skymania
Re:ACX rattle / noise problem fix
2013/09/23 11:05:49
I had a rattling sound on my 780 gtx acx sc card ! I fixed it myself. All I did was tighten the screw on the botom of the card and loosen a bit the one on the top. Its perfect now, no more rattling sounds. Maybe this can help someone.
post edited by skymania - 2013/09/23 11:16:22
Attachment(s)Attachments are not available: Download requirements not met
- Ribbons : 52
2013/09/23 11:27:16
Thanks for the advice. Happy gaming!
(Pazmeister: rjohnson.....YOU ARE A LEGEND, problem solved, i am sendning my missus round to you now so she may have your babies!!) , R.I.P Jeffreyham, R.I.P Corsair_Mike, R.I.P Wrinvert, i7 5820K, Corsair H100, Corsair Vengeance LPX 32GB (CMK32GX4M4A2666C16R), EVGA GTX 1080FTW ACX, Corsair AX1200, EVGA X99 Micro2, Samsung Sm961 m.2, One Corsair SSD, Crossover 4K,
2013/09/23 15:11:18
beelzebud I have a GTX 760 FTW, and I've noticed a slight rattle when the fan is spinning down from being under heavy load. It only lasts a second or two, and then stops as the fan levels off to idle speeds. I wasn't sure if I should be concerned about this, but as long as it just happens like it currently does, I'm not going to worry about it. Glad to see it's not an issue specific to my system.
Mine started out the same way as this, I believe the blocks may have been poorly fastened, in my case they got worse over time until I fixed them.
Coolermaster HAF-X Black Full Tower EVGA Supernova G2 1300W PSU Asus RoG Maximus VI Formula W/ Thermal Armor Core I7 4770K Corsair H100i Liquid Closed Loop CPU Cooler 2x EVGA GTX 780 Classified ACX Cooler Card SLI Corsair Dominator Platinum 16GB 4x4GB 2133MHZ Corsair Neutron GTX 480GB SSD 2x Western Digital RED 1TB Hard Drive (Mirrored)
2013/09/23 15:13:26
skymania I had a rattling sound on my 780 gtx acx sc card ! I fixed it myself. All I did was tighten the screw on the botom of the card and loosen a bit the one on the top. Its perfect now, no more rattling sounds. Maybe this can help someone.
Hmm.. interesting find. it makes sense if the sink blocks are held together that way, I will have to look at this too, thanks for the info.
Superbxxx
2013/09/24 03:10:09
I checked mine whem i was trying to fix the noise and it was ok...... but it is a nice find man.
ReaperX87
2013/10/17 10:13:55
I am having the same problem, evga gtx 770 sc 4 gb it's sooooo annoying I got the card 2 days ago.
ReaperX87
2013/10/17 10:15:58
Superbxxx
skymaniaI had a rattling sound on my 780 gtx acx sc card ! I fixed it myself.All I did was tighten the screw on the botom of the card and loosen a bit the one on the top. Its perfect now, no more rattling sounds. Maybe this can help someone.
which screws can you take a pic of which screws you tightened I'll give it a shot.
Superbxxx
2013/10/17 10:32:29
Near the sli conector is one screw on the plastic that holds the fans. Try that one first.
ReaperX87
2013/10/17 12:43:02
Ok I will try that when I get home thank you, I'll let you know if that works. Now you mentioned a couple screws one of which is on the bottom. What were the other ones.
Superbxxx
2013/10/17 12:45:13
See 8 answer obove for the pics
ReaperX87
2013/10/17 14:11:30
Superbxxx See 8 answer obove for the pics
Hey man thanks for the help, I just got home from work and loosened that screw and went all the way up to 100% fan speed, going 1% at a time and didnt hear a bloody thing. I think that did it man thank you for your help. Ill let you guys know if it comes back. Going to play some Metro Last Light so we should know soon.
ReaperX87
2013/10/17 14:33:20
ReaperX87
2013/10/18 04:43:16
Turns out if I push on the plastic fan housing it quites down, still don't know if I'm going to RMA it if they could send one that's 4gb without the acx cooler but the reference cooler I would be happy.
skymania
2013/10/18 04:58:01
ReaperX87
Did you tighthen the screw at the bottom? If you made it quiet when going threw 1 to 100% fan speed then your on the right track. You just need to find the right balance between tightening the bottom screw and looseining the top screw in my opinion.
ReaperX87
2013/10/18 05:14:07
If someone could take a pic of all the screws they want me to mess with I would appreciate it.
I was testing it in metro last light, last night and it seems to have quieted down for the most part still some noise here and there. Other than that it's pretty quiet. I really just don't feel like screwing with removing the backplate and what not.
skymania
2013/10/18 10:26:21
ReaperX87 If someone could take a pic of all the screws they want me to mess with I would appreciate it.
I had uploaded the pictures of all the screws in the first post on 2 page(current one) of this thread. You can't miss them. I have marked screws with a red circle.
iatacs19
2013/10/24 23:45:09
I need to try this as well. My 780 Classified has this same problem.
Superbxxx
2013/10/25 06:06:25
iatacs19 I need to try this as well. My 780 Classified has this same problem.
Nice, please teel us if it worked for you  !
JoergHe
2013/10/25 12:40:29
Same problem here with 3 (!!!) GTX780 Classified... I hear it, i RMA'ed it Next one, same Problem - RMA agaein Next one same Problem... Now, i life with it... i dont want to change something on the cooler, and at my card, it is only at 43%/44% RPM But this is a speed that i never "use", most time it is slower (idle 35%) or faster (BF3 53%)... so i hear it only on the way up or down... As long as it is only at these speeds, it is okay for me...
jason3539
2013/11/06 12:32:58
Motherboard: Asus Sabertooth Z77 | CPU: Intel Core i7 3770k - HSF: Noctua NH-C12P SE14 | RAM: GSkill Ripjaw 1333 CAS 7 - 4 x 4GB | Graphics: EVGA GTX 680 | PSU: Seasonic X760 | Hard drives: Corsair Force GT SSD 120GB system drive, Samsung 830 256GB game storage drive, Samsung SpinPoint F3 storage drive, 1TB eSATA WD drive | Ceton InfiniTV quad PCI Express card | Lite-On bluray burner | Case: SilverStone GD08B - 4 x 120mm Gentle Typhoon (2 x 1450RPM, 2 x 1150RPM) intake fans and 2 x 80mm Noctua exhaust fans | Windows 8.1 64bit Professional w/ Media Center | Monitor: Sony W900a TV connected to Denon 2112ci AVR
Superbxxx
2013/11/07 00:54:36
jason3539 Did the screw fix work for anyone? Post #31: http://forums.evga.com/FindPost/2028528
Not for me but give it a try and then if it does not work try the other metod. Let us know how it goes.
jason3539
2013/11/07 08:24:30
Superbxxx
Unfortunately, I don't want to pull the cooler off when I'm still within my 30 day return window. Screens didn't help. I am not hearing the rattle so much as the resonance.
jason3539
2013/11/07 08:25:39
Although there are some REALLY loose fins by the power connectors. Feels incredibly cheap and flimsy--almost like tin foil. This is a low budget cooler given a high budget name.
saelz8
2013/11/16 07:08:34
Superbxxx They will send you an acx version.The latest acx coolers should not make this noise so you will be fine. Or just try to make this fix...is up to you.
Best of luck
You sure about that? I got my 780 last week and I'm having this problem.
Superbxxx
2013/11/16 07:28:41
saelz8
Best of luck
The latest acx coolers should not make this noise......but i'm not the one making those coolers. So will you send it back? Or try my fix?
saelz8
2013/11/16 17:10:58
I'll probably be doing an RMA, but if the replacement card has the same problem I'll try the fix. Does it void EVGA's warranty to remove the heatsink?
Superbxxx
2013/11/17 00:45:04
saelz8 I'll probably be doing an RMA, but if the replacement card has the same problem I'll try the fix. Does it void EVGA's warranty to remove the heatsink?
ok. It does not voide the warranty to remove the heatsink.
2013/11/21 10:00:52
I had this problem on a GTX 760. I thought because it was due to the tight space in my Falcon Northwest Tiki. I ended up RMAing it for the blower style. That could have been my problem as well. At one point the ACX cooler on my Titan made a buzzing sound but that was only for about a minute and I haven't heard the noise since. Thanks for the post and if I run into this problem again, I will check out the fins as well. BR deserved Super!!
Superbxxx
2013/11/21 12:31:45
Drerex I had this problem on a GTX 760. I thought because it was due to the tight space in my Falcon Northwest Tiki. I ended up RMAing it for the blower style. That could have been my problem as well. At one point the ACX cooler on my Titan made a buzzing sound but that was only for about a minute and I haven't heard the noise since. Thanks for the post and if I run into this problem again, I will check out the fins as well. BR deserved Super!!
Thanks man!
Robbinb85
2013/11/21 13:39:22
How do you know if you have the new acx? Mine works perfect, although im thinking about to change paste to high quality to get temp down a couple. And y'all talking about heat tape? If i buy this, should it have some specific thickness? Edit: ok, i understand that it is no tape, i see now that the tape that followed was for aftermarket cooler. Cheers
post edited by Robbinb85 - 2013/11/22 14:28:30
