AnsweredACX rattle / noise problem fix
Page: << < ..678 Showing page 8 of 8
Dozinator
Re:ACX rattle / noise problem fix 2014/07/24 21:37:52 (permalink)
The noise got to me so I open up my gaming PC and pulled the GTX 760 out. Checked all screw on back side to make sure they were tight. Then flipped it over and there are 3 screws for each fan.
I found them loose. I got 1 to 2 full turns on each screw. There are 6 total. I put the GTX760 back in and started the PC. I ran SWTOR, UT2004 and Defiance on High settings.
No noise and I am happy again.
 GTX760 ACX |NEOHE 600 PSU|Samsung S24C200 24" LED|Solid State 150GB| 16GB  | Audigy 2 ZS | Win7 Pro SP1 64 | MX518|N52TE
Superbxxx
Re:ACX rattle / noise problem fix 2014/07/25 01:57:24 (permalink)
Dozinator
Nice man.
  • Ribbons : 92
Re:ACX rattle / noise problem fix 2014/07/25 20:07:57 (permalink)
Glad you got it sorted.          =)
My Affiliate Code: 8WEQVXMCJL
KLEYBA
  • Ribbons : 12
Re:ACX rattle / noise problem fix 2014/07/25 20:21:43 (permalink)
my 770 cards all started to make a loud chopping sound.  I found out that the ACX Cooler Fans are cut too close to the fan shroud.  so, when the card sags in the back after you install it, the rear fan--the one closest to the front of the computer case, starts to hit the fan shroud.  fix?  the only solution I found was to find a way to prop up the rear of the card.
I never had this problem before with any other card until this ACX Cooler came out.
camfaEVGA
Re:ACX rattle / noise problem fix 2014/08/02 11:06:04 (permalink)
Good news (for now) I came home from a one month vacation fully intending on fixing this annoying noise. To my surprise, its gone! (For now). I hope i dont see its return. thank you all for your help, and making me feel better. Being alone in a situation sucks.
good luck to all! cya (for now ;) )
ducknukem86
Re:ACX rattle / noise problem fix 2014/08/04 09:34:27 (permalink)
i have terrible rattle with my 780ti. I'll try your method Superbxxx. This will be the third time i take the cooler apart and apply thermal paste  So far, none of my methods have solved the problem. The only fins that are ¨loose¨ and by that i mean, that move and look flimsy are the ones close to the rear of the card. So i hope this method works! (what a waste of TIM)
ducknukem86
Re:ACX rattle / noise problem fix 2014/08/04 11:05:50 (permalink)
Well, I want to thank Superbxxx for the fix. I used the pink non-conductive tape included in my evga 780 classy. I put some of the tape on the place shown in Superb's guide and also some between the first fin and the plastic fan guard, as there was some space there and looked like the vibration could be generated there. Now i can say most, if not all, of the rattling is gone. I'll continue running test. But i'm super happy with this fix as my pc sits right next to me on the desk.
Edit: I also placed some pieces of rubber between the fins.
post edited by ducknukem86 - 2014/08/04 16:58:12
Attachment(s)
Attachments are not available: Download requirements not met
Superbxxx
Re:ACX rattle / noise problem fix 2014/08/04 14:10:53 (permalink)
ducknukem86
I am very happy to have helped man. Enjoy your grafics card.
Ps: I can not open your pictures. Can you see what is happening so people see?
ducknukem86
Re:ACX rattle / noise problem fix 2014/08/05 12:04:26 (permalink)
Here's the second pic where you can see the pink tape attached to the side of the loose fins. I think the last fin on the rear is the one that causes all the trouble
Attachment(s)
brianwilliams42
Re:ACX rattle / noise problem fix 2014/08/09 14:39:13 (permalink)
Got my first EVGA card (770) this week on a recommendation, first self-built PC, and the first thing I did was run all my fans to make sure they were quiet. At 50% and 75%+, the EVGA ACX fans have a rattle, and then I found this thread.
Putting my finger on the fins nearest the ports makes it better, less help but some by putting my finger on the rear fins, so that's definitely what's going on.
So, I'd rather not start applying tape to my new card, but also feel silly RMAing it if its a common problem.
Is every 770 ACX fan going to do the same thing?
ducknukem86
Re:ACX rattle / noise problem fix 2014/08/09 20:35:19 (permalink)
I've had two cards with the acx cooler. Both have rattling to some degree. It's just some have it more than others.
martin.prather
Re:ACX rattle / noise problem fix 2014/08/16 23:07:14 (permalink)
just applied this fix tonight, it helped a great deal with the higher speed resonance but unfortunately it somehow moved it down to idle speed, but when i bump the fan speed up to 40%, it disappeared.  How weird.  Bad quality control or design, imo.  I plan to use aftermarket cooling eventually, but thanks to the fix in this thread it's tolerable.  Appreciate it!
Update:  Well it's hard to say if any of it lasted.  I was super conservative with the tape, but it seems like it's either back or worse than it was.  I don't see how tape could really fix what I found inside that thing, seemed like dozens and dozens of fins were totally loose and at the RPMs these fans spin, it's not surprising they'd make noise.  Maybe soldering or welding the things together would work better...At this point I'm hoping for some sort of aftermarket cooling solution, but it sounds like nothing fits my board.
post edited by martin.prather - 2014/08/20 11:35:48
dantheicecreamman
Re: ACX rattle / noise problem fix 2014/09/27 10:23:58 (permalink)
I also bought EVGA GTX 660 FTW w/ ACX cooler about a month ago. Two times now, randomly when I restart Windows, I have heard funny noises that sound like the metal fins rattling. Re-Seating the card seems to fix the noise.   Those fins are very delicate and the two fans move lots of air.
I will be checking my card for loose fins and listening for more noises...
donchill
Re:ACX rattle / noise problem fix 2014/12/22 10:33:04 (permalink)
got a gtx 760 SC acx and have the same problem at 50-55% fan speed and some other speeds
im out of thermal tape, but will get some tomorrow and will report here with pics.
i dismantled it and found some loose fins near the pcie 6+8pin power connectors
edit: it got better, but then i did this
hardforum.com/
showpost.php?p=1041338891&postcount=16
post edited by donchill - 2015/01/06 08:56:30
Trides
Re:ACX rattle / noise problem fix 2015/02/13 00:39:46 (permalink)
donchill
hardforum.com/
hahahah, seriously? how stable is it?
you should start your own brand man, i'll buy your coolers
Trides
Re:ACX rattle / noise problem fix 2015/02/17 01:36:58 (permalink)
Hello! I've been suffering from same problem and I am thinking of applying this solution!
However, it is very hard to find thermal tape for me so I'm asking you, is the non-conductive tape that comes with box reliable enough? Will it melt? Also, can I use the thermal paste that comes with my cpu cooler (coolermaster)? I opened the syringe cap 6 months ago, did it dry out or perfectly fine for use? I also have a 4-5 years old zalman cpu thermal paste that wasn't opened, do you think it is past its shelf life? Will I damage the chip if I cleaned the residue with acetone on earswabs? I can't find alcohol related products for cleaning purposes either, it is banned in pharmacies here!
jf928
Re: ACX rattle / noise problem fix 2015/08/27 21:26:58 (permalink)
This is basically me right now mine started to make noise then would halt then i noticed the fin was seperated,I run this cards fan at 90% when gaming which is hours long. mainly because this card runs very hot, was  never able to overclock the card for this reason, but thats another subject.
Superbxxx
Re: ACX rattle / noise problem fix 2015/08/28 02:55:47 (permalink)
Hi jf928. You can try this fix and doing so you will apply new thermal paste that could fix your heating problems....So it could be a wiw/win situacion. Please tell us if it worked.
