black paint maybe?
#76
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/01 08:43:00 (permalink)
only if I find a reversible solution, It's two Intel 510 120Gb still under warranty
#77
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/01 11:37:43 (permalink)
budington
YGPM
#78
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/01 13:27:31 (permalink)
I have more or minus the same idea. Thank
#79
kerrgreg
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 03:11:29 (permalink)
Looking great! although wont all those 90deg fittings kill your water flow rate? Please correct me if I'm wrong or your solution Im reasonably new to water cooling.
#80
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 03:19:44 (permalink)
Hi Kerrgreg,
You are right, but the loops are simple with only one waterblock per loop ans using an overkill pump... so I dont think it will be a problem
#81
Gold Leader
  • Ribbons : 44
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 07:56:28 (permalink)
Very very cool setup this one!
The reason why I love it so much is because that it has four EVGA GeForce GTX 480's in it, also seems that two of your cards have no backplates, but for that I found you a solution, so I PM'ed you that
As for this picture:
As that layout goes, understandable about the layout since you told me via PM that the cards and the system will be setup upright hehe, are you using a  BTX based case due to this, since I have seen similar setups with upright placed setups, as weight dividing goes this would be  a better layout right?
As for the cards missing the EVGA logo's you could mail EVGA about this, they might send you the logo's you are missing, just an idea mate
post edited by Gold Leader - 2012/02/02 08:22:02
#82
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 08:21:25 (permalink)
Thanks,
The order of the cards on the picture as you are showed, is not representative of final setup.
on this four cards I have two green and two orange, I have decided to make G/O/G/O or O/G/O/G ....
You must also take into account that the motherboard is mounted in reverse ATX, so the backplate is not visible
#83
Gold Leader
  • Ribbons : 44
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 08:24:25 (permalink)
budington
Thanks,
Yeah I see what ya mean like how the BTX setups were made, makes me wonder what happened to BTX, didn't it become that much of a success? heh makes me wonder, unless that is BTX a reversed version of ATX
#84
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 08:34:48 (permalink)
humm Reverse ATX and BTX is no comparable ..
BTX is an layout totaly diferent
Reverse ATX is ATX with the motherboard upside down
#85
Gold Leader
  • Ribbons : 44
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/02 09:24:42 (permalink)
budington
Oh yeah that's right yeah thanks for pointing that out man
As for your setup that's a beefy 1920 CUDA Cores you got there, very nice man also a neat advantage of the GTX 480 is that they have GPGPU Precision point support something the 500 series lack, this can be very useful with your GPGPU workloads you plan to use these for hehe, Folding @ Home for example, I dunno if Folding @Home has GPGPU precison Point support, if so 480's would render more than a 580 heh, per CUDA Core per Mhz.
It would of been nice if the GTX 480 was made with 512 CUDA cores and 3GB of ram, that would of been a perfect scenario heh. I still have my GTX 480, it's a legendary GeForce actually, as GeForce history goes
post edited by Gold Leader - 2012/02/02 09:37:32
#86
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 01:44:40 (permalink)
I will try use DI-Noc 3M Vinyl film
HeThing
Black paint maybe?
#87
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 05:25:29 (permalink)
it's just a test to see how it looks with the DI-Noc Vinyl
what do you think?
Before...
After...
post edited by budington - 2012/02/03 05:29:32
#88
HeThing
  • Ribbons : 42
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 05:47:58 (permalink)
It looks much better, but why not cover the entire SSD?
#89
budington
  • Ribbons : 7
Re:Budington Project 2.0... 4x 480mm, 2x 140mm 5 pumps, 5 loops, SLI 4Way 2012/02/03 05:55:19 (permalink)
it's just for test purpose only
#90
