Re: Any fix for EVGA GTX 970 FTW 2.0 buzzing sound?
2015/05/27 21:55:21
A fix? No, not really, but to be honest I did an RMA on my card for coil whine and it was an EAR so it was free one my end. The new card they gave me is a lot better (70%) but it's still not silent when it gets 600fps, but I guess it's normal now for GPU's to have coil whine. Otherwise, you can enable vsync which will generally prevent it but will also cap your FPS at 60 which is all you can get on a 60hz monitor anyway or you can ignore it and close up your case more. Other than that, you just gotta live with it.
