Re:Lian-Li PC-A7110B
2010/04/29 00:07:24
simply for one question of performance. Raid 50 = 6 HDD min. 7= Raid 50 + Hot spare 2.3To of capacity 1.2Gb/s read 850Mo/s write
2010/04/29 13:05:28
Excellent job, very, very clean build, and I really like that case lian-li makes good stuff.
2010/04/30 14:58:24
So, my cards are in Germany ... I therefore took the opportunity to clean the computer. There was also a slight change, New PSU (Revolution 85+ 1250W) New cable managment, minor change in the fan setup. New hole in the motherboard tray for help the cable managment New tubing managment, fix minor probleme on the watercooling reservoir. more info soon
post edited by budington - 2010/05/02 03:57:32
2010/05/02 11:59:32
First step: dismantling the tower :D Tomorrow I remove rivets I have changed the fan on the watercooling radiator for 3 noctua After a quick clean-up going to a small surface treatment
rachet45
2010/05/02 12:10:51
why not go for some schythe ultra kaze's?
LOLCODE: adapting cats to programming at the speed of light! o hai i haz a displayHi { say("it beez caturday!") } k thx bye My rig: core i7 920 @4.0ghz (water cooled) evga 3x sli mobo (vregs and nb/swater cooled) corsair dominator 1600mhz patriot warp 64 gb ssd wd caviar black 1tb hard drive gtx 285 vcard ht omega striker 7.1 audio card
2010/05/02 12:24:07
because that is what I had
pwnzorz
2010/05/02 16:30:31
i'm still confused how that looping in the video cards work, is it viable to do on 1/2 ID tubing? with koolance blocks for a 5970 and 5870, i like how clean it looks. the pump isn't too powerful however 22 PSI about 500ish LPH
Evga E760 Classified 920 D0 @ 4.4ghz 6GB Mushkin Redline 2000mhz Radeon 5970 @ 950/1250 Radeon 5870 @ 950/1250 Dell 27inch U2771 Dell 30inch 3007 Koolance Exos 2.5 Intel X-25M G2 80GB SSD 300GB Western Digital Veliocraptor 750GB Western Digital Caviar
pwnzorz
2010/05/03 00:23:22
anyone input on how that would work?
2010/05/03 03:07:17
pwnzorz i'm still confused how that looping in the video cards work, is it viable to do on 1/2 ID tubing? with koolance blocks for a 5970 and 5870, i like how clean it looks. the pump isn't too powerful however 22 PSI about 500ish LPH My loops are in 1/2" and I use a Laing DCC-1T normaly it's work with any waterblock
2010/05/03 03:11:47
pwnzorz anyone input on how that would work? more info on this post #36
corpsmaker
2010/05/03 10:14:50
Yea I don't get how that video cooling is working very well. Anyone? CorpsMaker
CM 932 HAF / Asus P6T6 Revolution WS / i7 975 / CM V8 / 3 x 2GB G.Skill PC3 16000 2KMhz 8-8-8-8-21 1T B/LED Fan / 2 EVGA 285 FTW 1Gb SSC W/Bkplate in SLI / Zalman-MFC1+ Fan Ctrl / CM RPP 1250W PSU / 2 VelociRaptor WD3HLFS-10K Raid 0 / 1 Caviar Blk WD1001FALS-1TB, 7200, 32MB / Pioneer BDR-203 Blu-Ray 8X RW / 13-1 Flash Rdr / Samsung SH-S223B/BEBE 22X SATA DVD+/-RW / MS SideWinder X6 KYB Bklit / Win7 Ult 64Bit / Cath's (R,B) / Dell SP2309P 23" 2ms 80K Dyn,2.0 WC, 5 USB, 2048X1152 A change in personality is when your computer is not working.
[HazMatt]
- Ribbons : 9
2010/05/03 11:27:33
budington, Great system! I have awarded your pictures on the first page with a Blue Ribbon.
2010/05/03 11:41:21
2010/05/04 06:50:11
So This is the first stage
2010/05/04 13:46:10
The idea to make cleaning easier .... made in making the alloy less sensitive to stain, scratches and fingerprints ect. and well understood how his'm cool implemented in the coming days: Ceramic sandblasting, degreasing and Pralox® bath are scheduled in two-step, all tower parts first and a second time the motherboard tray that needs to go see a high pressure cutter for a little corrections of Cable Management
2010/05/05 09:09:56
EVGA have sended today two GTX 295
dlb134
2010/05/06 15:20:15
budington EVGA have sended today two GTX 295 And that is bad because? Oh waterblocks, well on the brightside that should be like having 3.x 285's.
2010/05/06 15:38:40
Wow this is a super nice build! I'm debating wether or not to watercool and this has got me thinking!
Current System i7 860 EVGA SLI FTW EVGA GTX 980 SC ACX Watercooled (EK HF, RX360, XSPC bay reservoir and pump)
2010/05/06 16:41:52
 Plain n' simple! <3
White Widow - NZXT 810 Processor: Intel Core i7 2700 @ ? Memory: 8GB Corsair Dominator GT Hard Drive(s): 1. 2x 120Gb Vertex 2 SSD 2. Raptor 70GB 3. Raptor 300GB 4. Western Digital 1TB Video Card: 3x EVGA GTX 480 w/ Back Plate & HF Bracket in SLI Sound Card: X-Fi Titanium Fatal1ty Champion Series Motherboard: EVGA z68 FTW
2010/05/07 15:07:43
when are the 480 FTW will be available?
hot_mic_64d
2010/05/07 15:46:02
How does your card cooling loop work? Doesnt seem like the pressure would want to flow through both evenly. Do both cards run the same temp. Just seems like one of the cards would receive a lot less flow. Nice rig though. Those are some sick reads and writes with that RAID setup. I like!
The "Red Queen" Corsair 900D Corsair 1200i ASUS Rampage Black Edition 32GB Corsair Vengance 1866 9-10-9-27 i7-34930 4.4 w/HT on @ 1.35 2x Samsung EVO 250G's in raid 0 2 X WD 2TB 2 X WD 1TB GTX 780 TI Classified Hydro Copper at stock clock until somebody fixes the Bios and drivers Single loop custom acrylic tubing water cooling
2010/05/08 11:01:50
it's very simple in fact. waterblock are the same so the pressure drop of each WB are the same. the pressure drop is the key on a parallel loops. if you put a Y and two meter of tube and another Y, water is moving at the same speed on each tube why ? because de pressure drop are the same
remenaker
2010/05/08 11:39:02
The parallel loops on the koolance systems work the same way and work go to. Nice work on the system what are you going to do keep the 295's or get new water blocks. Keep up the good work looks great.
2010/05/08 12:24:03
I dont want to use the 295 therefore, they are on sale. I want use a SLI of 480 + one 470 for Physx using FTW cards, no more problem for warranty
post edited by budington - 2010/05/08 13:14:07
2010/05/12 12:09:50
For those trying to understand how work my loop's this is flow modeling courtesy of EKwaterblock
post edited by budington - 2010/05/12 12:33:35
2010/05/14 12:40:10
Thx to Knud and Gregor (EVGA Netherlands Office) for the big help. So normaly my upgrade should be more or minus like this it's what does not change: Asus P6T7 WS Supercomputer Intel I7 965 EE Corsair Dominator GT 1866 7-8-7-20 @ 1.65v 6x2Go Adaptec 5805 7x Western Caviar Black 640Go 32Mo (6x Raid 50 + 1 hot spare) LG GGW-H20L and what changes 1x Lian Li PC-7110 Budington edition 1x Enermax Revolution 85+ 1250W 3x EVGA GTX 480 FTW 4x OCZ’s Vertex 2 50Gb 5x Papst 4412F/2GL 3x Noctua NF-P12 1x Papst 8412 N/2GLE 2x Innovatek Fan-O-Matic Micro New Bitspower Fitting for the two Loop's New ventilation system for my raid card estimate of the end of construction ~ before the end of June would be well........ after I'm in Spain
post edited by budington - 2010/05/15 16:15:04
2010/05/18 07:52:07
so my new Fittings are here Black PVD PCI Cover Plate case ready to sent on factory
mcarey6
2010/05/18 08:13:40
I love this build it's super clean looking. The Lian-Li cases have such a clean look to them. Where are you sending the case to have work done on it? I was thinking about stripping my HAF down and having it sent somewhere to be blasted and powder coated.
Matt "Barry" Carey Hardware: Asus Maximus V Formula Intel 3770k 32gb Corsair Vengeance Pro 1866 EVGA GTX 780ti Classy Corsair RM1000 PSU Samsung Evo 512gb Fractal Design Arc Midi R2
2010/05/18 09:04:02
I send my case to a specialist in Switzerland, but it's not powed coated it's anodized... ;)
2010/05/19 07:58:06
a small can of cleaning ... 2 years after he needed it
