Audio problems with GTX 950
Blackhawk3339
2016/11/18 09:38:58 (permalink)
I've been having an issue with audio on my system. When watching certain videos (I've only seen this on YouTube), the sound cuts out intermittently. After a lot of experimentation, I've discovered that it only happens on videos where speech is interrupted with moments of complete silence.  At the beginning I hear, "Please understand that there is a huge difference [ ] TES5Edit merge patch [ ] merging mods. Merge patch is a patch that is created [ ] records..." and so on. It is always the first word after a pause.
I have found that if I run another video in the background that provides constant sound (like playing a music video in VLC), it doesn't cut the words out. It almost seems as if the sound hardware is going into a 'sleep' mode or turning off when there is complete silence, and it takes a split second to reactivate when sound starts again, cutting off the first word.
I've tried every troubleshooting technique related to software that I could find: enabling and disabling hardware acceleration for the browser, disabling Flash, trying three different browsers.
I discovered that it plays fine if I plug in my USB headphones, bypassing the NVIDIA hardware entirely.
My current setup looks like this: video card ---> HDMI cable ---> HDMI splitter ---> TV ---> sound system (no, I don't have a receiver, and can't afford one.) It works beautifully for anything that doesn't have complete silence.
I've also tried switching out the HDMI cable, using a DisplayPort cable, bypassing the HDMI splitter, and using a different HDMI plug on the TV. None makes any difference.
It seems really likely at this point that the culprit is the card itself, or a setting for the card, and some sort of low-power/sleep feature seems likely, too. Any help would be appreciated.
Motherboard: Asus P6T
Video card: EVGA GTX 950
CPU: Core i7 920 2.67GHz
RAM: 8 GB
Windows 10 Home 64 Bit
TV: Panasonic TC-L42U25
7 Replies Related Threads
    • Ribbons : 122
    Re: Audio problems with GTX 950 2016/11/18 11:37:10 (permalink)
    Uninstall the nvidia hd audio driver. Reboot PC. Retest.
    Blackhawk3339
    Re: Audio problems with GTX 950 2016/11/18 12:44:06 (permalink)
    I tried that, restarted.  Same result.
    • Ribbons : 122
    Re: Audio problems with GTX 950 2016/11/18 12:44:43 (permalink)
    Blackhawk3339
    Did windows 10 automatically re-install the nvidia hd audio driver?
    Blackhawk3339
    Re: Audio problems with GTX 950 2016/11/18 13:09:14 (permalink)
    It is identifying it correctly through the device manager, so I'm going to guess it did.  I didn't check the version number before I uninstalled it, so I can't be sure if it replaced it with the version I had or the 'default' version built into Win10/Update.
    • Ribbons : 122
    Re: Audio problems with GTX 950 2016/11/18 13:14:06 (permalink)
    Blackhawk3339
    That is the problem. You need to stop windows from re-install the nvidia hd audio driver.
    Blackhawk3339
    Re: Audio problems with GTX 950 2016/11/18 13:29:48 (permalink)
    Ok, I blocked that.  Uninstalled again through the device manager.  Rebooted.  Checked the device manager and playback devices, and both showed a generic driver rather than recognizing it as Nvidia.   Problem persists.
    • Ribbons : 122
    Re: Audio problems with GTX 950 2016/11/18 14:04:00 (permalink)
    Time to test the card in another computer.
