LockedHot!Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit
Trip4w
2015/01/21 03:30:51 (permalink)
Ordered the backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR
The backplate has 9 screwholes and only 5 align with 5 on my gtx 980. I have the correct ID number on the backplate. In the PDF techincal Spec sheet on EVGA acessories page there is another backplate that would fit to my Gtx 980. I need the Backplate in the techincal Spec sheet.
Where is the backplate that fit my 04G-P4-2983-KR?
post edited by Trip4w - 2015/01/21 09:23:34
69 Replies Related Threads
    bkhan530
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 04:12:15 (permalink)
    Doesn't the straight pipe design of ACX 2.0 negate the need for a backplate anyhow? I had them on my Titans and I found it didn't really do much for them aside from just being a bit more aesthetically pleasing.
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 04:43:54 (permalink)
    bkhan530
    You are correct it probably will not make much difference on the performance but it looks very nice with backplate :)
    Hopper64
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 08:28:21 (permalink)
    I have the same video cards and was waiting on the backplate that you mention. Maybe that's why they are not in stock?? Do you have pictures of the incompatibility? Thanks.
    Asus R5Edition 10
    i7 6950X @ 4.3
    CorsairDP CMD64GX4M4A2400C14        Corsair AX 1500i
    Samsung 950 Pro
    Nvidia Titan X Pascal X2 SLI
    EK-XLC Predator 280
    Creative SBZ
    Asus PG348Q
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 09:09:26 (permalink)
    Hopper64
    The one I got is the picture of the item P/N: 100-BP-2981-B9 but if you check both on EU and US site and download the Manual that Backplate has another layout of the holes and that backplate is not the same as the one on the product page for P/N: 100-BP-2981-B9. The one in the Manual has 8 screwholes but the one featured on the product page has 9 and only 5 of them align with the screws of 04G-P4-2983-KR.
    post edited by Trip4w - 2015/01/21 09:15:25
    Hopper64
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 09:15:35 (permalink)
    Trip4w
    Hopper64
    The one I got is the picture of the item P/N: 100-BP-2981-B9 but if you check both on EU and US site and download the Manual that Backplate has another layout of the holes and that backplate is not the same as the one on th epropduct page. The one in the Manual has 8 screwholes but the one featured on the product page has 9 and only 5 of them align with the screws of .
    That's really strange. Hope you get it sorted. EVGA tech support/customer support should be helpful.
    Asus R5Edition 10
    i7 6950X @ 4.3
    Samsung 950 Pro
    EK-XLC Predator 280
    Creative SBZ
    Asus PG348Q
    Hopper64
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 09:25:10 (permalink)
    Thanks for adding the pictures too. That's helpful.
    I wonder why this has happened. I have installed several of their backplates without issue. ??
    post edited by Hopper64 - 2015/01/21 09:27:55
    Asus R5Edition 10
    i7 6950X @ 4.3
    Samsung 950 Pro
    EK-XLC Predator 280
    Creative SBZ
    Asus PG348Q
    VVhiplash
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 09:39:54 (permalink)
    EVGA is still trying to figure out what its doing with its own backplates. Because there are so many PCB revisions of the 980 and 970, (acx, evga-1982, nvidia refernce, ssc+, ftw+, etc) the original backplates they made no longer fit correctly. They're remanufacturing their backplates for the time being and will reannounce them in some way once they're finished. Sad, but true. But thats why a couple of those screw wholes don't line up. Also, if you try and use the backplate with the computer turned on, they're saying that it will ground-out, or short, the video card due to solder points making contact with the backplate. Soo.....
    ll Steiger-Dynamics Maven ll Intel i7-5930k 4.2Ghz ll ASRock X99 Extreme6/AC ll Liqmax II 240 ll GeiL Super-Luce 32gb 2666mhz ll (x2)EVGA GTX 980 SC ll Samsung XP941 500gb and 850 Pro 1TB ll EVGA PS 1000W Platinum ll
    Hopper64
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 11:21:06 (permalink)
    VVhiplash
    Wow, thanks for the insight. Had no idea. Wish EVGA would announce somethng about this.
    Asus R5Edition 10
    i7 6950X @ 4.3
    Samsung 950 Pro
    EK-XLC Predator 280
    Creative SBZ
    Asus PG348Q
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 11:24:04 (permalink)
    Thanks I also noticed that the middle hole do contact with soldering points on the PCB. I dont understand why they sell backplates that does not fit and if I were to try and attach it and start my graphiccard would most likely get destroyed?
    Fennicillin
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 11:34:19 (permalink)
    And for an $20 a pop on their upper echelon cards too when other vendors are including them.
    The Great Other - NZXT H440 white | 4770k @ 4.4Ghz | Z87 Sabertooth w/custom white TUF shield | 980 ti Classified | 16GB Patriot Viper 2400Mhz | 500GB Samsung 840 Evo | Seagate Barracua 2TB | EVGA Nova G2 1000 watt w/ blue cables
    VVhiplash
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 12:10:09 (permalink)
    Fennicillin
    Yup. I hear ya. Ive PM'd them about it, but havent heard anything back yet. As far as destroying the card by turnin it on with the backplate, i dont know. But id say you have a pretty good chance. Announcing the the world that their backplates dont fit looks pretty bad as far as company image goes. Which is probably why they havent said anything. Nor did they announce they were redoing the 970s before they released them, even though they did it because of community response. I dont like it either, but i do like evga, and i want backplates... So rather than make a huge case about it, im going to wait patiently and hope theyre on the tech gods nice list.
    Fennicillin
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/21 12:16:25 (permalink)
    VVhiplashYup. I hear ya. Ive PM'd them about it, but havent heard anything back yet. As far as destroying the card by turnin it on with the backplate, i dont know. But id say you have a pretty good chance. Announcing the the world that their backplates dont fit looks pretty bad as far as company image goes. Which is probably why they havent said anything. Nor did they announce they were redoing the 970s before they released them, even though they did it because of community response. I dont like it either, but i do like evga, and i want backplates... So rather than make a huge case about it, im going to wait patiently and hope theyre on the tech gods nice list.
    The 900 series release was like a train of mine carts crashing. Someone wanted to go way too fast to get the product through that tunnel. It seems to have been mostly cleaned up with cards being rereleased with new skus as revisions but it's eerily reminiscent of AAA game title patches. Release now, polish later.
    FlankerWang
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 09:58:28 (permalink)
    Since I'v decided to buy a FTW & backplate, I looked so carefully at the backplate 100-BP-2984-B9.
    Finally I found that, maybe EVGA exchanged the pics of 100-BP-2981-B9 and 100-BP-2984-B9 by mistakes?
    EVGA GTX 980 Backplate
    http://www.evga.com/Products/Product.aspx?pn=100-BP-2981-B9
    EVGA GTX 980 FTW Backplate
    http://www.evga.com/Products/Product.aspx?pn=100-BP-2984-B9
    This one is for the FTW, but looks familiar, right? Yes, you can see it in GTX 980 Backplate Installation, too.
    http://www.evga.com/products/pdf/m021-00-000056.pdf
    FlankerWang
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 10:02:04 (permalink)
    So I'm quite confused now. I ordered a backplate for FTW, but I dont know which style of backplate will be delivered to me. Especially considering I'm not living in US.
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 11:13:30 (permalink)
    Well it seems that EVGA got their backplate for SC and FTW mixed up in their inventory so that what should have been a backplate for SC is now a backplate for FTW and the other way around. Here is a full picture of my backplate where you can see that the part number is correct it is just that this backplate might be for the FTW version
     Thank you FlankerWang for the research
    post edited by Trip4w - 2015/01/22 11:20:16
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 11:18:10 (permalink)
    FlankerWang
    It will be very interesting if your backplate will fit, please get back us and fo ryour info I live in EU and ordered from the German warehouse it says it has been packaged in germany on the partnumber of the backplate so maybe the mixup is only in the EU warehouse.
    N.i.C
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 12:34:30 (permalink)
    I have exactly the same issue, i received my backplate yesterday, 100-BP-2981-B9, for my 980SC ( 04G-P4-2983-KR as the ts mentioned) and 4 screws out of 9 do not allign. I was about to open a thread today, but i stumbled on this one, so i don't think we need more images to understand the issue. I have already removed the backplate, not only because it was trembling, i know maybe there is no danger, but i didn't like having it that loose, but also there is obviously a real good chance for shortcutting the board as VVhiplash said (although it ran fine on me). Any chance we will be getting an formal answer from EVGA here?  Trip4w what did you do?
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 12:40:24 (permalink)
    N.i.C
    Good you didnt by accident shortcut the card because that middle hole is dangerous. I hope that FlankerWang solved the problem by identifying that it looks like a mixup by EVGA btw SC and FTW version of the backplate.
    I have a support ticket running and EVGA replied that they are checking with their tech team.
    post edited by Trip4w - 2015/01/22 12:44:15
    N.i.C
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 12:52:08 (permalink)
    Trip4w
    N.i.C
    Good you didnt by accident shortcut the card because that middle hole is dangerous. I hope that FlankerWag solved the problem by identifying that it looks like a mixup by EVGA btw SC and FTW version of the backplate.
    I see, i guess i need to open myself one too. Yep, FlankerWag let us know about your findings, if it's possible. Also, there were no instructions inside the package, i've changed a couple backplates in the past and i knew the drill (the "sticky" kinda plastic covers between the backplate and the card fooled a lot of people) and the .pdf file does not match, as you pointed out too. I think it will be good to have an official answer here, when this is sorted out.
    EVGATech_DaveB
    EVGA Tech Support
    • Ribbons : 43
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 13:52:21 (permalink)
    Hello all, I am pulling a card and a backplate to test fit as this should definitely not be happening.  I will follow up again once I have parts in hand to verify with.
    djcypher1
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 14:01:50 (permalink)
    EVGATech_DaveB
    Thanks for checking Dave
    System Specs:
    Metal box with an X99 system, a bunch of EVGA parts, and some wires inside of it.
    N.i.C
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 15:03:43 (permalink)
    Great, let us know Dave, thanks!
    #23
    EVGATech_DaveB
    EVGA Tech Support
    • Ribbons : 43
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 17:40:21 (permalink)
    I just pulled the card and the backplate, and i actually found no fit problems.
    After comparing the card I just assembled (I have pics if any of you are curious) and the backplates posted here, it looks as though the regular version and the FTW have been mis-packaged, I will let the support manager know about this so we can assist those who have had the issue and speak with our back end and get this resolved at the source.
    Again I apologize for the inconvenience, and we will work to get this resolved for all of you.
    **addendum**
    I have informed the heads of US and EU customer service know so we can get this straightened out for those of you who have the incorrect backplates.
    post edited by EVGATech_DaveB - 2015/01/22 18:10:09
    #24
    FlankerWang
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 18:29:48 (permalink)
    EVGATech_DaveB
    **addendum**
    My friend who helped me buy the backplate just send me the photos of my FTW backplate. It looks much the same as
    And it matches the paper GTX 980 FTW backplate installation.
    Actually when I replyed this post few hours ago, I didnt realise Trip4w and N.i.C are in EU. So I was quite uneasy.
    Now it seems that, EVGA US just put the pics in wrong place. But EVGA EU maybe really made a big mistake.
    post edited by FlankerWang - 2015/01/22 18:50:29
    #25
    EVGATech_ChrisB
    Administrator
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 19:34:53 (permalink)
    Dear Trip4w,
    I am very sorry for any inconvenience and I can confirm that I have requested that our German office sends you the correct backplate to assist.
    If anyone else did purchase one of these backplates and you did receive the wrong one for your card then please email me at chrisb@evga.com with a picture of the backplate received and your order number.
    I would also like to mention that this has been fixed and will not occur on future orders.
    Trip4w
    post edited by EVGATech_ChrisB - 2015/01/22 19:39:17
    #26
    Trip4w
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/22 22:49:13 (permalink)
    Great news and thanks for solving the problem.
    #27
    N.i.C
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/23 05:39:47 (permalink)
    Thanks Chris for taking immediate action. Kudos to Dave and FlankerWang for letting us know!
    #28
    Hopper64
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/23 09:54:58 (permalink)
    That makes things more clear, but in the pictures above, which is for the SC and which is for the FTW? The contours of each backplate are distinct, so which one goes with which card? Thanks.
    Asus R5Edition 10
    i7 6950X @ 4.3
    Samsung 950 Pro
    EK-XLC Predator 280
    Creative SBZ
    Asus PG348Q
    #29
    EVGATech_ChrisB
    Administrator
    Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit 2015/01/23 10:11:01 (permalink)
    GTX 980:
    GTX 980 FTW:
    Hopper64
    post edited by EVGATech_ChrisB - 2015/02/04 12:38:59
    #30
