Budington Project 1.0 [Finished] 3Way SLI, 3 Radiators, 11 Hard drive
Page: < 12345.. > >> Showing page 2 of 6
seth89
  • Ribbons : 11
Re:Lian-Li PC-A7110B 2010/02/21 13:00:53 (permalink)
looks nice.
i love the way you have the SLI set up
#31
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/02/22 16:27:17 (permalink)
Hi
Today was the agenda : Bench...
Pc mark Vantage: 18471 pts
Up to 1.2Go/s in reading, 450Mo/s in write  2.5 To Raid 50
post edited by budington - 2010/02/25 16:29:34
#32
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/02/25 13:49:47 (permalink)
A little change of the color for the leds on the top cover
Before
 after
post edited by budington - 2010/02/25 13:52:58
#33
johnnyfive622
Re:Lian-Li PC-A7110B 2010/02/25 14:47:27 (permalink)
Couple questions for you, what are you using to light up your top fans?  Also, what did you use to light up the inside of the case and where is it located?  That is a beautifully deep red!
Mobo: EVGA X58 Classified
Processor: Core i7 920 @ 3.2 Ghz
CPU Cooler: Watercooled
Memory:3 x 2gb Corsair XMS DDR3 Tri Channel 1600
Videocard: EVGA GTX 295 Watercooled and overclocked
Harddrive: Seagate Barracuda 500GB 7200rpm
PSU: Antec Signature Series 850W
CD/DVD: Plextor PX850-SA
Case: Case Labs M10
#34
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/02/25 15:13:39 (permalink)
Hi
where to start
the radiators are stackable, so they have input and output on both sides.
The problem is that the caps over the crankcase heater, this makes it impossible to mount, to solve the problem I did make Plexiglas spacer.
the spacer is set between the plate and top of the radiator, I therefore took the opportunity to put a strip of SMD LED
for inside there are two things, the first one is, Two red CCFL 31cm, one is located directly on the floor under the door and the second one on the side right  along the HDD, the second one is using a little bit of photoshop
I hope I have answered and I apologize again for my bad English
#35
jingiko
Re:Lian-Li PC-A7110B 2010/02/25 15:49:50 (permalink)
great amazing rig/colour contrast.
Thing is I still dont get how your GPU blocks circulate the water.
It just looks as if its pushing water in and pulling it right out, & whatevers in the blocks just basically stay there.
#36
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/02/25 16:07:02 (permalink)
This is an photo of the plexiglas version of the 285  waterblock 1.0  (mine is a little bit differant, My card is a  2Gb 285)
Water is like the most peoples, it uses the more easy way at first.
So you have two choices, the first is using the maze but is difficult , and the second way is the pipe to the second card...
water use the two way at the same time not at the same speed (low on the maze and speedy on the circuit) but not be forgotten that hydraulic pressure is always the same on all the circuit
using an parralel circuit, you have an benefit because you have minus pressure drop , have lost a bit of speed but using 13/19mm tube this is very correct
post edited by budington - 2010/02/25 16:10:05
#37
jingiko
Re:Lian-Li PC-A7110B 2010/02/25 17:31:04 (permalink)
ohhhh
interesting. cool i never seen loops done that way.
#38
johnnyfive622
Re:Lian-Li PC-A7110B 2010/02/26 05:31:07 (permalink)
You have answered my questions but brought up another.  Do you recall what manufacturer you bought the leds and the ccfls from?
Thanks
Case: Case Labs M10
#39
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/02/26 10:45:51 (permalink)
ho .. I think it was one 30mlum OEM strip  from my electronic shop.
the strip is complete with resistors already ride it enough to feed the strip
post edited by budington - 2010/03/09 11:50:28
#40
vaboycrevonte
Re:Lian-Li PC-A7110B 2010/02/26 18:44:16 (permalink)
wow..that looks good
Corsair 900D
Corsair 1000W
Acer Predator XB271HU
Asus Maximus Formula 6
Intel 4770k @4.5 OC
EVGA Geforce gtx 980 SC
Custome Water Cooling
16GB's of G.Skill Trident DDr3 2400MHz OC
http://www.heatware.com/eval.php?id=81241
#41
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/03/09 12:19:10 (permalink)
Hi a small change today
The connectors plates for hard drives, use three wired 4 pins connector... and ...  I dont like this.. so I change that
Before:
After:
#42
kt9394
Re:Lian-Li PC-A7110B 2010/03/09 13:16:53 (permalink)
nice rig and pics
  Heatware
#43
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/03/27 13:32:50 (permalink)
Thx
#44
seth89
  • Ribbons : 11
Re:Lian-Li PC-A7110B 2010/03/28 13:22:47 (permalink)
sweet rig. i love the red and white. thats so cool.
#45
qzwfcj
Re:Lian-Li PC-A7110B 2010/03/28 16:10:32 (permalink)
love that color, sweet
#46
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/27 14:25:49 (permalink)
My Two GTX are dead
#47
rachet45
Re:Lian-Li PC-A7110B 2010/04/27 14:58:28 (permalink)
how???
LOLCODE: adapting cats to programming at the speed of light!
o hai
i haz a displayHi {
say("it beez caturday!")
k thx bye
My rig:
core i7 920 @4.0ghz (water cooled)
evga 3x sli mobo (vregs and nb/swater cooled)
corsair dominator 1600mhz
patriot warp 64 gb ssd
wd caviar black 1tb hard drive
gtx 285 vcard
ht omega striker 7.1 audio card
#48
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/27 15:15:24 (permalink)
I do not know , the two cards are not working anymore @ default speed
Tested using two PSU (Corsair HX1000 + Enermax 85+ 1250W)
Tested on another computer and is the same things, in SLi or using only one card, @ default speed, game are crashing
#49
oloov
Re:Lian-Li PC-A7110B 2010/04/27 16:01:02 (permalink)
budington
Wow that's sucks. What are the chances of two cards going bad at the same time?
#50
{uZa}DOA
  • Ribbons : 15
Re:Lian-Li PC-A7110B 2010/04/27 19:10:23 (permalink)
Very nice setup! Love the raid card!
#51
Phoenixx45
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/27 19:19:05 (permalink)
Dang, beast of a rig man! Really awesome
White Widow - NZXT 810
Processor: Intel Core i7 2700 @ ?
Memory: 8GB Corsair Dominator GT
Hard Drive(s): 1. 2x 120Gb Vertex 2 SSD 2. Raptor 70GB   3. Raptor 300GB   4. Western Digital 1TB
Video Card: 3x EVGA GTX 480 w/ Back Plate & HF Bracket in SLI
Sound Card: X-Fi Titanium Fatal1ty Champion Series
Motherboard: EVGA z68 FTW
#52
dlb134
Re:Lian-Li PC-A7110B 2010/04/27 19:41:43 (permalink)
Are you sure windows update didn't push through a bad driver? Because if that isn't it the only thing that would cause 2 to go bad is a psu failure or motherboard failure (unless something could have went across the sli bridge?) Could it be the cpu overclock?
#53
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/28 00:12:50 (permalink)
Tested on Two computers with very different configuration...
If I downclock using precision utility the cards are working fine
and I have also tested separate the two card  ;)
#54
dlb134
Re:Lian-Li PC-A7110B 2010/04/28 12:28:30 (permalink)
Are they factory overclocked cards and are you downclocking them to nvidia specified clocks? Or are they royally screwed up?
#55
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/28 13:10:11 (permalink)
It's FTW card (720 MHz) @ 550 it's working normaly
#56
rachet45
Re:Lian-Li PC-A7110B 2010/04/28 13:33:57 (permalink)
hmm.... sin the nvidia control panel i think there is a reset to default button try that. or download the new drivers from evga and try to reload it (uninstall...reeinstall) hope i helped!
o hai
i haz a displayHi {
k thx bye
My rig:
gtx 285 vcard
#57
{uZa}DOA
  • Ribbons : 15
Re:Lian-Li PC-A7110B 2010/04/28 13:39:23 (permalink)
budington
Man that sucks I hope you get everything ironed out!
#58
budington
  • Ribbons : 7
Re:Lian-Li PC-A7110B 2010/04/28 15:02:12 (permalink)
The cards are go to Germany
#59
jorgen
Re:Lian-Li PC-A7110B 2010/04/28 17:19:37 (permalink)
Nice dude, looks very nice so far. Why so many HDD's lol
#60
