Hot!Best Water Cooling Case
xtremegamer
2016/08/26 12:00:28 (permalink)
what is the best water cooling case for 2 Way SLI and 3 Way ??
Intel Core i7 6950X l Rampage V Edition 10
 l 1080 SLI Soon
21 Replies Related Threads
    • Ribbons : 44
    Re: Best Water Cooling Case 2016/08/26 12:20:12 (permalink)
    Comes down to what your budget will allow
    I like my: Phanteks, Primo Case
    PSU is separate intake & exhaust
    Can fit 120 x 480 rad top & bottom  (I'm running dual 120 x 360 & modded bottom for better breathing - removed solid part)
    http://www.phanteks.com/enthoo-primo.html
    Also like my Cooler Master HaF 932 full tower
    But if my budget did not get in the way  there are some nice ones
    post edited by Cool GTX - 2016/08/28 22:01:14
    1) ASUS Z97-WS, i7-4790K@4.9GHz,  2-Way-SLI - EVGA GTX Titan X SC - EK block/plate, Custom loop, 32GB GSkill Ripjaws DDR3-2400, Samsumg Pro 850 SSD, 2-2TB WD Black, Phanteks Primo Case, Win 10 Pro 64bit, 4K Acer XB280HK monitor, EVGA 1600 P2 Supernova PSU, Fire Strike 1.1 = 21,842
    2) EVGA X99 Classified, I7-5960X, 2- Titan X Pascal, 32GB GSkill Ripjaws DDR4-3000, Intel NVMe PCIe 750 SSD, Win10 Pro,PSU EVGA 1200 P2 Folding 2.5M PPD    Affiliate code 05MLLDCG6B
    ragevirusqq
    Re: Best Water Cooling Case 2016/08/26 12:24:03 (permalink)
    Yes, Budget makes all the difference. In the 100 - 200 dollar range I love the phanteks cases and Fractal design define series.
    If you have big $$ go case labs. In my opinion the best cases in the world
    CaseLabs SM8 w/Pedestal- X99 Classified - EVGA 980ti HC's x 2 - 5930k @ 4.5 - 32GB Hyper X predator - 2 x 480mm EK rads - EK blocks and pump/res - All Bitspower black fittings - 1Tb samsung 850 evo 2tb total ssd space - EVGA 1300G2 - Predator X34 - Mayflower Objective 2 DAC/AMP - Beyerdynamic DT990 Pro - Sennheiser HD598 - Mackie CR4 monitors
    xtremegamer
    Re: Best Water Cooling Case 2016/08/26 18:53:30 (permalink)
    i don't have Budget hit me
     l 1080 SLI Soon
    • Ribbons : 68
    Re: Best Water Cooling Case 2016/08/26 18:57:45 (permalink)
    Check out   http://www.modsrigs.com you can find almost any type of case and photos.
    Mkkari
    Re: Best Water Cooling Case 2016/08/26 23:54:54 (permalink)
    Enthoo Primo already mentioned so 900D: http://www.corsair.com/en/obsidian-series-900d-super-tower-case
    Radiator Mount Locations
    Front: up to 360mm
    Top: up to 420/480mm
    Rear: 120/140mm
    Side: up to 420/480mm
    i5-2500k @ 4,2ghz / P8Z68 V-LX / Evga GTX770 SC / 8gig G.Skill DDR3 / HX650 / Corsair 750D / EK blocks, 240+360 Alphacool Rads
    Vlada011
    • Ribbons : 7
    Re: Best Water Cooling Case 2016/08/27 01:21:41 (permalink)
    Listen me... EVGA DG-87.
    You will not pay fortune, you will have excellent cooling option and for watercooling and for case cooling and one of nicest case on market at the moment. DG-87 is among 5 best cases for me, 2 are Caselabs, Lian-Li and EVGA. Price of other models is double...
    Much better than standard models as we look every day, Phanteks, CORSAIR, Thermaltake, etc...
    This is little uncommon look but perfect, exactly what most people like. And cables on back side are hidden.
    I could imagine your Rampage 10 inside and i7-6950X.
    Did you check black version DG-86, it's great as well, only no buttons on side.
    For me they are fantastic.
    Most important thing is because nothing similar you can't find on market.
    post edited by Vlada011 - 2016/08/27 01:30:09
    Zuhl3156
    • Ribbons : 30
    Re: Best Water Cooling Case 2016/08/27 07:22:46 (permalink)
    I took a chance with this new case and I really like it: http://www.newegg.com/Product/Product.aspx?Item=9SIA7TD4602092&
    The price isn't bad and the only complaint I have is that it is a little cramped in the back for cable management. It is workable though. http://www.modsrigs.com/detail.aspx?BuildID=35795
    It weighs a ton with the tempered glass side panels on it. Plenty of room up top for a nice 360mm radiator. Mine is a work in progress. I haven't decided how far I will go with the watercooling. My MSI Z77 motherboard may need to be replaced but I have to do some troubleshooting to make sure.
     Heatware
    Vlada011
    • Ribbons : 7
    Re: Best Water Cooling Case 2016/08/27 20:48:20 (permalink)
    Zuhl3156
    That's nice case as well, only DG-87 I really liked from first day because look good even with single graphic card.
    99% of other Full Tower Cases look empty without at least 2-3 graphic cards.
    Zuhl3156
    • Ribbons : 30
    Re: Best Water Cooling Case 2016/08/28 05:18:33 (permalink)
    I think my case is going to look empty no matter how many video boards I have until I get this EK pump installed: https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
     Heatware
    • Ribbons : 44
    Re: Best Water Cooling Case 2016/08/28 09:00:28 (permalink)
    Zuhl3156
    +1
    Nice, the all in ones are big.
    Zuhl3156
    • Ribbons : 30
    Re: Best Water Cooling Case 2016/08/28 09:17:47 (permalink)
    Airflow is great in that case. Aircooled 980 ti ran 20° cooler in that one compared to when I put it into my Corsair SPEC-01.
     Heatware
    • Ribbons : 44
    Re: Best Water Cooling Case 2016/08/28 11:46:45 (permalink)
    xtremegamer
    LIAN LI DK-04X Black Desktop
    Material: Tempered Glass Body Material: Aluminum Leg Material: Iron Computer Case
    http://www.newegg.com/Pro...x?Item=N82E16811112535
    $1500 + 200 shipping
    • Ribbons : 92
    Re: Best Water Cooling Case 2016/08/28 15:52:59 (permalink)
    Moving to the Cooling section.
    My Affiliate Code: 8WEQVXMCJL
    Slimshiesty
    Re: Best Water Cooling Case 2016/08/28 17:19:20 (permalink)
    Could post in both.. i mean he is asking about hardware.. and cooling.
    CPU  Intel i7 6700K @ 4.0 GHz
    MB   MSI Z170A M7
    GPU  EVGA GTX 1070 FTW
    MEM Avexir ROG Red Tesla DDR4 2666
    PSU  EVGA Supernova 850 G2
    CASE EVGA DG-87
    Slimshiesty
    Re: Best Water Cooling Case 2016/08/28 17:23:38 (permalink)
    xtremegamer
    Nice for a desk... overkill for a case.  just my personal opinion.
    The DG-87 is actually pretty good for watercooling.. was designed pretty much for it.
    I wish they went more for a traditional "left/Back" side, made it a little thicker for water cooling options on that side.
    Would be nice to be able to mount my H100i back there, and expell the hotter air out.
    With good front/right side airflow it would be perfect for this.
    MB   MSI Z170A M7
    CASE EVGA DG-87
    529th
    Re: Best Water Cooling Case 2016/08/28 18:43:12 (permalink)
    Love my 800D, go with a 900D
    CSPlayer089
    Re: Best Water Cooling Case 2016/08/28 19:58:09 (permalink)
    Sorry, but the 900D is crap. Did a few custom builds in it back when I worked for Tigerdirect. Way too cheap and plastic feeling. SUPER flimsy. Same thing with the 750D. Felt like I was going to snap everything in half every time I did work inside of it.
    As others have stated, go with an Enthoo Primo.
    AsRock Z170 Extreme7+
    Intel Core i7 6700K @ 4.5GHz
    2 NVIDIA GeForce GTX 1080 Founders Editions in SLI
    EVGA SuperNOVA 1300G2 PSU
    32GB (4x8GB) Mushkin Blackline DDR4-2400 15-15-15-35 2T
    Creative Labs Soundblaster X G5 USB DAC/Sound Card
    Swiftech H240-X Expandable AIO Liquid Cooler w/2 Noctua NF-A14 FLX
    Intel 750 Series 400GB NVMe PCI-E SSD (Windows 10 Pro UEFI Boot), 2 Intel 535 240GB SSDs (RAID 0, Intel chipset)
    Phanteks Enthoo Primo full tower case
    ASUS ROG Swift PG278Q 27" QHD/1440P G-Sync Monitor
    Corsair Strafe Cherry MX Red mech. keyboard
    EVGA Torq X10 Carbon/QcK Mass mousepad
    Kingston Hyper X Cloud headset
    Sennheiser  HD558 headphones
    Custom V-Moda Crossfade LP2 headphones
    Zuhl3156
    • Ribbons : 30
    Re: Best Water Cooling Case 2016/08/29 04:29:28 (permalink)
    Slimshiesty
    He just like moving things. We got used to it. You will too.
     Heatware
    hallowen
    • Ribbons : 12
    Re: Best Water Cooling Case 2016/08/29 05:30:04 (permalink)
    Primary Rig: Open Bench Table - 5960X/4.875GHz - ASUS RVE - Corsair 3000MHz-16GB - CPU-Phase Change - GPU-Chilled Water - Graphics (TBD) Secondary Rig: NZXT H630 - 980/4.5GHz - EVGA E760 - Corsair 2000MHz-12GB - CPU-HK/GPU-EK/MB-EK:Water Cooled - 3X-SLI EVGA 980ti Classified (06G-P4-4998-KR)
    Zuhl3156
    • Ribbons : 30
    Re: Best Water Cooling Case 2016/08/29 07:40:08 (permalink)
    hallowen
    https://www.nzxt.com/products/phantom-630-windowed-edition-white
    I wish I had known about this case sooner. It is more my style and I could have continued using a dual-bay reservoir like the one I am using now. $50 more is reasonable especially if it makes you happier.
     Heatware
    hallowen
    • Ribbons : 12
    Re: Best Water Cooling Case 2016/08/29 08:13:37 (permalink)
    I just thought ( For a Birthday Present to Myself ) I would Re-Do my Secondary Desktop Computer with this Case along with an AIO 280mm CPU Cooler and TWO AIO 140mm GPU Coolers for the Classys.
