Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards
Page: < 12345.. > >> Showing page 3 of 13
naokiura
Re:Battlefield BC2 GraphicSettings Guide 2011/07/13 23:50:25 (permalink)
maniacvvv
I have just recived a PM from a member asking about why his Ambient Occlusion setting was greyed out in his Nvidia control panel....
It appears that the setting when using stereoscopic 3D  ->It is "greyed out" in the global settings tab
And can only be found in the Program Setting TAB of the NVCP under the BFBC2.exe.
*I have no idea if it will work or not.
Since I have no experience with a 3D surround config and BFBC2, I really cannot share any (personal) information about running the game with such a setup...
Sorry guys, I am waiting for new monitor models to be released before making that upgrade for BF3
Hi Maniac,
I decided to reset my global setting in NVCP and use the BFBC2 program settings instead just in case it might affect another game. But according to NVCP in the BFBC2 settings Ambient Occlusion is not supported whether on or off in Global.
But even with it off in the Global settings I see no difference in game play as far as the now and from my first post here, reaction seems faster too. Still a good guide to me.
EVGA x79 dark *** INTEL 3930K *** 2 - EVGA GTX 980ti Hydrocopper  *** 4 - 4GB Corsair Vengence 1600 C7 ***  2 - Vertex 460A 240GB - RAID 0  *** 2 - 3TB Green WD *** Sony Blu-Ray Opti-Drive *** EVGA TORQ 10 *** Corsair K70 Keyboard *** Window 10 PRO - 64 Bit *** 3 - ASUS VG236H *** 1 - LG IPS235V Accessory monitor ***Corsair AX1200i PSU
#61
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/13 23:54:52 (permalink)
taniquetil
Thanks for putting together this guide.
Is there any way you could explain a little more in detail as to what FOV is affected by and how someone would go about getting a good setting?
I noticed you recommended 75 but another comment on this thread said 65.
FOV or Field of view is the degree of viewing angle that is shown on the screen.
55 degrees (BFBC2 default) is commonly used by consoles, as the reduced angle results in much less pixels having to be displayed. That is done, because of the memory and graphics restrictions in consoles....
There is very little, if any need to be forced to use such a restricted viewing angle with full computer setups.
This setting can be adjusted to "taste" for what you feel gives you the "best" experience.
Please feel free to input different numbers (max is 120) and try them out. I only recommended the value of 75 based on my own personal testing and what I feel is the max value (75) before the "fisheye effect" begins to become noticable...
Please try stepping up the value 10 points at a time and test the effect yourself and you find that value that works best for YOU
#62
FattysGoneWild
Re:Battlefield BC2 GraphicSettings Guide 2011/07/14 00:28:58 (permalink)
I have been playing at 55 and just tried at 75. HUGE difference. Everything seems so far away. But that is only because I am use to the 55. I also came across a FOV calculator for BC2. http://www.rjdown.co.uk/p...fbc2/fovcalculator.php I don't really understand it though? My monitor is 16x9 native 1600x900 resolution.
post edited by FattysGoneWild - 2011/07/14 00:33:13
HP Envy Phoenix 810-430qe
OS: Windows 10 64 bit
MOBO: MSI Kaili2 Z97
CPU: Intel i7 4790K liquid cooling
RAM: 16GB DDR3 1600
GPU: EVGA GTX 1080 Founders Edition
PSU: EVGA SuperNOVA 650 P2
SSD: Samsung 256GB MZ7TE256HMHP
HDD: 2TB Seagate Barracuda ST2000DM001
Sound: Logitech Z623 THX 2.1 Speakers
Monitor: Dell S2716DG 2560x1440 @144Hz G-Sync calibrated with ColorMunki Display
Keyboard: Razer Blackwidow Chroma
Mouse: Razer DeathAdder Chroma
EVGA Affiliate Code: C3OXU3I2N9
#63
btk1976
Re:Battlefield BC2 GraphicSettings Guide 2011/07/14 07:10:42 (permalink)
Just an update. I put pretty much every setting on low at one point and still got a CTD. Maniac, is it possible that my CPU overclock is causing this? I know that the obvious answer is yes since I have been OC'ing for quite a long time. But I dismissed this as a possible problem because everything else was running fine and my temps were stable and low. Well, this is the only option I have left as to what is causing the problem and I will try it next. I know, it should have probably been one of the first things I should've tried. But again, I dismissed it because everything else was fine. If this doesn't work I can only re-install the game or upgrade hardware. Or reinstall windows. I am running out of options here. I am confident that your guide holds the answer to my problem. And you did mention OC'ing as a possible cause of CTD. I will let you know what happens. Thanks again for everything.
#64
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/14 10:54:15 (permalink)
btk1976
The answer is yes.
The BFBC2 enigine is well known for being sensitive to overclocks. My suggestion is to either drop your overclock 1-200mhz -or- add a small amount of voltage to your CPU.. Both suggestions have been known to be very helpful.
#65
coolhand41
Re:Battlefield BC2 GraphicSettings Guide 2011/07/14 11:00:43 (permalink)
^  this or bump your GPU v,easy way to find out is buy running all stock first,could be your PSU also
  Asus M6 Impact 4770K,  single loop H20,  8Gb Trident X @ 2666c10,  120 GB KINGSTON ssd, ,  CM 1000W .  GTX780 Classy/Hydro copper
#66
jayy3218
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/14 17:15:35 (permalink)
good stuff man like ur style thx..:)
#67
Monst3r
  • Ribbons : 16
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/14 20:38:00 (permalink)
Dude thanks so much!! Your BC2 settings have helped me a bunch! No more crashes from the Bloom and I also found my sound was set to low, sounds so much better now on high! And the FOV looks great! Though I turned it down it 65.
#68
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/14 20:38:47 (permalink)
Awesome bro, glad to hear that
#69
btk1976
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/15 07:10:22 (permalink)
I have been waiting a looooong time to say this, BFBC2 was stable last night!!!  Thanks a ton maniac. Using your guide and a process of elimination I was at long last able to determine my problem. I returned my OC'd cpu to its stock settings and there were no CTD's or BSOD's after more than an hour of game play!
Now, I know that this was just one night.  And I will need many more hours of game play to be satisfied 100% that my system is stable. But what happened last night has never happened. So I am very optomistic.
If you are someone who has just found this post and are having cronic stability issues with BFBC2, read maniacs guide. And read it in its entirety! That was a problem for me when I read it the first time. I saw some things in it that I was sure was my problem.  It turned out that the answer to my problem was somewhere else in the guide. Read this post, eliminate possible causes one by one and you will find your answer. I did!!!
Thanks again maniac! Now that I am on my way to a stable BC2 I can focus on my gaming. It was just awesome last night! I was actually finishing rounds! And not losing my score every F-ing time! Once I am confident that I am stable I can adjust my settings a bit and see what exactly my set up can handle. I am so excited!
#70
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/15 07:32:37 (permalink)
Your welcome bro.
Its posts like yours that make doing a guide like this, totally worth it
#71
NemesisChild
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 07:34:39 (permalink)
The game engine is definitely sensitive to CPU overclocks or lack of higher CPU voltage.
I have also found that a CTD or BSOD free experience is directly related to memory overlocks & timings.
Overclocked memory runs fine, but run stability tests before launching the game.
BFBC2 is very sensitive to memory timings, especially the tRC and CR settings.
With my 1866 RipjawsX, I could pass all stability tests with a tRC of 35 and a 1T CR.
But with BFBC2, a much different story, had to settle with a tRC of 37 and a 2T CR.
Intel i7 6700K@ 4.8GHz
Corsair H90 Hydro
ASUS Maximus VIII Hero
G.Skill TridentZ@ 3200MHz 32GB CL14
SLI: 2x EVGA GTX 980Ti SC@ 1455/1455MHz
OS: Samsung 850 EVO 500GB
Storage: WD Black 7200 RPM 64MB Cache 1TB
EVGA SuperNova 1200 P2
CM HAF 932 Advanced
Windows 10 Home x64 (UEFI)
#72
shaneduce
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 07:49:52 (permalink)
First off tyvm for the post
Sec. I'm one of the lucky few that has zero problems instaling and playing
Intel i7 4960X 32 gb mem EK-DDC 3.2 PWM X-RES 140, 3x VisionTek R9 290X and Blocks.
ASUS Rampage 4 Black Edition MB EK-FB ASUS R4BE Monoblock- Nickel 2x 360 Rad
27" ASUS mg27Pq 2560x1440 rez. Logitech G13, Tt eSports Poseidon Keyboard, Tt eSports Theron Mouse, Corsair K70 RGB
DD Torch er Rack Heatwave http://www.heatware.com/eval.php?id=76561
#73
Baasha
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 11:53:47 (permalink)
Maniacvvv,
Thank you very much for this brilliant guide in tweaking the settings in BC2! The game looks so much more incredible than before I can't believe how good it looks.
I have a couple of questions/doubts that are specific to my rig so perhaps you can help.
First, the game is absolutely stable and rock solid even with my CPU OC (4.41GHz) and GPU OC (850MHz).
I have 3 EVGA GTX-580 3GB in Tri-SLI so they're working great. The Ambient Occlusion setting is 'grayed out' and I am not able to change the settings under the "Program Specific" control (I don't want to change the global settings). How do I enable to it to "Quality" or whatever is best for a Tri-SLI rig?
Secondly, I'm playing at 8100x1600px so the FoV being at 55 makes the sides look stretched. I have to LOWER it to make it somewhat tolerable but it's really hard to play like that. For example, if I set the FoV to 35, it looks like I'm running in the same spot (like a treadmill). I suppose I have to sit really far back but what is the ideal FoV for playing at this high resolution? I have it set right now to 45 and I'm getting used to it but do you have any good suggestions regarding that?
Thirdly, since I'm playing at such a high resolution, my AA settings are at 16xCSAA. Even if I change it to 16xQ CSAA, the game crashes to desktop. The same happens with 32XCSAA as well. I'm assuming that's way too high even for 3GB GTX-580s? Also, with my current settings (everything on HIGH, 16xAF, 16xCSAA, etc.) I get around 90-105FPS. If I turn HSAO (HBAO) 'ON', the FPS drops to around 45-50FPS. I just left it off but why is HSAO making such a big difference in FPS?
Lastly, is it possible for you to do a similar guide just for the NVCP for Crysis 2? If you were able to make BC2 look so much better with tweaking some settings in NVCP, I can't wait to see what we can do with Crysis 2 DX11/High-Res Textures already looking fantastic!
Thanks again.
post edited by Baasha - 2011/07/15 11:58:27
4K Gaming in all its Glory! - ThirtyIR
The Uber Rig
Please check out my FOR SALE thread!
#74
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 13:11:31 (permalink)
Baasha
Maniacvvv,
Thanks again.
Your welcome
The answer to your first question is the NVCP AO is not supported in surround setups...
For you second question, I would suggest trying different values until you find your own "sweet" spot.
For your third question I dont really have an answer for the higher AA levels at the screen res you are using. As far as in in-game HASO setting, yeah its a known framerate killer made much much worse the the huge screen size your running.
*note: use afterburner or precision to look at your videocard RAM use, if its not topped off.. there may be an issue, as AA levels do not cause a crash when they run out on memory space, the frames just drop and it might start buffering on the hard drives...
I cannot tell you how nice the feedback is to get
Its doubtful I'll do a Crysis2 guide, but you can COUNT on a BF3 Guide the day its released to BETA
post edited by maniacvvv - 2011/07/15 13:21:51
#75
DuRKe
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 21:29:51 (permalink)
Well deserved BR maniacvvv,
Knock on wood I haven't had any problems with the game and I have tried your settings and all is still well except for invisible water.
2D surround triple monitor and triple sli 580 GTX with 270.61 is working fine for me in BFBC2, except for invisible water.
Have any suggestions?
Cheers!
i7 920 4.189 / Win 7 64-bit / X58 Classified-Bios 79 / GTX 580-3GB x 3 SLI / 6GB Corsair 1600 / Antec h2o920 / Corsair 600T / Thermaltake 1200W / 3 Dell 24" 2D Surround / 270.61 driver
#76
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/15 21:54:56 (permalink)
DuRKe
Cheers!
Thanks
For the water, what are your AA settings? Have you tried setting water to Med or Low?
#77
btk1976
Re:Battlefield BC2 Graphic Settings Guide 2011/07/16 09:10:07 (permalink)
A question manic. I am setting dxversion to 9 but when I enter game it keeps going back to auto. Why? I have aa to 1. Is there anything else that is reverting it back? Thanks.
#78
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/16 09:17:52 (permalink)
btk1976
Make sure there is not a "space" between the equal sign and the number in the settings file.
it should look like this =9
Remember, after making changes to the settings file you can LOOK at the the in-game Adavanced panel. But if you make any changes in that panel, some values in the settings file will revert to defaults.
*Also: if the "in game" Options setting panel (advanced) is showing AA at 1, then your ARE running DX9
#79
DuRKe
Re:Battlefield BC2 Graphic Settings Guide 2011/07/16 11:36:50 (permalink)
maniacvvv
DuRKe
Cheers!
Thanks
I just changed the water setting in the config file since I don't see a setting in game.  It was "high" and was still invisible in "medium" but it works fine in "low".  I'm running 32x CSAA application controlled.  Everything is maxed and I have the same settings as you in nvidia control panel and in game.  I'm curious if your water is visible on medium  and high.  You can see my system in my sig.
[WindowSettings]
Width=6060
Height=1200
Fullscreen=true
RefreshRate=59.950001
VSync=false
[Sound]
Quality=high
VoipEnable=true
SpeakerCount=0
[Graphics]
Effects=high
Soldiers=high
Vehicles=high
Overgrowth=high
Undergrowth=high
StaticObjects=high
Terrain=high
Shadows=high
Bloom=false
HSAO=true
MSAA=7
Water=low
MainQuality=custom
Texture=high
DxVersion=auto
Aniso=4
Detail=high
RenderAheadLimit=2
Fov=65
Thanks again for the help.
Cheers
#80
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/16 19:00:26 (permalink)
DuRKe
266.58 will show WATER on High
post edited by maniacvvv - 2011/07/17 02:25:49
#81
saer.
Re:Battlefield BC2 GraphicSettings Guide 2011/07/16 23:22:56 (permalink)
naokiura
maniacvvv
Hi Maniac,
I too would like to figure out how to enable ambient occlusion but it is also greyed out in my NVCP.
I do not have any 3D software installed and I am running a single monitor at 120hz(have a feeling it has to do with this)
I've tried everything and cannot get it to enable, searched google high and low with no answer.
#82
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/17 09:47:12 (permalink)
saer.
naokiura
maniacvvv
Hi Maniac,
Thanks for your question
It appears that BFBC2 uses a in-game based HBAO that supported within the engine. The NVCP setting is NOT needed.
And Geforce.com shows it as a (in-game) menu based item (580 using 266.58)
After reading up, neither your screen res or your refresh rate should effect using the setting.
The only things which appear to prevent doing so are using hardware, programs or games which do NOT support the setting.
Since I do not know the exact setup you are using (and have no experience using 120hz)...
I'm not really able to give you a good answer as to why its greyed out on your setup, except to say that if the in-game HABO is set to TRUE, then you are getting the full effect as supported by the game. It appears that the Nvidia control panel setting does NOT effect how BFBC2 displays its in-game HABO rendering (as best as I understand).
It might be something in your setup, like a app or program overlay that does not support AO that is keeping the NVCP setting greyed out.. I really dont know bro.
Its a very good question
As with all NVCP settings and different game engines, Googling, playing around and testing are the best way to find out what works best on a given config and what settings give you the image quality and performance your looking for...
Sorry I cannot give you a more definitive answer.
post edited by maniacvvv - 2011/07/17 10:00:30
RedCell141
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/17 11:34:17 (permalink)
Thx 4 the great in depth guide!
MOBO Sabertooth Z-77 CPU i-7 3770K @4.25GHz EVGA GTX 970 SC @(stock)1165MHz Gpu Boost(stock) 1317MHz PSU Cool Master silent pro 700w SSDSamsung 840 Evo 250 Gigs HDD WD Black Caviar 1TB, and WD 580GB8Gigs of DDR3RAM@ 1866MHz
#84
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/17 13:46:57 (permalink)
Thanks bro, was my pleasure doing it.
post edited by maniacvvv - 2011/07/17 14:22:09
#85
blood4guts
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/17 21:17:56 (permalink)
Just finished a small LAN party with my friends and played bc2 on a 1920x1200 monitor with a stock 570 and 2500k... Silk smooth, thanks! Your guide helped another friend too
#86
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/17 21:30:54 (permalink)
Awsome! glad to hear that
#87
ssj92
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/18 02:40:53 (permalink)
I didn't know the FOV value was changeable. Put it at 70 and it looks great!
Desktop: Intel Core i7 5820k | 32GB DDR4 2400Mhz | AMD Fury X | Samsung SSD Raid0 | EVGA SuperNOVA 1300 G2 | Onkyo TX-NR838 | Samsung UN40JU6700 Curved | Corsair K95 RGB | Razer Mamba | P26055 | FS-20495
CS Phoenix Laptop: Intel Core i7 6700K | 16GB DDR4 2400Mhz | nVidia GeForce GTX 980 | 512GB Samsung 950 Pro M.2 SSD | 2x330w AC Adapters
#88
btk1976
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/18 07:04:39 (permalink)
Ok, final update. You can play BFBC2 on an older system like mine. Without crashing too! Thanks maniac. No CTD since your help. I am running game in DX9 currently with everything on medium except static objects, water, sound and effects. They are all on low. And no OC. I may try going back to DX10 and some other adjustments eventually, to see just what I can handle. But stability is a beautiful thing!
#89
tynitty
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards 2011/07/18 07:46:36 (permalink)
maniac your thread is the best set up guide i have used too date nice job. i was useing my surround set up with your settings an was still getting ctd but i saw you tell someone that aa can cause ctd because it is such a big res ia that right i have now gone back to useing my 30 inch panel and have not had one ctd yet which is great but i have one thing to ask if i use 16css aa should i turn off multisample in nvcp. again great guide maniac thanks
#90
