Budington Project 1.0 [Finished] 3Way SLI, 3 Radiators, 11 Hard drive
Page: 12345.. > >> Showing page 1 of 6
budington
  • Ribbons : 7
2010/02/18 13:22:05 (permalink)
Hi
voila this is my youngest -> Page 5 for final pics
a little computer for work @ home
Asus P6T7 Supercomputer
Intel I7 965 EE @ 4Ghz -> Intel I7 980X @ stock (for the moment)
Corsair Dominator GT 1866 7-8-7-20 @ 1.65v 6x2Go
EVGA GTX 285 SSC 2Go x 2  -> 3x GTX 480 FTW HC
Adaptec 5805 -> Adaptec 51245
7x Western Caviar Black 640Go 32Mo (6x Raid 50 + 1 hot spare) + 4x OCZ Vertex 2 50Go
Corsair HX 1000 -> Enermax Revolution 85+ 1250W
Lian Li PC-A7110B
Watercooling:
CPU: Apogee GTZ
GPU: EK Waterblock Proto 285 REV 2.0 x2 -> 3x 480 HC
Laing DCC x2
Swiftec MCR320-QP STACK x2
XSPC Dual Laing
3x Scyte 3000RPM -> 3x noctua NF-12 + 6 Scyte 12mm
Masterkleer 13/19 blanc
Innovatek Fan-o-Matik Pro + 2 fan o matik mico
3Dmark Vantage @ full stock 26805
More photos on post #30
I hope you like, all comments is very appreciated
Thx Cédric
P.s sorry for my bad english
post edited by budington - 2011/05/18 16:18:50
160 Replies Related Threads
    ug0tserved
    Re:Lian-Li PC-A7110B 2010/02/18 13:31:26 (permalink)
    Damn..... Nice RIG... are you getting good circulation on those Graphics cards?
    i7 960 Overclocked to 4.2Ghz
    EVGA 3 way SLI Classified
    Hyper X Kingston 6GB 2000
    GTX 295 Dual PCB FTW with Backplate
    GTX 275 with Backplate for PhysX
    Killer 2100 Gaming Network Card
    120GB OCZ Solid State Disk Colossus Series
    2TB Samsung Spinpoint F1 in RAID 0
    Corsair HX1000 PSU
    Mountain Mods Extended Ascension Case
    Alienware M17x-R1 Nebula Red Intel Core 2 Duo T9600 @ 2.8ghz 6GB DDR3 1333 2x Intel X25-V SSD 40GB in RAID0 Dual Nvidia GTX 280M's in SLI
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/18 13:58:12 (permalink)
    no problem with ventilation at minimum(1x120cm @5v) = 50 ° for each card
    with the ventilation in mode games (3x120cm @ 7v) = 38 ° for each card
    with the ventilation in mode O/c (3x120cm @ 12v) = 42° for each card (OCCT)
    the two cards that share a 360 radiator and the CPU to the other 360 radiator
    post edited by budington - 2010/02/24 14:03:24
    ug0tserved
    Re:Lian-Li PC-A7110B 2010/02/18 15:05:35 (permalink)
    oh ok cuz i thought that on the praphics card its not circulating good cuz of the way it been loop
    Corsair HX1000 PSU
    SnowmAnnn
    Re:Lian-Li PC-A7110B 2010/02/18 15:21:05 (permalink)
    WOw i havent seen that kinda GPUs Wc block setting in long time i love it great jop.
    post edited by SnowmAnnn - 2010/02/18 15:24:02
    -Case: Corsair 800D
    -Mobo: Evga Classified E670
    -CPU: intel core i7 920 D0
    -Cooler: Corsair H50
    -Ram: 6GB Corsair 8-8-8-24 1600mhz
    -GPU: 2 x Evga GTX285 with backplates
    -Psu: Corsair Hx1000 w
    -HDD: WD caviar black 500GB
    -Monitor: Asus 26" VW266H
    -OS: Win 7 64bit
    -May God Have Mercy Upon My Enemies, Because I Won't-
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/18 15:21:55 (permalink)
    This is two independent circuit
    The first one for the CPU :   DCC - GTZ - 360 - DCC
    The second one for the two GPU: DCC - GPU1 // GPU2 -360 - DCC
    post edited by budington - 2010/02/24 14:05:09
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/18 15:28:59 (permalink)
    SnowmAnnn
    Thx
    The reason is quite simple in fact, the raid card is between the two cars
    post edited by budington - 2010/02/24 14:05:22
    dlb134
    Re:Lian-Li PC-A7110B 2010/02/18 18:56:42 (permalink)
    Amazing.
    MCS1181
    Re:Lian-Li PC-A7110B 2010/02/18 19:03:17 (permalink)
    Pretty sweet looking rig man, nice work. Interesting use of radiator space there, getting two rads for two loops in a spot where most people just put one. I wouldn't have thought of that.
    That is a whole lot of hard disk space you have there, what do you plan on doing with this rig?
    i7 965 // R2E // EVGA 295s // Dominator GT // Obsidian 800D
    baldee
    Re:Lian-Li PC-A7110B 2010/02/19 02:27:24 (permalink)
    HDD city!!! Nice work there.....
    sims36
    Re:Lian-Li PC-A7110B 2010/02/19 02:54:46 (permalink)
    thats a nice system you have there bud, i bet the raid card set you back a bit!
    NEW MADNESS IN THE WORKS......STAY TUNED!!
    HEATWARE: sims36
    Bkatt
    • Ribbons : 38
    Re:Lian-Li PC-A7110B 2010/02/19 03:39:24 (permalink)
    Wow nice raid!!
    EVGA X58 (758)RV-1|1000W PSU|920 C0 @ 3.724 (19x196) 1.32V 200+VTT (HT on)|4GB EVGA 950 |5 250GB (raid 5)|windows 7 pro) & 1 1.5 TB|3 24" 1920x1200                          Code :X7G0Z0AY5U   CompTIA A+, Security +
    Jedi-Ritter
    Re:Lian-Li PC-A7110B 2010/02/19 03:53:53 (permalink)
    In picture 3 is this a PCI-E raid card? Which one is it and has it benefits over the mainboard raid controller? I can't see it installed on your MB?
    DD Waterbox
    Gigabyte Z68 UD7 B3
    i7 2600k
    2xGTX580
    1x SSD OCZ Vertex 3 120 (OS)
    1x SSD OCZ Vertex 2 60
    1x WD Caviar Green 2TB
    SnowmAnnn
    Re:Lian-Li PC-A7110B 2010/02/19 05:29:26 (permalink)
    Why is that back 120mm fan outside on the case?
    -Case: Corsair 800D
    -OS: Win 7 64bit
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 06:15:37 (permalink)
    Jedi-Ritter
    Yes is a PCI-E 8x  Adaptec 5805 Unified Raid Card (SAS/SATA) dual core 1.2Ghz 512Mb
    there are several benefits, many more band pass management mode type raid raid 50 / raid 60
    the card is on PCI-E N° 3 between the two GTX
    post edited by budington - 2010/02/24 14:05:38
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 06:18:08 (permalink)
    SnowmAnnn
    to save space ;)
    post edited by budington - 2010/02/24 14:05:50
    SnowmAnnn
    Re:Lian-Li PC-A7110B 2010/02/19 07:49:34 (permalink)
    How was it to install thouse EK full blocks and did the backplates fit there and line up just fine?
    Edit:fixed
    post edited by SnowmAnnn - 2010/02/19 10:58:39
    -Case: Corsair 800D
    -OS: Win 7 64bit
    josediaz
    Re:Lian-Li PC-A7110B 2010/02/19 08:39:28 (permalink)
    Wow just Beautiful!! Great build!!
    HEATWARE
    CPU: i7-920 (D0) @ 3.33 MOBO: X58 (758)
    GPU:2 x EVGA GTX 580 RAM: 3x2 DDR3 1333 Mushkin
    CASE:Corsiar 800D  PSU: Corsiar HX1000
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 10:54:15 (permalink)
    SnowmAnnn
    How was it to isntal thouse EK full blocks and ( i allso got back plates) did back fit there and line up just fine?
    Sorry but I do not understand what you trying to say
    post edited by budington - 2010/02/24 14:06:03
    SnowmAnnn
    Re:Lian-Li PC-A7110B 2010/02/19 10:59:28 (permalink)
    im trying to ask was it hard to install waterblocks
    -Case: Corsair 800D
    -OS: Win 7 64bit
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 11:13:44 (permalink)
    No absolutely not, we must be methodical and take the time to do its good
    post edited by budington - 2010/02/24 14:06:15
    ug0tserved
    Re:Lian-Li PC-A7110B 2010/02/19 15:08:15 (permalink)
    budington
    How did you manage to put put that fan on the RAD with screw on that lil space? cuz im about to water my system and i need to do the same but i tied and i cant seem to put it on that lil space? lil help?
    Corsair HX1000 PSU
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 15:49:09 (permalink)
    the Swiftec MCR320-QP-Stack allows 2 or more radiator to be stacked  en fact the radiator comes with  snap-rivets
    post edited by budington - 2010/02/24 14:06:29
    #23
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 16:40:07 (permalink)
    I just made a small test of optimization has the key with a little better in 3D Mark (28030) still a lot of work on the side software to improve all its
    post edited by budington - 2010/02/24 14:06:42
    #24
    wmmills
    • Ribbons : 18
    Re:Lian-Li PC-A7110B 2010/02/19 16:51:29 (permalink)
    is that a removeable shroud around the psu or part of the case?? if removeable, did u buy that seperately or did it come with it?? anyway, nice case and nice job man!!! lookin forward to more pics!!! you cant not like a Lian-Li case..... \m/
    MOBO: EVGA P67 FTW, CPU: I5 2500K, RAM: Gskill PI 1600 CAS 6, SSD: Samsung 830 128gb, HDD: WD Caviar Black 750gb, PSU: CoolerMaster V-1000, CPU HSF: EVGA ScC HSF~ P/P 88CFM Yate Loons, G-CARD:EVGA GTX780, CASE: LIAN-LI PC-V2010B, OS: Windows 7 Ultimate 64bit, MON: AOC i2367F, HdSet: steelseries Siberia
    NEVER CONFUSE EDUCATION WITH INTELLIGENCE!
    #25
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/19 17:09:21 (permalink)
    it is an original part from Lian-li
    post edited by budington - 2010/02/24 14:06:54
    #26
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/20 17:41:26 (permalink)
    post edited by budington - 2010/02/24 14:07:13
    #27
    sinsear
    Re:Lian-Li PC-A7110B 2010/02/20 19:57:37 (permalink)
    budington
    Jedi-Ritter
    Adaptec 5805
    How would you compare your raid card to something like Areca or 3ware? I'm in the market for an 8 port PCI-E X8 RAID card, and I'm not very familiar with the brands.
    Main Rig:
    Intel i7 920 [C0] @ 3.82Ghz | EVGA X58 [759] Classified (64) | MM Extended Ascension w/ Pedestal | Corsair HX1050
    24GB Patriot Viper II ‘Sector 7’ 2000mhz (9-11-9-27) @ 1.65v | 2x EVGA GTX480 (875/2000 @1.1v) | CPU, GPUs and Mobo on H2O
    Dedicated Folding Rig: ~In Progress~
    Intel i7 3770K | EVGA Panther Point Mobo | Corsair AX650 | 8GB Corsair Vengeance 2000mhz (10-10-10-27) @ 1.5v
    #28
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/21 03:44:52 (permalink)
    I find it hard to answer, not having had the opportunity to test this equipment in my terms of use. After the standpoint of reputation Areca products are quite correct but I would not compare the two brands.
    post edited by budington - 2010/02/24 14:07:26
    #29
    budington
    • Ribbons : 7
    Re:Lian-Li PC-A7110B 2010/02/21 11:49:58 (permalink)
    Here are some new photos
    The front face is not yet finished, I must make one support to prevent the reservoir move
    post edited by budington - 2010/05/06 04:32:15
    #30
