Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards
Page: < 12345.. > >> Showing page 2 of 13
Johnny Quest
Re:Battlefield BC2 GraphicSettings Guide 2011/07/10 05:15:14 (permalink)
lol,good for you...some of these people in this post do though,and i don't think it has anything with getting another computer...what are your settings 800x600?
Hog54
Never had a problem with the game by just installing it and playing it.Never had to do any tweaks to anything.If you have to do all that stuff in this guide,get another computer.
Asus Rampage II Extreme////EVGA GTX 580 SC////Corsair HX 1050 ////12gb,Corsair Dominator- 1600mhz//// OCZ Vertex 2 240G SSD////300gb Velocoraptor////2- 640gb Western Digital black////Nextar HD docking station////Intel i7 965 Extreme at 4.0////Logitech Z5500 5.1 THX////Razer Death Adder left hand////Razer Black Widow Ultimate keyboard////Swiftech MCP655////EK-D5-Xtop 2,Fesser Dual Rad////,Koolance cpu 350 water block//// Bitspower Silver Compression Ftngs.////Danger Den Delrin fillport////Primoflex Pro LRT clear////Swiftech MCRES micro rev.2////Thermaltake Armour E-ATX////Asus VG236H 23" 3D////Monster Power HTS3600 MKII clean power stage 3v.2.1 filtering////Windows 7 Professional 64bit////Sore Wallet////
#31
NemesisChild
Re:Battlefield BC2 Graphic Settings Guide 2011/07/10 23:28:16 (permalink)
DXVersion - why would you want to run it on Auto?
If you have a graphic card that supports DX11, why not set this accordingly?
Intel i7 6700K@ 4.8GHz
Corsair H90 Hydro
ASUS Maximus VIII Hero
G.Skill TridentZ@ 3200MHz 32GB CL14
SLI: 2x EVGA GTX 980Ti SC@ 1455/1455MHz
OS: Samsung 850 EVO 500GB
Storage: WD Black 7200 RPM 64MB Cache 1TB
EVGA SuperNova 1200 P2
CM HAF 932 Advanced
Windows 10 Home x64 (UEFI)
#32
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/10 23:34:22 (permalink)
NemesisChild
Thats what AUTO does, sets it according to -->what your graphic card (and OS) supports
-->Forcing a value on that setting should not be done, unless your trying to gain framerates by dropping it.
#33
naokiura
Re:Battlefield BC2 Graphic Settings Guide 2011/07/11 21:06:36 (permalink)
Hi Maniacvvv,
Tried all your setting last night, I had forgot about that bloom issue and reverting back thing.
Since I built my new rig, P67 FTW and my two GTX 580's I was just dragging along like my player was tired although everything was smooth and my frame rate was averaging around 180.
Since changing to your settings to the "T" my player was more reactive and faster, but my frame rates had decreased to an average around 140, which is still actually fine.
I'll play with the settings a little more to see if it was just the bloom setting that made the change. I had everything in the BC2 options already set to what you had, but I hadn't played with the NV or the game ini.
thanks for your help
EVGA x79 dark *** INTEL 3930K *** 2 - EVGA GTX 980ti Hydrocopper  *** 4 - 4GB Corsair Vengence 1600 C7 ***  2 - Vertex 460A 240GB - RAID 0  *** 2 - 3TB Green WD *** Sony Blu-Ray Opti-Drive *** EVGA TORQ 10 *** Corsair K70 Keyboard *** Window 10 PRO - 64 Bit *** 3 - ASUS VG236H *** 1 - LG IPS235V Accessory monitor ***Corsair AX1200i PSU
#34
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/11 22:39:49 (permalink)
Your very welcome, glad your happy
#35
  • Ribbons : 92
Re:Battlefield BC2 Graphic Settings Guide 2011/07/11 22:56:41 (permalink)
 Very well done Maniacvvv. One of the best threads I've seen in a long time! Great job!
My Affiliate Code: 8WEQVXMCJL
#36
btk1976
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 09:31:30 (permalink)
Hello maniacvvv, thank you for the time you put in to your post. You obviously know what you are talking about and it's refreshing. There are so many people putting info online re: this topic that don't have a clue.
On to my issue. I am running an older system and I want to know what you would suggest I do to get a stable gaming experience. Hopefully that's possible. I having been experiencing regular CTD's and recently BSOD with memory dump. I tried to catch what the error code was last night while playing, I believe it said 0x3b. I read your entire post and applied as much of it as I could to my setup. And the game ran smoother than ever last night, but unfortunately, still CTD and BSOD. Both within an hour. I think I may have an idea as to what you will say and what the problem is, but I have thought that many times before and have been wrong. So I am going right to you with my problem and avoid an more stress trying to figure this out on my own. Okay, so you need my system specs:
Windows 7 x64 (fully updated), Intel dual core e7400 2.8 oc'd to 3.4 (w/aftermarket rosewill cooler), nvidia gts250 512mb with the drivers installed that you suggested above (and all the settings you recommended, as best as they applied to me), 4gigs of 1066 DDR2 on a GIGABYTE GA-EP45-UD3R mobo (with F12 newest bios). If you need any other info on my system ask.
On to the game settings. I also adjusted the settings in the exact way you described above and was very hopeful to end the CTD problem. My audio is set to low quality and bloom is false. voip is false as well. However, I do have the resolution of the game set to 1280x1024 I believe. I'm not home right now but I'm pretty sure it's that or near that. And all the other graphics settings are on high. The way you described above. So now that I did pretty much everything you said above and still have problems, I am thinking it is my hardware that cannot handle the settings that I have set in the game. It is the only possible thing I can think of. My friends play this game with no problem but they have newer systems with quad cores. I have a dual core. And above you said if you still get CTD's after trying everything stated, lower your graphics settings. So, like I said above, I am pretty sure that is what you are going to say, but I am done guessing. I need to know for sure now. The game runs pretty well at my settings. But maybe my processor just craps out after a while. So maniac, please help me figure this out once and for all. Tell me what I need to do. I don't plan on upgrading my hardware anytime really soon, so I really want this to work. Thanks in advance for any help you can give.
#37
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 09:57:42 (permalink)
btk1976
Hi bro and welcome to the EVGA Fourms
Yeah, with that hardware low to medium overall graphics settings. That will help alot...
I also suggest turning the "Multisample" Transparency setting to OFF.
*dont forget to go back into the BFBC2 folder in My Documents and reset BLOOM to =false
** You could also Force DX9 in the settings file for a good jump in FPS. You will have to test, because higher FPS will also increase the load on the CPU.
But my suggestion for the biggest gain (and fewer CTD's) has to do with the servers you play on.
What you want is lower player counts and the smaller map sizes. This will really help your framerates/stabilty on that system with those specs, by making the CPU and graphics overhead much less.
Some servers host maps that are 1/3 the size of the regular maps, given your specs I would suggest trying to stay below 24 players, with 16 players or less being the best performer.
Good luck and happy gaming
post edited by maniacvvv - 2011/07/12 10:32:12
btk1976
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 10:01:46 (permalink)
Thanks a lot man. I will try that and let you know how it goes.
#39
Dedaciai
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 14:58:08 (permalink)
Hi Maniacvvv,
WOW!!! Just wow!  I followed the majority of your settings (just a personal preference but changed my fov to 65 instead of 75) and it made a big improvement in the smoothness of BC2.  Even though my framerates dropped a little bit (from avg 110 to about 85) I feel like I am floating as I run in the game.  I thought going from a single 570 to a dual helped a lot, but this was major improvement.
Thanks again and keep up the great work!
Intel Core 4770K @4.25GHz
Asus Maximus VI Impact
Crucial MX200 M.2 SSD 512GB
EVGA GTX 970 FTW+
Corsair Vengance PRO RAM 8GB @ 1866MHz
NCASE M1 V2
Noctua L9X65 CPU Cooler
Corsair SF450 450 Watt PSU
#40
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 15:01:05 (permalink)
Your welcome!
Yes, the settings can make a big difference to the "feel" of the game.
The word "wow" is often used to describe the reaction when ones game runs the way it was intended
post edited by maniacvvv - 2011/07/12 15:10:54
#41
NemesisChild
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 17:51:30 (permalink)
Changed the SpeakerCount from 2 to 0 and omg, I forgot what incredible sounds I was missing in BFBC2.
Maniac, you da man, thanks for the tip(s).
Corsair H90 Hydro
CM HAF 932 Advanced
#42
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide 2011/07/12 18:38:17 (permalink)
Yep
Alot of folks have been using incorrect information about the speaker codes.
I cannot tell you how many players have said to me on TS "what, I dont hear ANY that... you do?"
If you get your sound settings correct.. yes, you do
*This is NOT to say if your having problems, you shouldnt test out dfifferent setings (as noted in my guide).
post edited by maniacvvv - 2011/07/12 18:53:52
#43
major53
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:17:41 (permalink)
maniacvvv i get to this in game advance setting and I only have the option to go 1x on the ANTI ALIASING what can I be doing wrong?it only shows the option to go 1x
MSI Z87-G45 GAMING MOBO▐ Intel Core i5-4670K HASWELL (oc 4.4) ▐ Coolmaster hyper 212 plus 120mm Heatsink▐G.SKILL 8GB rip SNIPER SERIES 1866 (2 x 4GB) 240-Pin DDR3( 14900)▌ Samsung 500GB 2.5-inch SSD 840 Series (os)  EVGA SUPERCLOCKED 02G-P4-2765-KR G-SYNC GTX 760 2GB 256-BIT▐ Antec High Current Gamer Series HCG-900 900 Watt ATX12V v2.31 EPS12V v2.91COOLMASTER HAF 932 Case▐ WINDOWS 8.1  HOME 64 Bit ▌
#44
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:20:31 (permalink)
Check your--> DXversion =AUTO (line in the settings file)
Having only x1 showing is from running the game in DX9
*also as noted in the guide, you must do the NVCP settings first before continuing on to the setting file.
EDIT: I had forgotten about that. I went back and edited my guide to mention that issue
post edited by maniacvvv - 2011/07/12 19:27:31
#45
major53
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:26:51 (permalink)
maniacvvv thats why you are the doctor and I'm just Frankenstein.how yah bro you are correct again.thanks heir doctor .
post edited by major53 - 2011/07/12 19:31:57
#46
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:28:30 (permalink)
MANIAC senses another "WoW!" post incoming
#47
major53
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:33:39 (permalink)
here's your world of warcraft heir doctor.that a double?
#48
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:36:13 (permalink)
Wait till you play the game on a GTX 580, without forcing DX9 ON bro
#49
major53
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 19:43:22 (permalink)
heir doctor I guess that is the way I have been playing it, is that why dxversion should be set to auto.remember bro major is old school be easy on him heir doctor. got to get back to the guide see you around heir doctor.
post edited by major53 - 2011/07/12 19:51:06
#50
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 20:05:49 (permalink)
I have just recived a PM from a member asking about why his Ambient Occlusion setting was greyed out in his Nvidia control panel....
It appears that the setting when using stereoscopic 3D  ->It is "greyed out" in the global settings tab
And can only be found in the Program Setting TAB of the NVCP under the BFBC2.exe.
*I have no idea if it will work or not.
Since I have no experience with a 3D surround config and BFBC2, I really cannot share any (personal) information about running the game with such a setup...
Sorry guys, I am waiting for new monitor models to be released before making that upgrade for BF3
post edited by maniacvvv - 2011/07/12 20:19:30
#51
blood4guts
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 20:30:47 (permalink)
Just finished downloading BC2, followed your instructions, and it looks and acts like a charm. Thanks!
#52
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 20:33:44 (permalink)
Great to hear that bro
#53
coolhand41
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 22:33:09 (permalink)
thanks maniac ..FOV @75 is just insane ;)
  Asus M6 Impact 4770K,  single loop H20,  8Gb Trident X @ 2666c10,  120 GB KINGSTON ssd, ,  CM 1000W .  GTX780 Classy/Hydro copper
#54
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 22:40:10 (permalink)
Glad it hear it bro, makes doing this guide worth the work
#55
kmconstable
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 23:46:17 (permalink)
Do you have any advice for CTD with surround?  This is not 3D, but just surround with 3 monitors.  I get CTD every time I play.  I did try to turn off Bloom and I must say the game looks better and I don't get the horrible light problems anymore, but still CTD.  Thanks for any help.  I know the guide is not done.  The last stable driver I used for the game was 266.58.  Every driver beta or WHQL since has CTD.
Specs:
HAF-X | ASUS SABERTOOTH Z77 | i7 3770K @ 4.2 |  Corsair H100
Corsair AX1200 | 4x8gigs G.Skill Trident-X 2400 | 2 x ASUS DCUII GTX 670 | Intel 320 600gig | 3 x 27 inch monitors 2D Surround | HT Omega eClaro | Onkyo 7.1 receiver with Polk Monitor Series x 7 & 12in Sub | Denon AH-D5000s
#56
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/12 23:53:42 (permalink)
kmconstable
I dont have any personal experience with surround bro....
I could make some suggestions.
-->Try setting "Effects" to Medium-->then test
-->Try forcing DX10 (as explained in the guide)--> then test
--> make sure your NOT using any "overlay" software like the Afterburner or Precision OSD (known to cause issues)
--> If your CPU is overclocked, try a very small bump to the voltage (known to help in BFBC2)
Sorry I cant be more helpful in this area. Perhaps someone with Surround experience will post better information.
#57
kmconstable
Re:Battlefield BC2 GraphicSettings Guide 2011/07/13 00:01:54 (permalink)
Thanks for the fast response.  I also will probably test the game without surround to be sure the system is stable as well.   And btw thanks for the guide great work!
Specs:
#58
maniacvvv
  • Ribbons : 159
Re:Battlefield BC2 GraphicSettings Guide 2011/07/13 00:03:19 (permalink)
Thanks bro, really sorry I cant be of more help on this for you....
#59
taniquetil
Re:Battlefield BC2 GraphicSettings Guide 2011/07/13 22:27:05 (permalink)
Thanks for putting together this guide.
Is there any way you could explain a little more in detail as to what FOV is affected by and how someone would go about getting a good setting?
I noticed you recommended 75 but another comment on this thread said 65.
System Specs:
Chassis: Antec 1200
Mobo: EVGA x58 FTW3
CPU: i7 950 @ 3.9GHZ
CPU Cooler: Cooler Master V8
GPU: EVGA GTX470 @ 760/1520/1720
Folding GPU: EVGA 9800GT @ 700/1744/950
RAM: 3x2GB Patriot Sector 7
PSU: Corsair 750TX
Creative Sound Blaster...The One Everybody Has
#60
