maniacvvv
- Ribbons : 159
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards
2011/07/18 08:39:49
ssj92
I didn't know the FOV value was changeable. Put it at 70 and it looks great!
Yes, I find that slightly increasing the FOV makes a big change in how much fun the game is to play
maniacvvv
- Ribbons : 159
2011/07/18 08:41:01
btk1976
Ok, final update. You can play BFBC2 on an older system like mine. Without crashing too! Thanks maniac. No CTD since your help. I am running game in DX9 currently with everything on medium except static objects, water, sound and effects. They are all on low. And no OC. I may try going back to DX10 and some other adjustments eventually, to see just what I can handle. But stability is a beautiful thing!
Nice work bro, congrats
maniacvvv
- Ribbons : 159
2011/07/18 08:42:41
tynitty
maniac your thread is the best set up guide i have used too date nice job. i was useing my surround set up with your settings an was still getting ctd but i saw you tell someone that aa can cause ctd because it is such a big res ia that right i have now gone back to useing my 30 inch panel and have not had one ctd yet which is great but i have one thing to ask if i use 16css aa should i turn off multisample in nvcp. again great guide maniac thanks
Thanks bro  *your fine to leave Multisample on bro
2011/07/18 09:38:01
i fine getting 190fps in single player but for multiplayer I had to force down to DX9 to get above 60fps, now i'm running at 95fps?? oh well, better than before.
|| EVGA P67 FTW || 2600k || SLI 3GB EVGA 580's || Mushkin Blackline 2133Mhz 8GB 9-11-10-28 || Intel 510 SSD 250GB || 2x RAID 0 WD Raptor 600GB || WD Cavaier Black 2TB || Corsair HX1000 || Corsair H100 h2o || HAF X 942 ||
maniacvvv
- Ribbons : 159
2011/07/18 09:55:04
fakename
95fps is kinda low for that setup and the settings I have posted... is that with DX=Auto, or DX9? With my settings, you should be getting 150fps+ with DX=Auto and SLI 580's
2011/07/18 09:58:37
maniacvvv fakename i fine getting 190fps in single player but for multiplayer I had to force down to DX9 to get above 60fps, now i'm running at 95fps?? oh well, better than before. 95fps is kinda low for that setup and the settings I have posted... is that with DX=Auto, or DX9? With my settings, you should be getting 150fps+ with DX=Auto and SLI 580's DX=Auto gave me 60fps, DX=9 + the settings you listed (scaled back all the visual goodies too) only gave me 95fps . Any help to boost me back up would be very greatly appreciated. As I said, I'm getting 195 fps in single player. I play the game on steam, could that somehow be an issue?
maniacvvv
- Ribbons : 159
2011/07/18 10:01:18
fakename
maniacvvv
fakename
Sounds like you have/or had VSync on.. check the Nvidia control panel, make sure VSync is set to "Application Controlled". Then open the settings file (as posted in my guide) and check that Vsync=false Now change the DX setting back to Auto, make sure BLOOM didnt reset and save the changes and go test. If you want, post your BFBC2 settings file and I'll look it over
post edited by maniacvvv - 2011/07/18 10:06:04
2011/07/18 10:04:26
maniacvvv fakename maniacvvv fakename i fine getting 190fps in single player but for multiplayer I had to force down to DX9 to get above 60fps, now i'm running at 95fps?? oh well, better than before. 95fps is kinda low for that setup and the settings I have posted... is that with DX=Auto, or DX9? With my settings, you should be getting 150fps+ with DX=Auto and SLI 580's DX=Auto gave me 60fps, DX=9 + the settings you listed (scaled back all the visual goodies too) only gave me 95fps . Any help to boost me back up would be very greatly appreciated. As I said, I'm getting 195 fps in single player. I play the game on steam, could that somehow be an issue? Sounds like you have VSync on.. check the Nvidia control panel, make sure its on "Application Controlled". Then open the settings file (as posted in my guide) and check that Vsync=false Now change the DX setting back to Auto, make sure BLOOM didnt reset and save the changes and go test. i specifically turned vsync off in the settings file (didn't confirm in game though or the nvidia cpl), i will check that when i get home from work. also turned bloom to false in the settings file, but once again, did not make sure it was confirmed in game. I will once again check at home. I HOPE it is something that simple <<edit>> i'll confirm those settings tonight and if it doesn't work i'll post my settings **THANKS!!**
maniacvvv
- Ribbons : 159
2011/07/18 10:06:51
NP, lets get you those extra 50fps bro
2011/07/18 13:08:44
I get what I guess you would call micro stutter from time to time, very random issue. This is where you get a 2-3 second drop in FPS, game play slows a bit, then it goes back to normal. Not sure if it's a server (network) or game engine or settings issue.
Intel i7 6700K@ 4.8GHz Corsair H90 Hydro ASUS Maximus VIII Hero G.Skill TridentZ@ 3200MHz 32GB CL14 SLI: 2x EVGA GTX 980Ti SC@ 1455/1455MHz OS: Samsung 850 EVO 500GB Storage: WD Black 7200 RPM 64MB Cache 1TB EVGA SuperNova 1200 P2 CM HAF 932 Advanced Windows 10 Home x64 (UEFI)
2011/07/18 19:15:11
maniacvvv
sweeet!!! messed with the nvidia cpl per your guide and now i'm finally back to getting 153fps AFTER turning all my settings (which I had forced down) back up. No more DX9 or low texture packages for me! Thanks a ton!
maniacvvv
- Ribbons : 159
2011/07/18 19:19:51
Outstanding bro!
2011/07/19 13:23:55
Just want to point out that in the NVCP, there is an Application-contolled setting for Anisotrophic Filtering. You neglected to mention this under this topic for NVCP settings. So, if you use the in-game setting of 16x, you can set Anisotrophic Filtering to Application-controlled in the NVCP.
maniacvvv
- Ribbons : 159
2011/07/19 13:41:58
Thanks for pointing that out. I have gone back and edited it to show the default "Application controlled" setting.
Grobiatti
2011/07/19 20:44:12
eVGA X79 Dark Intel i7 3930k32 GB (4x8GB) Ballistix Elite DDR3 @ 2133 10-10-10-27-1t 2 HD7950's 3GB @ 1200/60001 120GB SATA3 Sandisk SSD (boot) 1 Seagate 2TB SATA3 (data) 1 LG Blu-ray writer eVGA 1300W G2 PSU Windows 7 Pro x64 Custom water cooling loopNZXT H630 Case My Heatware [link=http://www.heatware.com/eval.php?id=67526]http://www.hea
maniacvvv
- Ribbons : 159
2011/07/19 21:04:58
geswek
- Ribbons : 5
2011/07/19 21:21:03
Maniac's tips, tricks, and talking to me on the phone has made me freaking LEATHAL. I just pawned a two game streak with over 45 kills as a Sniper per run-- do not get in my cross hairs when I'm carrying my M95-- you won't survive very long. *GiGGLe* I also love me M16A2 Specat assault rifle too! I can't WAIT for BF3-- Thanks again Maniac for all your help!
LiquidKhaos v4 [build thread] [heatware] Case & PSU: MM U2-UFO Black Mirror · Corsair AX1200 System Core: I7-4930-E @ 4.5GHz 1.278v · EVGA X79 Dark · 16GB Corsair Dominator Platinum DDR-2133 9-11-11-31-2T Storage & OS: Samsung 850 Pro 512GB · Western Digital Caviar 1TB · Windows 10-64bit Pro Multimedia: EVGA GTX 780 SC SLI 1201/3151 · Dell Ultrasharp IPS 30in · X-Fi Fata1ty Champion Watercooling: HK 3.0 Rev 3 Black Nickel · (2) EK-FC GTX780 · (2) Black Ice Xtreme 3 3x120 · (2) Swiftech MCP655
maniacvvv
- Ribbons : 159
2011/07/19 21:35:14
You welcome bro, was pleasure meeting you. Glad to hear your getting your Game On properly!
geswek
- Ribbons : 5
2011/07/19 22:23:24
I'm getting there--Recon fully unlocked, working on Assault. I just want a damn scope on my M16A2--kinda hard iron-sighting these fools but I'm doing well. Average about 20 kills run and so far my deaths haven't exceeded my kills LOL.
maniacvvv
- Ribbons : 159
2011/07/20 01:54:12
NemesisChild
It could certainly be a server or connection issue... *(most likely) Such things are very hard to understand unless I can see it personally in front of me while its happening. *Its doubtful it has anything to do with any videocard settings given your dual 570 SLI performance levels. There -are- a few places on certain maps, while looking in a certain direction you will see a slight FPS drop due to certain quirks on how that view is being rendered.. you could test and see if its happening in the same places.. *(worth remembering "where" you saw the fps drop) There are also some configs, that appear to have random fps drops that seem to have something to do with having alot of USB devices, combined with a very high polling mouse. That can be tested by disconnecting as many USB devices as possible and/or dropping the polling rate on the mouse and testing... *(longshot) I'm sorry I dont have any real ideas besides the above. Such issues are very hard for one user to describe to another... If you continue to have issues, please post back and we can try to look things over and see if anything stands out.
post edited by maniacvvv - 2011/07/20 02:14:12
Fiko0
2011/07/21 04:44:58
NemesisChild I get what I guess you would call micro stutter from time to time, very random issue. This is where you get a 2-3 second drop in FPS, game play slows a bit, then it goes back to normal. Not sure if it's a server (network) or game engine or settings issue. Exactly the same issue here.. I had this with my older game pc and with my new game pc.. First and second gameplay in multiplayer its good than it starts the stutter like you said time to time.. Check out in singleplayer.. When you doing left right left right you see the gun moving very good.. When you do this at multiplayer, you will see that the gun stutters.. Personally i think that the game is not optimazed for PC platform. They do the best for console and for us they give us just piece of crap.. @topicopener: Thanks, it helped a bit.. The movement changed and its now like i run faster :D But as i said before still have stutter problems. I have a gtx580 SC btw.
2011/07/21 11:58:39
I have followed your settings to the letter and guess what, no more CTD's. I can even play with AfterBurner running in the background with OSD monitoring. However, my average GPU usage (both 570's in SLI) is only around 65-75%. My average FPS is in the 75-85 range, which seems low to me. But this is probably due to the fact that my GPU usage is somewhat low. My 1090T X6 is running a tad over 4.0GHz. Shouldn't I be getting higher GPU usage and subsequently higher FPS?
heritage1550
2011/07/21 18:33:49
maniac, just wanted you to know that I changed my settings to what you recommended in your guide a couple of days ago. I have a EVGA GTX 580 gpu. It makes a helluva difference compared to what I had.  I noticed in particular that it seems like I can run faster. Unfortunately it didn't improve my ability to hit anything. LOL!! Everything runs smooth and the detail is amazing. Thanks for taking the time to put the guide together. Don't forget, didn't you promise to do one for BF3??!!?? I hope. Thanks again.
maniacvvv
- Ribbons : 159
2011/07/21 18:35:05
GPU use with the settings I have posted should be showing 98% with some minor dips to 95 while playing... Please check your settings, you may have missed something or set it incorrectly.
maniacvvv
- Ribbons : 159
2011/07/21 18:36:43
heritage1550
Nice  Thank you bro
btk1976
2011/07/22 13:44:31
Hi maniac. I have seen posts on other websites that say running bad company 2 in administrator mode is the way to go. Is that true? Also saw people suggesting running the game in different compatibilty modes. I have Win7 x64. Should I just leave it set to windows 7 or have you heard of the game running better set to another option? Thanks!
2011/07/22 13:55:42
Just leave it on Windows 7 mode and you should run it as an admin. You may want to disable visual themes and desktop composition under the compatibility tab. All this does is disable Windows Aero from running in the background when launching BFBC2.
maniacvvv
- Ribbons : 159
2011/07/22 14:16:58
btk1976
Outstanding question! There is only one proper way to run BFBC2 START / ALL PROGRAMS / GAMES -then- "right click" on the BFBC2 icon and choose "Run as Admin" -->Running BFBC2 in any other fashion, is incorrect and it can and does cause all kinds of issues. Do not try and copy the .exe shortcut to the desktop. Do NOT use any compatibilty modes. DICE/EA designed the game to run this way (fromSTART/ALL PROGRAMS/GAMES) due to the way the games DRM is designed -and- because certain features and sub features (Punkbuster Etc.) cannot work properly if its not run that way due to Admin rights permissions issues. If your having disconnects, punkbuster problems, cant see other players pings real-time while your playing.... Then, you might be launching the game incorrectly. The game will still RUN when launched poorly, but it WILL have issues and problems that can be avoided by launching the game "correctly" Thanks for your question and I will be editing my post to show the correct steps
btk1976
2011/07/22 14:20:45
Oh man, thanks a lot again maniac. Unfortunately my ctd issue came back after a couple days with no problems. And all along I have not been running the game in admin mode. Thanks and I will try this and see if it helps me return to stability.
maniacvvv
- Ribbons : 159
2011/07/22 14:22:58
btk1976
Dont forget to open the BFBC2 "settings" file, and check that Bloom has not reset. Remember, making -any- changes to the in-game settings Options panel -will- reset it.
