Hopper64
Re: Backplate 100-BP-2981-B9 for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR does NOT fit
2015/01/23 10:44:55
OK. Thanks. Then the product pictures are reversed on your website product page then as FlankerWang pointed out above. So, are there any backplates available for my EVGA SC GTX 980 ACX 2.0. 04G-P4-2983-KR?
Asus R5Edition 10 i7 6950X @ 4.3 CorsairDP CMD64GX4M4A2400C14 Corsair AX 1500i Samsung 950 Pro Nvidia Titan X Pascal X2 SLI EK-XLC Predator 280 Creative SBZ Asus PG348Q
dragosturcu
2015/01/23 11:28:31
Now the question is, when are we going to get those backplates to buy them. I am on your website for more than 12 hours since the last 2 months and I cannot buy the SC ACX 2.0 backplate as are never available. And yes, I did subscribe to the auto-notification... I want to buy 2 of them. An estimate of availability would be nice (I live in Canada and checked everywhere... nowhere to be found). Thank you.
NightH4wx
2015/01/23 14:50:49
dragosturcu Now the question is, when are we going to get those backplates to buy them. I am on your website for more than 12 hours since the last 2 months and I cannot buy the SC ACX 2.0 backplate as are never available. And yes, I did subscribe to the auto-notification... I want to buy 2 of them. An estimate of availability would be nice (I live in Canada and checked everywhere... nowhere to be found). Thank you.
This!! I'm also waiting for the backplates to become available.. (the 980 SC ACX 2.0) So anyone out here that knows when they'll be in stock again? Btw, I'm in the EU.
post edited by NightH4wx - 2015/01/23 15:18:03
Fennicillin
2015/01/23 14:52:04
If anyone has an "FTW" backplate that turns out to be for the SC I'll gladly take it.
The Great Other - NZXT H440 white | 4770k @ 4.4Ghz | Z87 Sabertooth w/custom white TUF shield | 980 ti Classified | 16GB Patriot Viper 2400Mhz | 500GB Samsung 840 Evo | Seagate Barracua 2TB | EVGA Nova G2 1000 watt w/ blue cables
EVGATech_DominikU
Moderator
2015/01/26 01:28:58
Hello, I have to apologize, there was an issue with the backplates and the normal ones and FTW ones got mixed up. The way it is listed now in the EU store is the right way. The Backplate and all holes should fit, if the holes specially between the 4 spring screws and the power connectors do not fit you have probably received a wrong backplate. Please contact customer support at supporteu@evga.com or +49 89 / 189 049 11 for further assistance to get you the right model.
NightH4wx
2015/01/26 08:21:49
EVGATech_DominikU Hello, I have to apologize, there was an issue with the backplates and the normal ones and FTW ones got mixed up. The way it is listed now in the EU store is the right way. The Backplate and all holes should fit, if the holes specially between the 4 spring screws and the power connectors do not fit you have probably received a wrong backplate. Please contact customer support at or +49 89 / 189 049 11 for further assistance to get you the right model.
Good thing this has been cleared up. Although, if you had some insight as to when I could expect to see the standard 980 backplate back in stock on the EU store, that would be great!
Hopper64
2015/01/26 08:33:55
Fennicillin
2015/01/26 15:51:19
I see the webstore is showing in stock for 980 regular backplates but I have a trial on Amazon prime and was wondering when the Amazon store will reflect new stock.
dragosturcu
2015/01/26 17:37:16
Not anymore... I waited until I reached home to buy it and its no more available. Seriously?! What they had 10 pcs on stock?!
Fennicillin
2015/01/27 08:02:57
Hope that was just a stock correction for the ones that were mixed up as FTW...
NightH4wx
2015/01/27 08:31:53
Nooooo! Seriously?? Are you on the EU store or US store? I should recieve a notification on e-mail if they're in stock again, which I did not recieve... So, unless there's something wrong with the notification system, it could just be a glitch on the webstore. I really hope the normal 980 backplates are back in stock soon. Btw, does anyone here know how often these specific backplates (100-BP-2981-B9) are in stock and how long the stock lasts? Thanks From a frustrated European guy.
Fennicillin
2015/01/27 08:43:32
US Store. Jacob responded to my tweets saying there would be more in stock this week. Hope that wasn't the restock.
EVGATech_DominikU
Moderator
2015/01/28 06:04:29
Hello, both backplates are in stock again, if you received wrong backplates and had not contacted customer support so far please do so to get the wrong unit exchanged.
dragosturcu
2015/01/28 06:14:08
NightH4wx
2015/01/28 07:29:22
EVGATech_DominikU Hello, both backplates are in stock again, if you received wrong backplates and had not contacted customer support so far please do so to get the wrong unit exchanged.
Definately not in stock on the EU store......... Well, If it really was back in stock I should have been notified by e-mail. dragosturcu I do not know what you are talking about. The '100-BP-2981-B9' is out of stock according to your website?!
Also checked the above link on the US store and nothing there either...
post edited by NightH4wx - 2015/01/28 07:32:15
Hopper64
2015/01/28 08:19:43
Still out of stock for me too. And the image for the product is still incorrect according to EVGA staff in this thread. ??
EVGATech_ChrisB
Administrator
2015/01/28 09:58:25
Hi Everyone, I can confirm that Dominik was referring to the EU store and I have a inquiry into that office for when they will have more available for purchase. The pictures on EVGA.com are accurate for both of these GTX 980 backplates.
Hopper64
2015/01/28 10:22:34
EVGATech_ChrisB GTX 980 FTW:
 GTX 980:
Hopper64 That makes things more clear, but in the pictures above, which is for the SC and which is for the FTW? The contours of each backplate are distinct, so which one goes with which card? Thanks.
They don't look correct to me based on this.
Hopper64
2015/01/28 10:24:12
Oh, yes it does. I stand corrected. Thanks. Sorry for the confusion.
Fennicillin
2015/01/28 19:28:20
Store now showing in stock again, constant error when I go to check out.
dragosturcu
2015/01/28 19:39:37
You can place your order through google chrome. It looks like they have some problem with Explorer :)
Fennicillin
2015/01/28 19:55:56
dragosturcu You can place your order through google chrome. It looks like they have some problem with Explorer :)
I'm on firefox.
NightH4wx
2015/01/29 00:20:12
Wow.. I still can't see that this is in stock! Are we talking about the EU store here? Also, I've tried all the browsers I know of.. And I still haven't received a notification on e-mail.
Fennicillin
2015/01/29 02:23:01
I can't checkout with anything on the website with Chrome or Firefox. Error processing request.
NightH4wx
2015/01/29 02:47:00
Actually, I received a notification now and it is in stock. I was able to process the order through the link given in the email with Firefox. I'm relieved! Fennicillin I can't checkout with anything on the website with Chrome or Firefox. Error processing request.
As long as you don't confirm the order after you've done the paypal thing, you can try again without the risk of ordering multiple times (I think). SO maybe the error will go away if you try again. Happened to me, but then I tried again and the order went through.
Fennicillin
2015/01/29 02:48:26
I never get that far. It has an error right after confirming shipping address.
NightH4wx
2015/01/29 06:17:14
Try on your mobile phone if you can!
dragosturcu
2015/01/29 06:18:56
I used to get that with IE. Then I logged out from IE and open Chrome. Luckily when it reached to shipment it showed the choice of shipment and I could proceed with the order. I do not know if you are in US, but you could try calling them in about 4 hours.
icy1007
2015/01/29 14:05:28
I'd think the 2981 backplate was only for the 2981 GTX 980.
Hopper64
2015/02/04 09:42:38
I received my backplate today, but the images above appear to be reversed again to me. Anyone confirm this? I have the SC, not the FTW. Thanks.
