Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is not
adamf4i
2012/08/18 10:12:35 (permalink)
Working , does not detect or anything in control panel
Any help would be appreciated
13 Replies Related Threads
    anony-moose
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 10:48:06 (permalink)
    Does that model use a USB interface for the microphone and an analog 3.5mm jack a digital optical TOSLink S/PDIF interface for headphone output? If so, it's possible that they require special drivers for the USB-driven microphone. Seeing as those are meant for console, the drivers are most likely designed to auto-load when plugged in to an Xbox. Check the website to see if there are drivers for PC that you can manually install for the microphone. Make sure to go directly to the Turtle Beach website (www.turtlebeach.com) to look for drivers instead of using a search engine...
    adamf4i
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 10:59:37 (permalink)
    http://www.turtlebeach.com/support/index.php?View=files
    Not sure which of these drivers would work
    anony-moose
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:10:06 (permalink)
    I can't find anything about PC compatibility on the product page. Only shows instructions for connecting to XBox 350 and a side note that it also works with PS3..
    adamf4i
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:16:35 (permalink)
    Same here
    anony-moose
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:24:12 (permalink)
    I hate to have to say it, but I don't think the USB device is PC compatible
    The optical connection works only because there's a direct connection to your sound card/motherboard audio with only audio being transmitted with one-way output to the headset. USB communicates bidirectionally; ie: both input and output.
    Audio ports are standard but USB devices are driver-dependent. That's why it's not showing up on your control panel. I'm really sorry
    adamf4i
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:25:42 (permalink)
    That sucks
    anony-moose
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:38:06 (permalink)
    Do you have the budget to purchase a new headset? I can help you pick a good one that'll fit your needs, and I'm sure there are lots of others who can jump in with helpful recommendations.
    adamf4i
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 11:41:16 (permalink)
    GOnna need something , I bought this from someone on here
    Is there some kind of bluetooth comunicator you can get to make this one work
    tester300
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 12:11:20 (permalink)
    adamf4i
    The mic needs to be connected to the  input in the headset and to the headphone jack in the PC.
    Once there you have to set it up in the control panel as your default mic.
    The headset is wireless but the mic isn't.
    tester300
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 12:15:04 (permalink)
    The USB in this headset is only to power the R/F base.
    anony-moose
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 12:20:47 (permalink)
    @tester300:
    Thanks for the help! I must have overlooked that bit about the microphone but the documentation on the website wasn't all that great >.<
    I hope this works for the OP
    adamf4i
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 12:29:39 (permalink)
    Can you not use the headphone input jack on the transmitter for the x41
    tester300
    Re:Anyone else using turtlebeach x41 headset on PC - Headphones work but microphone is no 2012/08/18 12:42:17 (permalink)
    adamf4i
    No, you need the cable. I included the free adapter for the microphone to work with the PC.
    But I recommend that you use a long auxiliar radio cable in order to have some free space.
    anony-moose
    @tester300:
    No problem. I was the one that sold him the headset.
