Re:ACX rattle / noise problem fix
2014/02/09 17:47:50
Same, my K|NGP|N doesn't make a noise unless I manually up the fan speed past 40-50% haven't even heard any coil whine at +300/+400 MHz No rattling either
post edited by Myst3ri0n - 2014/02/09 18:05:41
Intel i7 4930K | ASUS Rampage IV Gene | Corsair Dominator Platinum 16GB 4x4@1866 MHz CL9 | Corsair H100i | Samsung 850 Pro Series 512GB | Corsair 350D | Corsair AX860i | K|NGP|N GTX 780 Ti Classified | Windows 8.1 Pro x64
2014/02/10 07:36:24
milcs What exactly is the rattling noise and the coil whine? I have different types of noise coming from my 780 Classified. One that is more like a vibration (When the fan is around 60-70%) and one that is really high pitched.
You have both coil whine (the high pitched noise) and the fan rattle.
milcs
2014/02/10 08:28:45
chrisdglong You have both coil whine (the high pitched noise) and the fan rattle.
Lucky me!!! :D I will try to post a video from youtube (is this possible?) on another thread to ask people their opinion on what to do. Cheers
Intel i7-2600K @ 3.90GHz, Asus P8P67 Pro, Corsair H70, Corsair Vengeance 8GB (2x4GB) DDR3PC315000C9 @1866MHz, Corsair Professional Series Gold AX850, OcUK GTX 570 (presently installed in the system), Corsair Obsidian 800D
hyperelite
2014/02/10 14:49:12
One of my Classifieds had this problem, so I tried the fix with some copper tape and it worked perfectly. Thank you! I also had another rattle coming from the bottom of the card, which copper tape also fixed.
Hyper Elite ANNIHILATOR SilverStone Temjin TJ11 Intel Core i7 3930K @ 4.4GHz NVIDIA EVGA GEFORCE GTX 1080 FTW ASUS Rampage IV Extreme G.SKILL RipjawsZ 32GB 1866MHz (4x8GB) Noctua NH-D14 Samsung 850 Pro 256GB | Samsung 850 EVO 1TB | Seagate Barracuda 3TB x2 | Seagate Archive 8TB Corsair AX1200 Dell U3014 & U3011 30" | Panasonic TH-P65ST50A 65" ASUS Xonar Essence STX | Beyerdynamic DT 990 (600Ohm)/770 Pro (250Ohm) Logitech G700 | Corsair K70 RGB Brown | Saitek X-55 Rhino H.O.T.A.S. CyberPower PRO PR1500ELCD 1500VA/1350W UPS
Gwiz187
2014/02/10 15:02:40
I have found the issue,see those lower fins at the bottom on the front?,those are entirely loose,on the backside they are a little loose. Tomorrow i will try to find some thermal tape or some good electrical tape,and will apply some artic cooling paste to see if it makes a difference compared to the paste that has been applied. So check the front and back of the GTX 770 SC ACX if you have this problem,it got a little annoying lol. Cheers.
post edited by Gwiz187 - 2014/02/10 15:31:13
2014/02/10 15:04:10
Gwiz, is there any heating or any sort of brace running through the ones you are talking about?
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
Gwiz187
2014/02/10 15:25:30
Scarlet-Tech Gwiz, is there any heating or any sort of brace running through the ones you are talking about?
Yes on the backend there's a copper pipe running trough it,but the part that's loose isn't i know i have to find a way to apply it on the closed part of the fins. But i am pretty sure this is the problem since they are loose on the beginning of the fins towards the end is the copper pipe. If you'll look at the picture you'll see the copper pipe at the end,is there a problem when i would apply some sort of tape ( prefereably heat resistant ) in the beginning?. There's no other way and it's quite obvious this would vibrate at a certain RPM either it be low or high,i am just thinking outloud here so i am not sure.
post edited by Gwiz187 - 2014/02/10 16:09:37
Gwiz187
2014/02/10 15:35:59
The Only problem is i don't want the tape to come loose and end up in the fan,as you can see possible from this side. To make perfectly clear those fins on the side of where it says's 770 those last ones if you would hold the card the right side,those lower ones. Those are basically the same as on the back,but those on the back are not a problem to apply tape on this side however it's very near a fan,and when i say loose i can actually move them around,on the back there's a slight movement but these are doing the boogwoogie lol. Anyone from EVGA have suggestions?.
post edited by Gwiz187 - 2014/02/10 16:01:30
2014/02/11 19:41:02
Gwiz187 The Only problem is i don't want the tape to come loose and end up in the fan,as you can see possible from this side.
Don't count on it, they haven't been very vocal about this issue... Nor have they admitted there even is an issue.
Superbxxx
2014/02/12 01:10:20
Hi there. You can put the tape near the pcb of the card so ifit came loose will not interfear with the fan. Good luck for the fix na please share the results here.
dustin_leet1983
2014/02/18 16:29:07
MY bran new evga gtx 780 classified does it but only above 85 perc fan speed, so i am not worried at all, but ty for info on it
Moded CM Stormscout case Intel 3770k @ 4.3 ghz Corsair H80i w Cors Perm fans 16 gigs corsair 1866 ram Evga GTX 780 Classified OCZ-Vertex4 128g/WD 2x1 TB
2014/02/22 17:46:12
GTX 780 Ti Classified I had RMA'd my first card and the 2nd wasn't as bad as the first one, it was audible from 40ish% fan speed and up, very loud. The 2nd card stats around 70 fan speed and just said screw it as far as another rma. I trimmed down a few stripes of electrical tape and applied them to the exact same area, and wow where they loose in that area. Thanks for posting this fix, and EVGA......... Get it Together.........
Hawkeye360
2014/02/22 18:04:58
I'm considering buying a 780 Ti K|NGP|N edition and I am concerned about this rattle issue, more so because I have to pay a silly amount of fees to get one since I live in Canada (not EVGA's fault) and it would be unfortunate for this to happen. I could just get a regular Classified from a Canadian retailer, although I had one before and it rattled. My main desire in a card is for it to be quiet. My entire PC is silence oriented so I want a card that is pretty quiet.
Chassis: Fractal Design Define R4 CPU: Intel 3770K @ 4.5GHz Cooling: Noctua NH-U12S, Noctua NF-A14 ULN x2 MOBO: Asus Z77 Sabertooth GPU: 780 Ti RAM: Corsair 16GB LP @ 1866MHz PSU: Seasonic X-1250 Monitor: ASUS VG248QE 144Hz Audio: Creative ZxR, Audioengine A5+, Shure SRH-840, Sennheiser PC350 Other: Pioneer BDR-207, NVIDIA 3D Vision 2 Kit, 4.5TB external storage
2014/02/22 18:17:57
Well you have a couple options, of course this fix here, it's not to tough and I don't know how the clear shroud will effect this but you should be able to hide it well, Or grab a waterblock and call it good. If neither sound good for you, I think you would be just as happy with the classified Ti its a great card, have 1 myself.
Hawkeye360
2014/02/22 18:43:16
Xantac Well you have a couple options, of course this fix here, it's not to tough and I don't know how the clear shroud will effect this but you should be able to hide it well, Or grab a waterblock and call it good. If neither sound good for you, I think you would be just as happy with the classified Ti its a great card, have 1 myself.
Yeah I loved the regular Classified when I had it. I won't be watercooling though, just air. It would cost me around $1100 to get one into Canada. The regular Classified is $849 here. Not sure if it's worth it to be honest.
2014/02/22 18:48:48
I personally do not believe you will have 250$ in extra performance rofl. To each their own , I know what I would do.
Hawkeye360
2014/02/22 19:11:17
Xantac I personally do not believe you will have 250$ in extra performance rofl. To each their own , I know what I would do.
The difference would be around $140 between the KPE and regular Classified after all is said and done. Still a pretty sizeable cost difference though.
Superbxxx
2014/02/23 02:08:40
Xantac GTX 780 Ti Classified I had RMA'd my first card and the 2nd wasn't as bad as the first one, it was audible from 40ish% fan speed and up, very loud. The 2nd card stats around 70 fan speed and just said screw it as far as another rma. I trimmed down a few stripes of electrical tape and applied them to the exact same area, and wow where they loose in that area. Thanks for posting this fix, and EVGA......... Get it Together.........
No prob man. Glad to help  .
Superbxxx
2014/02/23 02:09:56
Hawkeye360
If it was me i would go for the classified man. Especialy if you are going whith air  .
gadgets3434
2014/02/23 07:00:17
Attachments are not available: Download requirements not met Another good way to fix rattle and some other problems
Attachment(s)Attachments are not available: Download requirements not met
Franky
2014/02/28 01:56:52
I got the rattling 770sc acx aswell...
- Ribbons : 52
2014/02/28 02:36:58
If anyone has fan rattle (not coil whine) please contact EVGA tech support ASAP
(Pazmeister: rjohnson.....YOU ARE A LEGEND, problem solved, i am sendning my missus round to you now so she may have your babies!!) , R.I.P Jeffreyham, R.I.P Corsair_Mike, R.I.P Wrinvert, i7 5820K, Corsair H100, Corsair Vengeance LPX 32GB (CMK32GX4M4A2666C16R), EVGA GTX 1080FTW ACX, Corsair AX1200, EVGA X99 Micro2, Samsung Sm961 m.2, One Corsair SSD, Crossover 4K,
Superbxxx
2014/04/02 01:12:22
gadgets3434
Yep that works
Superbxxx
2014/04/02 01:13:54
Franky I got the rattling 770sc acx aswell...
Have you tried the fix?
2014/04/02 13:30:08
My 760 ACX seems to be fine. No rattles yet at any fan speed. Maybe I got lucky on mine seeing that a lot of users seem to have the rattling issues.
PhazeDelta1
2014/04/03 23:00:05
rjohnson11 If anyone has fan rattle (not coil whine) please contact EVGA tech support ASAP
I just sent one of my 770 Classifieds back to yall for this particular reason. Wish I would of seen this thread before hand.
wolfie81
2014/04/12 19:09:23
Hi guys, im tempted to pull apart my classy today as its annoying me and follow this guide. I found this video below on youtube of the exact noise mine makes but at different speeds though. Please watch and tell me if the fin/tape solution addresses this sound? Thank you http://www.youtube.com/watch?v=3jx-n77fsvU
PhazeDelta1
2014/04/12 20:03:25
wolfie81 Hi guys, im tempted to pull apart my classy today as its annoying me and follow this guide. I found this video below on youtube of the exact noise mine makes but at different speeds though. Please watch and tell me if the fin/tape solution addresses this sound? Thank you http://www.youtube.com/watch?v=3jx-n77fsvU
That's exactly the same noise mine was making at 40% fan speed. It was a bit worse above 55%. TBH, I would just take the cooler off and try the tape. If it's still making the noise, then it appears something is wrong with the fan and then I would contact EVGA and start a RMA.
wolfie81
2014/04/12 21:13:46
Ok I gave it a go and applied tape to all areas where fins appeared loose. Rebooted and that same humming is there at 1140-70 rpms. Didnt help. Thank you for the suggestion. On the plus side my temps have dropped some 4-6 degrees with the better paste I used. So not all was lost. Im just going to keep the fans at 1400rpms as the fans have the least resonance/humming at that level.
PhazeDelta1
2014/04/15 13:21:31
Well I finally got my RMA replacement back earlier and it rattled worse than the card I sent in. I don't even think anyone tested it before shipping it out. No worries though, as I have since fixed the noise using the method in post #1. Thanks OP for providing detailed instructions.
