SSSJDanny
So I was able to order one of the GTX 980 Ti Hybrids that were on sale last Thursday and it arrives sometime today. I was wondering what the best location and orientation to mount the rad and fan would be? I found 2 pictures from @mjs85 with his 980 hybrid/s The 1st Picture shows the rad mounted blowing air out the rear exhaust, and it shows the tubes at the bottom of the rad. The 2nd Picture shows he placed the rad pulling air from the front of the case this time with the tubes on the side. Also would you guys change the stock fan that comes with the hybrid?
ipkha
- Ribbons : 6
Re: Best location and orientation to position Hybrid Rad?
2015/08/04 05:32:33
Unless the fan noise bothers you I would not change it. As to the placement of the radiator. I wouldn't place it near a heat source Ala the rear positioning unless the CPU cooler was blowing a different way. Why push hot air into your radiator? If theres a top vent try that or the front setup looks best. The front looks best given the layout of the case.
yuukichan
2015/08/04 07:32:53
As long as you are not venting the hot air into your case or are trying to push lots of hot case air into the rad, you should be ok. Just remember the the radiator will never be cooler than the air put into it. The hotter the air going in the hotter your gpu will run.
post edited by yuukichan - 2015/08/04 07:36:01
compddd
2015/08/04 07:59:14
What about in a Silverstone FT02 or FT05 where the only exhaust vent is on the top of the case above the CPU?
CPU: CORE I7-4790K // MB: ASUS Z97-AR // GFX: EVGA RTX 2080 TI BLACK EDITION GAMING
starrbuck
2015/08/04 08:02:44
Are the tubes supposed to be coming out of the top of the rad? In these pics they are on the bottom or the side. Does it matter?
Laptop: EVGA SC15 | i7-7700HQ | GTX 1060 6GB GDDR5 | G.Skill 16GB (2x8GB) DDR4 2400MHz | Samsung MZVPW256HEGL 256GB M.2 NVMe SSD | Crucial MX500 1TB SSD | Win 10 Home 64-bitDesktop: AMD Ryzen 7 2700X | ASUS ROG C7H Wi-Fi X470 | EK-FB ASUS C6H Monoblock | EVGA GeForce RTX 2080 Ti XC | EK-Vector RTX 2080 Ti RGB Water Block / Backplate | G.Skill Trident Z RGB 16GB (2x8GB) DDR4 3200MHz CL14 | Corsair Force MP510 960GB M.2 NVMe SSD | Alienware AW3418DW 120Hz 3440x1440 G-Sync | Fractal Design Define R6 | 7x EK-Vardar EVO 120 RGB | EK-XRES 140 Revo D5 RGB PWM | EK-CoolStream SE 360 + Koolance HX-CU1020V | Corsair HX 1200i | ASUS ROG Claymore + Gladius II | Win 10 Pro 64-bit
Stephenk291
2015/08/04 08:08:30
starrbuck Are the tubes supposed to be coming out of the top of the rad? In these pics they are on the bottom or the side. Does it matter?
That's just the angle he installed it at. You can flip the radiator any which way you want assuming the mounting holes still line up.
|i7 8700k @4.9Ghz| 64GB 3200mhz DDR4 Corsair RGB Pro |Asus Strix Gaming z390 |EVGA 3080 Ti FTW3 | Corsair 500D | H105 Cooler | SuperNova 850G3 Associates Code E96KV2QZWOXVRZM
CSN7
- Ribbons : 6
2015/08/04 08:14:47
Whats your case? And is your Cpu air cooled or has it his own AIO? Ideally what you wanna do is to place the rad as an outtake. But Not at a place where it can only get air from your cpu air cooler then put it in the top of your case. Mounting in the front isnt the best, not so much because you push the hot air from the rad into your case but the rad has to be mounted above the pump otherwise noise!
starrbuck
2015/08/04 08:19:48
Stephenk291 That's just the angle he installed it at. You can flip the radiator any which way you want assuming the mounting holes still line up. Right, but I thought I read somewhere that the system works better with the tubes at the top. Of course I can't recall where I saw it or if it was from a reputable source.
Stephenk291
2015/08/04 08:55:05
starrbuck
Eh I don't really recall ever seeing anything of the sort. When you top mount a radiator there is really no ''top'' just either making the tubes be on the left or right side. As long as the tube aren't bent of overly constricted in any sort of way is what you want.
jlp209
2015/08/04 09:07:05
OP, the thread isn't popping up on Page 1 anymore, but for kicks have a look at the 980 Ti / Titan X Hybrid thread that was started awhile back, might be some useful input there: http://forums.evga.com/Titan-X-and-980-hybrid-cooler-official-thread-m2327117-p21.aspx As for radiator placement, generally you want it above the graphics card / pump. Also I agree with an exhaust configuration at the top of your case if you can accommodate it. Get that hot air out. I have not replaced the stock fan on the radiator, it has been fine for me.
post edited by jlp209 - 2015/08/04 09:12:21
Asus ROG Strix Z390-I / i9 9900K @ 4.8ghz / Noctua NH-U12A / EVGA RTX 3080 Ti FTW3 Ultra / 32 gb G.Skill DDR4 3600 ram / Inland Premium 2TB NVMe SSD / WD 4TB SSD / LG 27GN950 4K 144hz monitor / Silverstone SX1000 PSU / Lian Li TU150 ITX case
vegnar
2015/08/04 09:38:23
I'm going to be receiving my hybrid kit today and I might be limited to mounting the rad up front . The fan ideally should be pushing air out correct ? The picture here shows he has fan's pushing air in.
SSSJDanny
2015/08/04 10:01:52
Snipes7 Whats your case? And is your Cpu air cooled or has it his own AIO? Ideally what you wanna do is to place the rad as an outtake. But Not at a place where it can only get air from your cpu air cooler then put it in the top of your case. Mounting in the front isnt the best, not so much because you push the hot air from the rad into your case but the rad has to be mounted above the pump otherwise noise!
I have a Cooler Master Storm Stryker. I am cooling my CPU with a Corsair H100i pulling air out of the top of the case. starrbuck
I herd the same thing, that placing the tubes on top would cause the pump to fight gravity more? Im not 100% sure.
post edited by SSSJDanny - 2015/08/04 10:04:03
Crimson AL
2015/08/04 17:52:24
vegnar I'm going to be receiving my hybrid kit today and I might be limited to mounting the rad up front . The fan ideally should be pushing air out correct ? The picture here shows he has fan's pushing air in.
He chose to pull cool air through the raidator and into the case because he wanted his cards to be the coolest they could be and if he pushed air out of the case from the front he wouldn't have any intake fans since every fan would be an exhaust. That cool air will become warm air once it passes through the radiator though. It's what I did because I want my cards to be the coolest they can be since they cost more than anything else on my system and the rest of the stuff inside the case can take the added heat and I have good circulation in the case. The air isn't that hot coming out and I imagine it's still a lot cooler than cards that dump their hot air into the case and not out the back. You just have to decide do you want your cards the coolest or the inside of the case to be a little cooler. Basically however your fans are now, leave them that way and just stick the radiator there with it's fan whether you decide to pull air in into the case and through the radiator or push air out of the case through the radiator. Just have to decide which of those you want to put your radiator there and keep the same fan direction, moving air in or out of the case. Some cases have limited options because of their size though. And the direction the radiator is placed is also because of the length of the tube and how it fits in the case. I put mine up front and had to turn the radiator on the side so it would fit....on top the hose was pulled too tight and on bottom it twisted the hose funky. I'd love to see how someone 4-ways a set of these with all the radiators.
post edited by Crimson AL - 2015/08/04 17:57:49
vegnar
2015/08/04 18:24:54
This is going to be my situation , I have a Define R4 because I'm all about silent gaming and installed a Noctua NH-D14 cpu cooler so that doesn't leave me a lot of room between the cpu cooler and the rear fan, My option it seems is only up front on the upper fan slot. Here is what I'm pondering up front I currently have 2 fans (intake) pulling air in , if I place the radiation and push air out (top fan) does that air comes right back into the case because the bottom fan will pull it in? or because in theory it will be warm/hot air it will just rise and not going to be pulled by the bottom fan? I loaded some pics. sigh don't know what's going on , all the pics are less than 500kb and the won't load.
post edited by vegnar - 2015/08/04 18:37:02
vegnar
2015/08/04 18:38:27
ipkha
- Ribbons : 6
2015/08/04 20:51:20
You're probably better off just having the front fans blowing in across the radiator. The difference will probably be negligible and the split fan direction approach would just mess up the airflow onside the case.
jlp209
2015/08/04 22:40:05
vegnar This is going to be my situation , I have a Define R4 because I'm all about silent gaming and installed a Noctua NH-D14 cpu cooler so that doesn't leave me a lot of room between the cpu cooler and the rear fan, My option it seems is only up front on the upper fan slot. Here is what I'm pondering up front I currently have 2 fans (intake) pulling air in , if I place the radiation and push air out (top fan) does that air comes right back into the case because the bottom fan will pull it in? or because in theory it will be warm/hot air it will just rise and not going to be pulled by the bottom fan?
What is at the top of your case currently- any fans on top above the NH-D14 as exhaust? If you don't have any fans on top at the moment, you might be able to sneak in the radiator on top as exhaust. It will be really close with the tubes and likely won't fit, it was just a thought I had looking at your photos. I used to run a NH-D14, man, that thing is just too massive. It is totally awesome, but massive and needed to go. At the very least you should be fine installing the radiator at the top-front, may be your only option. You shouldn't have the radiator set up as exhaust on the front upper fan slot and then the bottom front fan set as intake, agree with above commenter. Both the radiator fan and case fan on the front of the case should be intake.
post edited by jlp209 - 2015/08/04 22:45:42
vegnar
2015/08/05 08:29:27
jlp209
I successfully installed the hybrid kit and was rather easy, I'm happy with my performance so far overclocked my card +202/450 and idle temps are 23c and max load while playing BF4 and Witcher 3 is 48c. I don't hear any pump noise and fan is quiet, only thing that I noticed is one the tubes vibrates really strong vs the other, this kind of makes the case rattle emitting a humming or vibrate type of noise, not too annoying but definitely noticeable at 1 am when it's all quiet. The hardest part for me was my stupid case (R4) doesn't have decent mounting options, the only place where the rad would fit for me is in the front, but the R4 has a stupid bracket for the fans so even though you can mount a 120mm fan, the rad would not fit as it's bigger than 120mm (140mm are snap on so no holes for that either). Luckily I had a Noctua P12 fan and 4 long screws that I had to do a push/pull type of mounting blowing air into the case to be able to mount it but it was not easy. So far happy just wondering about the vibration intensity of one of the tubes, is this normal? mainly because the other tube doesn't vibrate as hard.
kurosuke7t9
2015/08/05 12:27:15
Mine are positioned at the front and the front bottom of my case, with the fan pulling air from the outside going to the inside. Its on my ModsRigs images. The front panel rad is using a different fan connected to a fan controller. So I can control how fast they go + the sound it makes.
''If you work hard, you can make your own Luck" オール・イズ・バニッティー"(All is Vanity)
