Budington Project 1.0 [Finished] 3Way SLI, 3 Radiators, 11 Hard drive
Page: << < ..6 Showing page 6 of 6
corpsmaker
Re:Lian-Li PC-A7110B 2011/01/29 17:39:27 (permalink)
Yea you did a really good job. Lot of time and money on that sweet build but it is really remarkable how clean it came out.
CorpsMaker
CM 932 HAF / Asus P6T6 Revolution WS / i7 975 / CM V8 / 3 x 2GB G.Skill PC3 16000 2KMhz 8-8-8-8-21 1T B/LED Fan / 2 EVGA 285 FTW 1Gb SSC W/Bkplate in SLI / Zalman-MFC1+ Fan Ctrl / CM RPP 1250W PSU / 2 VelociRaptor WD3HLFS-10K Raid 0 / 1 Caviar Blk WD1001FALS-1TB, 7200, 32MB / Pioneer BDR-203 Blu-Ray 8X RW / 13-1 Flash Rdr / Samsung SH-S223B/BEBE 22X SATA DVD+/-RW / MS SideWinder X6 KYB Bklit / Win7 Ult 64Bit / Cath's (R,B) / Dell SP2309P 23" 2ms 80K Dyn,2.0 WC, 5 USB, 2048X1152
A change in personality is when your computer is not working.
OT6889
Re:Lian-Li PC-A7110B 2011/02/21 04:58:59 (permalink)
A truly outstanding build sir!
Very tidy and well thought out.
about to try clean up my wc setup.
May well try your way of doing it.
The logic is there but will in work on a single loop
EVGA Z170 Classified - i7 6700k @ 4.6hz WC -EVGA Z170 Classified - 32GB Corsair Dominator Platinum - Samsung M2 950 - Samsung 850 SSD -  EVGA GTX980 Ti Kingpin Sli - Corsair Axi1500 - Rog Swift 165Hz - Lian Li PC08 - Hyper Cloud 2 HP
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/02/21 16:09:16 (permalink)
Thank
the problem with a single loop is very simple. you have a lot of calorie  has dissipate and you have only two solution for this problem
the first one and the most easy is a very hight level of ventilation..
the second one is a very large superficy for your radiator...
so in any case the problem is the space available inside the case.
On the Obsidian you have space but it' is not easy to put two radiator on the top, you need two very thin radiator ok use stackable radiator like the swiftecs
OT6889
Re:Lian-Li PC-A7110B 2011/02/22 02:41:45 (permalink)
Thanks for you r come back on my message.
Running 6 fans on my 360 Rad in the roof of my 800D.
Runs my CPU (4.2) and 2x GPU overclocked at about 50 when full out benchmarking & gaming.
Thinking of changing to a better 360 radiator - xspc rs360 at the moment.
or maybe adding an extra loop for cpu  or another 120/240 Rad between the cpu/gpu on back fan area of case
thanks again for your comments
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/02/22 03:18:43 (permalink)
the Black ICE SR1 is maybe one good choice, it is very massive construction, but working very nicely with low ventilation.
I have mounted one of them the last week in a 800D with three scythe SFF21E  (49CFM) fith 980X and 580 FTW @ 100% load for CPU/GPU temp not exceed 45° and is totaly quiet
my three 480 mounted on a single loops with two 360 @ 100% load work @ 55° (8v fans) but is not quiet
farthestkris
  • Location: Crunching Location .......... Location Not Found
  • Ribbons : 12
Re:Lian-Li PC-A7110B 2011/02/22 03:24:54 (permalink)
god damn, sick build man
SandersAce
Re:Lian-Li PC-A7110B 2011/02/22 03:29:15 (permalink)
Vere un-standard watercooling :)
It's nice to see someone who is trying a fairly unused tubing route.
Very nice build !
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/03/29 14:33:15 (permalink)
Hi everyone....
I have to tell one thing....
It is time to upgrade this rig....
I love build so, I will increase the dificulty...
The plane is : "supermassive Wcooling"
I have to try to increase by 200% my cooling power output.... and like all the time since my first build, full integrated...
More info soon
lewis907
Re:Lian-Li PC-A7110B 2011/03/29 14:41:54 (permalink)
Wow very nice....
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/04/05 14:13:58 (permalink)
Okay so... The plan is on his way
4 pumps, 4 radiators, 4 loops and more of 16 fans
two only words... Quiet Performance
All integrated inside a "big Tower"
Start of the project. in 40 days
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/05/18 16:16:25 (permalink)
Hi guys.
The Budington Project 2.0 is Started and can be found here
Thank you for your support and your Help on this project
This is the end of the Budington Project 1.0
