Budington Project 1.0 [Finished] 3Way SLI, 3 Radiators, 11 Hard drive
Page: < 12345.. > >> Showing page 5 of 6
totallyunr3al
Re:Lian-Li PC-A7110B 2010/08/19 05:49:13 (permalink)
Awesome, very sinister looking.
Rig #1
Core i7 980x
EVGA x58 Classified 4 Way SLI
Corsair Dominator 6gb 1600Mhz
EVGA GTX 480 4 way SLI
Silverstone Strider 1500watt PSU
HAF X
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/24 05:21:35 (permalink)
The third Rad. in place with 2 slim 120mm (12mm) all tube in place
dozer3000
Re:Lian-Li PC-A7110B 2010/08/24 05:34:32 (permalink)
Uhaa.. an extreme system. :)
Nice !!!
EVGA X79 DARK | 4930K | 16GB DDR3 Dominator Platinum 2400
EVGA GTX 780Ti Classified HC | Creative ZxR | Corsair AX850W
Silverstone TJ07 murderMod | Samsung EVOs | 4TB HDD
Heatkiller 3.0 | Swiftech MCP35x
 | Watercool MoRa 3
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/08/30 10:42:58 (permalink)
Power supply sleeving
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/09/02 04:26:24 (permalink)
the fixed cables are done
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/09/07 13:33:45 (permalink)
So to make an inventory of what remains to do ...
finish wiring.
mounting the new backplate for the 480's.
Wcooling test (24h).
many little things
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/09/14 14:33:16 (permalink)
sleeving... sleeving and sleeving
Backplate for 480... but  necessarily it does not work on the FTW, I have to drill more bigger for put long screw
z3r0t0l0rence
  • Ribbons : 20
Re:Lian-Li PC-A7110B 2010/09/14 22:09:02 (permalink)
Very nice build!  Inspirational...is the only word I could think of!
i7 930 OC 4.21
EVGA E758
GSkill 12GB
Evga GTX 780 SC
2x Kingston 240 Raid 0
2x Seagate 4TB
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/11/29 13:41:10 (permalink)
Hi, sorry for not have given new about that, but I have bin very very busy with opening my own compagny.
The computer is finich from some time yet, and is working fine ,
~ 50K @ Vantage @ stock GPU / 4Ghz CPU
I'll try put some new pictures near the end of this week
Thank you very much for your support during this long term project
Johnny-1987
Re:Lian-Li PC-A7110B 2010/11/30 00:26:40 (permalink)
awesome mate, lovin the backplate!
Core i7-975 / 3x2GB 1866mhz Dominator Gt's / EX58-UD3R /
SLI GTX 295 Co-ops / 2x 128gb SSD's / Corsair HX-1000W /
Heatkiller Water Block
7/16 Primochill U/V Tubing
360GTX Black ice rad/ PA 120.3
D5-Vario Pump
 EK-Multioption 250 Rev Reservoir
Primochill Non-Conductive Coolant
1/2 DD fatboy Fittings
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/02 12:18:59 (permalink)
So sorry for the bad quality of that pictures, when I have a little bit of free time, I make more picture
boredgunner
Over 9000!
  • Ribbons : 78
Re:Lian-Li PC-A7110B 2010/12/02 12:49:26 (permalink)
Damn that's incredible.  I need to pick up a Lian-Li case myself but I won't have that much awesomeness going on inside of it.
dyson1936
Re:Lian-Li PC-A7110B 2010/12/02 13:27:57 (permalink)
Wow that is a nice looking build!  I would have to have another job just to finance a project like that.
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/06 13:52:03 (permalink)
Thx
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/08 15:45:36 (permalink)
So that is the last pictures.
click on the thumbnails for HD
3Dmak Vantage P48729 http://3dmark.com/3dmv/2749869 Full stock
post edited by budington - 2010/12/08 16:36:27
boredgunner
Over 9000!
  • Ribbons : 78
Re:Lian-Li PC-A7110B 2010/12/08 16:34:14 (permalink)
Damn!  That really looks incredible.  I need to save up some funds for a Lian-Li case so badly.
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/10 13:10:13 (permalink)
I have an Little update on the next week with a 980X and fans for the two 360...
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/20 15:36:56 (permalink)
little Benchmark
This is a little Raid 5 in Intel ICH10R with  3x SSD OCZ Vertex 2 50Go
and that, it's my big  Raid 50 on an Adaptec 5805 with 7x WD Caviar Black 640Go
Please click on the picture for bigger version
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/12/28 07:41:07 (permalink)
On the last days some little things have changed.
My i7 965 dead was remplaced and upgraded by an 980X
My Adaptec 5805 dead was remplaced and upgraded with an Adaptec 51245
upgrade of fan and WC loop for the GPU...
initially the two 360 was disposed in paralel, with 3 noctua... This configuration provide a 58° on the 3 GPU's in Burn with 24° in the room (fan @ 12V).
this is not bad but not really good either...
I have put six more fans on my setup, the three noctuas at the same place ( between the two rads ) but adding three fans on inferior rad and three on the supperior rad
all three fans (by level) are controlled at the same time by the Fan-O-Matik (12w per canal).
I have also moved the loop, the loops start with the superior rad and down to the second rad. like that I have the warmer waer on the top and a cooling in two stage.
with the same 24° in the room the three GPU in burn now  a 45° with all fan @ 12V and 48° with the six scytes @ 8.5V and the three noctuas @12V with the same noise...
Thx
Brazen_NL
Re:Lian-Li PC-A7110B 2011/01/03 03:53:58 (permalink)
Nice and clean looking, just the way I like it!
 Linx stable at 4.25 GHz and cooled using one 120 mm radiator.
 See and rate [+1] my system in EVGA MODS RIGS.
 Your PC can help find cures for diseases while you browse the web.
 My affiliate code for product registration is D9G79LRPS5. Thanks!
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/01/07 13:34:40 (permalink)
Thx.
Three  new things.
Firstly.
One of my OCZ Vertex 2 is dead...  many Thank to my shop for changing this 50Go by one 120Go (today is the same price)
I want to try one thing with this new 120 Go... Adaptec Raid card have the posibilityl, of use one "hybrid raid" using SSD/HDD, so I want to check if my Raid 50 will be faster, in this raid I have all my applications and my games
Secondly.
One of my 480HC Is dead... send two days ago, receiveid today in Deutchland... and "Preparing to Ship Product" Fast service !!!! like always.
Thirdly.
Absolutely nothing to do with computers.
but my new mountain bike is on his way to home.
Cannondale Jekyll 2011 Ultimate
post edited by budington - 2011/01/07 13:45:42
kiki5334
Re:Lian-Li PC-A7110B 2011/01/07 23:03:37 (permalink)
WoW, one of the best Lian Li mod i seen in a while. Good Job
Fbmbirds
Re:Lian-Li PC-A7110B 2011/01/08 08:22:13 (permalink)
whats with the powersupply
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/01/08 08:54:29 (permalink)
it's an Enermax Revolution 85+ 1250W
damenj
Re:Lian-Li PC-A7110B 2011/01/08 09:05:58 (permalink)
Nice pc and Bike
Antec 300 | Corsair H50 P/P | AMD Phenom II X4 965 Black Edition Deneb 3.8GHz | GA-MA790FXT-UD5P
OCZ Vertex 30GB SSD OS | WD 500GB Storage | 4GB G.Skill Ram | Asus 4870 1GB BK CF
PC Power & Cooling Silencer 910
"In order to make an apple pie from scratch, you must first create the universe" ...Carl Sagan
Fbmbirds
Re:Lian-Li PC-A7110B 2011/01/08 10:23:53 (permalink)
budington
and is sticking half way out the case
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/01/08 10:36:34 (permalink)
yes she is pulled back to make more space inside the case...
I have a lot of material inside and free space is not easy to make...
so I use this solution with an Lian li original accesorie
post edited by budington - 2011/01/08 10:42:50
PanzerMensch
Re:Lian-Li PC-A7110B 2011/01/08 11:35:47 (permalink)
Very nice! Sweet build!
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2011/01/11 16:08:53 (permalink)
Thank you PanzerMensh
My 480 (back from RMA) is in hand of UPS.
I could eventually exceed 85K PPD with the third card
Gold Leader
  • Ribbons : 44
Re:Lian-Li PC-A7110B 2011/01/29 13:04:08 (permalink)
budington
That is simple a masterpiece mate!!
