Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards
Page: 12345.. > >> Showing page 1 of 13
maniacvvv
  • Ribbons : 159
2011/07/06 22:39:46 (permalink)
This Guide is intended to help users of 400 and 500 series Nvidia graphics cards, have a stable and graphically satisfying experiance when playing Battlefield BadCompany 2 on the PC.
With the outstanding rendering capacity of todays modern graphics cards and the awesome computing power of todays latest CPU's and motherboards, only one thing is missing...
-The correct information on how to properly configure ones GPU drivers and system to run Battlefield BC2-
This Guide will try and gather all the information available in one place, as an easy reference for users having questions, setting up the game for the first time or experiencing issues.
*non registered users will not be able to view the screenshots in this guide.
  For users really needing help, I suggest registering as the screenshots are VERY important to the guide.
Disclaimer: I make no claim to know everything about graphics cards or systems which I have not used personally. I am just another user, who is devoted to great gameplay and running as well as possible with the hardware available. Everything in this Guide is information that is available to anyone on the web, and certainly is not always my own personal experience or knowledge. Like everyone else, I have had to learn what works and what does not the hard way, with lots of help from others doing the same thing.
By making this Guide, I hope to make running BFBC2 an easier and more enjoyable experiance for those who choose to play it.
Any suggestions, settings or config information contained in this Guide, may or may not be applicable to your hardware, graphics card(s), system drivers or installed operating system.
-->As such, any actions taken based on information in this guide... are at the users own risk.
Part One: System Configuration before installing BFBC2
Part Two: Nvidia Drivers  (what drivers to use and how to properly install them)
Part Three: Nvidia Control Panel Settings  (what NVCP settings to use for BFBC2)
Part Four: The BFBC2 in-game settings Panel  (Where to make settings changes to the game)
Part Five: Multiplayer, system tips and tweaks
Part Six: Other Stuff  (how to launch the game properly to avoid Punkbuster, CTD and Ping issues)
Please note the following information:
This Guide is for BFBC2. While some of the content may be applicable to other games, some parts of the information and many of the Nvidia graphics settings may NOT work or will CONFLICT with other games and game engines. I will try to note such "exclusive" settings when possible.
This Guide, and the information contained within it--> is for Battlefield Bad Company 2
PART ONE: System Configuration before installing BFBC2
Before installing Battlefield BC2, it is recommended that you take a close look at your system config and drivers. If your system has issues or problems before installing the game, your gaming experience will suffer.
A stable system with good working device drivers is important. Know what your CPU and GPU max temps are under extreme conditions, as any game will always be less. Take an inventory of your attached devices and subsystems and determine if they are working properly with your current drivers in your current config...
Before installing any game on a hard drive (not a SSD) it is always best to Defrag once ->before the install and ->again after patching. The current BFBC2 install (with the latest patch) is 8.20gigs but you should think of it as 15gigs and base your space requirements on that (some digital installs can reach 10gigs). It is always recommended to have at least 30% of free hard drive space (or SSD volume) left after installing any game, and trying to install a game without such free space can lead to issues later. It is always perfered to have your game installed on the same drive as the OS, as this lessens the chance of rights and permissions errors and completly does away with issues like bandwith traffic or interupts.
For video drivers, having 266.58 (older 400 and 500 series cards) or 270.61 for the newer 500 series cards is suggested for pre-install testing purposes and stabilty/temps ->and will save a driver reinstall later, but is not required. Make sure you have updated your DirectX to the latest version. What is important is knowing your current driver is working properly with your system and display(s) and that it has been tested with Vantage, Heaven or Mark11 (I prefer testing with all three). I will mention Furmark here -once-, its simple -->do not use it. Properly configured for high loading and looped, the testing programs I have mentioned will give you the stablity and temp information that you need.
A word about high system overclocks (CPU/MEM), just as it is recommended not to install a OS with high clocks the same is true with large complex game installs. If you are running a 4.4Ghz CPU clock and are 300Mhz over spec on your RAM..Etc, Back it down to defaults or something sane and save yourself the headaches from a flaky game install or patching. Battlefiled BC2 (like many games today) has certain hidden features, background processes and DRM which interact with many parts of the OS and hardware drivers.
Some words on the minimum specs for BFBC2. They just are not true... EA wants to sell games, so they tell you a dual core C2D at 2.0ghz with 2gigs of memory, Win XP and a 256mb videocard will run BFBC2..... Dont belive a word of it.
-->BFBC2 needs at a minimum a older Quad core at 2.8ghz or higher, 2gigs of ram and a 512mb videocard, and at those specs its not going to look good (low to med settings in DX9) or play smoothly. Yeah, DICE has implemented a mod to the network stack and predictive coding in Multiplayer to remove visual client based lag effects, but that cant change the basic facts of how well your game is running. Its no fun to try and shoot at people who are not really there...or be shot before you turn the corner.
To properly enjoy BFBC2 at decent settings and framerates, no less than modern Intel HT quad or modern AMD Quad, running at 3.0ghz or better is required, plus 4gigs of RAM and a 768mb videocard.
Before installing BFBC2 it is suggested that you close down any anti-virus programs and programs that use the internet like your browser, Skype, messsaging or social apps, and -any- p2p programs like Xfire or torrents. Having such things running during the install can cause all kinds of strange issues later.. dont do it.
I am going to make one last comment about BFBC2 pre-install, and it is concerned with the users "type".
There is the "Casual" type of user, who's system performs many functions. This user has many devices attached and has many installed programs that have nothing to do with gaming. This type of users setup can be very problematic because of the extra driver/program overhead. If your having game or driver issues that are so bad as to force a OS reinstall, then for this type of user I recommend the following. A fresh OS install, motherboard/chipset driver, fully update the OS, install the latest DX version and then the display driver, and STOP. Defrag (non SSD) and then-> put in the game before anything else, then patch it and Defrag it again. Then begin BFBC2 testing and add in your other device drivers and programs -slowly- not all at once and test the game again each time. In this manner you avoid issues or at least have a better chance to determine it might be your webcam software driver that was causing CTD's in BFBC2
*Test your config before installing BFBC2 to resolve outstanding issues. Know your systems/videocard max temps under stress. Prep your drive before the install if needed, and turn off every background program possible when installing the game. If a device is not needed to play the game, consider unpluging it or disable it during the install process and then-> test the game -before- your plug it back in or re-enable it.
Getting the game cleanly installed will help reduce issues, and can provide helpful guidance for issues that may crop up later.
This is the number one issue when running BFBC2.
Certain Nvidia driver sets can cause artifacts and CTD's all by themselves at default settings in BFBC2. And using the incorrect settings in the Nvidia control panel (even with the correct drivers) can cause flickering, artifacts, black screens, white screens, game lockups and CTD's.
This section will cover the best drivers to use ->for BFBC2<- and how to install and configure them.
First off, you must have the latest Microsoft DirectX installed on your system.
Go here: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=35 and follow the instructions. This will update all DX9,DX10 and DX11 files to the most current versions for your installed OS.
*be aware that Microsoft "reserves" certain updated DirectX features to Service pack updates and different OS purchase levels. You cannot get these updates using the DX update service.
(in this case, with BFBC2 it appears not to matter if you have installed the Win7 SP1 or not. Although It cannot be ruled out that having SP1 might cause issues (possibly with DX input device drivers). So if your reinstalling your OS to run BFBC2 because of problems/issues, be sure to test BFBC2 -before- installing SP1 to rule that possibility out)
The next step is to get the "best" driver for BFBC2 and your installed videocard(s).
"Best" is a relative term here, in this case it's not the latest version, or the one that will give the highest benchmarking scores or is intended for "other" videogames more recently released...
They are the drivers that are known to work most consistently and with the fewest issues in BFBC2.
-->That driver (if supported by your videocard)...
*edit ---> 285.79 is now also recommended for BFBC2
*edit --->Nvidia Forceware version 285.27 is awesome, and is now my primary!
--->is Nvidia Forceware version 266.58
For newer Nvidia cards that do not support 266.58, the recommended driver...
--->is Nvidia Forceware version 270.61
*note: These drivers are the recommended "starting point" for running BFBC2. I only suggest these drivers because from my experiance they are the best all around drivers with the fewest reported issues across many different configs and videocard setups.
While there are many places to download drivers from, the source is always the best.
Go here  http://www.nvidia.com/Download/index.aspx?lang=en-us and choose BETA and Archived Drivers (as shown)
Now select the -correct- information for your videocard series, model and Operating system (on the page shown below)
Now download your driver choice. Always "Save" this file and do NOT choose "Run"
*Important note: Everyone has their downloads setup differently due to their hard drive setup, browser choice and folder layout. While "where" it ends up is not important... It is -very- important that before installing the driver you downloaded, that you COPY the file and PASTE it onto your desktop. This needs to become a habit-->running installers from the desktop, because of the problems and issues that can occur from -not- doing so...
OK we have our driver downloaded and the file itself (not a shortcut) is on the Desktop.
*Important Note: Whenever working on uninstalling, installing or re-installing your Nvidia display drivers, it is always suggested to shutdown, disable or uninstall any software that interacts with your videocard(s) -or- it's sensors. This includes programs like Precision,Afterburner,Desktop monitotring softwares and/or anything else that affects or uses the videodrivers. This will prevent certain issues and problems from cropping up, and not all such software may be compatible with the driver you might be installing. If in doubt, just shut it down before working on the Nvidia drivers. You can turn it back on or enable it later, after your done.
Now before we continue, we have to make sure that Windows wont try and download or install a display driver on it's own
-->after a display driver uninstall and a reboot.
Open the Windows Control panel and go to "Windows Update" choose "Change Settings" (as shown below)
Now Open settings flyout and pick "Check for Updates, but let me choose whether to download and install them"
Now it gets a little confusing (sorry)
I myself, like to go to Programs and Features in the Control Panel and uninstall all Nvidia display driver software--> one by one, with the last being the Display Driver itself. Then when it asks to reboot, I reboot into "safe mode" and use Driver Sweeper (ver. 2.1.0) to clean Nvidia Display drivers and PhysX, then proceed to boot normally into windows and install my new driver using the "Custom" install option, with only the driver, PhysX and Clean install options checked.
The problem is, that ver. 2.1.0 is no longer hosted at Guru3D (it was removed with malice) and newer versions and updates (hosted elsewere) are said to contain what many would consider to be malware. I cannot find a 2.1.0 version to download that I would consider safe, and because of that I cannot give out any links for it.
--->I cannot recommend that you try to use the program at this time.
*(unless you have a previous "clean" version saved somewhere like I do)
Luckly, many would consider using DriverSweeper outdated and unneeded today given Nvidia's new "clean" install option, so thats what I am going to recommend.
I still suggest that you go to Programs and Features in the Control Panel and uninstall all Nvidia display driver software--> one by one (letting each uninstall finish), with the last being the Display Driver itself.
Here is a screen shot showing the "last" driver to be removed, the Graphics driver itself. Your list may show other entries, such as Nvidia HD audio drivers and Stereoscopic 3D drivers along with PhysX Drivers. They may all be removed -first- one at a time (let them finish uninstalling), then do the "Graphics" driver entry -last-
As shown below
Upon that last uninstall, you will be asked to Reboot. Do so normally, if Windows asks, or attempts to install a display driver for your Videocard(s) simply hit "Cancel"...
OK, so we have uninstalled our previous Nvidia Display driver and additional Nvidia graphics card software and have now rebooted into Windows and are sitting at the desktop looking at the "new" Nvidia driver we downloaded beforehand. Its time to install it.
Double ckick and Launch the installer.
The very first thing that should happen is a Windows "User Account Control" dialog box should appear, asking for permission to allow a "Downloaded" program to make changes to your system. Click on "Yes" to allow the program to start.
Next a Dialog box will appear showing the extraction path for the driver we are installing (shown below)
Do NOT change or redirect this extraction path from its defaults. If your on a fresh OS install, the dialog box will ask to "create" the folder for you, and will use the Default path--> (your primary logged-in OS drive letter):/Nvidia/Display driver.
Do not mess around with where the driver extracts to, leave the settings at defaults.
After the driver package has extracted, you will automaticly begin the install process. The first dialog box displayed will be the Nvidia "System Check" that makes sure that you are installing the correct driver that is "supported" by your videocard and installed OS version. A "Check Mark" will appear after its it passed the check, next to "System Check" in the top lefthand corner.
-->You will now be looking at the Nvidia licence agreement, simply hit the "Agree and Continue" button.
Ok, now we come to the "Installer Option" panel, the place where many problems start.
-->Whoever is working at Nvidia and designed this, is a nutso crazy mean person...
If you use the "Default" Express Option (recommended by some crazy person at Nvidia) you will install the Nvidia HD Audio Drivers which can cause all kinds of issues for novice users, people with non standard audio setups, users with very outdated audio drivers and even users who just happen to be using a monitor or TV that is equipped with speakers or even just a headphone jack. This can become a nitemare for people who have not installed the correct software drivers for their monitor/audio subsystems -before- trying to install the display drivers in Express Mode (the dreaded blackscreen at boot issue) when the HD Audio driver detects a connected sound device but does NOT recive the proper DRM handshake from it...Thanks Nvidia
The "Express" option will also install the Stereoscopic 3D driver, which is completly unneeded if your not using a 120hz monitor and 3D glasses.
*-->Never use the "Express" install option for Nvidia graphics driver installs
Choose the "Custom" Advanced install option (as shown below)
Now the "Custom" install options dialog comes up. You only want (3) things checked off (as shown below).
The "Graphics Driver"(already checked by default), the "PhysX System Software" and the "Perform Clean Install" options...
We are now ready to install the driver, hit the "Next" button to start the install...
Continued on the Next post....
post edited by maniacvvv - 2012/02/17 11:28:47
389 Replies Related Threads
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/06 23:05:42 (permalink)
    Part two: Nvidia Drivers (continued)
    Ok so you hit "Next" and the driver began installing, when its done, your screen "may" look like this.
    Do not panic if it doesnt look like the screenshot above...
    Depending on what driver version you had installed previously, or a lack of a driver because of a fresh OS install, you may -or- may NOT be prompted to reboot your system for the changes to take effect.
    It does not matter, whether it prompts you or not--> you NEED to reboot after the installer is finished.
    Make NO changes, do NOT try and open the Nvidia Control Panel and do NOT enable anything you had turned off.
    -->just REBOOT the system now.
    OK, you have just rebooted after the driver install, now its time to check and make sure the driver installed correctly. I find the easiest way to check, is to simply "Right Click" on any open area of the desktop and look for the option in the flyout for the "Nvidia Control Panel" as shown below.
    choose Nvidia..trol panel
    If you see the option -good-, if you do NOT see it dont panic. Just like the option to enable SLI (which I will cover later), sometimes after a driver install, the Nvidia Control Panel will not show in the context menu flyout. The proper way to see if you really have a problem, is to perform another reboot and check it again. If its STILL not showing (and it has happened to me once) then you should simply reinstall the driver -again- "over the top" of the install you just finished, without performing -any- uninstall steps first. Just launch the driver installer again and follow the same steps as before, but this time, "without" the "Clean install" option checked... it "should" fix it.
    *Note: If your still NOT seeing it, then there are a few issues that could be causing the problem. First off, you may have failed to complety disable your anti-virus software, you may have your Windows security settings cranked up too high (back them down to Medium), or you may be logged into Windows on a User account that does not have the proper Admin permissions -or- on a account that was setup without a Admin password. For the User account without the correct permissions, simply log out and log back in on the primary Admin account and try installing the driver again. For those who have installed windows -without- using a password for the Admin account, the only fix is OS reinstall and to use a password this time.
    Ok, we have the new driver installed and Nvidia Control panel is showing up when you "right click" on the desktop.
    Now, open the Nvidia Control Panel
    Choose "Manage 3D Settings" on the top left (as Shown)
    These are the "DEFAULT" settings that the driver comes setup with after installing.
    ->And thats where most users "create" issues when changing these settings for BFBC2, without knowing what settings to choose. Make the wrong choices on your settings, and you will get flickering, studdering, blackscreens, white screens, game lockups, CTD's and higher than normal temps..Etc
    ...and thats what we are going to be covering next
    Part Three: Nvidia Control Panel Settings (for BFBC2)
    *if you dont want to read all this, there is a screenshot at the bottom with my recommended NVCP settings for BFBC2
    Ok, before we start on this section I want to make a few things clear. I do not pretend to be a graphics driver "expert", there are many users on this fourm who could run rings around me when it comes to the esoteric aspects of in depth graphics driver knowledge.
    What I am, is a serious gamer who demands the finest hardware/driver settings for the ability to spot targets, the best graphic performance for smooth gaming and total game responsiveness for the best experience when playing.
    I can play on a given rig for a few minutes and very closely guess what the framerates are (if I have time on the game engine), But in all honesty, it is also true that -when playing- I really cannot tell the difference betwwen x32CSAA and x8MSAA. Yeah, if I look at still screenshots I can "sometimes" spot the difference, but when playing my bottom line standard is "does it look good, does it play well"...
    With that said, The settings I will be suggesting in this section are first and foremost---> the settings which will NOT cause issues in BFBC2. On top of that first requirement, the second most important part of this guide is to provide the best "total gaming experience" in terms of High Settings and Smooth gameplay. Lastly, a very important part of this guide is to help other users "learn" enough about the BFBC2 game engine needs and quirks -and- their Nvidia graphics driver... to make their OWN explorations about what settings will work best on their hardware with BFBC2.
    OK first off, there are a couple of settings that need to be changed that are completly independent of BFBC2, and are simply gaming settings that need to be changed from defaults right away.
    The first one simply tells the graphics card about your monitor setup. (example is for using ONE monitor)
    The second one tells the graphics card to stay clocked up when the game is running (set to prefer max performance)
    The last one allows the Nvidia driver to use a SLI profile (Nvidia recommended, is what you want for BFBC2)
    Make the changes (that match your config) and apply them...
    Speaking of SLI (for dual card systems) lets get that turned on now (as shown below)
    Enable SLI and be sure to set PhysX to the card your monitor is NOT plugged into... (this is a BFBC2 setting)
    *Important Note: If you are having issues with getting SLI enabled there are a few steps to take when troubleshooting. First off, reboot and try again. If that doesnt work, open the case and remove the SLI bridge then lift out each card slightly and reseat it. Re-install the bridge, boot up and try again. If that doesnt do the trick, examine your SLI bridge to see if you have it on backwards (yes, it can be put on backwards) It wont hurt the cards to try it in the other direction if its still not working. If you have another 2way bridge or even a 3way one, you should try those also.
    *If its STILL not enabling (and this has happened to me once with dual SC 470's) then you should simply try reinstalling the driver -again- "over the top" of the install you just finished, without performing -any- uninstall steps first. Just launch the driver installer again and follow the same steps as before, but this time, "without" the "Clean install" option checked...
    OK, its time to go down the list in the "Manage 3D Settings" panel starting at the top.
    Ambient Occlusion = the available settings are OFF (default) and "Performance" or "Quality"
    This setting -is not- supported by the BFBC2 Engine thru the Nvidia control panel. BFBC2 uses its own "in-game" method called HSAO. Using that in-game HSAO setting provides slight background shadowing of forward objects and can add a great deal to the "looks" of the game -and- the ablity to spot targets. Make no mistake, this setting is VERY GPU intensive and will -really- effect framerates when using a single card config. Unless your using SLI or a GTX 470 or above, it is best to leave this setting at the default value of OFF. I suggest to everyone to leave this setting to OFF when first playing, then later to enable it and test see if they notice the effect or not, while keeping an eye out for FPS drops and/or slight studdering (if you cannot notice the effects, its not worth using).
    *This setting can be played around with. The only issues I know of are that it can produce artifacts in BFBC2 with extreme transparency supersampling.
    **Known issues: studdering from low FPS, artifacts using high levels of supersampling, heavy footprint on the GPU
    MANIAC's suggested setting for Ambient Occlusion-->OFF
    Anisotropic filtering = The available settings are default Application controlled and OFF, x2, x4, x8 and x16
    This setting basicly makes distant textures on objects clearer (you can see your targets better) crank it up!
    There are no issues I know of or performance drops of any kind, by setting this value to x16
    MANIAC's suggested setting for Anisotropic filtering--> set to x16
    *EDIT: there are issues with Crysis2 when forcing x16 AF in the NVCP. Use Application Controlled instead.
    Antialiasing- Gamma correction  = The available settings are OFF or ON
    This setting does NOT apply to the BFBC2 game engine. It should NOT be turned ON.
    Maniac's suggested setting for Antialiasing-Gamma Correction-- OFF
    Antialiasing - MODE
    The available settings are --->Application Controlled (default)
                                              --->OFF
                                              --->Enhance the application setting
                                              --->Override any application setting
    Choosing between these settings in BFBC2 can get -very very- technical, so I will try and make it plain and simple.
    The "Application Controlled" setting will use the in-game AA settings options (sample rates).
    The "OFF" setting does just that, and can provide an very ugly but extremely large jump in FPS. (not suggested)
    The "Enhance the application" setting will use the in-game settings as a "starting point" and allow for higher sample rates to be applied than is normally shown in the game. (more sample options in the NVCP)
    The "Override any application" setting will do just that, and "force" AA samples. (this should not be done with BFBC2)
    What does all this mean?
    -->MANIAC suggests you leave it at default "Application Controlled"
    If you leave the setting at it's "default" value of "Application Controlled" you will get the following options in the -in-game Graphics Settings (advanced) options panel to choose from, if they are supported by your NVCP settings and hardware.
    x1 MSAA
    x2 MSAA
    x4 MSAA
    x8 MSAA or x8 CSAA
    x16 CSAA or x16 (Q)CSAA
    x32 CSAA
    (That in-game BFBC2 settings panel flyout is shown below)
    *Important note: If you make -any- changes in the in-game "Advanced" settings tab (shown above) your BFBC2 settings file in your My Doucuments folder will re-enable the hidden BLOOM setting. After making -any- changes in this panel, you must leave the game and chnage that setting back to "False" OR YOU WILL EXPERIENCE ISSUES (I will be covering how to do that in the next section, you MUST make those changes)
    If you change the setting to "Enhance", you will then get the option in the NVCP to "set" those options.
    -->In the previously "greyed out" --> Antialising - Setting
    *Note: not all these settings will show up depending on your videocard(s) config.
    (Here is a SS of where you would change -those- settings)
    *These settings can produce the highest quality results, but using them is recommened for experienced users only.
    For more information on AA and its different modes and forms, go here  http://www.nhancer.com/?dat=d_AA and  http://www.tweakguides.com/NVFORCE_6.html and read up. (dont forget to click on the embedded "blue links" in the second link, that will really blow your mind if your a math freak)
    I will make it simple
    -->Leave the setting at default "Application Controlled" and then pick the highest level your config (CPU/Videocard(s)) can run without dropping framerates too low for you, causing your game to studder or effecting the "smoothness" of your gameplay.
    -->I personally use default "Application Controlled" and x32 CSAA off the BFBC2 in-game options panel.
    (to be honest, because I can with dual 580's. Its doubtful I could really tell the differance between x8 MSAA with "transparency" enabled or x16 or x32  while playing in-game)
    **Important note: High levels of AA in BFBC2 conflict with the "Bloom" setting that is hidden in the settings config file, within the BFBC2 folder in My Documents. When using higher levels of AA you -MUST- disable the "BLOOM" setting or you WILL experience flickering, black screens, studdering and other reported issues like black screen with sound running or overlay issues. (I will cover this in depth in another section)
    Antialiasing - Transparency
    The available settings are OFF, Multisample and x2,x4 and x8 Supersample
    This setting effects textures like leaves, wires, fences ETC
    MANIAC's suggested setting is--> Multisample
    *This setting makes a big differance in the looks of the game and using Multisample avoids some known issues with supersampling (artifacts and studdering).
    Cuda - GPUs
    MANIAC's suggested setting is default-->ALL
    Maximum pre-rendered frames
    The settings are 0-8 with the default setting at 3
    This setting attempts to balance ready to display frames and input lag. BFBC2 has a in-game vaule of -2- preset in the config file, and this value should be set here to match that in-game setting.
    MANIAC's suggested setting is -->2
    *you should not use anything but 2 here, unless your using a TV as a monitor (input lag). You "can" play with this setting if using a TV, but when testing you MUST match this NVCP value with the value in the game config file. If you change one, you must change the other to match.
    **any mis-match between this number and the one in the BFBC2 settings config file, can result in studdering and a "slow" feeling in-game when playing.
    Multi-display/mixed-GPU acceleration
    The settings are default -->Multiple display performance Mode, Single display performance Mode and Compatibility performance Mode.
    If your using ONE monitor--> change this setting to Single display performance mode
    Power management mode
    The settings are default Adaptive and Prefer maximum performance
    *do NOT use the default "Adaptive" setting for BFBC2
    MANIAC's suggested setting is --> Prefer maximum performance
    SLI rendering mode
    The default is--> Nvidia recommended
    *do not change this setting from its default for BFBC2
    Texture filtering-Anisotropic sample optimization
    The settings are default OFF and ON
    MANIAC's suggested setting is-- OFF (default)
    *do NOT turn this setting on for BFBC2
    Texture filtering-Negitive LOD bias
    The settings are default Allow and Clamp
    MANIAC's suggested setting is --> CLAMP
    *do NOT leave this setting at default Allow, you need it set to Clamp when using AA
    Texture filtering- Quality
    The settings are default-->Quality, then the options of Performance, High performance and High Quality
    *do NOT set this to High Quality. Doing so turns OFF all the killer stuff built into your videocard to make it run better, and FORCES the card to do things by BRUTE FORCE. This will have a HUGE impact on performance levels and will INCREASE your videocard temps. Dont do it!!
    MANIAC's suggested setting is-- QUALITY (and nothing else)
    Texture filtering- Trilinear optimization
    The settings are default ON and Off
    MANIAC's suggested setting is --> ON (default)
    Threaded optimization
    The settings are default Auto, ON and OFF
    MANIAC's suggested setting is--> AUTO (default)
    Triple Buffering
    MANIAC's suggested setting is--> OFF (default)
    *even if you are using VSync, you do NOT need to turn this on in BFBC2
    Vertical Sync
    The settings are default "Use the 3D application setting", Force off and Force On
    MANIAC's suggested setting is--> Use the 3D application setting (default), you can turn it on in-game
    *I personally do not use Vsync, it is not needed with my setup.
    *BFBC2 is a "heavy" game and even with the most powerful SLI graphics setups it is impossible to have runaway framerates in BFBC2. Many people complain of "tearing", but this is most often caused by bad NVCP settings and slow monitors. If you think you like using it, do so. For users with good hardware setups (strong cards and good monitors) it is NOT needed, and should not be used.
    Apply the changes and answer "yes" to save them
    -->Below is a screenshot of the settings I recommend using for BFBC2 (for most users)
    *the reasons for these settings/options are discussed in my post above. Read it if you have questions about the choices I have posted
    *Note: The settings above, MUST be used with correct choices in the BFBC2 Settings file (next section) or issues can occur
    Part Four: The BFBC2 in-game settings panel
    This section is VERY VERY important to avoid almost -all- of the reported issues people experience when running BFBC2 that are "settings" releated
    *Before making the settings changes listed below, you MUST have setup your Nvidia control panel (Manage 3D settings) as noted in the section above. Failure to do so, will cause issues, problems and you wont be able use the settings options I will be suggesting.
    -->if you have not setup your 3D settings in the Nvidia Control Panel (as noted in the above section) you must go back and do so NOW, before you can use my suggestions in this section.
    Your Nvidia control panel settings must -match exactly- the screenshot posted below
    -->before, your continue with this section!!!  (except for multi-monitor setups, or having Ambient Occlusion OFF)
    Ok, you have your NVCP settings setup.
    Now, start the game up and hit the "Options" button on the top, then choose -->"Settings"
    Now, choose "Advanced" where its says "Overall Quality"
    (as shown in the screenshot, that will open the "advanced" settings flyout panel)
    First off, set the games screen res to -match- your monitors "native" settings.
    Next, set -everything to HIGH as shown in the screenshot (I will be showing you "where" to change this later)
    -->Match -all- of the settings as shown in the "Advanced" flyout -EXCEPT- for the AA level.
    * for single cards (midrange GTX 460 Etc.) I suggest you choose 4x MSAA or 8xMSAA
    **for single cards (GTX 470,560Ti,570's Etc.) I suggest 8xMSAA or 16x CSAA
    ***for power users (SLI or GTX 480,580,590's) this setting should be set (as shown) to 32x CSAA
    Now close the game
    You wont normally be -ever- going back to that Options/Settings panel again
    From now on, you will be making any settings changes somewhere "else" and thats what I'm going to show you next...
    Go to My Documents, find the yellow BFBC2 folder, Open the BFBC2 folder, then open the "settings" file with Notepad.
    This is where the "magic" happens. It is settings in THIS file, that cause 90% of problems in BFBC2
    When setting up BFBC2 settings or trouble shooting, this file is where you will be making changes
    Here are my personal "Settings" file settings that I use for BFBC2
    [WindowSettings]
    Width=1920
    Height=1080
    Fullscreen=true
    RefreshRate=60
    VSync=false
    [Sound]
    Quality=high
    VoipEnable=false
    SpeakerCount=0
    [Graphics]
    Effects=high
    Soldiers=high
    Vehicles=high
    Overgrowth=high
    Undergrowth=high
    StaticObjects=high
    Terrain=high
    Shadows=high
    Bloom=false
    HSAO=true
    MSAA=7
    Water=high
    MainQuality=custom
    Texture=high
    DxVersion=auto
    Aniso=4
    Detail=high
    RenderAheadLimit=2
    Fov=75
    We will now go over what each setting does and what the options are.
    What settings work best and why we would want to choose them for a given config.
    --->We will also go over which of these settings CAN and DO cause problems and issues when running BFBC2.
    First Section:  [WindowSettings]
    Width=1920  -------->Width of your monitors "Native" screen size. (since I use a 1920x1080 monitor)
    Height=1080 -------->Height of your monitors "native screen size.
    Fullscreen=true ----->a setting here of "true" runs the game in fullscreen, a "false" setting runs it in a window
                                      *very useful running in windowed mode for underbuilt systems, you can drop down and get large
                                        framerate increases, also useful for recording with Fraps to keep file sizes down.
                                        Example: on a 1920x1080 monitor, running the game in a window at 1680x1050
    RefreshRate=60 ----> your monitors native refresh rate, as reported by the Nvidia control panel and nothing else
                                       Do NOT enter any values here, only in the NVCP should those be adjusted.
                                      *if this is showing at 59.9999 leave it, thats fine
    VSync=false ---------> false turns it OFF, true turns it on
    Second Section[Sound]
    Quality=high ------> The settings are high, medium and low. This should be set to HIGH
    *Note: Since BFBC2 uses the CPU for sound rendering, the -only- reason to drop it from high is if your CPU isnt able to run the game or is clocked slow. IE dual cores need LOW always, older or very slow quads need Medium. The slower Ghz your CPU runs at, the lower this setting needs to be. Any CPU running below 3.0ghz, quad or not should use medium or low.
    ** it does NOT MATTER what sound card you have, whatever you are using is -only- a output device for the sound rendering done on the CPU
    *** Incorrect values, or forcing a setting that is not supported.. will STILL output sound, but is a very well known cause of CTD, studdering and lockups.
    --> the correct way to setup your sound device for BFBC2 is to have it tested and working PROPERLY with all the correct settings in Windows -and- in your audio device software BEFORE installing BFBC2, then leave the Speaker Count value at zero
    VoipEnable=false ---> This is the in-game voice chat feature. I recommend turning it to false.
    *Note: there are known CTD issues when this is enabled, but not used. It also can cause strange effects in your clients connection, router ports and can sometimes not play nice when other chat clients are used.
    -->Set it to False.
    SpeakerCount=0 ----> it appears that only (3) settings are available.
    Code (0) appears to use windows -and- your audio device drivers/software settings to "use" for output
    -->(I personally use this setting)
    Code (2) appears to "Force" 2-channel stereo
    Code (6) appears to "Force" the highest quality SUPPORTED in the game, which is 5.1
    The reason everything "appears" to do something, is that it is impossible to test the setting without owning 2channel headphones, a 2 speaker system, a 2.1 system, a 5.1 system..ETC.
    *MANIAC suggests that you leave the setting at (0) as this will use your Audio device software settings and Windows settings
    **If you cannot hear footsteps or are hearing the wrong positional sounds, feel free to test away with your sound setup. Do NOT input code values in the settings file to do so, use ONLY the in-game BFBC2 Audio settings panel, Your Windows audio settings and Your audio device software settings, and then test your changes.
    ***Putting in codes which are unsupported is more likely to simply DEFAULT to zero anyway
    Third section:   [Graphics]
    Effects=high
    Effects are a big part of this game. For some games, "high" effects can cause blinding smoke, exploisions Etc that can be so overwhelming that turning them off results in better visibilty and better gameplay. This is NOT the case in BFBC2. With effects set to "high", you can see much better when a smoke grenade goes off, than with effects set to low...
    The -only- reason to turn this down is framerates.
    Soldiers=high
    Detail levels on Soldiers, looks great on high
    The only reason to turn this down is framerates
    This is a good place to gain framerates with lower settings, -without- effecting GAMEPLAY.
    Vehicles=high
    Detail level on Veichles, looks great on high
    This can be a place to gain framerates with lower settings, although it will have a slight effect on gameplay.
    Overgrowth=high
    Detail level on Overgrowth, looks great on high
    This can be turned down for framerates...
    *Setting this to Med makes tree and bush branches and leaves "slightly" more solid. Setting this to Low, makes branches and leaves "solid blocks". Anything below HIGH, will allow targets to hide much better... I suggest HIGH at all times.
    Undergrowth=high
    Detail level on Undergrowth, looks great on high
    StaticObjects=high
    Detail level on Objects in the game, looks great on high
    This is a very good place to gain framerates with lower settings, -without- effecting GAMEPLAY.
    Terrain=high
    Terrain detail, looks great on high
    Shadows=high
    Shadow complexity, looks awesome on high
    Normally this is a good place to gain some frames, but as you drop down the settings it becomes -harder- to see targets in BFBC2. Test and see what you can live with... High is best.
    Bloom=false   this is THE setting that causes issues, when set to: true
    Bloom, the art of light reflecting off of objects.
    Yeah right! DICE did such a poor job with this buggy feature, that its hard -->for most people to even see it in-game (unless your on a desert map, and cant see BECAUSE of it). And even when its working with AA, it can just decide its time for a CTD, an overlay issue, black flickering or a game lockup...
    Good job Dice
    This setting is NOT available in-game, and unless you open the Settings file in the BFBC2 My Documents folder and set it to False, its always set to true. Even worse, any settiings changes in the game options panel will re-enable it!
    Good job again DICE
    Set BLOOM to false, false, false and everytime you make any changes or patch BFBC2, come to the setting file and make SURE its set to false.
    FALSE is the setting for BLOOM
    *Having Bloom set to true, can cause studdering, black flickering, black screens, white screens, CTD's
    HSAO=true
    This is a Ambient Occulison feature, looks good enabled
    This is a good place to gain some framerates, with only a minor hit to gameplay
    MSAA=7
    This is a coded feature the number 7= x32 MSAA
    When we set the level in the in-game options panel (posted in the first part of this section) we set the Code up for the level of AA you picked-->and that is the code that is now showing.(the choice you made then) leave it alone, make any changes to AA in the in-game settings panel, then come BACK HERE and you will see the code changed
    *Important Note: after any changes to AA levels, you MUST set BLOOM to false as it will reset to True
    Water=high
    Water detail, looks good on high
    -very good- place to save some CPU overhead and gain framerates. Low is fine
    MainQuality=custom
    This only means we are using custom settings, do NOT set it to anything else.
    Texture=high
    Texture quality, looks good on high
    Not recommended to drop this setting unless you are having real overhead issues, Medium setting is OK but the low setting looks like junk.
    DxVersion=auto
    Auto is recommended. But forcing DX10 or DX9 is possible using this value.
    =10 will limit the game to DX10 and =9 will limit the game to DX9
    *Forcing DX9 can DOUBLE framerates and is very recommended for midrange single cards like the GTX 460
    **Running in DX9 will limit AA to x1 in the options panel.
    Aniso=4
    This is a coded feature 4= x16 Anisotropic filtering
    This should always be set at the value 4 and should not be changed. Nothing is gained by doing so.
    Detail=high
    This is the "overall" detail level, looks good on high
    This presets some settings to high, this is a value in the in-game panel to set overall quality levels.
    RenderAheadLimit=2
    This is the in-game setting for the BFBC2 engine, I recommend the default value of 2 set HERE in the settings file, AND also in the Nvidia control panel 3d settings.
    *Important: The value shown here MUST match the Render Ahead limit in the NVCP. Failue to match settings can cause studdering, CTD and a overall "slow" or "clunky" feeling in the game.
    Fov=75
    The is the games "field of view" setting, at default the value is set to 55 ( a console port value)
    MANIAC recommends the setting of 75 for enhancing gameplay and increasing the "fun" factor.
    *settings above 75 can be used, but the increasing fisheye effect will not help your gaming... try it if you want to.
    Part five: Mutilplayer, system tips and tweaks
    Multiplayer gaming is why most of us play BFBC2.
    I will be covering some basic system tips for online playing, and then go on to cover the most important factors that are unique to BFBC2.
    The first general rule for playing online? Use a hardwired connection!! Do NOT share your connection when playing!
    While online games "can" be played using a wireless connection, doing so will always introduce negitive effects and generate issues.
    The second general rule for playing online? Know "what else" your system is doing on the internet while your playing your game. One of the most common issues today that causes online multiplayer problems (lag, studdering, BFBC2 disconnects, Punkbuster issues), is background processes being active online while playing.
    The -only- way to really know what is really going on in a given users config, is to install network monitoring software. This will show you what is happening and who is doing it...
    Many of the users I have helped with such problems have been totally shocked by by the number of things that were actively using their connection, when they thought -nothing- was using it but the game they were playing.
    -->Make no mistake, alot of software does things online the normal user is totally unaware of, and has no control over.
    Finding out what is going on within your system and its connection to the internet is critical. Until you understand what is happening and which programs are doing what, there is no way to gain control over it or understand how to stop it.
    *Important note: using anykind of p2p software (like Skype, X-fire Etc), can trigger some ISP's into throttling your connection.
    The last general tip, is the BIG LIE about internet connections.
    For gaming, a quality VDSL 2.5mb connection is just as good as a 80mb cable one (and often can be much better). Game servers do NOT adjust traffic based on a given users internet speed, everybody gets the same bandwith treatment from the server, and on the server poll (unless of course your missing it due to issues).
    Low signal to noise ratio on your physical connection, the quality of your ISP's primary server and your physical location, your ISP's node contracts and throttle levels, and the quality of the game server, its distance from you, its physical location and -its- ISP's services, the "Type" of internet service (Cable, DSL, VDSL) you are using and its native congestion levels and lastly the network congestion present along your pipeline to the server, all come together as one, and determine your overall internet performance levels in a given game.
    Make no mistake, your SpeedTested 40mb cable connection is actually running at the USA average-->700kbps when connected to a game server. Unless you pay for business class service or use a "specialty" ISP provider, its unlikely you receive sustained connection speeds above 700kbps.
    The speed you are "really" getting can be easily tested. Go to a known host with unlimmited return bandwith contracts such as Microsoft Update or Nvidia.com and download a file, or open a torrent client (for non ISP p2p throttled users).... What you see -is- what your really getting
    Now on to the BFBC2 tips.
    In the BFBC2 engine DICE has chosen to implement a Mod to the network stack, to help with client/server generated lag effects. The system actually works quite well for removing such visual effects (you wont "see" a player with 600ping skipping 20ft at a time across the map). But it has a unintended effect in generating "predictive" effects when playing... that guy getting a totally impossible shot on you... it only looked that way to you, as far as the server was concerned everything was fair. Because of the way your client generated that frame sequence during that shot, it only "looked" like a cheat to YOU.
    There is no doubt that increasing your framerates, will help you to use this feature in the engine for better gameplay. The "better" you run the game vs the person your shooting at, the more likely you will be happy and the other guy will rage quit because it looked so bad...
    -->The "sweet spot" for taking advantage of this engine feature appears to be around 120-130fps, higher than that and it appears that the effect drops away and such higher frames may begin to hurt you against players running much lower fps.
    If your getting CTD's after doing all the config stuff I have posted, consider dropping your overall quality levels down a notch (you may be running them too high, graphics and/or sound. Or you may have overclocks that are causing issues). The BFBC2 engine is much like the BF2 engine before it, it generates natural rendering, sound and effects errors all the time (even when its running perfectly). If you had the editor you would see stuff like "texture x failed to generate proceedure xxx", "the sound XX.XX did not attach itself properly to object XXX and has defaulted to a idle state"...Etc. You can "see" and "hear" these errors happening if you pay attention and look for them (even when the game is running fine without CTD). The CTD problem occurs when too many of these errors happen on a given frame, or a certain error propagates until failure. One of the MAIN causes of "end of round" CTD's is the errors have propagated in a predictive fashion (because of the engine) and as the map closes too many calls are outstanding and unresolved Etc, this results in a CTD as the map changes.
    *if your running boarderline (dropping below 25fps) -or- your system is totally screaming overclocked to the hilt, such can cause CTD's because of the above issues in the BFBC2 engine...
    **End of map CTD can also be caused by dropping packets -exactly- when the server tries to restock the players as it sets up the next maps polling.
    -->Consider testing to determine if this is happening to you
    The number one BFBC2 multiplayer tip
    -->The location and quality of the server you are connecting to -and- the connections and framerates of the users you are playing against -and- your connection quality and distance to that server.
    Many users fail to understand that most, if not all BFBC2 servers are not just running "one" game, but are really running mutiple games at the same time. This means that server "overhead" and "stress" can be affected, because of the fps and connections of the players on it. If everyone in a server is running low framerates and pinging 400+ even the best server will start to tank...
    This is why its important to pay attention to the pings (and possible framerates) of other players in the server. Your gaming experence will be much much better if the players on it are running fairly equal...
    For the best Multiplayer experience, play on quality servers with the lowest pings as close as possible to your geographical location, and with players who's fps rates and pings are closest to your own....
    -->Continued on next post
    post edited by maniacvvv - 2011/09/15 23:48:51
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/06 23:07:17 (permalink)
    How to properly Launch BFBC2 to -avoid- issues with (Punkbuster, CTD's, Seeing pings.. Etc)
    One of the well known causes of many issues with BFBC2 is a failure to Launch/Run it properly.
    For a variety of reasons, many users launch their BFBC2 game improperly. The most common reason is that after installing BFBC2, the user noted that a "desktop" launch icon was not installed. This caused many users to search out the games .exe and copy a shotcut to the desktop to use for launching the game.
    This can cause all sorts of problems/issues within the BFBC2, like CTD's, Punkbuster failues and Ping problems...
    ->The worst part, is that the game will still "Run" when launched improperly (but will have issues)
    *This is because the BFBC2 installer -did- create a launch icon, in START-ALL PROGRAMS-GAMES
    -->This was done INTENTIONALLY by the Developers, to take advantage of certain properties built into the Windows 7 "Games" folder having to deal with Admin rights in sub folders, internet access features and DRM.
    If the game is not launched -from the correct location and in the correct manner, certain features of BFBC2 will not work correctly. Issues with Punkbuster, EA Updates and the in-game ping features of BFBC2 may all work incorrectly when the game is launched incorrectly.
    To launch BFBC2 go to the Windows 7 START Menu, then ALL PROGRAMS
    And open the yellow "Games" folder (as shown above)
    Now, once the games folder is open.. "Right Click" on the BFBC2 Launch Icon. (do NOT left click on it)
    This will "OPEN" the the correct panel for proper launching of BFBC2
    As you can see from the above screenshot, this is the CORRECT place to launch BFBC2 with -Full Admin Rights- for all the imbedded folders and sub programs in BFBC2.
    -->Launching in this manner will allow all the "other" features in BFBC2 to run properly!
    --->and will AVOID all kinds of reported user issues.
    **Do not make/force any changes to "compatibilty mode" for launching BFBC2. Such changes are NOT needed!
    I'm going to Add stuff in here that comes up in the responces for this thread.
    I will also be adding in some Stuff here when the 280.xx driver is released after testing it
    post edited by maniacvvv - 2011/07/23 08:26:17
    MajestacaL
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 00:32:48 (permalink)
    Here is one that lastsamurairick has going also it may help you with some of your tweaks/guide also.  http://forums.evga.com/tm.aspx?m=488637&high=bfbc2+tweak
    I always love reading peoples guides/tweak suggestions for this game thanks!
    x3 Acer 23.6" 3D Monitors @5760x1080, Cooler Master HAF X, Asus Crosshair Formula V, Antec Kuhler H20 620/PP, AMD 1100T BE @ 4.01Ghz, 16GB Corsair Vengeance 9-9-9-24 @ 1600MHz, x2 Evga 580GTX SLI, x2 300GB Western Digital VelociRaptor Drives Raid 0, Antec HCP-1200W
    EVGA Affiliate Code: QFVZM37BXK
    STEAM Profile http://steamcommunity.com/id/majestacal
    EA ORIGIN ID: MajestacaL
    cjgentile
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 20:05:35 (permalink)
    A 17 part guide? Its not that complicated...
    I'm assuming the windows registry mods that give you a better ping wont be in this guide... cause you know... that would be cheating and dishonest.
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 21:37:47 (permalink)
    cjgentile
    Troll much?
    Perhaps if you bothered to but some effort into your config and gaming skills, you wouldnt have to hack your OS registry and play with dishonor in the multiplayer servers.
    There are those who can PLAY and run their systems cleanly and fairly...
    And then there are those who try to gain a unfair advantage running background programs and using registry hacks instead of running clean and working on their skillsets or upgrading their hardware.
    Dont bother looking in this thread for cheats or dishonorable tricks, your not going to find any
    -->luckly those like you are not the majority on these fourms.
    Thanks for your support, in my effort to help people run BFBC2 without issues.
    post edited by maniacvvv - 2011/07/07 22:02:27
    SGTHACK
    EGC Admin
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 22:06:23 (permalink)
    MANIAC, keep going! You are supported....
    NemesisChild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 22:07:29 (permalink)
    Nice work (so far) Maniac, look forward to seeing the rest of your guide.
    Always looking for ways to tweak performance in BFBC2, just love the game.
    I'm sure you're as excited about BF3 as many of us are here in the forum.
    Intel i7 6700K@ 4.8GHz
    Corsair H90 Hydro
    ASUS Maximus VIII Hero
    G.Skill TridentZ@ 3200MHz 32GB CL14
    SLI: 2x EVGA GTX 980Ti SC@ 1455/1455MHz
    OS: Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 1TB
    EVGA SuperNova 1200 P2
    CM HAF 932 Advanced
    Windows 10 Home x64 (UEFI)
    shafat
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 22:20:37 (permalink)
    Keep up the honest hard work bro. I am looking forward to the final product. I am in the process of tweaking the game myself. Let us know if you need us to do any testing or anything. Will be glad to be of any help
    Evga x79 Dark. Bios 2.09
    I7 4820K @ 4.6 Ghz w/ HT 1.285v
    2x Evga GTX 980 SC @1560mhz, GTX 950 physx
    4x4 gb G.Skill Ripjaws 1866 @ 8-9-9-23-1T 1.52v
    Evga Supernova P2 1200w
    Samsung 850 Evo 250gb (OS) / 850 Evo 500gb (gaming)
    ACER Predator XB271HU WQHD 144hz Gsync
    3dMark Firestrike 20252
    http://www.3dmark.com/fs/3971717
    heritage1550
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/07 22:39:42 (permalink)
    maniac, thanks for taking the time and putting in the effort to make BFBC2 a more enjoyable experience for everyone here. I'm totally addicted to the game and I need all the help I can get keeping K-bars out of my back!! Looking forward to the completed guide.
    Now for the future, how about one for BF3??!!??
    Thanks again.
    NemesisChild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/08 06:48:33 (permalink)
    Here's the direct link to Drive Sweeper from the authors site:
    http://phyxion.net/Driver-Sweeper/Driver-Sweeper/
    Never had any issues with malware since I always get it from here.
    Corsair H90 Hydro
    CM HAF 932 Advanced
    major53
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/08 10:54:32 (permalink)
    maniac how about helping a old bro out,let me send my pc to you and you work your magic on it and I will put a envelope between the two hard drives , just printed out a new batch of Jackson and need to try them out.hehehe
    keep up the good work bro it's looking good.
    MSI Z87-G45 GAMING MOBO▐ Intel Core i5-4670K HASWELL (oc 4.4) ▐ Coolmaster hyper 212 plus 120mm Heatsink▐G.SKILL 8GB rip SNIPER SERIES 1866 (2 x 4GB) 240-Pin DDR3( 14900)▌ Samsung 500GB 2.5-inch SSD 840 Series (os)  EVGA SUPERCLOCKED 02G-P4-2765-KR G-SYNC GTX 760 2GB 256-BIT▐ Antec High Current Gamer Series HCG-900 900 Watt ATX12V v2.31 EPS12V v2.91COOLMASTER HAF 932 Case▐ WINDOWS 8.1  HOME 64 Bit ▌
    nine_dragon
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/08 11:01:26 (permalink)
    Keep up the good work
    Motherboard: Asus P8P67 PRO
    PSU: Corsair HX750w
    HDD (s): Samsung F3 1TB 7200 RPM + Intel 320 80GB
    RAM: 8GB Corsair Vengeance @ 1600MHz CAS 9
    GPU (Monitor): 2x EVGA GTX 560 Ti FPB SLI
    CPU: Intel i5-2500k (4.5 GHz) Cooling: Corsair H70
    Case: Cooler Master HAF 932
    Laptop: ASUS G51JX-A1
    Baasha
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/08 13:59:44 (permalink)
    Excellent effort! I'm always looking to tweak the system for better performance.
    4K Gaming in all its Glory! - ThirtyIR
    The Uber Rig
    Please check out my FOR SALE thread!
    Ta1k0n
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/08 15:30:34 (permalink)
    SGTHACK
    Roger that!
    MydasDiablo
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 04:38:13 (permalink)
    Just follow Manicvvv's instructions to the letter and you will be good to go. I had major stutter problems with my GTX 590, sent a PM to maniacvvv and having adjusted my config & settings in accordance with his expert advice and the details in his post the game is running smoother and happier than ever before. I can't thank him enough for his wisdom.
    For all the haters out there, stop moaning about voltage limits, throttling, SLI stutter etc etc and just get your config right for the actual game you are playing, Maniacvvv is your man, take it from me, you won't be dissapointed.
    Lian Li PC-X2000F Full Tower + 5 x Noiseblocker NB-BlackSilentPRO PK3 140mm
    Corsair Professional HX1000 1000w PSU
    Asus X58 Sabertooth  M/B
    OCZ Vertex 2E 120GB SSD
    Samsung Spinpoint F3 1TB HDD
    Samsung Storybook 1.5TB External USB HDD
    i7 950 @ 4.3Ghz
    Prolimatech Megahalems + 2 x Noiseblocker NB-Multiframe M12-P 120mm in Push-Pull
    6GB Corsair Dominator Triple Channel 1866Mhz 8-8-8-24 1T
    EVGA Classified GTX 590 650Mhz / 3700Mhz
    NuForce Icon HDP DAC, Headphone Amp & Pre-Amp
    Cambridge Soundworks 250D 300Watt 2.1 Speaker & Subwoofer System
    Ultrasone Pro 900 Cans
    Benq XL2410T 24" 1080p 3D LED 120Hz Monitor
    Hog54
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 05:50:38 (permalink)
    Never had a problem with the game by just installing it and playing it.Never had to do any tweaks to anything.If you have to do all that stuff in this guide,get another computer.
    AMD PhenomII 1090T@ 3.6
    Corsair H50 cooler
    Asus M3N72-D board
    Evga GTX460 SC 1GB
    4 gb G-skill PC8500 @1066
    G-skill Sniper 120 GIG SSD
    Corsair HX650
    Windows7 Ultimate 64bit\
    NemesisChild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 17:12:29 (permalink)
    It's advisable to adjust SpeakerCount to match you sound system.
    For 2 or 2.1 systems, it should be set at 2
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    Corsair H90 Hydro
    CM HAF 932 Advanced
    sputnik7913
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 17:17:17 (permalink)
    Never had any issues with BC2!
    FattysGoneWild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 17:29:31 (permalink)
    Fantastic guide!
    I just got my GTX560 and the game was running weird. Studdering and all that jazz. Soon as I done this fix. Smooth as butter with max settings. As for the following with audio.
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    I have a 2.1 setup and the settings have it set to 0. I could be wrong. But thought I remember reading 0 was actually correct for 2.1 setup?
    HP Envy Phoenix 810-430qe
    OS: Windows 10 64 bit
    MOBO: MSI Kaili2 Z97
    CPU: Intel i7 4790K liquid cooling
    RAM: 16GB DDR3 1600
    GPU: EVGA GTX 1080 Founders Edition
    PSU: EVGA SuperNOVA 650 P2
    SSD: Samsung 256GB MZ7TE256HMHP
    HDD: 2TB Seagate Barracuda ST2000DM001
    Sound: Logitech Z623 THX 2.1 Speakers
    Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display
    Keyboard: Razer Blackwidow Chroma
    Mouse: Razer DeathAdder Chroma
    EVGA Affiliate Code: C3OXU3I2N9
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 17:51:01 (permalink)
    FattysGoneWild
    Fantastic guide!
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    Thanks bro, glad its working now...  Thats what this guide was for.
    As for the other stuff about the Sound code (speaker count)...
    --->your setting of - 0 - is correct for your 2.1 sound setup
    This posting of:
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    Is 100% false
    The numbers in the settings file are CODES  -DO NOT use those settings, they are wrong and will cause issues!!
    -->Speaker count / MSAA / Aniso
    Values are CODED! What you "see" is NOT what you get!!
    You guys need to WAIT until I cover that section and post up the PROPER codes.
    post edited by maniacvvv - 2011/07/09 18:09:13
    FattysGoneWild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 18:36:07 (permalink)
    What we see is not what we get? What do you mean by that? Is this game that broke?!?!
    maniacvvv
    FattysGoneWild
    Fantastic guide!
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    This posting of:
    3.1 = 3
    4.1 = 4
    5.1 = 5
    7.1 = 7
    Is 100% false
    RAM: 16GB DDR3 1600
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 18:39:54 (permalink)
    LOLOL
    No, was just pointing out that using a Speaker count setting of - 2
    Does not mean its for 2 speakers
    I will be covering all this.... please just wait
    #23
    FattysGoneWild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 18:41:58 (permalink)
    Got ya. Just misunderstood.
    RAM: 16GB DDR3 1600
    #24
    kmconstable
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 20:03:27 (permalink)
    Great so far. Am waiting for ctd guide for surround as that is my issue.
    Specs:
    HAF-X | ASUS SABERTOOTH Z77 | i7 3770K @ 4.2 |  Corsair H100
    Corsair AX1200 | 4x8gigs G.Skill Trident-X 2400 | 2 x ASUS DCUII GTX 670 | Intel 320 600gig | 3 x 27 inch monitors 2D Surround | HT Omega eClaro | Onkyo 7.1 receiver with Polk Monitor Series x 7 & 12in Sub | Denon AH-D5000s
    #25
    FattysGoneWild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 23:00:53 (permalink)
    I have a question about the following from the guide. I am confused.
    This setting -is- supported by the BFBC2 Engine. It provides slight background shadowing of forward objects and can add a great deal to the "looks" of the game -and- the ablity to spot targets. Make no mistake, this setting is VERY GPU intensive and will -really- effect framerates when using a single card config. Unless your using SLI or a GTX 470 or above, it is best to leave this setting at the default value of OFF. I suggest to everyone to leave this setting to OFF when first playing, then later to enable it and test see if they notice the effect or not, while keeping an eye out for FPS drops and/or slight studdering (if you cannot notice the effects, its not worth using).
    -->I personally use the setting of "Quality" with 580's in SLI, as they can handle it just fine.
    *This setting can be played around with. The only issues I know of are that it can produce artifacts in BFBC2 with extreme transparency supersampling -and- having it set to anything but OFF in the Global Settings Tab of the Nvidia Control panel "can" cause serious issues when running other game engines that do not support the feature. If your config isnt up to it, using this setting will let you know about it right away...
    *(leave this off until you have played for a few hours, then play around with it and see if it works for you and your config)
    HSAO=true
    Following the guide. Since I have AO set to off in the nvidia control panel. If I enable HSAO in BC2. Is that feature not working since AO is disabled through nvidia control panel? Or is this 2 completely different things we are talking about. What do you advise as I have a GTX560 SC non Ti.
    post edited by FattysGoneWild - 2011/07/09 23:03:50
    RAM: 16GB DDR3 1600
    #26
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 23:20:03 (permalink)
    FattysGoneWild
    HSAO=true
    I belive HSAO is a DICE coded in-game feature (stand alone)
    Ambient Occlusion in the Nvidia 3D settings panel is a (add-in) effect, -if- the game is coded in such a way to be able to support it. BFBC2 is such a game.
    For a GTX560--> I would suggest HSAO=false, and the Nvidia 3D setting at "performance"
    Feel free to try out different settings and go into the game and see if you can notice them, if they "add" to your gameplay and what performance levels you are getting with such settings ON and OFF..
    post edited by maniacvvv - 2011/07/09 23:22:50
    #27
    FattysGoneWild
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/09 23:46:50 (permalink)
    Might want to add this or maybe you know about it. Easy way of keeping the settings and make sure they hold 100% of the time. Right click on the settings.ini go to properties, put a check on read-only, apply and ok. The game cannot make changes to the file when it feels like it.
    Good job Dice
    Good job again DICE
    RAM: 16GB DDR3 1600
    #28
    maniacvvv
    • Ribbons : 159
    Re:Battlefield BC2 GraphicSettings Guide 2011/07/10 00:04:01 (permalink)
    FattysGoneWild
    Good job Dice
    Good job again DICE
    LOL the read only trick does NOT work with BFBC2 because of the permissions the game has...
    Go ahead and try and lock the file, make some changes in the in-game options panel... now go back and look what happened
    #29
    Johnny Quest
    Re:Battlefield BC2 Graphic Settings Guide 2011/07/10 05:08:55 (permalink)
    Thanks a ton Maniac...as i said in the previous post ..you are an asset to these forums...always eager to solve issues.[if people will listen]lol..alot of work went into your post..i hope all take benefit from your research..kudos ...nice job my man
    Asus Rampage II Extreme////EVGA GTX 580 SC////Corsair HX 1050 ////12gb,Corsair Dominator- 1600mhz//// OCZ Vertex 2 240G SSD////300gb Velocoraptor////2- 640gb Western Digital black////Nextar HD docking station////Intel i7 965 Extreme at 4.0////Logitech Z5500 5.1 THX////Razer Death Adder left hand////Razer Black Widow Ultimate keyboard////Swiftech MCP655////EK-D5-Xtop 2,Fesser Dual Rad////,Koolance cpu 350 water block//// Bitspower Silver Compression Ftngs.////Danger Den Delrin fillport////Primoflex Pro LRT clear////Swiftech MCRES micro rev.2////Thermaltake Armour E-ATX////Asus VG236H 23" 3D////Monster Power HTS3600 MKII clean power stage 3v.2.1 filtering////Windows 7 Professional 64bit////Sore Wallet////
    #30
    Page: 12345.. > >> Showing page 1 of 13
