Budington Project 1.0 [Finished] 3Way SLI, 3 Radiators, 11 Hard drive
Page: < 12345.. > >> Showing page 4 of 6
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/05/26 13:07:54 (permalink)
So, all the part of my upgrade are on the way
Three 480HC are in the hand of UPS
The power supply are leaving Germany tonight
Some electronics parts arrive Friday.
One bad news is arrived today from the factory, some pannel are using steel threads ... steel will be disolved by the anodic bath...
Only 100% aluminum parts will be treated,
parts can not be treated I will be back and I would find another solution
#91
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/05/27 03:47:11 (permalink)
#92
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/05/27 09:39:20 (permalink)
#93
Phoenixx45
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/05/27 16:48:50 (permalink)
Amazing dude, those 480 should perform incredibly!
White Widow - NZXT 810
Processor: Intel Core i7 2700 @ ?
Memory: 8GB Corsair Dominator GT
Hard Drive(s): 1. 2x 120Gb Vertex 2 SSD 2. Raptor 70GB   3. Raptor 300GB   4. Western Digital 1TB
Video Card: 3x EVGA GTX 480 w/ Back Plate & HF Bracket in SLI
Sound Card: X-Fi Titanium Fatal1ty Champion Series
Motherboard: EVGA z68 FTW
#94
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/05/28 15:13:48 (permalink)
so following history
OCZ Vertex 2 50Go and these three brothers
Innovatek Fan-O-Matic PRO an two Fan-O-Matic MICRO
#95
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/06/01 15:34:33 (permalink)
1250W
#96
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/06/09 10:37:39 (permalink)
I'm leaving for vacation at the end of the month, so the project are not progressing but this part of the case are ready for the next step
#97
xTemon
Re:Lian-Li PC-A7110B 2010/06/09 16:09:54 (permalink)
That's a sweet finish on the anodized parts! ...ceramic sand-blasted
Very nice rig and build; can't wait to see it when it's put back together
#98
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/06/14 13:19:22 (permalink)
Some new picture from cable sleeving
#99
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/07/14 02:22:01 (permalink)
So.....
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/07/21 08:02:11 (permalink)
so I am working on the case, removing the gray rivet and using black rivet (thx MDPC)
so normaly one week for finish the work.
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/07/22 04:25:27 (permalink)
here are the new power connector for the hot swap plate (#42 )
and the case with the hard drive bay in place
post edited by budington - 2010/07/22 06:02:57
jpeg387
Re:Lian-Li PC-A7110B 2010/07/22 11:49:28 (permalink)
budington
simply for one question of performance.
Raid 50 = 6 HDD min. 7= Raid 50 + Hot spare
2.3To of capacity 1.2Gb/s read 850Mo/s write
Very nice and very clean build, at least for as long as you can leave it in one piece
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/07/22 14:14:50 (permalink)
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/07/25 07:00:12 (permalink)
Following assembly....
4x SSD OCZ Vertex 2
Additional switch for lighting
Fan monitoring
Filter and fan for Hard drive
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/02 14:41:16 (permalink)
Hi....
Well....
I had to make some changes because there have sometimes bad idea...
My bad idea is putting the SSD on the two first 5.25" bay
why ? just a problem of space... when the radiators are in place.... I dont have place for the SSD
the solution is... find a new place for the ssd but first is find a fixation system...  more info about this topic when the pieces are here
In another topic I have just finished building a computer for one friend, (twelve hundred, 3x 480SC, 3 SSD, I7 980X etc.) and these 480 are very very hot ~90° in full load...
So I have looked what is the most easy way for expand my cooling capacity...
I have two 360 in place and this 360 are stackable... It is a non sens using a 360 just for a overclocked I7...
So my little solution is... adding a single 120mm radiator and modifing the CPU loop
so the GPU loops use the two 360 in // and the cpu the second loop only for him with the new 120mm.
I'm still working on the cable managment ( this is a very long work)...
So I have not yet finish with this project...
Thank you for supporting this project.
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/04 06:46:50 (permalink)
New plate for SSD.
Phoenixx45
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/04 16:41:39 (permalink)
Looking good dude... subscribed!
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/10 14:26:02 (permalink)
Hi.
I add some pictures.
Swiftech Apogee XT for the CPU .
The motherboard tray are from one A77, my tray it's not yet finished.
Black Blu-ray burner
build the cabling the computer is an big works... and I dont have finished
Halo_003
  • Ribbons : 50
Re:Lian-Li PC-A7110B 2010/08/10 15:23:31 (permalink)
Looks great I can't wait to see the end!
Ultimatum01
Re:Lian-Li PC-A7110B 2010/08/10 15:38:37 (permalink)
Really nice man. I want to see more. Are you planning on Oc'ing much?  So let me get this right.....2*360's for the 480's and a single 120 for the cpu?
post edited by Ultimatum01 - 2010/08/10 15:41:21
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/10 16:21:45 (permalink)
normal OC on this CPU is 4.1Ghz but max usable OC is 4.8ghz
and yes one loop for the Three 480 using two 360's and the cpu loop with a dedicated 120
seabigbear
The Polar Rig Master
  • Ribbons : 61
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/10 23:40:05 (permalink)
budington
  • Ribbons : 7
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/11 06:59:04 (permalink)
EVIIILJ
  • Ribbons : 15
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/11 11:06:09 (permalink)
Really nice build, quality of parts, details of build, and looks are top notch. I'm in love with the finish of your case. How much did it cost you to do the ceramic finish and where would you get it done (if you didn't do it yourself)?
Again, nice Job and keep the pics coming :)
-EVIIILJ
budington
  • Ribbons : 7
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/11 13:12:07 (permalink)
Hi thx for your comment, it is get on a Swiss factory, working for aerospace, I have some contact and they make me a favor.
I dont have the real price but it is very expensive, more of market value of my case .
budington
  • Ribbons : 7
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/12 04:47:52 (permalink)
First test with the 2nd loop
clic on itch picture for HD
  • Ribbons : 52
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/12 10:32:28 (permalink)
This build keeps looking better and better
budington
  • Ribbons : 7
Re:[Work in progress] Lian Li 7110, 3xSLI, Dual loops, Dual Pumps, Dual rads, Raid 2010/08/18 04:47:08 (permalink)
So the seven caviar black are in place
painting the 480 bracket in black
clic on the picture for view HD
post edited by budington - 2010/08/18 06:06:18
laserscottman
Re:Lian-Li PC-A7110B 2010/08/18 06:00:07 (permalink)
Very nice work.  Fun!
Mobo: EVGA nForce 790i FTW (132-YW-E179-A1)
Proc: Intel E8500, Core 2 Duo, 3.16GHz, 45nm, 65w., Socket 775
Video: EVGA GTX 260SSC, 896Mb DDR3, Core 216
Ram: Corsair 4GB (2x2048) XMS3, DHX, DDR3, 1333MHz. 9-9-9-24; 1.70v. ver 3.1
PSU: Antec TPQ-1000, Modular (1000w.)
HDD: Seagate Barracuda SATA, 7200rpm/32MbCache, 1.5 TB, 6 partitions; Another 1TB Seagate, 160GB IDE
O.S.:Currently Win7 Ultimate32bit, also Win XP Pro Ver. 2002, SP3 (5.1 Build2600)
Case: Antec P182
