AIO 1080 Hybrid cooler fan specs
Nereus
  • Ribbons : 25
2016/10/21 19:34:21 (permalink)
Anyone able to advise what the specs are on the fan that comes with the AIO 1080 cooler? There doesn't seem to be any details provided that I can find.
Specifically looking for :
  • air pressure (mm/H2O)
  • airflow (cfm)
  • fan speed (rpm)
when at full speed..
Thanks in advance.
*edit* got it - see following post for specs.
post edited by Nereus - 2016/10/22 11:07:23
11 Replies Related Threads
    Nereus
    • Ribbons : 25
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/21 19:52:08 (permalink)
    Oh wait, seems I found it myself after a bit more searching (and added more from posts following, thanks), so I'll post the EVGA fan specs here for future reference :
    EVGA fan specs :
    • max air pressure 2.76 mm/H2O
    • max airflow 69.5 cfm
    • max fan speed 2,000 rpm
    • max noise 34.2 dB(A)
    • lifespan 50,000 hours
    • max input power 2.88 watts
    I'm looking at replacement fan : BeQuiet! Silent Wings 3, 120mm high-speed, model BL068 (or BL070 for PWM) - specs :
    • max air pressure 3.37 mm/H2O
    • max airflow 73.3 cfm
    • max fan speed 2,200 rpm
    • max noise 28.6 dB(A)
    • lifespan 300,000 hours
    • max input power 4.4 watts
    • can purchase 3 pin model or 4 pin PWM model
    I already use the 120mm BeQuiet! case fans and they are awesome and super quiet (but obviously low pressure is not for radiators) :
    • max air pressure 1.63 mm/H2O
    • max airflow 50.5 cfm
    • max fan speed 1,500 rpm
    • max noise 15.7 dB(A)
    • max input power 2.4 watts
    post edited by Nereus - 2016/10/22 11:00:39
    • Ribbons : 68
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/21 19:53:00 (permalink)
    I would wait till the FTW model is out or they start shipping this model with the New  vRAM Copper Plate.
    Nereus
    • Ribbons : 25
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/21 20:05:19 (permalink)
    I'm going to use the 1080 AIO cooler on a Titan X (Pascal). Talked to Jacob a day or so ago and there's definitely an AIO in the works for the Titan XP, but no ETA as yet.. hopefully this year, but not definite, and I can always swap out the 1080 AIO cooler for the Titan-specific model when it comes out. I'm adding some mosfet passive copper heatsinks to help cool the vrm, but apparently they don't get all that hot on the Titan anyway. There's a video here on fitting the 1080 AIO cooler to the Titan with no physical modding required. :)
    post edited by Nereus - 2016/10/21 20:07:27
    • Ribbons : 68
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/21 20:10:36 (permalink)
    This is what I like about the FTW Model Hybrid Cooler
    Dedicated Memory Plate
    A dedicated memory plate that makes DIRECT contact with the water cooling block. Giving the lowest memory temperatures possible.
    Nereus
    • Ribbons : 25
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/21 20:25:15 (permalink)
    Oh for sure, that's ideal design, although the FTW model is probably(?) not going to be 100% compatible with the Titan XP. I assume (hope) that a similar direct-contact memory plate will come with the Titan XP AIO Hybrid cooler, whenever that comes out.
    edit: just checked - the layout is very different between FTW and Titan.
    post edited by Nereus - 2016/10/21 20:31:53
    trilegdog
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/22 09:17:34 (permalink)
    Nereus
    • airflow (cfm)
    • fan speed (rpm)
    Thanks in advance.
     Specs here also:  http://forums.evga.com/FindPost/2515115
    Asus Formula VIII, i7-6700k, Tt Riing 360 AIO, 16GB Corsair Dom/Plat 3K,
    EVGA GTX 1080 ACX 3.0 (6181), SS 850 Pro 512, 2xWD Blk 2TB, EVGA P2 1000w,
    Dual Boot Win7Pro64 /Win10Pro, Tt Core X-9, SS2693HM 1900x1200, Fuzzy Dice
    6181-KR Step-Up began 29 June, queue hit 29 Aug = 62 days
    RMA 980Ti SC+ to EVGA 31 Aug. Recvd by EVGA 10:41 am 2 Sep
    UPS track # issued 8 Sep - delivered 13 Sep 2:54 PM EST
    HYBRID AIO 400-HY-5188-B1 Ordered 8 July - Recvd 15 July
    EVGA 780i, E8400, 8GB OCZ (4x2), XPpro/Vista64
    EVGA 8800 GTS G92 512 SLI (2), OCZ900MXS PS
    lead, follow, or get out of the way
    • Ribbons : 68
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/22 09:39:10 (permalink)
    trilegdog
    Why not just post the info and not a link to it.
    Non-FTW Hybrid Fan Info
     Fan: standard 120mm fan.
    • 2.88watts peak (.24amp @ 12v)
    • ~2000RPM max
    • 69.5CFM
    • 2.76mm-H2O (static pressure)
    • 34.2db max
    • MTBF 50,000 hours
    Radiator and tube specs:
    • Height: 152.5mm / 6in
    • Width: 121mm / 4.76in
    • Thickness: 27.5mm / 1.08in (this measurement does NOT include the fan)
    • Tube Length: 400mm / 15.75in
    post edited by bcavnaugh - 2016/10/22 09:42:03
    Nereus
    • Ribbons : 25
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/22 11:01:39 (permalink)
    Updated earlier post accordingly for the fan too, thanks.
    trilegdog
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/22 20:32:34 (permalink)
    trilegdog
    Because that's what I decided to do. Link cited for reference only.  Nereus seems to be doing a fine job on his research.
    Peace, out
    • Ribbons : 68
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/23 10:18:22 (permalink)
    trilegdog
    trilegdog
    Peace, out
    Indeed, I butting out.
    trilegdog
    Re: AIO 1080 Hybrid cooler fan specs 2016/10/31 06:58:40 (permalink)
    It's all good, no need to butt out. You're technical input is valued in this community.
